  4. [Problem] Install ioBroker in Raspbian Jessie geht nicht weiter, Fehler
17 Beiträge 6 Kommentatoren 4.0k Aufrufe
  • H Offline
    hajo48
    MOD-Edit by eric2905; 02-05.2017/20:07 - Betreff angepasst und Code-Tags gesetzt
    ich bin Anfänger und hab ein Problem mit der Einrichtung/Konfiguration von ioBroker.
    Ist-Zustand:
    Raspberry 1 Modell B
    Raspbian Jessie installiert ok
    Nach Installationsanleitung inclusive Node.js neu für Raspberry 1 ok.
    Anschliesende Installation von ioBroker geht nicht weiter, was läuft da schief.
    Hier der Ablauf:
    login as: pi
    pi@192.168.xxx password:
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Wed Apr 26 00:44:12 2017 from xxxx-pc.fritz.box
    pi@raspberrypi:~ $ node -v
    v0.12.6
    pi@raspberrypi:~ $ sudo mkdir /opt/iobroker
    pi@raspberrypi:~ $ sudo chmod 777 /opt/iobroker
    pi@raspberrypi:~ $ cd /opt/iobroker
    pi@raspberrypi:/opt/iobroker $ sudo npm install iobroker --unsafe-perm
    > iobroker@0.9.0 install /opt/iobroker/node_modules/iobroker
    > node lib/setup.js
    npm install iobroker.js-controller --production --prefix /opt/iobroker
    npm WARN engine request@2.81.0: wanted: {"node":">= 4"} (current: {"node":"0.12.6","npm":"2.11.2"})
    npm WARN engine har-validator@4.2.1: wanted: {"node":">=4"} (current: {"node":"0.12.6","npm":"2.11.2"})
    npm WARN engine har-schema@1.0.5: wanted: {"node":">=4"} (current: {"node":"0.12.6","npm":"2.11.2"})
    Ich bitte um Hilfe! :(
    • K Offline
      keynight
      ssh raspberrypi
      wget https://github.com/ioBroker/ioBroker/blob/master/install/linux/install-raspbian8.sh
      sudo bash install-raspbian8.sh
      мой блог http://eumax.ru/blog/haus/ Telegram http://t.me/smarthome_de/
        Wo hast du die uralte Version von nodejs her, du benötigst mindestens 4.xx
        http://www.iobroker.net/?page_id=5106&lang=de
        Rainer
        • eric2905E Offline
          eric2905E Offline
          eric2905
          Hallo und Willkommen an Bord,
          der Fehler steht doch im Log drin:
          Du verwendest eine zu alte Version von ppm und node.js.
          Schau Dir mal diese Anleitung an - da steht erklärt, wie Du node.js updates ==> http://www.iobroker.net/?page_id=5106&lang=de
          Bitte achte drauf, das Du den Abschnitt für Raspberry 1 verwendest!!!
          Gruß,
          Eric
          PS: Rainer war schneller :D
          • H Offline
            hajo48
            @Homoran:
            Rainer `
            Hallo Rainer,
            vielen Dank für die Antwort, hilft mir nur nicht wirklich weiter, habe die Installation genau nach dieser, von dir genannten
            Url/Seite vorgenommen.
            Habe auch Node.js wie angegeben, nur für Raspberry 1 genommen.
            Was muss ich denn nun laut Installationsanleitung Node.js Raspberry 1 anders machen?
            Gruss
            Joachim
            • H Offline
              hajo48
              @eric2905:
              Gruß,
              Eric
              Hallo Eric,
              Das selbe habe ich auch Rainer geschrieben.
              PS: Rainer war schneller :D `
                @hajo48:
                Was muss ich denn nun laut Installationsanleitung Node.js Raspberry 1 anders machen? `
                Mit dem Pi1 wirst du nicht lange glücklich werden.
                Geh mal auf diese Seite
                http://www.iobroker.net/?page_id=2563&lang=de
                Dort habe ich ein Image für den Pi1 mit nodejs 6.xx gemacht.
