[gelöst] HM Rega und HM RCP (HM IP) /Authentifizierung
@dirkheider sagte in HM Rega und HM RCP (HM IP) /Authentifizierung an CCU3:
die Einstellungen der Adapter hatte ich ja schon gepostet
und die wichtigen dinge dort und in der firewall geschwärzt
host.raspberry 2022-10-27 19:35:06.539 info Restart adapter system.adapter.hm-rpc.2 because enabled host.raspberry 2022-10-27 19:35:06.538 info instance system.adapter.hm-rpc.2 terminated with code 0 (NO_ERROR) hm-rpc.2 2022-10-27 19:35:05.825 info Terminated (NO_ERROR): Without reason hm-rpc.2 2022-10-27 19:35:05.823 debug Plugin sentry destroyed hm-rpc.2 2022-10-27 19:35:05.821 info terminating hm-rpc.2 2022-10-27 19:35:05.811 error Cannot call init: [http://192.168.178.22:42010, ""] Unknown XML-RPC tag 'TITLE' hm-rpc.2 2022-10-27 19:35:05.782 info xmlrpc -> 192.168.178.22:42010/ init ["http://192.168.178.22:42010",""] hm-rpc.2 2022-10-27 19:35:05.677 error Init not possible, going to stop: Unknown XML-RPC tag 'TITLE' hm-rpc.2 2022-10-27 19:35:05.657 debug xmlrpc -> 192.168.178.22:42010/ init ["http://192.168.178.22:42010","raspberry:hm-rpc.2:54d0607bb1a7ae11c6aacc831c9ec486"] hm-rega.0 2022-10-27 19:35:02.921 debug Set state 20452: true hm-rega.0 2022-10-27 19:35:02.921 debug stateChange hm-rega.0.20452 {"val":true,"ack":false,"ts":1666892102919,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1666890826537} hm-rega.0 2022-10-27 19:35:02.805 debug Set state 11738: true hm-rega.0 2022-10-27 19:35:02.805 debug stateChange hm-rega.0.11738 {"val":true,"ack":false,"ts":1666892102803,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1666878346191} hm-rega.0 2022-10-27 19:34:54.457 error ReGaHSS 192.168.178.22 down hm-rega.0 2022-10-27 19:34:54.457 error <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n <title>401 Unauthorized</title>\n </head>\n <body>\n <h1>401 Unauthorized</h1>\n </body>\n</html>\n"der HM Rega ist auch down
Kann ich dir die screens ohne Schwärzung auch per PN senden?
nein, da kann man nichts anhängen.
Aber erkläre mir was die Schwärzungen bringen sollen.
die Ports sind bekannt und in den Konfigurationen auch drin.
die IPs ebenfalls und sind außerdem nur in deinem anetzerreichbat
der Username sollte auch bekannt sein, nur ggf. falsch geschrieben. Das Passwort ist eh gesternt.wat nu?
Okay du hast mich überzeugt:-) Stimmt ja was du sagst.
Username und Passwort sind definitiv richtig -
Username und Passwort sind definitiv richtigUser hat auch Adminrechte.
Username und Passwort sind definitiv richtig@dirkheider schmeiss doch erst einmal alles raus was nicht von dir ist. dann wir des übersichtlicher
wenn ich das richtig sehe ist 42010 doppeltund die IP Bereiche hast du doch auch nicht
was soll ich rausschmeißen? Ist doch alles von mir:-)
in iob bei h-rpc.2 ist doch 42010 drinIn der ccu hast du aber noch die alten ports freigegeben.
42010 fehlt dort.
Oder man sieht es nur nicht ! -
@dirkheider
42010 fehlt dort.
Oder man sieht es nur nicht !ist drin....hat sich vielleicht im bild überschnitten
deswegen alles rauswerfen was du nicht brauchst
@homoran hat sich im Laufe der Jahre so angesammelt und wird irgendwo bestimmt noch gebraucht:-)
Siehste denn irgendwas? Ich denke es ist alles drin und deshalb ist es für mich so verdammt seltsam
@dirkheider
42010 fehlt dort.
@bahnuhr sagte in HM Rega und HM RCP (HM IP) /Authentifizierung an CCU3:
42010 fehlt dort.
ist sogar doppelt
@homoran habe ich auch eben gesehen und einen rausgeworfen
42010 fehlt dort.
ist sogar doppelt
@homoran ist im Laufe der Verzweiflung die Tage passiert......man versucht ja alles irgendwie
Und cuxd geht nicht mit https
ich hab bisher nur die Konfiguration von rpc.2 gesehen. wofür @dirkheider 8x hm-rpc braucht weiß ich nicht
@dirkheider
Nur mal so für mich.
Warum willst du überhaupt die authetifizierung.
Ohne lief es doch einwandfrei.Bist doch auch im eigenen Netz.
Router hat doch auch firewall.Habe dies noch nie so richtig nachvollziehen können.
@homoran sagte in HM Rega und HM RCP (HM IP) /Authentifizierung an CCU3:
Im #3 hat er es dargestellt:
Hat sogar 7 x rpc
Hat sogar 7 x rpc
Hat sogar 7 x rpc
digital denken!
0...7 = 8
@dirkheider
@bahnuhr
1 Instanz lauft Virtual Devices
1 x rfd
2x CUX
und ich sehe gerade das noch eine Instanz läuft mit Homematic IP :-)
