  5. Daten aus URL in blocky
45 Beiträge 3 Kommentatoren 8.7k Aufrufe 1 Beobachtet
    @ingranu sagte: unten keine Info Ausgabe mehr
    Wo befindet sich jetzt der Block "die Schleife abbrechen"?
    ingranuI Offline
    ingranuI Offline
    ingranu
    • ingranuI ingranu
      Ja die Schleife habe ich korrigiert, die Ausgabe erfolgt jetzt wie folgt, also alle Geräte:
      javascript.0 (4987) script.js.common.Mediola_states4: [{"type":"FS20","adr":"443525","state":"00:A7"},{"type":"FS20","adr":"2b063b","state":"FF:FF"},{"type":"EVENT","adr":"02","state":"1"},{"type":"FS20","adr":"8d3700","state":"FF:FF"},{"type":"FS20","adr":"aaf900","state":"FF:FF"},{"type":"FS20","adr":"20d600","state":"FF:FF"},{"type":"EVENT","adr":"03","state":"1"},{"type":"FS20","adr":"903702","state":"FF:FF"},{"type":"FS20","adr":"1c291e","state":"FF:FF"},{"type":"FS20","adr":"8d3702","state":"FF:FF"},{"type":"FS20","adr":"0b3212","state":"FF:FF"},{"type":"FS20","adr":"ffffa9","state":"FF:FF"},{"type":"FS20","adr":"015301","state":"FF:FF"},{"type":"FS20","adr":"231a42","state":"FF:FF"},{"type":"ELRO","adr":"123409","state":"FF:FF"},{"type":"FS20","adr":"ffff01","state":"FF:FF"},{"type":"IT","adr":"aa3c0080","state":"FF:FF"},{"type":"FS20","adr":"271b20","state":"FF:FF"},{"type":"FS20","adr":"800001","state":"FF:FF"},{"type":"ELRO","adr":"000550","state":"00:13"},{"type":"IT","adr":"518b1180","state":"06:13"},{"type":"IT","adr":"010","state":"FF:FF"},{"type":"ELRO","adr":"100550","state":"00:FF"},{"type":"IT","adr":"1db90080","state":"FF:FF"},{"type":"IT","adr":"b3930080","state":"FF:FF"},{"type":"IT","adr":"2e340080","state":"06:A7"},{"type":"IT","adr":"a5430080","state":"FF:FF"},{"type":"IT","adr":"7f450080","state":"FF:FF"},{"type":"IT","adr":"44240080","state":"06:13"},{"type":"FS20","adr":"1a0132","state":"FF:FF"},{"type":"IT","adr":"25ca0080","state":"06:FF"},{"type":"EVENT","adr":"01","state":"0"},{"type":"IT","adr":"60b5a280","state":"FF:FF"},{"type":"IT","adr":"518b1181","state":"06:7B"},{"type":"IT","adr":"6616a881","state":"FF:FF"},{"type":"IT","adr":"60b5a282","state":"06:55"},{"type":"IT","adr":"00","state":"FF:FF"},{"type":"IT","adr":"44205800","state":"FF:FF"},{"type":"IT","adr":"a1234561","state":"FF:FF"},{"type":"IT","adr":"af760080","state":"06:13"},{"type":"IT","adr":"13b80080","state":"FF:FF"},{"type":"IT","adr":"6616a880","state":"06:A7"}]
      Aber wie kann ich jetzt da ne Automation mache, respektive kann ich den Wert welche in benötige irgendwo als Variable eintragen lassen?
      @ingranu sagte: die Ausgabe erfolgt jetzt wie folgt, also alle Geräte:
      Ist das die gesamte Log-Ausgabe (Variable result)?
      Wenn ja, fehlt dort der Anfang "{XC_SUC}".
      Dann frage mal zusätzlich ab:
      ingranuI 1 Antwort Letzte Antwort
      • ingranuI ingranu
        @ingranu
        Bei "aktualisiere" ist der Datenpunkt noch nicht zugewiesen.
          ingranuI Offline
          ingranuI Offline
          ingranu
          @paul53 Wo fehlt das {XC_SUC} ?
          • ingranuI ingranu
            @ingranu sagte in Daten aus URL in blocky:
            im result! Deswegen wollte ich das result schon ganz am Anfang sehen
            • ingranuI ingranu
              @ingranu sagte: Wo fehlt das {XC_SUC} ?
              In der Log-Ausgabe von result.
                ingranuI Offline
                ingranuI Offline
                ingranu
                @paul53 so ?
                • ingranuI ingranu
                  @paul53 so ?
                  @ingranu sagte: so ?
