  4. [gelöst] HM Rega und HM RCP (HM IP) /Authentifizierung
    5.7k
65 Beiträge 3 Kommentatoren 5.5k Aufrufe 2 Beobachtet
  • D dirkheider
    die Einstellungen der Adapter hatte ich ja schon gepostet
    @dirkheider sagte in HM Rega und HM RCP (HM IP) /Authentifizierung an CCU3:
    und die wichtigen dinge dort und in der firewall geschwärzt
      dirkheider
      host.raspberry
      2022-10-27 19:35:06.539	info	Restart adapter system.adapter.hm-rpc.2 because enabled
      host.raspberry
      2022-10-27 19:35:06.538	info	instance system.adapter.hm-rpc.2 terminated with code 0 (NO_ERROR)
      hm-rpc.2
      2022-10-27 19:35:05.825	info	Terminated (NO_ERROR): Without reason
      hm-rpc.2
      2022-10-27 19:35:05.823	debug	Plugin sentry destroyed
      hm-rpc.2
      2022-10-27 19:35:05.821	info	terminating
      hm-rpc.2
      2022-10-27 19:35:05.811	error	Cannot call init: [http://192.168.178.22:42010, ""] Unknown XML-RPC tag 'TITLE'
      hm-rpc.2
      2022-10-27 19:35:05.782	info	xmlrpc -> 192.168.178.22:42010/ init ["http://192.168.178.22:42010",""]
      hm-rpc.2
      2022-10-27 19:35:05.677	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
      hm-rpc.2
      2022-10-27 19:35:05.657	debug	xmlrpc -> 192.168.178.22:42010/ init ["http://192.168.178.22:42010","raspberry:hm-rpc.2:54d0607bb1a7ae11c6aacc831c9ec486"]
      hm-rega.0
      2022-10-27 19:35:02.921	debug	Set state 20452: true
      hm-rega.0
      2022-10-27 19:35:02.921	debug	stateChange hm-rega.0.20452 {"val":true,"ack":false,"ts":1666892102919,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1666890826537}
      hm-rega.0
      2022-10-27 19:35:02.805	debug	Set state 11738: true
      hm-rega.0
      2022-10-27 19:35:02.805	debug	stateChange hm-rega.0.11738 {"val":true,"ack":false,"ts":1666892102803,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1666878346191}
      hm-rega.0
      2022-10-27 19:34:54.457	error	ReGaHSS 192.168.178.22 down
      hm-rega.0
      2022-10-27 19:34:54.457	error	<-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n <title>401 Unauthorized</title>\n </head>\n <body>\n <h1>401 Unauthorized</h1>\n </body>\n</html>\n"
      der HM Rega ist auch down
      • D dirkheider
        host.raspberry
        host.raspberry
        hm-rpc.2
        hm-rpc.2
        hm-rpc.2
        hm-rpc.2
        hm-rpc.2
        hm-rpc.2
        hm-rpc.2
        hm-rega.0
        hm-rega.0
        hm-rega.0
        hm-rega.0
        hm-rega.0
        hm-rega.0
        dirkheider
        Kann ich dir die screens ohne Schwärzung auch per PN senden?
        • D dirkheider
          nein, da kann man nichts anhängen.
          Aber erkläre mir was die Schwärzungen bringen sollen.
          die Ports sind bekannt und in den Konfigurationen auch drin.
          die IPs ebenfalls und sind außerdem nur in deinem anetzerreichbat
          der Username sollte auch bekannt sein, nur ggf. falsch geschrieben. Das Passwort ist eh gesternt.
          wat nu?
            wat nu?
            dirkheider
            schrieb am zuletzt editiert von dirkheider
            Okay du hast mich überzeugt:-) Stimmt ja was du sagst.
            Username und Passwort sind definitiv richtig
            D HomoranH bahnuhrB 3 Antworten Letzte Antwort
            • D dirkheider
              dirkheider
              User hat auch Adminrechte.
              • D dirkheider
                @dirkheider schmeiss doch erst einmal alles raus was nicht von dir ist. dann wir des übersichtlicher
                wenn ich das richtig sehe ist 42010 doppelt
                und die IP Bereiche hast du doch auch nicht
                  dirkheider
                  was soll ich rausschmeißen? Ist doch alles von mir:-)
                  • D dirkheider
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    @dirkheider
                    in iob bei h-rpc.2 ist doch 42010 drin
                    In der ccu hast du aber noch die alten ports freigegeben.
                    42010 fehlt dort.
                    Oder man sieht es nur nicht !
                    Danke.
                    D HomoranH 2 Antworten Letzte Antwort
                    • bahnuhrB bahnuhr
                      @dirkheider
                      42010 fehlt dort.
                      dirkheider
                      ist drin....hat sich vielleicht im bild überschnitten
                      HomoranH bahnuhrB 2 Antworten Letzte Antwort
                      • D dirkheider
                        deswegen alles rauswerfen was du nicht brauchst
                          dirkheider
                          @homoran hat sich im Laufe der Jahre so angesammelt und wird irgendwo bestimmt noch gebraucht:-)
                          Siehste denn irgendwas? Ich denke es ist alles drin und deshalb ist es für mich so verdammt seltsam
                          • bahnuhrB bahnuhr
                            @dirkheider
                            42010 fehlt dort.
                            @bahnuhr sagte in HM Rega und HM RCP (HM IP) /Authentifizierung an CCU3:
                            42010 fehlt dort.
                            ist sogar doppelt
                            D 2 Antworten Letzte Antwort
                              42010 fehlt dort.
                              ist sogar doppelt
                              dirkheider
                              @homoran habe ich auch eben gesehen und einen rausgeworfen
                              • D dirkheider
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                @dirkheider
                                Und cuxd geht nicht mit https
                                oder @Homoran bin ich da falsch.
                                Lt. Anleitung:
                                Danke.
                                  42010 fehlt dort.
                                  ist sogar doppelt
                                  dirkheider
                                  @homoran ist im Laufe der Verzweiflung die Tage passiert......man versucht ja alles irgendwie
                                  • bahnuhrB bahnuhr
                                    @dirkheider
                                    Lt. Anleitung:
                                    ich hab bisher nur die Konfiguration von rpc.2 gesehen. wofür @dirkheider 8x hm-rpc braucht weiß ich nicht
                                    • D dirkheider
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      @dirkheider
                                      Nur mal so für mich.
                                      Warum willst du überhaupt die authetifizierung.
                                      Ohne lief es doch einwandfrei.
                                      Bist doch auch im eigenen Netz.
                                      Router hat doch auch firewall.
                                      Habe dies noch nie so richtig nachvollziehen können.
                                      Danke.
                                        bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        @homoran sagte in HM Rega und HM RCP (HM IP) /Authentifizierung an CCU3:
                                        Im #3 hat er es dargestellt:
                                        Hat sogar 7 x rpc
                                        Danke.
                                        • bahnuhrB bahnuhr
                                          Hat sogar 7 x rpc
                                          Hat sogar 7 x rpc
                                          digital denken!
                                          0...7 = 8