                Wie weiß ich im Moment selber nicht :oops:
                Rainer
                • H Offline
                  hajo48
                  Hallo Rainer,
                  entschuldige meine späte Antwort, das Image hatte ich schon mal installiert und ließ sich auch starten aber die vorgeschlagenen Update's lassen sich nicht installieren bzw. erst garnicht herrunterladen. Es kommen immer Errors.
                  Mein Vorhaben ist es eigendlich mit den Raspbi und einen nano CUL Bausatz CC1101 433Mhz CUL 433 USB-Stick für FHEM
                  meine Somfy Markiese zu steuern / bedienen.
                  Hast du da einen guten und nachvollziehbaren Vorschlag für einen Anfänger?
                  Vielen Dank im Voraus für deine Mühe.
                  Joachim :|
                  • kmxakK Offline
                    kmxakK Offline
                    kmxak
                    Für den Pi1 brauchst du armv6 hatte auch probleme mit der installation auf einem zero.
                    Der Code siehe unten müsste theoretisch gehen. Habe ich aber noch nicht getestet.
                    Node v4.8.3 Installieren
                    wget https://nodejs.org/dist/v4.8.3/node-v4.8.3-linux-armv6l.tar.gz
                    tar -xvf node-v4.8.3-linux-armv6l.tar.gz
                    cd node-v4.8.3-linux-armv6l
                    sudo cp -R * /usr/local/
                    Version Prüfen
                    > node -v
                    ggf fall es noch nicht geht folgendes ausführen
                    sudo ln -s /usr/local/bin/nodejs /usr/bin/node
                    Wenn es immer noch nicht geht meld dich einfach nochmal
                    (@ Mod wir sollten die Installation für den pi1 oder zero und zero w mal anpassen. Die Anleitung für den Pi 1 geht bzw ging bei mir auch nicht.)
                    Gruß Alex
                    • H Offline
                      hajo48
                      Hallo Alex,
                      vielen Dank für deinen Tip, die v4.8.3 habe ich installiert aber bei der Insallation von ioBroker
                      kommen Fehler über Fehler, die ich als Anfänger im Moment nicht einordnen kann.
                      Hier mal der Ablauf:
                      v4.8.3
                      mkdir: das Verzeichnis ▒/opt/iobroker▒ kann nicht angelegt werden: Die Datei existiert bereits
                      pi@raspberrypi:/opt/iobroker $ sudo npm install iobroker –unsafe-perm
                      node lib/setup.js
                      npm install iobroker.admin --production --prefix /opt/iobroker
                      npm install iobroker.discovery --production --prefix /opt/iobroker
                      In file included from ../src/dns_sd.cpp:1:0:
                      ../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
                      #include <dns_sd.h>^
                      compilation terminated.
                      make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
                      gyp ERR! build error
                      gyp ERR! stack Error: make failed with exit code: 2
                      gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                      gyp ERR! stack at emitTwo (events.js:87:13)
                      gyp ERR! stack at ChildProcess.emit (events.js:172:7)
                      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
                      gyp ERR! System Linux 4.9.24+
                      gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/mdns
                      gyp ERR! node -v v4.8.3
                      gyp ERR! node-gyp -v v3.4.0
                      gyp ERR! not ok
                      npm WARN optional dep failed, continuing mdns@2.3.3
                      node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAd … arm.tar.gz
                      node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.8.3 (node-v46 ABI) (falling back to source compile with node-gyp)
                      Write "./iobroker start" to start the ioBroker
                      Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
                      iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
                      iobroker@0.9.0 node_modules/iobroker
                      └── yargs@7.1.0 (get-caller-file@1.0.2, decamelize@1.2.0, camelcase@3.0.0, y18n@3.2.1, which-module@1.0.0, set-blocking@2.0.0, yargs-parser@5.0.0, require-main-filename@1.0.1, require-directory@2.1.1, string-width@1.0.2, cliui@3.2.0, os-locale@1.4.0, read-pkg-up@1.0.1)
                      pi@raspberrypi:/opt/iobroker $ The programs included with the Debian GNU/Linux system are free software;
                      -bash: The: Kommando nicht gefunden.
                      pi@raspberrypi:/opt/iobroker $ the exact distribution terms for each program are described in the
                      -bash: the: Kommando nicht gefunden.
                      pi@raspberrypi:/opt/iobroker $ individual files in /usr/share/doc/*/copyright.
