  4. [Aufruf] IKEA-Trådfri Adapter testen
471 Beiträge 49 Kommentatoren 175.9k Aufrufe 5 Beobachtet
    pxstd
    #241
    Ich befürchte einen Vorführeffekt.
    Ich lasse den Adapter nochmal im Debug laufen.
      pxstd
      #242
      Hey,
      also seit letztem Posting laufen gelassen - jetzt gerade reagiert keine Lampe mehr, deshalb anbei der Export:
      3277_tradfri_log_1.txt.zip
      • AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        #243
        Danke für den Log. Der relevante Part scheint dieser zu sein:
        2017-12-18T13:13:31.611Z node-coap-client workOffSendQueue > queue empty
        2017-12-18T13:13:40.618Z node-coap-client getConnection(coaps://10.1.15.102:5684) => found existing connection
        2017-12-18T13:13:40.618Z node-coap-client remembering request: msgID=0x122, token=, url=coaps://10.1.15.102:5684
        2017-12-18T13:13:40.618Z node-coap-client added message to send queue, new length = 1
        2017-12-18T13:13:40.618Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        2017-12-18T13:13:40.618Z node-coap-client concurrency low enough, sending message 0x122
        2017-12-18T13:13:40.618Z node-coap-client request 0x122: concurrency changed => 1
        2017-12-18T13:13:40.626Z node-coap-client received message: ID=0x122
        2017-12-18T13:13:40.626Z node-coap-client request 0x122: concurrency changed => 0
        2017-12-18T13:13:40.627Z node-coap-client workOffSendQueue > queue empty
        2017-12-18T13:13:40.627Z node-coap-client received response to ping with ID 0x122
        2017-12-18T13:13:40.627Z node-coap-client forgetting request: token=; msgID=0x122
        ping successful...
        2017-12-18T13:13:41.620Z node-coap-client workOffSendQueue > queue empty
        2017-12-18T13:13:50.625Z node-coap-client getConnection(coaps://10.1.15.102:5684) => found existing connection
        2017-12-18T13:13:50.625Z node-coap-client remembering request: msgID=0x123, token=, url=coaps://10.1.15.102:5684
        2017-12-18T13:13:50.625Z node-coap-client added message to send queue, new length = 1
        2017-12-18T13:13:50.625Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        2017-12-18T13:13:50.625Z node-coap-client concurrency low enough, sending message 0x123
        2017-12-18T13:13:50.625Z node-coap-client request 0x123: concurrency changed => 1
        2017-12-18T13:13:51.627Z node-coap-client workOffSendQueue > queue empty
        2017-12-18T13:13:55.627Z node-coap-client forgetting request: token=; msgID=0x123
        2017-12-18T13:13:55.627Z node-coap-client request 0x123: concurrency changed => 0
        2017-12-18T13:13:55.627Z node-coap-client workOffSendQueue > queue empty
        ping unsuccessful...
        In Summe nichts auffälliges, außer dass das Gateway auf den letzten Ping nicht antwortet und danach auch nicht mehr.
        Auf vorherige Anfragen werden aber weiterhin Updates geschickt… Seltsam. Ich muss nochmal mit dem automatischen Restart spielen, schätze da führt kein Weg dran vorbei.
          pxstd
          #244
          Das wäre toll. Der Adapter ist genial und löst einige meiner Probleme - wenn er denn dann reagiert! :D
          • N Offline
            N Offline
            Nanouk
            #245
            Hallo in die Runde,
            nach langer Zeit hab ich mich auch mal wieder mit dem Tradfri Adapter beschäftigt.
            Da iobroker bei mir auf einer Windows Kiste läuft und ich mehrfach alles zerschossen hatte beim Node update, habe ich gedacht ich teste den Adapter mal wieder, da jetzt Node auf der Windows Kiste auch auf v6 läuft.
            Leider bekomme ich keine Verbindung zum Adapter. Ampel bleibt gelb.
            tradfri.0	2017-12-22 10:04:10.760	error	at process._tickCallback (internal/process/next_tick.js:109:7)
            tradfri.0	2017-12-22 10:04:10.760	error	at fulfilled (D:\ioBroker\node_modules\iobroker.tradfri\node_modules\node-tradfri-client\build\tradfri-client.js:4:58)
            tradfri.0	2017-12-22 10:04:10.760	error	at next (native)
            tradfri.0	2017-12-22 10:04:10.760	error	> stack: TypeError: Generator is already running
            tradfri.0	2017-12-22 10:04:10.760	error	unhandled promise rejection: Generator is already running
            tradfri.0	2017-12-22 10:04:10.744	info	startfile = D:\ioBroker\node_modules\iobroker.tradfri\main.js
            tradfri.0	2017-12-22 10:04:10.604	info	starting. Version 1.0.0 in D:/ioBroker/node_modules/iobroker.tradfri, node: v6.12.0
            Kann vielleicht jemand was mit den Fehlermeldungen anfangen?
