  4. Test Adapter Tuya 3.8.0 - BEENDET
94 Beiträge 13 Kommentatoren 18.1k Aufrufe 13 Beobachtet
  • apollon77A Offline
    #61
    Uups die version von letzter Nacht ging gar nicht sauber auf GitHub raus ... Einmal vergessen zu klicken ;-) Also dann jetzt nochmal
    • sigi234S Online
      sigi234S Online
      sigi234
      #62
      @apollon77
      tuya.0
      2022-11-06 09:25:52.990	info	{"schemaExt":"[{\"complexType\":\"\",\"id\":1,\"inputStyle\":\"\",\"inputType\":\"plain\"},{\"complexType\":\"\",\"id\":2,\"inputStyle\":\"\",\"inputType\":\"plain\"},{\"complexType\":\"\",\"id\":6,\"inputStyle\":\"\",\"inputType\":\"\"},{\"complexType\":\"\",\"id\":7,\"inputStyle\":\"\",\"inputType\":\"\"},{\"complexType\":\"\",\"id\":8,\"inputStyle\":\"\",\"inputType\":\"\"},{\"complexType\":\"\",\"id\":9,\"inputStyle\":\"\",\"inputType\":\"\"}]","schema":"[{\"code\":\"switch_1\",\"defaultValue\":\"false\",\"canTrigger\":true,\"iconname\":\"icon-dp_power\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"开关1\",\"property\":{\"type\":\"bool\"},\"id\":1,\"editPermission\":false},{\"code\":\"switch_2\",\"defaultValue\":\"false\",\"canTrigger\":true,\"iconname\":\"icon-dp_power\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"开关2\",\"property\":{\"type\":\"bool\"},\"id\":2,\"editPermission\":false},{\"code\":\"add_ele\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"增加电量\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":50000,\"scale\":3,\"step\":100,\"type\":\"value\"},\"id\":6,\"editPermission\":false,\"extContent\":\"{\\\"property\\\":{\\\"scale\\\":3}}\"},{\"code\":\"cur_current\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前电流\",\"property\":{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":7,\"editPermission\":false},{\"code\":\"cur_power\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前功率\",\"property\":{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":8,\"editPermission\":false},{\"code\":\"cur_voltage\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前电压\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":2500,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":9,\"editPermission\":false}]"}
      tuya.0
      2022-11-06 09:25:52.990	info	new Schema added for product type PaYQNcPunOhPeS1X. Please send next line from logfile on disk to developer!
      tuya.0
      2022-11-06 09:25:52.582	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 85. Please resync devices
      tuya.0
      2022-11-06 09:25:52.522	info	0765200084f3eb247f4f: Unknown datapoint 9 with value 2349. Please resync devices
      tuya.0
      2022-11-06 09:25:52.522	info	0765200084f3eb247f4f: Unknown datapoint 8 with value 6. Please resync devices
      tuya.0
      2022-11-06 09:25:52.522	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 52. Please resync devices
      tuya.0
      2022-11-06 09:25:52.522	info	0765200084f3eb247f4f: Unknown datapoint 2 with value true. Please resync devices
      tuya.0
      2022-11-06 09:25:52.521	info	0765200084f3eb247f4f: Unknown datapoint 1 with value true. Please resync devices
      tuya.0
      2022-11-06 09:25:52.474	info	Listen for encrypted local Tuya devices on port 6667
      tuya.0
      2022-11-06 09:25:52.474	info	Listen for local Tuya devices on port 6666
      tuya.0
      2022-11-06 09:25:52.354	info	Try to sync devices from Cloud using stored cloud credentials
      tuya.0
      2022-11-06 09:25:52.352	info	Existing devices initialized
      tuya.0
      2022-11-06 09:25:52.349	info	0765200084f3eb247f4f Init with IP=192.168.178.35, Key=xxxxxxxxxxxxxxxxxx, Version=3.1
      tuya.0
      2022-11-06 09:25:52.144	info	starting. Version 3.8.0 (non-npm: Apollon77/ioBroker.tuya#xxxxxxxxxxxxxxxxxx) in C:/ioBroker/node_modules/iobroker.tuya, node: v16.18.0, js-controller: 4.0.23
      tuya.0
      2022-11-06 09:25:46.425	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      tuya.0
      2022-11-06 09:25:46.424	info	terminating
      tuya.0
      2022-11-06 09:25:43.414	info	Got terminate signal TERMINATE_YOURSELF
      tuya.0
      2022-11-06 09:25:43.389	info	Set data for tuya.0 to appDeviceId=xxxxxxxxxxxxxxx / sid=xxxxxxxxxxxxxxxxxxxxx. Restart adapter now!