                  Nein, result muss unverändert bleiben. So:
                  Noch besser so:
                    Noch besser so:
                    ingranuI Offline
                    ingranuI Offline
                    ingranu
                    @paul53 Folgende Ausgabe erhalte ich so:
                    15:53:48.504	info	javascript.0 (4987) script.js.common.Mediola_states6: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                    15:53:50.003	info	javascript.0 (4987) script.js.common.Mediola_states6: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
                    15:53:55.002	info	javascript.0 (4987) script.js.common.Mediola_states6: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
                    15:54:00.002	info	javascript.0 (4987) script.js.common.Mediola_states6: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
                    15:54:05.002	info	javascript.0 (4987) script.js.common.Mediola_states6: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
                    15:54:07.465	info	javascript.0 (4987) Stop script script.js.common.Mediola_states6
                    • ingranuI ingranu
                      @ingranu sagte: Folgende Ausgabe erhalte ich so:
                      Da hilft nur Debuggen:
                        ingranuI Offline
                        ingranuI Offline
                        ingranu
                        @paul53 said in Daten aus URL in blocky:
                        Folgende Ausgabe nun:
                        16:06:45.063	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'010','state':'FF:FF'}
                        16:06:45.064	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'b3930080','state':'FF:FF'}
                        16:06:45.063	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'ELRO','adr':'100550','state':'00:FF'}
                        16:06:45.063	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'1db90080','state':'FF:FF'}
                        16:06:45.065	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'7f450080','state':'FF:FF'}
                        16:06:45.064	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'2e340080','state':'06:B2'}
                        16:06:45.064	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'a5430080','state':'FF:FF'}
                        16:06:45.065	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'44240080','state':'06:1E'}
                        16:06:45.065	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'FS20','adr':'1a0132','state':'FF:FF'}
                        16:06:45.065	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'25ca0080','state':'06:FF'}
                        16:06:45.066	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'EVENT','adr':'01','state':'0'}
                        16:06:45.066	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'60b5a280','state':'FF:FF'}
                        16:06:45.066	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'518b1181','state':'06:86'}
                        16:06:45.067	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'6616a881','state':'FF:FF'}
                        16:06:45.067	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'00','state':'FF:FF'}
                        16:06:45.068	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'a1234561','state':'FF:FF'}
                        16:06:45.067	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'60b5a282','state':'06:60'}
                        16:06:45.067	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'44205800','state':'FF:FF'}
                        16:06:45.068	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'af760080','state':'06:1E'}
                        16:06:45.068	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'13b80080','state':'FF:FF'}
                        16:06:45.069	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'6616a880','state':'06:B2'}
                        • ingranuI ingranu
                          @ingranu sagte:
                          Hinter dieser Zeile 11 müsste noch eine Ausgabe
                          06:1E
                          hinterher kommen und die Schleife abgebrochen werden.
                          Poste bitte den erzeugten Javascript-Code in Code tags, denn im Blockly kann ich keinen Fehler erkennen.
                          ingranuI 2 Antworten Letzte Antwort
                            @ingranu sagte:
                            06:1E
                            ingranuI Offline
                            ingranuI Offline
                            ingranu
                            @paul53 Also eine Ausgabe das es ins LOG geschrieben wird oder welche?
                              @ingranu sagte:
                              06:1E
                              ingranuI Offline
                              ingranuI Offline
                              ingranu
                              @ingranu sagte:
                              06:1E
                                <variables>
                                  <variable id="a53#cD`9m.m^/sDvE|%/">result</variable>
                                  <variable id="pggQh3[cd#U:nf-=7B}2">arrayStart</variable>
                                  <variable id="OsWBYNgKRnY1AT._O^]O">json</variable>
                                  <variable id="T[V(!A,H,F8FBIfq_jn^">obj</variable>
                                </variables>
                                <block type="schedule" id="D]Ns;]+7ol~%34IWt{0e" x="-862" y="-1137">
                                  <field name="SCHEDULE">*/5 * * * * *</field>
                                  <statement name="STATEMENT">
                                    <block type="request" id="%by~Y1|my.FF[3LR)p8O">
                                      <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                                      <field name="WITH_STATEMENT">TRUE</field>
                                      <field name="LOG">log</field>
                                      <value name="URL">
                                        <shadow type="text" id="/uoTPJtK:4`s1yeNPV`c">
                                          <field name="TEXT">http://192.168.3.97/command?XC_USER=admin&amp;XC_PASS=D000000&amp;XC_FNC=getstates</field>
                                        </shadow>
                                      </value>
                                        <block type="debug" id="_P!k1cg`T%frNRj1/|^p">
                                          <field name="Severity">debug</field>
                                          <value name="TEXT">
                                            <shadow type="text">
                                            </shadow>
                                            <block type="variables_get" id="{~hez)S@#_:Ne|E;`h]e">
                                              <field name="VAR" id="a53#cD`9m.m^/sDvE|%/">result</field>
                                            </block>
                                          </value>
                                          <next>
                                            <block type="controls_if" id="Z+k7e33N~b+5?+NN/7LZ">
