  3. Off Topic
  4. [Gelöst] Ubuntu updaten
64 Beiträge 6 Kommentatoren 7.0k Aufrufe 4 Beobachtet
  • KusselinK Offline
    KusselinK Offline
    Kusselin
    schrieb am zuletzt editiert von Kusselin
    Hallo Zusammen, ich bekomme wenn ich mich über die Console anmlede udn ein apt-get udate && apt-get upgrade mache folgende Meldung:
    Welcome to Ubuntu 21.10 (GNU/Linux 5.15.35-1-pve x86_64)
     * Documentation:  https://help.ubuntu.com
     * Management:     https://landscape.canonical.com
     * Support:        https://ubuntu.com/advantage
    Your Ubuntu release is not supported anymore.
    For upgrade information, please visit:
    http://www.ubuntu.com/releaseendoflife
    New release '22.04.1 LTS' available.
    Run 'do-release-upgrade' to upgrade to it.
    Nach der Anmeldung das:
    Updaten das hier dann:
    apt-get update
    Hit:1 http://ppa.launchpad.net/ondrej/php/ubuntu impish InRelease
    Ign:2 http://archive.ubuntu.com/ubuntu impish InRelease
    Ign:3 http://archive.ubuntu.com/ubuntu impish-updates InRelease
    Ign:4 http://archive.ubuntu.com/ubuntu impish-security InRelease
    Err:5 http://archive.ubuntu.com/ubuntu impish Release
      404  Not Found [IP: 91.189.91.38 80]
    Err:6 http://archive.ubuntu.com/ubuntu impish-updates Release
    Err:7 http://archive.ubuntu.com/ubuntu impish-security Release
    Reading package lists... Done
    E: The repository 'http://archive.ubuntu.com/ubuntu impish Release' no longer has a Release file.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    E: The repository 'http://archive.ubuntu.com/ubuntu impish-updates Release' no longer has a Release file.
    E: The repository 'http://archive.ubuntu.com/ubuntu impish-security Release' no longer has a Release file.
    und das beim upgraden:
     apt-get upgrade
    Building dependency tree... Done
    Calculating upgrade... Done
    The following packages will be upgraded:
      apt apt-utils isc-dhcp-client isc-dhcp-common libapt-pkg6.0 libkeyutils1
      libnss-systemd libpam-systemd libsystemd0 libudev1 python3-distupgrade
      systemd systemd-sysv systemd-timesyncd ubuntu-advantage-tools
      ubuntu-release-upgrader-core udev
    17 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 10.4 MB of archives.
    After this operation, 32.8 kB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Err:1 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libnss-systemd amd64 248.3-1ubuntu8.6
      404  Not Found [IP: 185.125.190.39 80]
    Err:2 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libsystemd0 amd64 248.3-1ubuntu8.6
    Err:3 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 systemd-timesyncd amd64 248.3-1ubuntu8.6
    Err:4 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 systemd-sysv amd64 248.3-1ubuntu8.6
    Err:5 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libpam-systemd amd64 248.3-1ubuntu8.6
    Err:6 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 systemd amd64 248.3-1ubuntu8.6
    Err:7 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 udev amd64 248.3-1ubuntu8.6
    Err:8 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libudev1 amd64 248.3-1ubuntu8.6
    Err:9 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libapt-pkg6.0 amd64 2.3.9ubuntu0.1
    Err:10 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 apt amd64 2.3.9ubuntu0.1
    Err:11 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 apt-utils amd64 2.3.9ubuntu0.1
    Err:12 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libkeyutils1 amd64 1.6.1-2ubuntu2.1
    Err:13 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 isc-dhcp-client amd64 4.4.1-2.3ubuntu1.1
    Err:14 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 isc-dhcp-common amd64 4.4.1-2.3ubuntu1.1
    Err:15 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 ubuntu-advantage-tools amd64 27.9~21.10.1
    Err:16 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 ubuntu-release-upgrader-core all 1:21.10.10
    Err:17 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 python3-distupgrade all 1:21.10.10
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libnss-systemd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libsystemd0_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd-timesyncd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd-sysv_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libpam-systemd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/udev_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libudev1_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/libapt-pkg6.0_2.3.9ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/apt_2.3.9ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/apt-utils_2.3.9ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/k/keyutils/libkeyutils1_1.6.1-2ubuntu2.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/i/isc-dhcp/isc-dhcp-client_4.4.1-2.3ubuntu1.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/i/isc-dhcp/isc-dhcp-common_4.4.1-2.3ubuntu1.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-advantage-tools/ubuntu-advantage-tools_27.9%7e21.10.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-release-upgrader/ubuntu-release-upgrader-core_21.10.10_all.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-release-upgrader/python3-distupgrade_21.10.10_all.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
    Was macht man denn in solch einem Fall?