            Grüße,
            Nanouk
            • DutchmanD Offline
              DutchmanD Offline
              Dutchman
              #246
              @Nanouk:
              Kann vielleicht jemand was mit den Fehlermeldungen anfangen? `
              hast du das system mal neu durchgestartet ?
              • N Offline
                N Offline
                Nanouk
                #247
                Ja, ich hab alles neu gestartet und auch den Gateway schon zwei mal neu gestartet.
                Adapter komplett gelöscht und neu installiert etc.
                Hostname und Passwort stimmen auch.
                Gruß Nanouk
                  Thorsten
                  #248
                  @AlCalzone:
                  @The Spirit:
                  kann man schon den Bewegungsmelder und Dimmer von Tradfri nutzen? `
                  Siehe mein Post hier http://forum.iobroker.net/viewtopic.php?p=89973#p89973
                  Das Gateway sendet nur leere Platzhalter-Objekte für Bewegungsmelder und Dimmer/Remote. `
                  Hmmm, wieso kann FHEM dann den Status der HUE Bridge auslesen? Siehe:
                  https://wiki.fhem.de/wiki/HUE_Dimmer_Switch
                  Oder gilt Deine Aussage nur für die Schalter und Dimmer von Tradfri?
                    AlCalzoneA Offline
                    AlCalzone
                    #249
                    @Thorsten:
                    Oder gilt Deine Aussage nur für die Schalter und Dimmer von Tradfri? `
                    Was denkst du? Du bist hier im IKEA-Trådfri Adapter Thread ;)
                    Meine Aussage bezieht sich auf das IKEA-Gateway, das meine Info nach nur mit IKEA-Geräten zusammenarbeitet.
                      Thorsten
                      #250
                      @AlCalzone:
                      @Thorsten:
                      Meine Aussage bezieht sich auf das IKEA-Gateway, das meine Info nach nur mit IKEA-Geräten zusammenarbeitet. `
                      Mea culpa, mea maxima culpa! Und ein Frohes Fest!
                        AlCalzoneA Offline
                        AlCalzone
                        #251
                        @Thorsten:
                        Mea culpa, mea maxima culpa! Und ein Frohes Fest! `
                        Kein Problem und ebenfalls Frohe Weihnachten!
                          pxstd
                          #252
                          @AlCalzone:
                          ping successful...
                          Auf vorherige Anfragen werden aber weiterhin Updates geschickt… Seltsam. Ich muss nochmal mit dem automatischen Restart spielen, schätze da führt kein Weg dran vorbei. `
                          Gibt's eine Art Workaround den ich erstmal basteln könnte?
                          Ich hatte schon überlegt via PING Adapter und bei "unreachable" state den Tradfri Adapter neu zu starten. Leider pongt das GW aber.
                          Desweiteren hatte ich schon einen 5-Minuten Cronjob mit Tradfri Adapter restart angedacht, aber das funktioniert leider auch nicht.
                          Ideen?
                            AlCalzoneA Offline
                            AlCalzone
                            #253
                            Probier bitte mal Version 1.0.2 (auf Github und npm) und berichte wie es sich jetzt verhält.
                              pxstd
                              #254
                              Bekomme ich die via
                              iobroker update
                                AlCalzoneA Offline
                                AlCalzone
                                #255
                                @pxstd:
                                Bekomme ich die via
                                iobroker update
                                Wenn du latest repo ausgewählt hast, ja. Sonst in der Adapter Liste aufs github Symbol klicken und TRÅDFRI aus der Liste auswählen. Nach Update von github musst du die Instanz neu starten.
                                  pxstd
                                  #256
                                  Was genau sagt mir
                                  > Adapter "tradfri" : 1.0.0 , installed 1.0.2
                                  1.0.2 ist installiert, aber 1.0.0 läuft in der Instanz?
                                  Habe Adapter + iobroker neugestartet.