                      -bash: individual: Kommando nicht gefunden.
                      pi@raspberrypi:/opt/iobroker $ Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                      -bash: Debian: Kommando nicht gefunden.
                      pi@raspberrypi:/opt/iobroker $ permitted by applicable law.
                      -bash: permitted: Kommando nicht gefunden.
                      pi@raspberrypi:/opt/iobroker $ Last login: Fri May 5 20:21:37 2017 from winmac.fritz.box
                      -bash: Last: Kommando nicht gefunden.
                      pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:~ $ node -v
                      -bash: pi@raspberrypi:~: Kommando nicht gefunden.
                      pi@raspberrypi:/opt/iobroker $ v4.8.3
                      -bash: v4.8.3: Kommando nicht gefunden.
                      pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:~ $ sudo mkdir /opt/iobroker
                      icht angelegt werden: Die Datei existiert bereitshnis ▒/opt/iobroker▒ kann n
                      -bash: mkdir:: Kommando nicht gefunden.
                      pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:~ $ sudo chmod 777 /opt/iobroker
                      pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:~ $ cd /opt/iobroker
                      pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:/opt/iobroker $ sudo npm install iobroker --unsafe-perm
                      -bash: pi@raspberrypi:/opt/iobroker: Datei oder Verzeichnis nicht gefunden
                      pi@raspberrypi:/opt/iobroker $ /
                      -bash: /: Ist ein Verzeichnis
                      pi@raspberrypi:/opt/iobroker $ > iobroker@0.9.0 install /opt/iobroker/node_modules/iobroker
                      install: Fehlender Zieldatei-Operand hinter ▒/opt/iobroker/node_modules/iobroker▒
                      ▒install --help▒ liefert weitere Informationen.
                      pi@raspberrypi:/opt/iobroker $ > node lib/setup.js
                      -bash: lib/setup.js: Datei oder Verzeichnis nicht gefunden
                      pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller --production --prefix /opt/iobroker
                      npm ERR! Linux 4.9.24+
                      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production" "--prefix" "/opt/iobroker"
                      npm ERR! node v4.8.3
                      npm ERR! npm v2.15.11
                      npm ERR! path /opt/iobroker/node_modules/.bin/iobroker
                      npm ERR! code EACCES
                      npm ERR! errno -13
                      npm ERR! syscall unlink
                      npm ERR! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.bin/iobroker'
                      npm ERR! at Error (native)
                      npm ERR! { [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.bin/iobroker']
                      npm ERR! errno: -13,
                      npm ERR! code: 'EACCES',
                      npm ERR! syscall: 'unlink',
                      npm ERR! path: '/opt/iobroker/node_modules/.bin/iobroker' }
                      npm ERR!
                      npm ERR! Please try running this command again as root/Administrator.
                      npm ERR! error rolling back Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.bin/iobroker'
                      npm ERR! error rolling back at Error (native)
                      npm ERR! error rolling back { [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.bin/iobroker']
                      npm ERR! error rolling back errno: -13,
                      npm ERR! error rolling back code: 'EACCES',
                      npm ERR! error rolling back syscall: 'unlink',
                      npm ERR! error rolling back path: '/opt/iobroker/node_modules/.bin/iobroker' }
                      npm ERR! Please include the following file with any support request:
                      npm ERR! /opt/iobroker/npm-debug.log
                      pi@raspberrypi:/opt/iobroker $ npm install iobroker.admin –production --prefix /opt/iobroker
                      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.admin" "--production" "--prefix" "/opt/iobroker"
                      npm ERR! path /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/.bin/uuid
                      npm ERR! errno -13
                      npm ERR! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/.bin/uuid'
                      npm ERR! { [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/.bin/uuid']
                      npm ERR! path: '/opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/.bin/uuid' }
                      npm ERR!
                      npm ERR! error rolling back Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/.bin/uuid'
                      npm ERR! error rolling back { [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/.bin/uuid']
                      npm ERR! error rolling back path: '/opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/.bin/uuid' }
                      Joachim</dns_sd.h>
                      • kmxakK Offline
                        kmxakK Offline
                        kmxak
                        hast du auch folgenden code ausgeführt?