                                              <value name="IF0">
                                                <block type="variables_get" id="#qSkV3?-?Y]8n-o}8v^=">
                                                </block>
                                              </value>
                                              <statement name="DO0">
                                                <block type="variables_set" id="j#0`q5Y2LNM^Z8@j;btG">
                                                  <field name="VAR" id="pggQh3[cd#U:nf-=7B}2">arrayStart</field>
                                                  <value name="VALUE">
                                                    <block type="text_indexOf" id="fghnaP5Z,6Xp]vQ{4-mg">
                                                      <field name="END">FIRST</field>
                                                        <block type="variables_get" id="5lw,irPU/N4OBfLbmO;C">
                                                        </block>
                                                      </value>
                                                      <value name="FIND">
                                                        <shadow type="text" id="QWdXUZxDk+OaWER}058N">
                                                          <field name="TEXT">[</field>
                                                        </shadow>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                    <block type="variables_set" id="b[i]jip4Oy;w)`8#1*S[">
                                                      <field name="VAR" id="OsWBYNgKRnY1AT._O^]O">json</field>
                                                        <block type="text_getSubstring" id="x-8rm|IpRnTt_m)k%VX2">
                                                          <mutation at1="true" at2="false"></mutation>
                                                          <field name="WHERE1">FROM_START</field>
                                                          <field name="WHERE2">LAST</field>
                                                          <value name="STRING">
                                                            <block type="variables_get" id="o~s|WPoNyhUb;Vl@|B1i">
                                                            </block>
                                                          </value>
                                                          <value name="AT1">
                                                            <block type="variables_get" id="/)d^~Jn+Y-6]7F(,,wm;">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <next>
                                                        <block type="debug" id="S(eR(-#t91[Y)ZJ|DYs!">
                                                          <value name="TEXT">
                                                            <shadow type="text" id="2/2ub}SKk)9zAWV4FTvK">
                                                            </shadow>
                                                            <block type="variables_get" id="f4k,FmPzkG:Ql.EsZswV">
                                                            </block>
                                                          </value>
                                                          <next>
                                                            <block type="controls_forEach" id="?8QxPrns1xMcVUonzy;C">
                                                              <field name="VAR" id="T[V(!A,H,F8FBIfq_jn^">obj</field>
                                                              <value name="LIST">
        <block type="convert_json2object" id="Nu09x`s%H3?Qr#SYjx@2">
        <block type="variables_get" id="ieUi9aOpO4:+9HT^Z$9E">
        </block>
        </value>
        </block>
                                                              </value>
                                                              <statement name="DO">
        <block type="debug" id="WwKX./zJO!bQdy7Dp#RQ">
        <value name="TEXT">
        </shadow>
        <block type="variables_get" id="f!8O3?=+]3|2t+Sd0iWS">
        </block>
        </value>
        <next>
        <block type="controls_if" id="Q^MF/(]`v@bN=auz8e4:">
        <value name="IF0">
        <block type="logic_operation" id="Ddp+,dBTw~dWG7$Wvr^o" inline="false">
        <field name="OP">AND</field>
        <value name="A">
        <block type="get_attr" id="AB}QS3Katqvs2HzfGPA0">
        <value name="PATH">
        <shadow type="text" id="*F=*NkXztw%R)UGbTgSU">
        <field name="TEXT">type</field>
        </shadow>
        </value>
        <value name="OBJECT">
        <block type="logic_compare" id="m3U*;T=Gj7lvn?69?VlB">
        <field name="OP">EQ</field>
        <value name="A">
        <block type="variables_get" id="?nz#C/d0i`,R4#gg*/7.">
        </block>
        </value>
        <value name="B">
        <block type="text" id="Q3jHkZF?)$q#V,KAmAxj">
        <field name="TEXT">IT</field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="get_attr" id=",6Q30We6V(OpV$J.,Z:I">
        <value name="PATH">
        <shadow type="text" id="V(^430l{^2BEGNn5lXO7">
        <field name="TEXT">adr</field>
        </shadow>
        </value>
        <block type="logic_compare" id="(MO0RnbIZ6d6WR@C_%U$">
        <value name="A">
        <block type="variables_get" id="3k`ILAOI;-[3HBa4yC~;">
        </block>
        </value>
        <value name="B">
        <block type="text" id="-dmm]cBqu[i,MU;=hS}6">
        <field name="TEXT">44240080</field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <block type="debug" id="uh@rKCjV,Ib@SX7W_3S;">
        <value name="TEXT">
        <shadow type="text" id="#q^Tr+m{O3]i+=3z{fY7">
        <field name="TEXT">state</field>
        </shadow>
        <block type="get_attr" id="-NNE,jc@4qz=!9E-4lO~">
        <value name="PATH">
        <shadow type="text" id="Nw?A#mALg$Kvu`k/2IZk">
        </shadow>
        </value>
        <block type="variables_get" id="wOPFu7erG.7NDn*en9t;">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="a%[3P:karCgR(B3M$}~K">
        <field name="OID">0_userdata.0.FS20</field>
        <block type="get_attr" id="rQ$pWfT!1`AwYS_EQ`wV">
        <value name="PATH">
        <shadow type="text" id="HYsU9Dol@9GPv[CH8(*?">
        <field name="TEXT">state.state</field>
        </shadow>
        </value>
        <block type="variables_get" id="w|Ul2(,0)!,^%(}X@QCW">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="controls_flow_statements" id="y[YT8RCRfpgN.[u?V{%G">
        <field name="FLOW">BREAK</field>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
                                                              </statement>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </statement>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                    </block>
                                  </statement>
                                </block>
                              </xml>
                              • ingranuI ingranu
                                @ingranu
                                Habe jetzt den Fehler gesehen: Die Blöcke sind falsch verschachtelt. Richtig:
                                Der Vergleich außen und innen "Attribut type vom Objekt obj".
