  4. [gelöst] HM Rega und HM RCP (HM IP) /Authentifizierung
    5.7k
65 Beiträge 3 Kommentatoren 5.5k Aufrufe 2 Beobachtet
    @dirkheider sagte in HM Rega und HM RCP (HM IP) /Authentifizierung an CCU3:
    die Einstellungen der Adapter hatte ich ja schon gepostet
    und die wichtigen dinge dort und in der firewall geschwärzt
    dirkheider
    host.raspberry
    2022-10-27 19:35:06.539	info	Restart adapter system.adapter.hm-rpc.2 because enabled
    host.raspberry
    2022-10-27 19:35:06.538	info	instance system.adapter.hm-rpc.2 terminated with code 0 (NO_ERROR)
    hm-rpc.2
    2022-10-27 19:35:05.825	info	Terminated (NO_ERROR): Without reason
    hm-rpc.2
    2022-10-27 19:35:05.823	debug	Plugin sentry destroyed
    hm-rpc.2
    2022-10-27 19:35:05.821	info	terminating
    hm-rpc.2
    2022-10-27 19:35:05.811	error	Cannot call init: [http://192.168.178.22:42010, ""] Unknown XML-RPC tag 'TITLE'
    hm-rpc.2
    2022-10-27 19:35:05.782	info	xmlrpc -> 192.168.178.22:42010/ init ["http://192.168.178.22:42010",""]
    hm-rpc.2
    2022-10-27 19:35:05.677	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    hm-rpc.2
    2022-10-27 19:35:05.657	debug	xmlrpc -> 192.168.178.22:42010/ init ["http://192.168.178.22:42010","raspberry:hm-rpc.2:54d0607bb1a7ae11c6aacc831c9ec486"]
    hm-rega.0
    2022-10-27 19:35:02.921	debug	Set state 20452: true
    hm-rega.0
    2022-10-27 19:35:02.921	debug	stateChange hm-rega.0.20452 {"val":true,"ack":false,"ts":1666892102919,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1666890826537}
    hm-rega.0
    2022-10-27 19:35:02.805	debug	Set state 11738: true
    hm-rega.0
    2022-10-27 19:35:02.805	debug	stateChange hm-rega.0.11738 {"val":true,"ack":false,"ts":1666892102803,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1666878346191}
    hm-rega.0
    2022-10-27 19:34:54.457	error	ReGaHSS 192.168.178.22 down
    hm-rega.0
    2022-10-27 19:34:54.457	error	<-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n <title>401 Unauthorized</title>\n </head>\n <body>\n <h1>401 Unauthorized</h1>\n </body>\n</html>\n"
    der HM Rega ist auch down
    • D dirkheider
      host.raspberry
      host.raspberry
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rega.0
      hm-rega.0
      hm-rega.0
      hm-rega.0
      hm-rega.0
      hm-rega.0
      dirkheider
      Kann ich dir die screens ohne Schwärzung auch per PN senden?
      • D dirkheider
        nein, da kann man nichts anhängen.
        Aber erkläre mir was die Schwärzungen bringen sollen.
        die Ports sind bekannt und in den Konfigurationen auch drin.
        die IPs ebenfalls und sind außerdem nur in deinem anetzerreichbat
        der Username sollte auch bekannt sein, nur ggf. falsch geschrieben. Das Passwort ist eh gesternt.
        wat nu?
          wat nu?
          dirkheider
          schrieb am zuletzt editiert von dirkheider
          Okay du hast mich überzeugt:-) Stimmt ja was du sagst.
          Username und Passwort sind definitiv richtig
          D HomoranH bahnuhrB 3 Antworten Letzte Antwort
          • D dirkheider
            dirkheider
            User hat auch Adminrechte.
            • D dirkheider
              @dirkheider schmeiss doch erst einmal alles raus was nicht von dir ist. dann wir des übersichtlicher
              wenn ich das richtig sehe ist 42010 doppelt
              und die IP Bereiche hast du doch auch nicht
                dirkheider
                was soll ich rausschmeißen? Ist doch alles von mir:-)
                • D dirkheider
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  @dirkheider
                  in iob bei h-rpc.2 ist doch 42010 drin
                  In der ccu hast du aber noch die alten ports freigegeben.
                  42010 fehlt dort.
                  Oder man sieht es nur nicht !
                  Danke.
                  D HomoranH 2 Antworten Letzte Antwort
                  • bahnuhrB bahnuhr
                    @dirkheider
                    42010 fehlt dort.
                    dirkheider
                    ist drin....hat sich vielleicht im bild überschnitten
                    HomoranH bahnuhrB 2 Antworten Letzte Antwort
                    • D dirkheider
                      deswegen alles rauswerfen was du nicht brauchst
                        dirkheider
                        @homoran hat sich im Laufe der Jahre so angesammelt und wird irgendwo bestimmt noch gebraucht:-)
                        Siehste denn irgendwas? Ich denke es ist alles drin und deshalb ist es für mich so verdammt seltsam
                        • bahnuhrB bahnuhr
                          @dirkheider
                          42010 fehlt dort.
                          @bahnuhr sagte in HM Rega und HM RCP (HM IP) /Authentifizierung an CCU3:
                          42010 fehlt dort.
                          ist sogar doppelt
                          D 2 Antworten Letzte Antwort
                            42010 fehlt dort.
                            ist sogar doppelt
                            dirkheider
                            @homoran habe ich auch eben gesehen und einen rausgeworfen
                            • D dirkheider
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              @dirkheider
                              Und cuxd geht nicht mit https
                              oder @Homoran bin ich da falsch.
                              Lt. Anleitung:
                              Danke.
                                42010 fehlt dort.
                                ist sogar doppelt
                                dirkheider
                                @homoran ist im Laufe der Verzweiflung die Tage passiert......man versucht ja alles irgendwie
                                • bahnuhrB bahnuhr
                                  @dirkheider
                                  Lt. Anleitung:
                                  ich hab bisher nur die Konfiguration von rpc.2 gesehen. wofür @dirkheider 8x hm-rpc braucht weiß ich nicht
                                  • D dirkheider
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    @dirkheider
                                    Nur mal so für mich.
                                    Warum willst du überhaupt die authetifizierung.
                                    Ohne lief es doch einwandfrei.
                                    Bist doch auch im eigenen Netz.
                                    Router hat doch auch firewall.
                                    Habe dies noch nie so richtig nachvollziehen können.
                                    Danke.
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      @homoran sagte in HM Rega und HM RCP (HM IP) /Authentifizierung an CCU3:
                                      Im #3 hat er es dargestellt:
                                      Hat sogar 7 x rpc
                                      Danke.
                                      • bahnuhrB bahnuhr
                                        Hat sogar 7 x rpc
                                        Hat sogar 7 x rpc
                                        digital denken!
                                        0...7 = 8
                                        • bahnuhrB bahnuhr
                                          @dirkheider
                                          dirkheider
                                          @bahnuhr
                                          1 Instanz lauft Virtual Devices
                                          1 x rfd
                                          2x CUX
                                          und ich sehe gerade das noch eine Instanz läuft mit Homematic IP :-)
                                          HomoranH D 2 Antworten Letzte Antwort