                        sudo apt-get install build-essential python python-rpi.gpio
                        Gruß Alex
                        • H Offline
                          hajo48
                          Hallo Alex,
                          der code unter "Node.js neu installieren nur für Raspberry 1" unter Punkt 3 habe ich übersehen .
                          Was muß denn nun unter "Node.js neu installieren nur für Raspberry 1" wirklich in der Reihenfolge
                          eigegeben werden und was muß weggelassen oder geändert werden?
                          Joachim
                          • kmxakK Offline
                            kmxakK Offline
                            kmxak
                            node ist ja nun schon drauf dann noch
                            nachinstallieren.
                            Ich persönlich würde nochmals den (/opt/)iobroker ordner löschen neu anlegen chmod 777 setzen und nochmal die iobroker installation probieren
                            Gruß Alex
                            • H Offline
                              hajo48
                              @kmxak:
                              nachinstallieren.
                              Hallo Alex,
                              vielen Dank für deinen Tip aber trotzdem kein Erfolg erst dauert es eine Ewigkeit bis ioBroker Installation startet, hier mein Logg:
                              login as: pi
                              pi@192.168.xxxxxx password:
                              mkdir: das Verzeichnis „/opt/iobroker“ kann nicht angelegt werden: Die Datei exi stiert bereits
                              node lib/setup.js
                              ../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefun den
                              gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_ modules/node-gyp/lib/build.js:276:23)
                              gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_proces s.js:211:12)
                              gyp ERR! System Linux 4.4.50+
                              gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_mod ules/node-gyp/bin/node-gyp.js" "rebuild"
                              gyp ERR! not ok
                              node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyA dvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux -arm.tar.gz
                              node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.8 .3 (node-v46 ABI) (falling back to source compile with node-gyp)
                              └── yargs@7.1.0 (get-caller-file@1.0.2, decamelize@1.2.0, camelcase@3.0.0, y18n@3.2.1, wh ich-module@1.0.0, set-blocking@2.0.0, yargs-parser@5.0.0, require-main-filename@1.0.1, re quire-directory@2.1.1, cliui@3.2.0, os-locale@1.4.0, string-width@1.0.2, read-pkg-up@1.0. 1)
                              pi@raspberrypi:/opt/iobroker $</dns_sd.h>
                                DeepCore
                                Diesen Fehler hatte ich heute auch bei einer Testinstallation in Virtualbox und Debian 8 …
                                ...</dns_sd.h> `
                                Meine Lösung war folgende, ausgehend von einem frisch installierten Debian 8 64-bit System:
                                # Using Debian, as root
                                apt-get update
                                apt-get upgrade
                                apt-get install build-essential python libavahi-compat-libdnssd-dev
                                apt-get install curl
                                curl -sL https://deb.nodesource.com/setup_4.x | bash -
                                apt-get install -y nodejs
                                npm install node-gyp
                                npm install mdns
                                mkdir /opt/iobroker
                                cd /opt/iobroker
                                npm install --unsafe-perm iobroker
                                ioBroker muss dann trotzdem noch manuell gestartet werden
                                ./iobroker start
                                • kmxakK Offline
                                  kmxakK Offline
                                  kmxak
                                  das wird nicht gehen mit
                                  er hat nen pi1 da brauchst wie oben schon erwähnt ein anderes node
                                  Gruß Alex
                                    DeepCore
                                    @kmxak
                                    Meine Antwort bezog sich auf den Fehler bei der Installation von iobroker.discovery, wo eine fehlende Datei bemängelt wird
                                    Geht den libavahi-compat-libdnssd-dev auf dem Pi 1?