      tuya.0
      2022-11-06 09:25:43.198	info	0765200084f3eb247f4f: Unknown datapoint 8 with value 6. Please resync devices
      tuya.0
      2022-11-06 09:25:43.198	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 85. Please resync devices
      tuya.0
      2022-11-06 09:25:41.676	info	0765200084f3eb247f4f: Unknown datapoint 9 with value 2332. Please resync devices
      tuya.0
      2022-11-06 09:25:41.675	info	0765200084f3eb247f4f: Unknown datapoint 8 with value 7. Please resync devices
      tuya.0
      2022-11-06 09:25:41.675	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 84. Please resync devices
      tuya.0
      2022-11-06 09:25:41.675	info	0765200084f3eb247f4f: Unknown datapoint 2 with value true. Please resync devices
      tuya.0
      2022-11-06 09:25:41.674	info	0765200084f3eb247f4f: Unknown datapoint 1 with value true. Please resync devices
      tuya.0
      2022-11-06 09:25:41.588	info	Listen for encrypted local Tuya devices on port 6667
      tuya.0
      2022-11-06 09:25:41.587	info	Listen for local Tuya devices on port 6666
      tuya.0
      2022-11-06 09:25:41.393	info	Try to sync devices from Cloud using stored cloud credentials
      tuya.0
      2022-11-06 09:25:41.391	info	Existing devices initialized
      host.Medion
      2022-11-06 09:34:58.058	error	instance system.adapter.tuya.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.Medion
      2022-11-06 09:34:58.058	error	Caught by controller[0]: at UDP.onMessage (node:dgram:930:8)
      host.Medion
      2022-11-06 09:34:58.058	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
      host.Medion
      2022-11-06 09:34:58.058	error	Caught by controller[0]: at Socket.emit (node:events:513:28)
      host.Medion
      2022-11-06 09:34:58.058	error	Caught by controller[0]: at Socket.<anonymous> (C:\ioBroker\node_modules\iobroker.tuya\main.js:740:9)
      host.Medion
      2022-11-06 09:34:58.058	error	Caught by controller[0]: at initDevice (C:\ioBroker\node_modules\iobroker.tuya\main.js:570:29)
      host.Medion
      2022-11-06 09:34:58.058	error	Caught by controller[0]: at Object.getObjectsForSchema (C:\ioBroker\node_modules\iobroker.tuya\lib\mapper.js:80:12)
      host.Medion
      2022-11-06 09:34:58.058	error	Caught by controller[0]: at Array.forEach (<anonymous>)
      host.Medion
      2022-11-06 09:34:58.058	error	Caught by controller[0]: at C:\ioBroker\node_modules\iobroker.tuya\lib\mapper.js:161:30
      host.Medion
      2022-11-06 09:34:58.057	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading '1')
      tuya.0
      2022-11-06 09:34:57.803	error	Cannot read properties of undefined (reading '1')
      tuya.0
      2022-11-06 09:34:57.803	error	TypeError: Cannot read properties of undefined (reading '1') at C:\ioBroker\node_modules\iobroker.tuya\lib\mapper.js:161:30 at Array.forEach (<anonymous>) at Object.getObjectsForSchema (C:\ioBroker\node_modules\iobroker.tuya\lib\mapper.js:80:12) at initDevice (C:\ioBroker\node_modules\iobroker.tuya\main.js:570:29) at Socket.<anonymous> (C:\ioBroker\node_modules\iobroker.tuya\main.js:740:9) at Socket.emit (node:events:513:28) at Socket.emit (node:domain:489:12) at UDP.onMessage (node:dgram:930:8)
      tuya.0
      2022-11-06 09:34:57.803	error	uncaught exception: Cannot read properties of undefined (reading '1')
      Immer Daten sichern!
      • sigi234S sigi234
        @apollon77
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        host.Medion
        host.Medion
        host.Medion
        host.Medion
        host.Medion
        host.Medion
        host.Medion
        host.Medion
        host.Medion
        host.Medion
        tuya.0
        tuya.0
        tuya.0
        #63
        @sigi234 Fix auf GitHub
        • apollon77A apollon77
          sigi234S Online
          sigi234S Online
          sigi234
          #64
          @apollon77 sagte in Test Adapter Tuya 3.8.0:
          Keine Änderung
          • sigi234S sigi234
            Keine Änderung
            #65
            @sigi234 meeehhhhh. Nochmal bitte. Merke: vor zwei Kaffee oder zu spät nix machen ;-))
              sigi234S Online
              sigi234S Online
              sigi234
              #66
              Leider nein
              tuya.0
              2022-11-06 10:17:47.365	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 84. Please resync devices
              tuya.0
              2022-11-06 10:17:45.368	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 83. Please resync devices
              tuya.0
              2022-11-06 10:17:43.355	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 84. Please resync devices
              tuya.0
              2022-11-06 10:17:41.349	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 83. Please resync devices
              tuya.0
              2022-11-06 10:17:39.336	info	0765200084f3eb247f4f: Unknown datapoint 9 with value 2332. Please resync devices
              tuya.0
              2022-11-06 10:17:39.335	info	0765200084f3eb247f4f: Unknown datapoint 8 with value 7. Please resync devices
              tuya.0
              2022-11-06 10:17:35.325	info	0765200084f3eb247f4f: Unknown datapoint 8 with value 6. Please resync devices
              tuya.0
              2022-11-06 10:17:35.324	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 84. Please resync devices
              tuya.0
              2022-11-06 10:17:31.315	info	0765200084f3eb247f4f: Unknown datapoint 8 with value 7. Please resync devices
              tuya.0
              2022-11-06 10:17:31.315	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 83. Please resync devices
