  4. JSON Wert mit Blockly schreiben
    5.3k
41 Beiträge 10 Kommentatoren 5.3k Aufrufe 7 Beobachtet
  • L Offline
    Lucky_ESA
    Vielleicht hilft das.
     <variables>
       <variable id="nl2mcBg+v./1.n=r[lbN">arr</variable>
       <variable id="Tn3lhvSQ*_}iAfZ_9Otb">att</variable>
       <variable id="x%B53[~zQVyc=3qtd7n|">value</variable>
       <variable id="w15a1MGC2*azw~AFrt}A">array_1</variable>
     </variables>
     <block type="procedures_defcustomreturn" id="Rp_Yt5xHvYYYfyg%d-=[" x="-262" y="-37">
       <mutation statements="false">
         <arg name="arr" varid="nl2mcBg+v./1.n=r[lbN"></arg>
         <arg name="att" varid="Tn3lhvSQ*_}iAfZ_9Otb"></arg>
         <arg name="value" varid="x%B53[~zQVyc=3qtd7n|"></arg>
       </mutation>
       <field name="NAME">etwas tun</field>
       <field name="SCRIPT">YXJyW2F0dF0gPSB2YWx1ZTsNCnJldHVybiBhcnI7</field>
     </block>
     <block type="variables_set" id="*p1g(R6$#k@!Bk8K52IB" x="-262" y="13">
       <field name="VAR" id="w15a1MGC2*azw~AFrt}A">array_1</field>
       <value name="VALUE">
         <block type="convert_json2object" id="k8q%UwJPqTq|49)xlj=0">
             <block type="get_value" id="!zK?6WTB%BG@?]-/k:V@">
               <field name="OID">0_userdata.0.hallo</field>
             </block>
           </value>
         </block>
       </value>
       <next>
         <block type="debug" id="[3-#pbr!!l*w*wXx3d4@">
           <value name="TEXT">
             <shadow type="text" id="5D^j`kV?g@O=^hg5DQL$">
             </shadow>
             <block type="procedures_callcustomreturn" id=",f+Y(N6*X^iy+JoCRK;]">
               <mutation name="etwas tun">
                 <arg name="arr"></arg>
                 <arg name="att"></arg>
                 <arg name="value"></arg>
               </mutation>
               <value name="ARG0">
                 <block type="variables_get" id="=D1@Frh?cQA~|],t:d2P">
                 </block>
               </value>
               <value name="ARG1">
                 <block type="text" id="Zjr0C+m-(*f[5U`LYIr6">
                   <field name="TEXT">preconditioning_weekdays_only</field>
                 </block>
               </value>
               <value name="ARG2">
                 <block type="logic_boolean" id="?6|ikyT*e}L0kM5l[8;Z">
                 </block>
               </value>
             </block>
           </value>
           <next>
             <block type="update" id="}EPy[_WE9z{wIq){455^">
                 <block type="convert_object2json" id="_F^7#k~c%D(yODCA_nhe">
                   <field name="PRETTIFY">FALSE</field>
                     <block type="variables_get" id="H24!l/J[aXOJCKYX1!a{">
                     </block>
                   </value>
                 </block>
               </value>
             </block>
           </next>
         </block>
       </next>
     </block>
    </xml>
    Gruß//Lucky
    • L Lucky_ESA
       <variables>
       </variables>
         </mutation>
       </block>
               </block>
             </value>
           </block>
         </value>
         <next>
             <value name="TEXT">
               </shadow>
                 </mutation>
                 <value name="ARG0">
                   </block>
                 </value>
                 <value name="ARG1">
                   </block>
                 </value>
                 <value name="ARG2">
                   </block>
                 </value>
               </block>
             </value>
             <next>
                       </block>
                     </value>
                   </block>
                 </value>
               </block>
             </next>
           </block>
         </next>
       </block>
      </xml>
      Gruß//Lucky
      @lucky_esa sagte: Vielleicht hilft das.
      Das ist aufgrund der verwendeten Bezeichner eher verwirrend. Außerdem benötigt man kein return, da Objekte per Referenz übergeben werden.
      Inhalt der Funktion setAttribut(obj, attr, val):
      obj[attr] = val;
      • J jr28
        das heißt, dass ich das json immer erst komplett zusammenbauen muss, um es dann als Text in das Objekt zu schreiben?
        (Sorry, wenn das jetzt eine "blöde" Frage ist, aber ich beschäftige mich jetzt erst seit 14 Tagen mit IO-Broker.)
        Lucky_ESA
        @jr28 sagte in JSON Wert mit Blockly schreiben:
        Das Blockly ist für dich gedacht.
        Wie man die Function und die Variablen benennt ist jedem selber überlassen. Jeder hat sein eigenes System wie man was wie schreibt. Ein return dient bei großen Blocklys zur besseren Übersicht. Aber auch das ist jedem selber überlassen.
        Gruß//Lucky
        paul53P CodierknechtC 2 Antworten Letzte Antwort
        • L Lucky_ESA
          Gruß//Lucky
          @lucky_esa sagte: Wie man die Function und die Variablen benennt ist jedem selber überlassen.
          Ja, aber mit der Bezeichnung Array werden gerade Anfänger auf eine falsche Fährte geführt.
          L 1 Antwort Letzte Antwort
            Lucky_ESA
            @paul53 sagte in JSON Wert mit Blockly schreiben:
            Auch das ist Ansichtssache. Einem Anfäger mit einem Bild zu zeigen wie man ein Attribut hinzufügt statt zu ändern kann auch verwirren 😁
            Gruß//Lucky
            • L Lucky_ESA
              Gruß//Lucky
              @lucky_esa sagte: Bild zu zeigen wie man ein Attribut hinzufügt statt zu ändern
              Habe das Bild geändert.