                                  @ingranu
                                  ingranuI Offline
                                  ingranuI Offline
                                  ingranu
                                  @paul53 ist ja so drin. stimmt das nicht?
                                  • ingranuI ingranu
                                    @ingranu sagte: ist ja so drin.
                                    Nein, ist so drin:
                                    obj wird mit den Strings verglichen.
                                      Nein, ist so drin:
                                      ingranuI Offline
                                      ingranuI Offline
                                      ingranu
                                      @paul53 okey hab geändert Ausgabe nun so:
                                      BlocklyJavascriptTypeScriptRules
                                      Skript läuft nicht
                                      16:26:05.003	info	javascript.0 (4987) script.js.common.Mediola_states7: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
                                      16:26:05.056	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'443525','state':'00:B5'}
                                      16:26:05.056	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'2b063b','state':'FF:FF'}
                                      16:26:05.057	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'EVENT','adr':'02','state':'1'}
                                      16:26:05.057	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'8d3700','state':'FF:FF'}
                                      16:26:05.057	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'aaf900','state':'FF:FF'}
                                      16:26:05.058	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'20d600','state':'FF:FF'}
                                      16:26:05.058	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'EVENT','adr':'03','state':'1'}
                                      16:26:05.058	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'903702','state':'FF:FF'}
                                      16:26:05.058	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'1c291e','state':'FF:FF'}
                                      16:26:05.059	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'8d3702','state':'FF:FF'}
                                      16:26:05.059	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'0b3212','state':'FF:FF'}
                                      16:26:05.059	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'ffffa9','state':'FF:FF'}
                                      16:26:05.059	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'015301','state':'FF:FF'}
                                      16:26:05.064	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'231a42','state':'FF:FF'}
                                      16:26:05.065	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'ELRO','adr':'123409','state':'FF:FF'}
                                      16:26:05.065	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'ffff01','state':'FF:FF'}
                                      16:26:05.066	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'aa3c0080','state':'FF:FF'}
                                      16:26:05.066	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'271b20','state':'FF:FF'}
                                      16:26:05.066	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'800001','state':'FF:FF'}
                                      16:26:05.066	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'ELRO','adr':'000550','state':'00:21'}
                                      16:26:05.067	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'518b1180','state':'06:21'}
                                      16:26:05.067	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'010','state':'FF:FF'}
                                      16:26:05.067	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'ELRO','adr':'100550','state':'00:FF'}
                                      16:26:05.068	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'1db90080','state':'FF:FF'}
                                      16:26:05.068	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'b3930080','state':'FF:FF'}
                                      16:26:05.069	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'2e340080','state':'06:B5'}
                                      16:26:05.069	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'a5430080','state':'FF:FF'}
                                      16:26:05.069	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'7f450080','state':'FF:FF'}
                                      16:26:05.070	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'44240080','state':'06:21'}
                                        Nein, ist so drin:
                                        ingranuI Offline
                                        ingranuI Offline
                                        ingranu
                                        schrieb am zuletzt editiert von ingranu
                                        @ingranu Es wird nun ein Wert geschrieben.
                                        • ingranuI ingranu
                                          Skript läuft nicht
                                          @ingranu sagte: Ausgabe nun so:
                                          Nach der letzten Zeile müsste noch kommen:
                                          06:21
                                          Der Schleifenabbruch erfolgte anscheinend (falls es nicht der letzte Eintrag im Array war).