              tuya.0
              2022-11-06 10:17:29.314	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 82. Please resync devices
              tuya.0
              2022-11-06 10:17:25.305	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 83. Please resync devices
              tuya.0
              2022-11-06 10:17:21.296	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 77. Please resync devices
              tuya.0
              2022-11-06 10:17:19.294	info	0765200084f3eb247f4f: Unknown datapoint 8 with value 6. Please resync devices
              tuya.0
              2022-11-06 10:17:13.286	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 82. Please resync devices
              tuya.0
              2022-11-06 10:17:11.275	info	0765200084f3eb247f4f: Unknown datapoint 8 with value 7. Please resync devices
              tuya.0
              2022-11-06 10:17:11.275	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 52. Please resync devices
              tuya.0
              2022-11-06 10:17:09.276	info	0765200084f3eb247f4f: Unknown datapoint 8 with value 6. Please resync devices
              tuya.0
              2022-11-06 10:17:07.265	info	0765200084f3eb247f4f: Unknown datapoint 9 with value 2315. Please resync devices
              tuya.0
              2022-11-06 10:17:07.265	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 82. Please resync devices
              tuya.0
              2022-11-06 10:17:06.714	info	0765200084f3eb247f4f: Unknown datapoint 9 with value 2325. Please resync devices
              tuya.0
              2022-11-06 10:17:06.713	info	0765200084f3eb247f4f: Unknown datapoint 8 with value 7. Please resync devices
              tuya.0
              2022-11-06 10:17:06.713	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 84. Please resync devices
              tuya.0
              2022-11-06 10:17:06.713	info	0765200084f3eb247f4f: Unknown datapoint 2 with value true. Please resync devices
              tuya.0
              2022-11-06 10:17:06.713	info	0765200084f3eb247f4f: Unknown datapoint 1 with value true. Please resync devices
              tuya.0
              2022-11-06 10:17:06.702	info	0765200084f3eb247f4f Init with IP=192.168.178.35, Key=xxxxxxxxxxxxx, Version=3.1
              tuya.0
              2022-11-06 10:17:06.091	info	IOT Cloud ID/Secret not configured, disabling real time State updates from Cloud MQTT
              tuya.0
              2022-11-06 10:17:06.079	info	{"schemaExt":"[{\"complexType\":\"\",\"id\":1,\"inputStyle\":\"\",\"inputType\":\"plain\"},{\"complexType\":\"\",\"id\":2,\"inputStyle\":\"\",\"inputType\":\"plain\"},{\"complexType\":\"\",\"id\":6,\"inputStyle\":\"\",\"inputType\":\"\"},{\"complexType\":\"\",\"id\":7,\"inputStyle\":\"\",\"inputType\":\"\"},{\"complexType\":\"\",\"id\":8,\"inputStyle\":\"\",\"inputType\":\"\"},{\"complexType\":\"\",\"id\":9,\"inputStyle\":\"\",\"inputType\":\"\"}]","schema":"[{\"code\":\"switch_1\",\"defaultValue\":\"false\",\"canTrigger\":true,\"iconname\":\"icon-dp_power\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"开关1\",\"property\":{\"type\":\"bool\"},\"id\":1,\"editPermission\":false},{\"code\":\"switch_2\",\"defaultValue\":\"false\",\"canTrigger\":true,\"iconname\":\"icon-dp_power\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"开关2\",\"property\":{\"type\":\"bool\"},\"id\":2,\"editPermission\":false},{\"code\":\"add_ele\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"增加电量\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":50000,\"scale\":3,\"step\":100,\"type\":\"value\"},\"id\":6,\"editPermission\":false,\"extContent\":\"{\\\"property\\\":{\\\"scale\\\":3}}\"},{\"code\":\"cur_current\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前电流\",\"property\":{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":7,\"editPermission\":false},{\"code\":\"cur_power\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前功率\",\"property\":{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":8,\"editPermission\":false},{\"code\":\"cur_voltage\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前电压\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":2500,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":9,\"editPermission\":false}]"}
              tuya.0
              2022-11-06 10:17:06.079	info	new Schema added for product type PaYQNcPunOhPeS1X. Please send next line from logfile on disk to developer!
              tuya.0
              2022-11-06 10:17:05.609	info	0765200084f3eb247f4f: Unknown datapoint 9 with value 2325. Please resync devices
              tuya.0
              2022-11-06 10:17:05.609	info	0765200084f3eb247f4f: Unknown datapoint 8 with value 7. Please resync devices
              tuya.0
              2022-11-06 10:17:05.609	info	0765200084f3eb247f4f: Unknown datapoint 7 with value 84. Please resync devices
              tuya.0
              2022-11-06 10:17:05.608	info	0765200084f3eb247f4f: Unknown datapoint 2 with value true. Please resync devices
              tuya.0
              2022-11-06 10:17:05.608	info	0765200084f3eb247f4f: Unknown datapoint 1 with value true. Please resync devices
              tuya.0
              2022-11-06 10:17:05.542	info	Listen for encrypted local Tuya devices on port 6667
              tuya.0
              2022-11-06 10:17:05.542	info	Listen for local Tuya devices on port 6666
              tuya.0
              2022-11-06 10:17:05.433	info	Try to sync devices from Cloud using stored cloud credentials
              tuya.0
              2022-11-06 10:17:05.432	info	Existing devices initialized
              Name ist jetzt aber da.
