  4. Materialdesign Dialog widget
21 Beiträge 3 Kommentatoren 1.6k Aufrufe 2 Beobachtet
  • B Blechbixn
    Hallo.
    Habe ein Problem das ich selber nicht gelöst bekomme.
    Habe mir ein Materialdesign Dialog widget gezogen und einer view zugewiesen.
    Öffnet sich leider nur ein weißer Balken, der inhalt der view wird nicht dargestellt.
    was mach ich falsch?
    Widget:
    [{"tpl":"tplVis-materialdesign-Vuetify-Dialog-View","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","showDialogMethod":"button","fullscreenResolutionLower":"360","vibrateOnMobilDevices":"50","clickSoundVolume":"0.5","buttonStyle":"raised","mdwButtonPrimaryColor":"var(--materialdesign-widget-theme-color-button-default-primary)","mdwButtonSecondaryColor":"var(--materialdesign-widget-theme-color-button-default-secondary)","textFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.button.default.text","textFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.button.default.text","imageColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.button_icon","iconPosition":"left","closingClickOutside":"true","backgroundColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.background","headerBackgroundColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.header_background","footerBackgroundColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.footer_background","dividerColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.divider","overlayColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.overlay","showTitle":"true","titleFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.dialog.title","titleFont":"#mdwTheme:vis-materialdesign.0.fonts.dialog.title","titleColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.header_text","buttonPosition":"flex-end","buttonSize":"medium","buttonFont":"#mdwTheme:vis-materialdesign.0.fonts.dialog.button","buttonFontColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_text","pressColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_press","fullscreenCloseIconColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_icon","fullscreenCloseIconPressColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_fullscreen_press","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"contains_view":"view_trash","showDialogOid":"0_userdata.0.Vis.Neuer_Zustand","dialogMaxWidth":"550","viewHeight":"275"},"style":{"left":"917px","top":"598px","width":"100px","height":"30px"},"widgetSet":"materialdesign"}]
    Meine Trash view:
    und hier die Ausagabe aktuell:
    sigi234S Online
    sigi234S Online
    @blechbixn
    Teste mal eine andere View, da auch?
    GlasfaserG B 2 Antworten Letzte Antwort
    • sigi234S sigi234
      @blechbixn
      GlasfaserG Offline
      GlasfaserG Offline
      @Blechbixn
      Habe nur meine Testview eingetragen.
      Runtime :
      Wenn es nicht geht dann mache mal ein
      iobroker upload all
      • sigi234S sigi234
        @blechbixn
        Blechbixn
        @sigi234 hi sigi, danke für deine antwort. Auch da ist das der Fall.
        @Glasfaser ich probiers mal und geb rückmeldung!
        Das interessante ist, das es einmal gaaanz kurz ging und dann wieder weiß wurde...
        Danke euch beiden erstmal!
        • GlasfaserG Offline
          GlasfaserG Offline
          @blechbixn sagte in Materialdesign Dialog widget:
          Ja ... den Effekt gibt es machmal ,
          wurde hier sehr oft erwähnt :
          https://forum.iobroker.net/topic/32232/material-design-widgets-wetter-view
          • GlasfaserG Glasfaser
            Blechbixn
            @glasfaser den befehl hab ich ausgeführt, leider funktionierts immer noch nicht.
            Echt komisch, am widget kanns ja nicht liegen.
            • B Blechbixn
              GlasfaserG Offline
              GlasfaserG Offline
              @blechbixn
              Lege ein Testprojekt an mit zwei Views und teste dort .
                @blechbixn
                Blechbixn
                @glasfaser hab ich gerade probiert. funktioniert auch nicht.
                GlasfaserG sigi234S 2 Antworten Letzte Antwort
                • B Blechbixn
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @blechbixn
                  Kann das sein , das du CSS Anweisungen in deinem Projekt hast !?
                  • B Blechbixn
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Auch in einem anderen Browser mal versucht !?
                    • B Blechbixn
                      sigi234S Online
                      sigi234S Online
                      @blechbixn
                      Wenn du die view_trash in der Runtime öffnest, geht es da?
                        @blechbixn
                        Blechbixn
                        @glasfaser ich nutze CSS, ja.
                        @sigi234 auch im Edge funktionierts nicht, nutze normal firefox
                        in der Runtime läufts ->
                        B GlasfaserG 2 Antworten Letzte Antwort
                        • B Blechbixn
                          Blechbixn
                          schrieb am zuletzt editiert von Blechbixn
                          Hab jetzt mal die view aufs netwerk geändert.
                          da bekomme ich jetzt auf einmal ein bild im editor:
                          in Firefox / edge ist davon nichts zu sehen, wenn ich wieder umschalte auf view_trash bleibts wieder weiß.
                          --edit; bleibt bei jeder view weiß bis auf netzwerk --
                          • B Blechbixn
                            GlasfaserG Offline
                            GlasfaserG Offline
                            aber erst jetzt ...
                            oben zeigst du ein Screenshot wo es im Runtime nur weiß ist !
                              aber erst jetzt ...
                              Blechbixn
                              @glasfaser sorry, hab mich wohl falsch ausgedrückt.
                              In der Runtime funktioniert die view_trash wie sie soll. nur über das Dialog feld lässt sie sich nicht anzeigen.
                              Nicht das ich hier jetzt für verwirrung stifte.
                              • B Blechbixn
                                sigi234S Online
                                sigi234S Online
                                @blechbixn
                                Denke es hat was mit der Auflösung zu tun. Nimm den Vollbilddialog mal raus und erhöhe die PX im Dialog
                                Funktioniert bei mir auch.
                                Edit:
                                Mit dem Widget Trash geht es bei mir auch nicht.
                                • sigi234S sigi234
                                  @blechbixn
                                  Edit:
                                  Blechbixn
                                  hab beides verändert mag aber immer noch nicht :/
                                  an den views selber wirds nicht liegen oder?
                                  • B Blechbixn
                                    sigi234S Online
                                    sigi234S Online
                                    @blechbixn
                                    Hast du Inventwo Widgets installiert?
                                    • sigi234S sigi234
                                      @blechbixn
                                      Blechbixn
                                      @sigi234 jetzt ja :)
                                      mit dem funktionierts...
                                      • B Blechbixn
                                        Hallo.
                                        Widget:
                                        Meine Trash view:
                                        sigi234S Online
                                        sigi234S Online
                                        Daran liegt es
                                        • sigi234S sigi234
                                          Daran liegt es
                                          Blechbixn
                                          @sigi234 Wie meinst?
                                          Durch das standart jqui Dialog widget läufts jetzt. Passt mir nur vom design her garnicht, da würde ich den dialog von materialdesign schon besser finden.