                                    #257
                                    Nein, es heißt dass es in dem von dir gewählten repository in der Version 1.0.0 vorliegt, du aber bereits (auf anderen Wegen) die 1.0.2 installiert hast und somit deiner Zeit voraus bist ;-)
                                    Rainer
                                      pxstd
                                      #258
                                      @AlCalzone:
                                      Probier bitte mal Version 1.0.2 (auf Github und npm) und berichte wie es sich jetzt verhält. `
                                      Es ist hübsch! Sehr hübsch! :)
                                      ! tradfri.0 2017-12-29 10:17:47.013 info received all groups and scenes
                                      ! tradfri.0 2017-12-29 10:17:47.013 info received all devices
                                      ! tradfri.0 2017-12-29 10:17:47.013 info Connection to gateway reestablished
                                      ! tradfri.0 2017-12-29 10:17:42.007 warn Lost connection to gateway
                                      ! tradfri.0 2017-12-29 10:07:08.158 info received all groups and scenes
                                      ! tradfri.0 2017-12-29 10:07:08.157 info updating possible scenes for group 131081: ["196632","196633","196634"]
                                      ! tradfri.0 2017-12-29 10:07:08.088 info updating possible scenes for group 131081: ["196632","196633"]
                                      ! tradfri.0 2017-12-29 10:07:08.011 info updating possible scenes for group 131081: ["196632"]
                                      ! tradfri.0 2017-12-29 10:07:07.941 info updating possible scenes for group 131080: ["196629","196630","196631"]
                                      ! tradfri.0 2017-12-29 10:07:07.897 info updating possible scenes for group 131080: ["196629","196630"]
                                      ! tradfri.0 2017-12-29 10:07:07.854 info updating possible scenes for group 131080: ["196629"]
                                      ! tradfri.0 2017-12-29 10:07:07.809 info updating possible scenes for group 131077: ["196620","196621","196622"]
                                      ! tradfri.0 2017-12-29 10:07:07.701 info updating possible scenes for group 131077: ["196620","196621"]
                                      ! tradfri.0 2017-12-29 10:07:07.578 info updating possible scenes for group 131077: ["196620"]
                                      ! tradfri.0 2017-12-29 10:07:07.474 info updating possible scenes for group 131073: ["196608","196609","196610"]
                                      ! tradfri.0 2017-12-29 10:07:07.393 info updating possible scenes for group 131073: ["196608","196609"]
                                      ! tradfri.0 2017-12-29 10:07:07.309 info updating possible scenes for group 131073: ["196608"]
                                      ! tradfri.0 2017-12-29 10:07:07.225 info got all scenes in group 131081: [196632,196633,196634]
                                      ! tradfri.0 2017-12-29 10:07:07.207 info got all scenes in group 131080: [196629,196630,196631]
                                      ! tradfri.0 2017-12-29 10:07:07.191 info got all scenes in group 131077: [196620,196621,196622]
                                      ! tradfri.0 2017-12-29 10:07:07.170 info got all scenes in group 131073: [196608,196609,196610]
                                      ! tradfri.0 2017-12-29 10:07:07.069 info got all groups: [131081,131080,131077,131073]
                                      ! tradfri.0 2017-12-29 10:07:07.059 info received all devices
                                      ! tradfri.0 2017-12-29 10:07:06.828 info got all devices: [65536,65544,65546,65538,65545,65541,65551,65537,65543,65553,65552,65548,65550,65549]
                                      ! tradfri.0 2017-12-29 10:07:06.769 info startfile = /opt/iobroker/node_modules/iobroker.tradfri/main.js
                                      ! tradfri.0 2017-12-29 10:07:06.735 info starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.tradfri, node: v6.12.0
                                      ! tradfri.0 2017-12-29 10:07:03.848 info terminating
                                      ! tradfri.0 2017-12-29 10:07:03.846 error Please restart the adapter!
                                      ! tradfri.0 2017-12-29 10:07:03.846 error Cannot send changes.
                                      ! tradfri.0 2017-12-29 10:07:03.846 error The connection to the gateway is dead.
                                      ! tradfri.0 2017-12-29 10:07:01.502 error Please restart the adapter!
                                      ! tradfri.0 2017-12-29 10:07:01.502 error Cannot send changes.
                                      ! tradfri.0 2017-12-29 10:07:01.502 error The connection to the gateway is dead.
                                      ! tradfri.0 2017-12-29 10:06:59.726 error Please restart the adapter!
                                      ! tradfri.0 2017-12-29 10:06:59.726 error Cannot send changes.
                                      ! tradfri.0 2017-12-29 10:06:59.726 error The connection to the gateway is dead.
                                      ! tradfri.0 2017-12-29 10:06:58.755 error Please restart the adapter!
                                      ! tradfri.0 2017-12-29 10:06:58.755 error Cannot send changes.
                                      ! tradfri.0 2017-12-29 10:06:58.755 error The connection to the gateway is dead.
                                      ! tradfri.0 2017-12-29 10:06:58.093 error Please restart the adapter!
                                      ! tradfri.0 2017-12-29 10:06:58.093 error Cannot send changes.
                                      ! tradfri.0 2017-12-29 10:06:58.093 error The connection to the gateway is dead.
                                      ! tradfri.0 2017-12-29 10:06:57.090 error Please restart the adapter!