              Ist doch das?
              • sigi234S sigi234
                Leider nein
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                tuya.0
                Ist doch das?
                #67
                @sigi234 Ok der Crash ist aber weg. gehen updates der Geräte trotzdem danach? Oder kommen die Meldungen immer? (Oder kommen diese meldungen nur wenn du manuell den Sync machst?)
                  sigi234S Online
                  sigi234S Online
                  sigi234
                  #68
                  Kommen immer im Sekundentakt
                  • sigi234S sigi234
                    #69
                    @sigi234 schickst mir bitte mal debug log vom Start und den Meldungen fix per email?
                    EDIT: ok warte kurz. Hab ne Idee. 10 mins…
                      sigi234S Online
                      sigi234S Online
                      sigi234
                      #70
                      Draußen
                        #71
                        Ok, aber jetzt .... :-) Nochmal GitHub bitte ... fixed?? (Bitte sag ja) :-)
                          sigi234S Online
                          sigi234S Online
                          sigi234
                          #72
                          • sigi234S sigi234
                            #73
                            @sigi234 du hast nicht ja gesagt ;-))
                            Thomas BraunT sigi234S O 3 Antworten Letzte Antwort
                              #74
                              Dann musst du auch weiter suchen! 😆
                                sigi234S Online
                                sigi234S Online
                                sigi234
                                #75
                                JA
                                  O Offline
                                  O Offline
                                  oFbEQnpoLKKl6mbY5e13
                                  #76
                                  @apollon77
                                    @latzi Ok, Bitte nochmal GitHub version versuchen. Kommen dann Namen wieder und bleiben?
                                    Weiterhin @Snopy_16 Bitte auch mal neue GitHub version versuchen. jetzt werden die neu gelesenen Schema auch genutzt um die States zu aktualisieren ... ich denke da gabs "updates" :-) Deswegen hatte Cloud mehr als der Adapter. Warnungen damit weg?
                                    Und gibt noch minimal mehr:
                                    Changelog:
                                    • (Apollon77) Allow to update names of devices when changed in App
                                    • (Apollon77) Use read Schema details from Sync instead the already contained ones
                                    • (Apollon77) When MQTT connection is established change device names directly when changed in App
                                    • (Apollon77) When Datapoints (e.g sockets) have custom names, also use them as State Names
                                    LatziL Online
                                    LatziL Online
                                    Latzi
                                    #77
                                    Na da geht´s ab! Kurz mal weg und dann komm ich kaum mehr mit dem lesen nach ;-)
                                    Namensänderungen laufen und bleiben auch 👍
                                    Ich hab vorhin mal das Abfrageintervall auf 10 sek gestellt und jede Menge Fehler bis zum Adapterstop bekommen, verschwinden aber, sobald man das Intervall wieder erhöht. @apollon77 brauchst du die entstandenen Fehler-Meldungen?
                                    Anbei noch die neuen Schemata die laut log für den Entwickler hilfreich sind (mir sagt das leider gar nichts).
                                    2022-11-06 11:45:35.006 - info: tuya.0 (3607870) new Schema added for product type 37mnhia3pojleqfh. Please send next line from logfile on disk to developer!
                                    2022-11-06 11:45:35.006 - info: tuya.0 (3607870) {"schemaExt":"[{\"complexType\":\"\",\"id\":1,\"inputStyle\":\"\",\"inputType\":\" \"},{\"complexType\":\"\",\"id\":2,\"inputStyle\":\"\",\"inputType\":\" \"}]","schema":"[{\"code\":\"switch_on\",\"defaultValue\":\"false\",\"canTrigger\":true,\"iconname\":\"icon-dp_power3\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"id\":1,\"editPermission\":false},{\"code\":\"countdown\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"passive\":true,\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"延迟\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":2,\"editPermission\":false,\"extContent\":\"{\\\"passive\\\":true}\"},{\"code\":\"add_ele\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"电量\",\"property\":{\"unit\":\"度\",\"min\":0,\"max\":500000,\"scale\":3,\"step\":100,\"type\":\"value\"},\"id\":3,\"editPermission\":false,\"extContent\":\"{\\\"property\\\":{\\\"scale\\\":3}}\"},{\"code\":\"cur_current\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"电流\",\"property\":{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":4,\"editPermission\":false},{\"code\":\"cur_power\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"功率\",\"property\":{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":5,\"editPermission\":false},{\"code\":\"cur_voltage\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"电压\",\"property\":{\"unit\":\"V\",\"min\":0,\"max\":2500,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":6,\"editPermission\":false},{\"code\":\"over_current_alarm\",\"defaultValue\":\"false\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"过流预警\",\"property\":{\"type\":\"bool\"},\"id\":7,\"editPermission\":false}]"}
                                    2022-11-06 11:45:35.012 - info: tuya.0 (3607870) new Schema added for product type fnxgcsysunpyxkou. Please send next line from logfile on disk to developer!
