  4. Visualisierung mit Node Red erstellen
4.8k Beiträge 4 Kommentatoren 2.9m Aufrufe 4 Beobachtet
  • mickymM mickym
    @damrak2022 Na keine Eile.
    Damrak2022D Offline
    Damrak2022D Offline
    Damrak2022
    #4661
    @mickym Ist gelöscht
    Mit besten Grüßen
    Andy
    • Damrak2022D Damrak2022
      mickymM Offline
      mickymM Offline
      mickym
      #4662
      @damrak2022 So dann probier halt mal mit einer get-Node den Datenpunkt auszulesen:
              "id": "be4f312afb9e4c3b",
              "type": "ui_template",
              "z": "289f539dcc33814e",
              "group": "5b02a0802660a23d",
              "name": "",
              "order": 0,
              "width": "12",
              "height": "12",
              "format": "<img src={{msg.payload}}>",
              "storeOutMessages": true,
              "fwdInMessages": true,
              "resendOnRefresh": true,
              "templateScope": "local",
              "className": "",
              "x": 780,
              "y": 4860,
              "wires": [
              "id": "d7a7cba9a481811d",
              "type": "ioBroker get",
              "name": "",
              "topic": "0_userdata.0.Test.Bild",
              "attrname": "payload",
              "payloadType": "value",
              "errOnInvalidState": "nothing",
              "x": 560,
              "y": 4860,
              "wires": [
                      "be4f312afb9e4c3b"
              "id": "84bdc0f2f51c9803",
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "true",
              "payloadType": "bool",
              "x": 370,
              "y": 4860,
              "wires": [
                      "d7a7cba9a481811d"
              "id": "5b02a0802660a23d",
              "type": "ui_group",
              "name": "Bild",
              "tab": "2ce144dc.d7472c",
              "order": 2,
              "disp": true,
              "width": "12",
              "collapse": false,
              "className": ""
              "id": "2ce144dc.d7472c",
              "type": "ui_tab",
              "name": "test",
              "icon": "dashboard",
              "order": 23,
              "disabled": false,
              "hidden": false
      • mickymM mickym
                "name": "",
                "order": 0,
                "width": "12",
                "height": "12",
                "className": "",
                "x": 780,
                "y": 4860,
                "wires": [
                "name": "",
                "x": 560,
                "y": 4860,
                "wires": [
                        "be4f312afb9e4c3b"
                "type": "inject",
                "name": "",
                "props": [
                        "p": "payload"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "true",
                "x": 370,
                "y": 4860,
                "wires": [
                        "d7a7cba9a481811d"
                "type": "ui_group",
                "name": "Bild",
                "order": 2,
                "disp": true,
                "width": "12",
                "collapse": false,
                "className": ""
                "type": "ui_tab",
                "name": "test",
                "order": 23,
                "disabled": false,
                "hidden": false
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        schrieb am zuletzt editiert von Damrak2022
        #4663
        @mickym Da hängt es auch. Wenn ich von einem anderen Tab zurück will zum Staubsauger. Dann tauch auch einmal kurz der Ladekreis in (orange) auf, dann kann ich einmal was machen, dann wieder warten. Ich versteh es halt nicht, weil man es ja auch in der Vis einbinden kann. Da kann ja kein besonderer Unterschied sein.
        Bildschirm­foto 2023-03-27 um 19.31.39.png Bildschirm­foto 2023-03-27 um 19.31.31.png
        Und so sieht das aus, wenn ich im Browser zurück auf iobroker wechseln will:
        Mit besten Grüßen
        Andy
          mickymM Offline
          mickymM Offline
          mickym
          #4664
          @damrak2022 Nur mal zum Test kopiere mal den Inhalt des Datenpunktes nun in einen selbstestellten Datenpunkt unter 0_userdata und schau ob Du damit Probleme hast. datentyp ist string.
          Damrak2022D 2 Antworten Letzte Antwort
          • mickymM mickym
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            #4665
            @mickym Moment
            Mit besten Grüßen
            Andy
            • mickymM mickym
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              #4666
              @mickym Wie kopiere ich da was rein?
              Mit besten Grüßen
              Andy
                @mickym Moment
                mickymM Offline
                mickymM Offline
                mickym
                #4667
                @damrak2022 Kopieren bitte über die Schaltfläche und nicht mit der Maus ziehen:
                und dann in einen Datenpunkt mit typ String kopieren:
                • mickymM mickym
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  #4668
                  @mickym Okay, habe ich direkt nach dem einsetzen hat sich der Ladekreis für 2 Sekunden gezeigt, ist jetzt aber drin
                  Mit besten Grüßen
                  Andy
                  • mickymM mickym
                    Damrak2022D Offline
                    Damrak2022D Offline
                    Damrak2022
                    #4669
                    @mickym Jetzt dauert es wieder einen Moment bis ich den Datenpunkt in der Get Node anpassen kann.
                    Mit besten Grüßen
                    Andy
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #4670
                      @damrak2022 So dann schau mal wenn Du die get Node nun auf den Userdaten punkt setzt ob es geht.
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #4671
                        @damrak2022 sagte in Visualisierung mit Node Red erstellen:
                        Wir haben viel Zeit.
                        • mickymM mickym
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          #4672
                          @mickym Musste neu importieren, denn öffnen lässt sich eine Node bei mir nicht mehr, wenn sie mit dem orginal Datenpunkt bestückt ist.
                          Momentan schaut es so aus:
                          Bildschirm­foto 2023-03-27 um 19.49.29.png Bildschirm­foto 2023-03-27 um 19.49.23.png
                          Oh warte mal, der hat die Daten in eigenen Datenpunkt garnicht übernommen - also nochmal
                          Mit besten Grüßen
                          Andy
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #4673
                            @damrak2022 Du musst dann auf die Schaltfläche Wert setzen klicken
                            Ob das Bild drin ist siehst doch ob der Anfang des Strings drin ist:
                            • mickymM mickym
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              #4674
                              @mickym Das habe ich mittlerweile 3 mal gemacht, nur erfolglos
                              Mit besten Grüßen
                              Andy
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #4675
                                @damrak2022 Du musst Geduld haben. Ansonsten mach mal folgendes - geh auf Kopieren und kopier halt die Daten in einen Editor und dann kopierst Du von dort in den Datenpunkt.
                                • mickymM mickym
                                  Damrak2022D Offline
                                  Damrak2022D Offline
                                  Damrak2022
                                  #4676
                                  @mickym Auch der Umweg über den Editor geht nicht. Sobald ich auf das Feld klicke kann ich das einsetzen und wenn ich dann Wett schreiben anklicke und danach nachschaue wieder das gleiche. Es ist nichts drin.
                                  Mit besten Grüßen
                                  Andy
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    #4677
                                    @damrak2022 Na vielleicht ist es nur ein Anzeigeproblem - ansonsten ist Dein mac vielleicht überfordert. Mach mal den Browser komplett zu udn wieder auf.
                                    • mickymM mickym
                                      Damrak2022D Offline
                                      Damrak2022D Offline
                                      Damrak2022
                                      #4678
                                      @mickym Jetzt ist da glaube ich ein anderes Fenster:
                                      Soll ich da was bestimmtes reinschreiben?
                                      Mit besten Grüßen
                                      Andy
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #4679
                                        @damrak2022 Na da kommt der Riesenstring rein den Du aus Dem Staubsaugerdatenpunkt kopierst.
                                        • mickymM mickym
                                          Damrak2022D Offline
                                          Damrak2022D Offline
                                          Damrak2022
                                          #4680
                                          @mickym Ich denke der kommt hier rein?
                                          Mit besten Grüßen
                                          Andy