                @jr28
                jr28
                da ich mir sicher sein wollte alles richtig zu machen habe ich folgendes gemacht:
                Wieso schlägt der Vergleich fehl?
                Ich will absolut sicher sein bevor ich in den Tiefen meines Tesla was schreibe.
                • L Lucky_ESA
                  Gruß//Lucky
                  CodierknechtC Offline
                  Codierknecht
                  @lucky_esa sagte in JSON Wert mit Blockly schreiben:
                  Klar, aber Code wird zum allergrößten Teil gelesen. Alte Weisheit: "Jeder Code muss irgendwann gewartet werden".
                  Dann sitzt man davor und denkt sich "welcher Horst hat das denn verbrochen?" ... um dann nach mehr oder langem Sinnieren festzustellen ... "Upps, ist ja mein Code" 😁
                  Choose descriptive and unambiguous names
                  "Clean Code" (Robert C. Martin)
                  HmIP|ZigBee|Tasmota|Unifi
                  Zabbix Certified Specialist
                  • mickymM Offline
                    mickymM Offline
                    mickym
                    Blockly, Objekte und JSON einfach nur grauslig. 😬
                    Verstehe nicht warum man Eigenschaften von Objekten lesen kann
                    JSONs in Objekte und umgekehrt wandeln kann.
                    aber man nicht in der Lage ist Attribute in einem Objekt zu beschreiben. Einfach schlimm. ;)
                    • J jr28
                      @jr28 sagte: Wieso schlägt der Vergleich fehl?
                      So ein String-Vergleich ist problematisch, da schon ein Leerzeichen mehr oder weniger oder ein unsichtbares Sonderzeichen zu einem negativen Ergebnis führen. Dabei spielen Leerzeichen im JSON keine Rolle.
                      Deshalb mache mal - nur für den Vergleich - eine doppelte Konvertierung JSON --> Objekt --> JSON.
                      • K Offline
                        kalle-r
                        hmmm.... bei mir klappt das irgendwie nicht:
                        hab einen Datenpunkt "test" vom Typ JSON
                            "Art": "A1",
                            "Tag": "A2"
                            "Art": "B1",
                            "Tag": "B2"
                            "Art": "C1",
                            "Tag": "C2"
                        Blockly von oben:
                        Result:
                        hat jemand eine Idee wo das hängt?
                        DJMarc75D paul53P 2 Antworten Letzte Antwort
                        • K kalle-r
                              "Art": "A1",
                              "Tag": "A2"
                              "Art": "B1",
                              "Tag": "B2"
                              "Art": "C1",
                              "Tag": "C2"
                          Blockly von oben:
                          Result:
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          @kalle-r Warum sollte das auch funktionieren ?! Wo bitte gibt es in Deinem Json das Attribute "1.Tag" ?
                          Lehrling seit 1975 !!!
                          K 1 Antwort Letzte Antwort
                          • K kalle-r
                                "Art": "A1",
                                "Tag": "A2"
                                "Art": "B1",
                                "Tag": "B2"
                                "Art": "C1",
                                "Tag": "C2"
                            Blockly von oben:
                            Result:
                            @kalle-r sagte: klappt das irgendwie nicht
                            Wie soll man das beurteilen, wenn der Inhalt der JS-Funktion verschwiegen wird?
                            • DJMarc75D DJMarc75
                              kalle-r
                              @djmarc75
                              sorry, bin nur so ein halbwissender 😎
                              also nach meinem bisherigen Ermittlungen kann ich mit
                              0.xxx
                              1.xxx
                              2.xxx
                              auf die jeweiligen Einträge zugreifen.
                              0.Tag liefert A2
                              1.Tag liefert B2
                              2.Tag liefert C2
                              1.Art liefert entsprechend B1
                              das funktioniert so weit.
                              Ich möchte jetzt z.B. aus B2 einen anderen Text machen und habe gehofft daß das mit dem Skript
                              von weiter oben klappt....
                                kalle-r
                                ja Du hast Recht, hier der Inhalt:
                                • K kalle-r
                                  @kalle-r sagte: hier der Inhalt
                                  Versuche es mal mit dieser JS-Funktion (ohne Ergebnis, denn ein Array wird ohnehin per Referenz übergeben):
                                  att = att.split('.');
                                  arr[att[0]][att[1]] = value;
                                    kalle-r
                                    das schaut gut aus 👍
                                    kannst Du mir erklären warum das in Deinem Beispiel weiter oben mit dem original-Skript funktioniert hat
                                    und in meinem Beispiel nicht?
                                    ich will ja schliesslich was dazu lernen ;-)
                                    • K kalle-r
                                      @kalle-r sagte: warum das in Deinem Beispiel weiter oben mit dem original-Skript funktioniert hat
                                      Im Original wird das Attribut eines Objektes geändert und nicht das Attribut eines Objektes in einem Array von Objekten.
                                      Anmerkung: Den Zugriff auf ein Array-Element per Punkt-Notation kennt Javascript nicht. Das kann nur die speziell für Blockly entwickelte Funktion getAttr().
                                        kalle-r
                                        jetzt ist's klar, danke!
                                        Noch eine doofe? Frage:
                                        wie kommt man zu dem Funktionsaufruf den ich ohne debug verwenden kann?
                                        ich hab nur den den ich nach links andocken muss
                                        • K kalle-r
                                          @kalle-r sagte: wie kommt man zu dem Funktionsaufruf den ich ohne debug verwenden kann?
                                          Javascript-Funktion (ohne Ergebnis).