                                    2022-11-06 11:45:35.012 - info: tuya.0 (3607870) {"schemaExt":"[{\"complexType\":\"\",\"id\":1,\"inputStyle\":\"\",\"inputType\":\"plain\"},{\"complexType\":\"\",\"id\":2,\"inputStyle\":\"\",\"inputType\":\" \"},{\"complexType\":\"\",\"id\":3,\"inputStyle\":\"\",\"inputType\":\" \"},{\"complexType\":\"\",\"id\":4,\"inputStyle\":\"\",\"inputType\":\" \"}]","schema":"[{\"code\":\"led_switch\",\"defaultValue\":\"false\",\"canTrigger\":true,\"iconname\":\"icon-dp_power\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"id\":1,\"editPermission\":false},{\"code\":\"work_mode\",\"defaultValue\":\"white\",\"canTrigger\":true,\"iconname\":\"icon-dp_box2\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"模式\",\"property\":{\"range\":[\"white\",\"colour\",\"scene\",\"scene_1\",\"scene_2\",\"scene_3\",\"scene_4\"],\"type\":\"enum\"},\"id\":2,\"editPermission\":false},{\"code\":\"bright_value\",\"defaultValue\":\"25\",\"canTrigger\":true,\"iconname\":\"icon-dp_light2\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"亮度值\",\"property\":{\"unit\":\"\",\"min\":25,\"max\":255,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":3,\"editPermission\":false},{\"code\":\"temp_value\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-a_mode_heat\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"冷暖值\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":255,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":4,\"editPermission\":false},{\"code\":\"colour_data\",\"defaultValue\":\"\",\"canTrigger\":true,\"iconname\":\"icon-dp_filter\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"彩光模式数\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":5,\"editPermission\":false},{\"code\":\"scene_data\",\"defaultValue\":\"\",\"canTrigger\":true,\"iconname\":\"icon-dp_list\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"情景模式数\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":6,\"editPermission\":false},{\"code\":\"flash_scene_1\",\"defaultValue\":\"\",\"canTrigger\":true,\"iconname\":\"icon-FanSpeed\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"柔光模式\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":7,\"editPermission\":false},{\"code\":\"flash_scene_2\",\"defaultValue\":\"\",\"canTrigger\":true,\"iconname\":\"icon-yanse\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"缤纷模式\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":8,\"editPermission\":false},{\"code\":\"flash_scene_3\",\"defaultValue\":\"\",\"canTrigger\":true,\"iconname\":\"icon-dp_flower\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"炫彩模式\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":9,\"editPermission\":false},{\"code\":\"flash_scene_4\",\"defaultValue\":\"\",\"canTrigger\":true,\"iconname\":\"icon-a_mode_turbo\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"斑斓模式\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":10,\"editPermission\":false}]"}
                                    2022-11-06 11:45:35.013 - info: tuya.0 (3607870) new Schema added for product type IGzCi97RpN2Lf9cu. Please send next line from logfile on disk to developer!
                                    2022-11-06 11:45:35.014 - info: tuya.0 (3607870) {"schemaExt":"[{\"complexType\":\"\",\"id\":1,\"inputStyle\":\"\",\"inputType\":\" \"},{\"complexType\":\"\",\"id\":9,\"inputStyle\":\"\",\"inputType\":\"countdown1\"},{\"complexType\":\"\",\"id\":17,\"inputStyle\":\"\",\"inputType\":\" \"}]","schema":"[{\"code\":\"switch_1\",\"defaultValue\":\"false\",\"canTrigger\":true,\"iconname\":\"icon-dp_power2\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"开关1\",\"property\":{\"type\":\"bool\"},\"id\":1,\"editPermission\":false},{\"code\":\"countdown_1\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-dp_time2\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"开关1倒计时\",\"property\":{\"unit\":\"s\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":9,\"editPermission\":false},{\"code\":\"add_ele\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-battery\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"增加电量\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":50000,\"scale\":3,\"step\":100,\"type\":\"value\"},\"id\":17,\"editPermission\":false},{\"code\":\"cur_current\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-Ele\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前电流\",\"property\":{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":18,\"editPermission\":false},{\"code\":\"cur_power\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-dp_tool\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前功率\",\"property\":{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":1,\"step\":1,\"type\":\"value\"},\"id\":19,\"editPermission\":false},{\"code\":\"cur_voltage\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-a_function_turbo\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前电压\",\"property\":{\"unit\":\"V\",\"min\":0,\"max\":5000,\"scale\":1,\"step\":1,\"type\":\"value\"},\"id\":20,\"editPermission\":false},{\"code\":\"test_bit\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-dp_direction\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"产测结果位\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":5,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":21,\"editPermission\":false},{\"code\":\"voltage_coe\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-gaodiyin\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"电压校准系数\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":1000000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":22,\"editPermission\":false},{\"code\":\"electric_coe\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-gaodiyin\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"电流校准系数\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":1000000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":23,\"editPermission\":false},{\"code\":\"power_coe\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-gaodiyin\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"功率校准系数\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":1000000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":24,\"editPermission\":false},{\"code\":\"electricity_coe\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-gaodiyin\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"电量校准系数\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":1000000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":25,\"editPermission\":false},{\"code\":\"fault\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"scope\":\"fault\",\"name\":\"故障告警\",\"property\":{\"label\":[\"ov_cr\"],\"type\":\"bitmap\",\"maxlen\":1},\"id\":26,\"editPermission\":false}]"}
                                    2022-11-06 11:45:35.016 - info: tuya.0 (3607870) new Schema added for product type 63s9mjrkzs6ejl1w. Please send next line from logfile on disk to developer!