    Gibts da ein How to?
    Danke und Gruss
    ? crunchipC 2 Antworten Letzte Antwort
    • KusselinK Kusselin
      apt-get update
       apt-get upgrade
      Danke und Gruss
      @kusselin Liegt wohl daran, dass einige Repositories nicht mehr verfügbar bzw. veraltet sind.
      Hier ein StackOverflow Beitrag, der dir vielleicht weiter hilft.
      KusselinK 1 Antwort Letzte Antwort
        KusselinK Offline
        KusselinK Offline
        Kusselin
        @tmartin O.K. aber was heisst das?
        gibts da nicht einfacheres ?
        J Thomas BraunT 2 Antworten Letzte Antwort
          Jan1
          @kusselin
          Dein Ubuntu ist wohl zu alt und Du solltet ein aktuelles verwenden.
            @kusselin
            sudo do-release-upgrade
            Und künftig keine Zwischenversionen einsetzen sondern nur LTS-Releases.
              apt-get update
               apt-get upgrade
              Danke und Gruss
              crunchipC Abwesend
              crunchipC Abwesend
              @kusselin sagte in Ubuntu updaten:
              Steht ja auch da, wie Thomas schon schrieb
              • J Jan1
                @kusselin
                KusselinK Offline
                KusselinK Offline
                Kusselin
                @jan1 ja genau...das sehe ich ja auch...das es alt ist....
                und da muss es doch eine möglichkeit über console geben ubzugraden auf die nächst höhere version
                  @kusselin
                  Ja, mit
                    @kusselin
                    KusselinK Offline
                    KusselinK Offline
                    Kusselin
                    @thomas-braun sagte in Ubuntu updaten:
                    @kusselin
                    O.K. danke Dir ..mit dem befehl solls gehen?
                      @kusselin
                      @kusselin
                      Ja.
                        @kusselin
                        Ja.
                        KusselinK Offline
                        KusselinK Offline
                        Kusselin
                        @thomas-braun schau...was muss ich hier denn machen??
                        Checking for a new Ubuntu release
                        Please install all available updates for your release before upgrading.
                          @kusselin
                          sudo apt update
                          sudo apt full-upgrade
                          sudo reboot
                            @kusselin
                            sudo apt update
                            sudo reboot
                            KusselinK Offline
                            KusselinK Offline
                            Kusselin
                            nee thomas.....das klappt so nicht...das wäre zu einfach :-)
                             sudo apt update
                              404  Not Found [IP: 91.189.91.39 80]
                            root@Nextcloud-live:~# sudo apt full-upgrade
                               sudo apt update
                              @kusselin
                              Installier es neu und halte da dann das EndOfLife im Auge und spring vorher auf den Nachfolger.
                                 sudo apt update
                                @kusselin
                                Kannst aber auch hier mal schauen:
                                https://help.ubuntu.com/community/EOLUpgrades
                                  @kusselin
                                  KusselinK Offline
                                  KusselinK Offline
                                  Kusselin
                                  @kusselin
                                  andree Möglichkeit wie neuinstallation gibts nicht?
                                    @kusselin
                                    @kusselin
                                    Steht im dem Link drin:
                                    Aber auch dort wird geschrieben:
                                    Reinstalling is usually easier and faster, especially if you would have to upgrade through several releases.
                                      @kusselin
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      @kusselin hatte das kürzlich auch bei einer VM gemacht, sourceslist anpassen aufs aktuelle Ubuntu und danach das full update, geht ohne Probleme
                                      HomoranH KusselinK 2 Antworten Letzte Antwort
                                        @crunchip sagte in Ubuntu updaten:
                                        war da das alte Repo auch nicht mehr erreichbar?
                                          KusselinK Offline
                                          KusselinK Offline
                                          Kusselin
                                          das hier:
                                          ## EOL upgrade sources.list
                                          # Required
                                          deb http://old-releases.ubuntu.com/ubuntu/ CODENAME main restricted universe multiverse
                                          deb http://old-releases.ubuntu.com/ubuntu/ CODENAME-updates main restricted universe multiverse
                                          deb http://old-releases.ubuntu.com/ubuntu/ CODENAME-security main restricted universe multiverse
                                          # Optional
                                          #deb http://old-releases.ubuntu.com/ubuntu/ CODENAME-backports main restricted universe multiverse
                                          muss in die source list.....
                                          Bitte an euch...wo bzw. welche pfad ist das /etc/......?
                                          und muss ich das alte dann komplett rausnehmen aus der source list udn das hier neu rein?