                                      ! tradfri.0 2017-12-29 10:06:57.090 error Cannot send changes.
                                      ! tradfri.0 2017-12-29 10:06:57.090 error The connection to the gateway is dead.
                                      ! tradfri.0 2017-12-29 10:06:55.719 error Please restart the adapter!
                                      ! tradfri.0 2017-12-29 10:06:55.719 error Cannot send changes.
                                      ! tradfri.0 2017-12-29 10:06:55.719 error The connection to the gateway is dead.
                                      ! tradfri.0 2017-12-29 10:06:54.297 error Please restart the adapter!
                                      ! tradfri.0 2017-12-29 10:06:54.297 error Cannot send changes.
                                      ! tradfri.0 2017-12-29 10:06:54.296 error The connection to the gateway is dead.
                                      ! tradfri.0 2017-12-29 10:06:53.826 error Restarting the adapter in 10 seconds!
                                      ! tradfri.0 2017-12-29 10:06:53.826 error Three consecutive reset attempts failed!
                                      ! tradfri.0 2017-12-29 10:06:25.814 error unhandled promise rejection: CoapClient was reset
                                      ! tradfri.0 2017-12-29 10:06:25.812 warn 3 consecutive pings failed, resetting connection (attempt #3)…
                                      ! tradfri.0 2017-12-29 10:06:14.059 error at Timer.listOnTimeout (timers.js:214:5)
                                      ! tradfri.0 2017-12-29 10:06:14.059 error at tryOnTimeout (timers.js:250:5)
                                      ! tradfri.0 2017-12-29 10:06:14.059 error at ontimeout (timers.js:386:11)
                                      ! tradfri.0 2017-12-29 10:06:14.059 error at Timeout.action [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-tradfri-client/node_modules/node-coap-client/build/CoapClient.js:281:38)
                                      ! tradfri.0 2017-12-29 10:06:14.059 error at Function.retransmit (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-tradfri-client/node_modules/node-coap-client/build/CoapClient.js:364:40)
                                      ! tradfri.0 2017-12-29 10:06:14.059 error > stack: Error: Retransmit counter exceeded
                                      ! tradfri.0 2017-12-29 10:06:14.058 error unhandled promise rejection: Retransmit counter exceeded
                                      ! tradfri.0 2017-12-29 10:06:05.815 warn Lost connection to gateway
                                      ! tradfri.0 2017-12-29 10:05:38.843 info updating possible scenes for group 131077: ["196620","196621","196622"]
                                      ! tradfri.0 2017-12-29 10:05:38.727 info updating possible scenes for group 131077: ["196620","196621","196622"]
                                      ! tradfri.0 2017-12-29 10:05:38.629 info updating possible scenes for group 131077: ["196620","196621","196622"]
                                      ! tradfri.0 2017-12-29 09:58:00.629 info received all groups and scenes
                                      ! tradfri.0 2017-12-29 09:58:00.629 info received all devices
                                      ! tradfri.0 2017-12-29 09:58:00.628 info Connection to gateway reestablished
                                      ! tradfri.0 2017-12-29 09:57:55.628 warn Lost connection to gateway
                                      ! tradfri.0 2017-12-29 09:56:30.595 info received all groups and scenes
                                      ! tradfri.0 2017-12-29 09:56:30.595 info received all devices
                                      ! tradfri.0 2017-12-29 09:56:30.595 info Connection to gateway reestablished
                                      ! tradfri.0 2017-12-29 09:56:25.591 warn Lost connection to gateway
                                      ! tradfri.0 2017-12-29 09:51:50.490 info received all groups and scenes
                                      ! tradfri.0 2017-12-29 09:51:50.490 info received all devices
                                      ! tradfri.0 2017-12-29 09:51:50.489 info Connection to gateway reestablished
                                      ! tradfri.0 2017-12-29 09:51:35.473 warn Lost connection to gateway
                                        pxstd
                                        #259
                                        Nachtrag: Sobald allerdings ein Restart passiert, funktioniert das aktuell angezeigte VIS nicht mehr korrekt.
                                        Ich habe ein Tablet im EG über das ich steuere - wird der Adapter neu gestartet, sind alle Veränderungen im VIS ohne Funktion. (iPad Air, iPad 1)
                                          AlCalzoneA Offline
                                          AlCalzone
                                          #260
                                          @pxstd:
                                          wird der Adapter neu gestartet, sind alle Veränderungen im VIS ohne Funktion. (iPad Air, iPad 1) `
                                          Bin kein VIS-Mensch, daher weiß ich nicht obs da was zu beachten gibt.
                                          Lassen sich die Änderungen, die du per VIS vornehmen willst, nach einem Neustart manuell in der Objektliste vornehmen?