                                    2022-11-06 11:45:35.017 - info: tuya.0 (3607870) {"schemaExt":"[{\"complexType\":\"\",\"id\":1,\"inputStyle\":\"\",\"inputType\":\" \"},{\"complexType\":\"\",\"id\":9,\"inputStyle\":\"\",\"inputType\":\" \"},{\"complexType\":\"\",\"id\":17,\"inputStyle\":\"\",\"inputType\":\" \"}]","schema":"[{\"code\":\"switch_1\",\"defaultValue\":\"false\",\"canTrigger\":true,\"iconname\":\"icon-dp_power\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"id\":1,\"editPermission\":false},{\"code\":\"countdown_1\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-dp_time2\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"开关倒计时\",\"property\":{\"unit\":\"s\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":9,\"editPermission\":false},{\"code\":\"add_ele\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-battery\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"增加电量\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":50000,\"scale\":3,\"step\":100,\"type\":\"value\"},\"id\":17,\"editPermission\":false},{\"code\":\"cur_current\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-Ele\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前电流\",\"property\":{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":18,\"editPermission\":false},{\"code\":\"cur_power\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-dp_tool\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前功率\",\"property\":{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":1,\"step\":1,\"type\":\"value\"},\"id\":19,\"editPermission\":false},{\"code\":\"cur_voltage\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-a_function_turbo\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前电压\",\"property\":{\"unit\":\"V\",\"min\":0,\"max\":5000,\"scale\":1,\"step\":1,\"type\":\"value\"},\"id\":20,\"editPermission\":false},{\"code\":\"test_bit\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-dp_direction\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"产测结果位\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":5,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":21,\"editPermission\":false},{\"code\":\"voltage_coe\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-gaodiyin\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"电压校准系数\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":1000000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":22,\"editPermission\":false},{\"code\":\"electric_coe\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-gaodiyin\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"电流校准系数\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":1000000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":23,\"editPermission\":false},{\"code\":\"power_coe\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-gaodiyin\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"功率校准系数\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":1000000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":24,\"editPermission\":false},{\"code\":\"electricity_coe\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-gaodiyin\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"电量校准系数\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":1000000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":25,\"editPermission\":false},{\"code\":\"fault\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"scope\":\"fault\",\"name\":\"故障告警\",\"property\":{\"label\":[\"ov_cr\"],\"type\":\"bitmap\",\"maxlen\":1},\"id\":26,\"editPermission\":false}]"}
                                    2022-11-06 11:45:35.017 - info: tuya.0 (3607870) new Schema added for product type heeU2AWVxpxfqP6D. Please send next line from logfile on disk to developer!
                                    2022-11-06 11:45:35.018 - info: tuya.0 (3607870) {"schemaExt":"[{\"complexType\":\"\",\"id\":1,\"inputStyle\":\"\",\"inputType\":\"plain\"},{\"complexType\":\"\",\"id\":2,\"inputStyle\":\"\",\"inputType\":\"plain\"},{\"complexType\":\"\",\"id\":3,\"inputStyle\":\"\",\"inputType\":\"percent\"}]","schema":"[{\"code\":\"led_switch\",\"defaultValue\":\"false\",\"canTrigger\":true,\"iconname\":\"icon-dp_power\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"id\":1,\"editPermission\":false},{\"code\":\"work_mode\",\"defaultValue\":\"white\",\"canTrigger\":true,\"iconname\":\"icon-dp_box2\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"模式\",\"property\":{\"range\":[\"white\",\"colour\",\"scene\",\"scene_1\",\"scene_2\",\"scene_3\",\"scene_4\"],\"type\":\"enum\"},\"id\":2,\"editPermission\":false},{\"code\":\"bright_value\",\"defaultValue\":\"25\",\"canTrigger\":true,\"iconname\":\"icon-dp_light2\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"亮度值\",\"property\":{\"unit\":\"\",\"min\":25,\"max\":255,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":3,\"editPermission\":false},{\"code\":\"colour_data\",\"defaultValue\":\"\",\"canTrigger\":true,\"iconname\":\"icon-dp_filter\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"彩光模式数\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":5,\"editPermission\":false},{\"code\":\"scene_data\",\"defaultValue\":\"\",\"canTrigger\":true,\"iconname\":\"icon-dp_list\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"情景模式数\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":6,\"editPermission\":false},{\"code\":\"flash_scene_1\",\"defaultValue\":\"\",\"canTrigger\":true,\"iconname\":\"icon-FanSpeed\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"柔光模式\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":7,\"editPermission\":false},{\"code\":\"flash_scene_2\",\"defaultValue\":\"\",\"canTrigger\":true,\"iconname\":\"icon-yanse\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"缤纷模式\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":8,\"editPermission\":false},{\"code\":\"flash_scene_3\",\"defaultValue\":\"\",\"canTrigger\":true,\"iconname\":\"icon-dp_flower\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"炫彩模式\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":9,\"editPermission\":false},{\"code\":\"flash_scene_4\",\"defaultValue\":\"\",\"canTrigger\":true,\"iconname\":\"icon-a_mode_turbo\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"斑斓模式\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":10,\"editPermission\":false},{\"code\":\"flashscreen\",\"defaultValue\":\"\",\"canTrigger\":true,\"iconname\":\"icon-dp_house\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"新场景\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":11,\"editPermission\":false}]"}
                                    2022-11-06 11:45:35.018 - info: tuya.0 (3607870) new Schema added for product type KFAHKrKO9XTIV1V4. Please send next line from logfile on disk to developer!
