  4. Materialdesign Dialog widget
21 Beiträge 3 Kommentatoren 1.6k Aufrufe 2 Beobachtet
    Blechbixn
    Hallo.
    Habe ein Problem das ich selber nicht gelöst bekomme.
    Habe mir ein Materialdesign Dialog widget gezogen und einer view zugewiesen.
    Öffnet sich leider nur ein weißer Balken, der inhalt der view wird nicht dargestellt.
    was mach ich falsch?
    Widget:
    [{"tpl":"tplVis-materialdesign-Vuetify-Dialog-View","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","showDialogMethod":"button","fullscreenResolutionLower":"360","vibrateOnMobilDevices":"50","clickSoundVolume":"0.5","buttonStyle":"raised","mdwButtonPrimaryColor":"var(--materialdesign-widget-theme-color-button-default-primary)","mdwButtonSecondaryColor":"var(--materialdesign-widget-theme-color-button-default-secondary)","textFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.button.default.text","textFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.button.default.text","imageColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.button_icon","iconPosition":"left","closingClickOutside":"true","backgroundColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.background","headerBackgroundColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.header_background","footerBackgroundColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.footer_background","dividerColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.divider","overlayColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.overlay","showTitle":"true","titleFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.dialog.title","titleFont":"#mdwTheme:vis-materialdesign.0.fonts.dialog.title","titleColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.header_text","buttonPosition":"flex-end","buttonSize":"medium","buttonFont":"#mdwTheme:vis-materialdesign.0.fonts.dialog.button","buttonFontColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_text","pressColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_press","fullscreenCloseIconColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_icon","fullscreenCloseIconPressColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_fullscreen_press","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"contains_view":"view_trash","showDialogOid":"0_userdata.0.Vis.Neuer_Zustand","dialogMaxWidth":"550","viewHeight":"275"},"style":{"left":"917px","top":"598px","width":"100px","height":"30px"},"widgetSet":"materialdesign"}]
    Meine Trash view:
    und hier die Ausagabe aktuell:
    sigi234S 2 Antworten Letzte Antwort
    • B Blechbixn
      Hallo.
      Widget:
      Meine Trash view:
      sigi234S Online
      sigi234S Online
      sigi234
      @blechbixn
      Teste mal eine andere View, da auch?
      Immer Daten sichern!
      GlasfaserG B 2 Antworten Letzte Antwort
      • sigi234S sigi234
        @blechbixn
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        @Blechbixn
        Habe nur meine Testview eingetragen.
        Runtime :
        Wenn es nicht geht dann mache mal ein
        iobroker upload all
        • sigi234S sigi234
          @blechbixn
          Blechbixn
          @sigi234 hi sigi, danke für deine antwort. Auch da ist das der Fall.
          @Glasfaser ich probiers mal und geb rückmeldung!
          Das interessante ist, das es einmal gaaanz kurz ging und dann wieder weiß wurde...
          Danke euch beiden erstmal!
          • GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            @blechbixn sagte in Materialdesign Dialog widget:
            Ja ... den Effekt gibt es machmal ,
            wurde hier sehr oft erwähnt :
            https://forum.iobroker.net/topic/32232/material-design-widgets-wetter-view
            B 1 Antwort Letzte Antwort
            • GlasfaserG Glasfaser
              Blechbixn
              @glasfaser den befehl hab ich ausgeführt, leider funktionierts immer noch nicht.
              Echt komisch, am widget kanns ja nicht liegen.
              GlasfaserG 2 Antworten Letzte Antwort
              • B Blechbixn
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                @blechbixn
                Lege ein Testprojekt an mit zwei Views und teste dort .
                  @blechbixn
                  Blechbixn
                  @glasfaser hab ich gerade probiert. funktioniert auch nicht.
                  GlasfaserG sigi234S 2 Antworten Letzte Antwort
                  • B Blechbixn
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Glasfaser
                    @blechbixn
                    Kann das sein , das du CSS Anweisungen in deinem Projekt hast !?
                    • B Blechbixn
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      Auch in einem anderen Browser mal versucht !?
                      • B Blechbixn
                        sigi234S Online
                        sigi234S Online
                        sigi234
                        @blechbixn
                        Wenn du die view_trash in der Runtime öffnest, geht es da?
                          @blechbixn
                          Blechbixn
                          @glasfaser ich nutze CSS, ja.
                          @sigi234 auch im Edge funktionierts nicht, nutze normal firefox
                          in der Runtime läufts ->
                          B GlasfaserG 2 Antworten Letzte Antwort
                          • B Blechbixn
                            Blechbixn
                            schrieb am zuletzt editiert von Blechbixn
                            Hab jetzt mal die view aufs netwerk geändert.
                            da bekomme ich jetzt auf einmal ein bild im editor:
                            in Firefox / edge ist davon nichts zu sehen, wenn ich wieder umschalte auf view_trash bleibts wieder weiß.
                            --edit; bleibt bei jeder view weiß bis auf netzwerk --
                            • B Blechbixn
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Glasfaser
                              aber erst jetzt ...
                              oben zeigst du ein Screenshot wo es im Runtime nur weiß ist !
                                aber erst jetzt ...
                                Blechbixn
                                @glasfaser sorry, hab mich wohl falsch ausgedrückt.
                                In der Runtime funktioniert die view_trash wie sie soll. nur über das Dialog feld lässt sie sich nicht anzeigen.
                                Nicht das ich hier jetzt für verwirrung stifte.
                                • B Blechbixn
                                  sigi234S Online
                                  sigi234S Online
                                  sigi234
                                  @blechbixn
                                  Denke es hat was mit der Auflösung zu tun. Nimm den Vollbilddialog mal raus und erhöhe die PX im Dialog
                                  Funktioniert bei mir auch.
                                  Edit:
                                  Mit dem Widget Trash geht es bei mir auch nicht.
                                  • sigi234S sigi234
                                    @blechbixn
                                    Edit:
                                    Blechbixn
                                    hab beides verändert mag aber immer noch nicht :/
                                    an den views selber wirds nicht liegen oder?
                                    • B Blechbixn
                                      sigi234S Online
                                      sigi234S Online
                                      sigi234
                                      @blechbixn
                                      Hast du Inventwo Widgets installiert?
                                      • sigi234S sigi234
                                        @blechbixn
                                        Blechbixn
                                        @sigi234 jetzt ja :)
                                        mit dem funktionierts...
                                        • B Blechbixn
                                          Hallo.
                                          Widget:
                                          Meine Trash view:
                                          sigi234S Online
                                          sigi234S Online
                                          sigi234
                                          Daran liegt es