                                    2022-11-06 11:45:35.019 - info: tuya.0 (3607870) {"schemaExt":"[{\"complexType\":\"\",\"id\":1,\"inputStyle\":\"\",\"inputType\":\" \"},{\"complexType\":\"\",\"id\":2,\"inputStyle\":\"\",\"inputType\":\" \"}]","schema":"[{\"code\":\"switch_on\",\"defaultValue\":\"false\",\"canTrigger\":true,\"iconname\":\"icon-dp_power\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"id\":1,\"editPermission\":false},{\"code\":\"countdown\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-dp_time2\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"倒计时剩余时间\",\"property\":{\"unit\":\"s\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":2,\"editPermission\":false}]"}
                                    2022-11-06 11:45:35.019 - info: tuya.0 (3607870) new Schema added for product type yvczn2lhjubluzdl. Please send next line from logfile on disk to developer!
                                    2022-11-06 11:45:35.019 - info: tuya.0 (3607870) {"schemaExt":"[]","schema":"[{\"code\":\"switch_on\",\"defaultValue\":\"false\",\"canTrigger\":true,\"iconname\":\"icon-dp_power2\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"id\":1,\"editPermission\":false},{\"code\":\"countdown\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-dp_time\",\"type\":\"obj\",\"passive\":true,\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"倒计时剩余时间\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":2,\"editPermission\":false,\"extContent\":\"{\\\"id\\\":2,\\\"passive\\\":true}\"},{\"code\":\"add_ele\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"增加电量\",\"property\":{\"unit\":\"kwh\",\"min\":0,\"max\":500000,\"scale\":3,\"step\":1,\"type\":\"value\"},\"id\":3,\"editPermission\":false,\"extContent\":\"{\\\"id\\\":3,\\\"property\\\":{\\\"scale\\\":3,\\\"unit\\\":\\\"kwh\\\",\\\"max\\\":500000}}\"},{\"code\":\"cur_current\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-dp_curve\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前电流\",\"property\":{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":4,\"editPermission\":false},{\"code\":\"cur_power\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-dp_flower\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前功率\",\"property\":{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":5,\"editPermission\":false},{\"code\":\"cur_voltage\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前电压\",\"property\":{\"unit\":\"V\",\"min\":0,\"max\":2500,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":6,\"editPermission\":false}]"}
                                    2022-11-06 11:45:35.020 - info: tuya.0 (3607870) new Schema added for product type zzj2h0nl2mjlpr0g. Please send next line from logfile on disk to developer!
                                    2022-11-06 11:45:35.020 - info: tuya.0 (3607870) {"schemaExt":"[{\"complexType\":\"\",\"id\":1,\"inputStyle\":\"\",\"inputType\":\" \"},{\"complexType\":\"\",\"id\":9,\"inputStyle\":\"\",\"inputType\":\" \"},{\"complexType\":\"\",\"id\":17,\"inputStyle\":\"\",\"inputType\":\" \"}]","schema":"[{\"code\":\"switch_1\",\"defaultValue\":\"false\",\"canTrigger\":true,\"iconname\":\"icon-dp_power2\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"开关1\",\"property\":{\"type\":\"bool\"},\"id\":1,\"editPermission\":false},{\"code\":\"countdown_1\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-dp_time2\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"开关1倒计时\",\"property\":{\"unit\":\"s\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":9,\"editPermission\":false},{\"code\":\"add_ele\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-battery\",\"type\":\"obj\",\"executable\":true,\"mode\":\"rw\",\"defaultRecommend\":false,\"name\":\"增加电量\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":50000,\"scale\":3,\"step\":100,\"type\":\"value\"},\"id\":17,\"editPermission\":false},{\"code\":\"cur_current\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-Ele\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前电流\",\"property\":{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":18,\"editPermission\":false},{\"code\":\"cur_power\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-dp_tool\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前功率\",\"property\":{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":1,\"step\":1,\"type\":\"value\"},\"id\":19,\"editPermission\":false},{\"code\":\"cur_voltage\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-a_function_turbo\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"当前电压\",\"property\":{\"unit\":\"V\",\"min\":0,\"max\":5000,\"scale\":1,\"step\":1,\"type\":\"value\"},\"id\":20,\"editPermission\":false},{\"code\":\"test_bit\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-dp_direction\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"产测结果位\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":5,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":21,\"editPermission\":false},{\"code\":\"voltage_coe\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-gaodiyin\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"电压校准系数\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":1000000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":22,\"editPermission\":false},{\"code\":\"electric_coe\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-gaodiyin\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"电流校准系数\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":1000000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":23,\"editPermission\":false},{\"code\":\"power_coe\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-gaodiyin\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"功率校准系数\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":1000000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":24,\"editPermission\":false},{\"code\":\"electricity_coe\",\"defaultValue\":\"0\",\"canTrigger\":true,\"iconname\":\"icon-gaodiyin\",\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"name\":\"电量校准系数\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":1000000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":25,\"editPermission\":false},{\"code\":\"fault\",\"defaultValue\":\"0\",\"canTrigger\":true,\"type\":\"obj\",\"executable\":true,\"mode\":\"ro\",\"defaultRecommend\":false,\"scope\":\"fault\",\"name\":\"故障告警\",\"property\":{\"label\":[\"ov_cr\"],\"type\":\"bitmap\",\"maxlen\":1},\"id\":26,\"editPermission\":false}]"}
                                    • O oFbEQnpoLKKl6mbY5e13
                                      @apollon77
                                      #78
                                      @ofbeqnpolkkl6mby5e13 aktuellste github version? dann bitte debug Log an mich per email. Bzw man nochmal nen Sync via admin(falls login Daten nicht gespeichert)
                                      O 1 Antwort Letzte Antwort
                                      • LatziL Latzi
                                        #79
                                        @latzi ja logs wären ggf interessant. Zeig mal
                                        LatziL 1 Antwort Letzte Antwort
                                          O Offline
                                          O Offline
                                          #80
                                          @apollon77
                                          Ja.
                                            "type": "device",
                                            "common": {
                                              "name": "Device 41465054f4cfa21eff44",
                                              "read": true
                                            "native": {
                                              "virtual": false,
                                              "dpName": {
                                                "1": "Leuchtturm",
                                                "2": "Lichterkette"
                                              "lon": "10.3062",
                                              "uuid": "41465054f4cfa21eff44",
                                              "mac": "f4cfa21eff44",
                                              "iconUrl": "https://images.tuyaeu.com/smart/icon/1511839633_0.png",
                                              "runtimeEnv": "prod",
                                              "lat": "52.0414",
                                              "devId": "41465054f4cfa21eff44",
                                              "dpMaxTime": 1667422875696,
                                              "productId": "EQD8hAQw543vzh6O",
                                              "activeTime": 1665658263,
                                              "categoryCode": "wf_kg",
                                              "moduleMap": {
                                                "wifi": {
                                                  "upgradeStatus": 0,
                                                  "cdv": "1.0.0",
                                                  "bv": "5.57",
                                                  "pv": "2.2",
                                                  "verSw": "1.0.7",
                                                  "isOnline": true,
                                                  "id": 15940216,
                                                  "cadv": ""
                                                "mcu": {
                                                  "upgradeStatus": 0,
                                                  "cdv": "",
                                                  "verSw": "1.0.7",
                                                  "isOnline": true,
                                                  "id": 15940217,
                                                  "cadv": ""
                                              "devAttribute": 3,
                                              "name": "Carport (Doppelstecker)",
                                              "timezoneId": "Europe/Berlin",
                                              "category": "kg",
                                              "localKey": "68ed92497a87380e",
                                              "schema": [
                                                  "mode": "rw",
                                                  "code": "switch_1",
                                                  "name": "开关",
                                                  "property": {
                                                    "type": "bool"
                                                  "iconname": "icon-dp_power",
                                                  "id": 1,
                                                  "type": "obj",
                                                  "desc": ""
                                                  "mode": "rw",
                                                  "code": "switch_2",
                                                  "name": "开关 2",
                                                  "property": {
                                                    "type": "bool"
                                                  "id": 2,
                                                  "type": "obj",
                                                  "desc": ""
                                                  "mode": "rw",
                                                  "code": "countdown2",
                                                  "name": "倒计时2",
                                                  "property": {
                                                    "unit": "",
                                                    "min": 0,
                                                    "max": 86400,
                                                    "scale": 0,
                                                    "step": 1,
                                                    "type": "value"
                                                  "id": 101,
                                                  "type": "obj",
                                                  "desc": ""
                                                  "mode": "rw",
                                                  "code": "countdown1",
                                                  "name": "倒计时1",
                                                  "property": {
                                                    "unit": "",
                                                    "min": 0,
                                                    "max": 86400,
                                                    "scale": 0,
                                                    "step": 1,
                                                    "type": "value"
                                                  "id": 102,
                                                  "type": "obj",
                                                  "desc": ""
                                              "productKey": "EQD8hAQw543vzh6O",
                                              "schemaExt": [
                                                  "id": 6,
                                                  "inputStyle": "",
                                                  "inputType": ""
                                              "version": "3.3",
                                              "ip": "192.168.0.40",
                                              "gwId": "41465054f4cfa21eff44",
                                              "active": 2,
                                              "ability": 0,
                                              "mode": 0,
                                              "encrypt": true,
                                              "devKey": ""
                                            "from": "system.adapter.tuya.0",
                                            "user": "system.user.admin",
                                            "ts": 1667731711824,
                                            "_id": "tuya.0.41465054f4cfa21eff44",
                                            "acl": {
                                              "object": 1636,
                                              "owner": "system.user.admin",
                                          "devAttribute": 3,
