  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Smartmeter ISKRA MT175 HICHI IR Lesekopf
    5.2k
58 Beiträge 6 Kommentatoren 8.9k Aufrufe 4 Beobachtet
  • J JOBI59
    @homoran sagte in Smartmeter ISKRA MT175 HICHI IR Lesekopf:
    @jobi59 sagte in Smartmeter ISKRA MT175 HICHI IR Lesekopf:
    Und das Protokoll:
    bitte als text in code-tags!
    da steht was rotes
    2022-08-15 12:10:14.187 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 started with pid 872
    2022-08-15 12:10:21.895 - info: smartmeter.0 (872) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
    2022-08-15 12:10:21.992 - error: smartmeter.0 (872) Serial port device is undefined, check your configuration!
    2022-08-15 12:10:22.752 - info: smartmeter.0 (872) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
    2022-08-15 12:10:27.782 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 (force=false, process=true)
    2022-08-15 12:10:27.802 - info: smartmeter.0 (872) Got terminate signal TERMINATE_YOURSELF
    2022-08-15 12:10:27.811 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 send kill signal
    2022-08-15 12:10:27.808 - info: smartmeter.0 (872) terminating
    2022-08-15 12:10:27.815 - info: smartmeter.0 (872) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-08-15 12:10:28.461 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-08-15 12:10:30.876 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 started with pid 893
    2022-08-15 12:10:37.962 - info: smartmeter.0 (893) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
    2022-08-15 12:10:39.024 - info: smartmeter.0 (893) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
    2022-08-15 12:12:38.174 - info: smartmeter.0 (893) Error: No or too long answer from Serial Device after last request.
    2022-08-15 12:12:38.180 - warn: smartmeter.0 (893) No or too long answer from Serial Device after last request.
    2022-08-15 12:14:15.885 - info: smartmeter.0 (893) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
    2022-08-15 12:17:32.014 - info: smartmeter.0 (893) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
    2022-08-15 12:19:38.202 - info: smartmeter.0 (893) Error: No or too long answer from Serial Device after last request.
    2022-08-15 12:19:38.204 - warn: smartmeter.0 (893) No or too long answer from Serial Device after last request.```
    Ich hoffe, ich habe die richtige Passage.
    oder probiere den mal
      nimm mal userdefined und trag manuell ein
      JOBI59
      Habe ich gemacht, leider immer noch die gleiche Meldung.
      Das ist beim Protokoll dazugekommen.
      2022-08-15 12:24:03.175 - info: smartmeter.0 (893) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
      2022-08-15 12:24:39.369 - info: smartmeter.0 (893) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
      2022-08-15 12:25:01.641 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 (force=false, process=true)
      2022-08-15 12:25:01.658 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 send kill signal
      2022-08-15 12:25:01.658 - info: smartmeter.0 (893) Got terminate signal TERMINATE_YOURSELF
      2022-08-15 12:25:01.667 - info: smartmeter.0 (893) terminating
      2022-08-15 12:25:01.672 - info: smartmeter.0 (893) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-08-15 12:25:02.278 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-08-15 12:25:04.723 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 started with pid 1034
      2022-08-15 12:25:11.607 - info: smartmeter.0 (1034) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
      2022-08-15 12:27:11.777 - info: smartmeter.0 (1034) Error: No or too long answer from Serial Device after last request.
      2022-08-15 12:27:11.784 - warn: smartmeter.0 (1034) No or too long answer from Serial Device after last request.
      • J JOBI59
        Habe ich gemacht
        Was von beiden?
        immer zeigen!
        immerhin sehe ich kein undefined mehr. Außer du hast es oben abgeschnittrn
        J 1 Antwort Letzte Antwort
          Habe ich gemacht
          Was von beiden?
          immer zeigen!
          JOBI59
          Habe ich gemacht
          Was von beiden?
          immer zeigen!
          Ich habe nun beides ausprobiert.
          Einmal mit /dev/ttyS0
          und einmal mit /dev/ttyAMA0
          Bei beiden die gleichen Meldungen.
          Hier das Protokoll. Einmal /dev/ttyS0 und dann /dev/ttyAMA0
          2022-08-15 12:31:03.474 - info: smartmeter.0 (1034) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
          2022-08-15 12:31:20.343 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 (force=false, process=true)
          2022-08-15 12:31:20.359 - info: smartmeter.0 (1034) Got terminate signal TERMINATE_YOURSELF
          2022-08-15 12:31:20.364 - info: smartmeter.0 (1034) terminating
          2022-08-15 12:31:20.370 - info: smartmeter.0 (1034) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2022-08-15 12:31:20.375 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 send kill signal
          2022-08-15 12:31:20.977 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2022-08-15 12:31:23.440 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 started with pid 1054
          2022-08-15 12:31:30.378 - info: smartmeter.0 (1054) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
          2022-08-15 12:31:38.541 - info: smartmeter.0 (1054) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
          2022-08-15 12:31:50.445 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 (force=false, process=true)
          2022-08-15 12:31:50.458 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 send kill signal
          2022-08-15 12:31:50.460 - info: smartmeter.0 (1054) Got terminate signal TERMINATE_YOURSELF
          2022-08-15 12:31:50.742 - info: smartmeter.0 (1054) terminating
          2022-08-15 12:31:50.749 - info: smartmeter.0 (1054) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2022-08-15 12:31:51.359 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2022-08-15 12:31:53.514 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 started with pid 1070
          2022-08-15 12:32:00.480 - info: smartmeter.0 (1070) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
          2022-08-15 12:34:00.652 - info: smartmeter.0 (1070) Error: No or too long answer from Serial Device after last request.
          2022-08-15 12:34:00.659 - warn: smartmeter.0 (1070) No or too long answer from Serial Device after last request.
          HomoranH Ralla66R 2 Antworten Letzte Antwort
          • J JOBI59
            Habe ich gemacht
            Was von beiden?
            immer zeigen!
            immer zeigen!
            BITTE!
            stell mal die Smartmeter Instanz auf debug
            • J JOBI59
              Habe ich gemacht
              Was von beiden?
              immer zeigen!
              Ralla66R Offline
              Ralla66R Offline
              Ralla66
              @jobi59
              Baudrate ?
              • Ralla66R Ralla66
                @jobi59
                Baudrate ?
                @ralla66 sagte in Smartmeter ISKRA MT175 HICHI IR Lesekopf:
                Baudrate ?
                sollte der Adapter mit dem Zähler aushandeln
                  immer zeigen!
                  BITTE!
                  JOBI59
                  immer zeigen!
                  BITTE!
                  OK, nehme ich mir zu Herzen.
                  Als nun Instanz auf folgendes eingestellt:
                  Instanz auf debug gestellt:
                  Jetzt laufen im Protokolle jede Mengen Daten auf und ich kann das LOG nich downlowden.
                  Deshalb hier mal direkt aus dem Protokoll.
                  smartmeter.0
                  	2022-08-15 12:49:58.376	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  smartmeter.0
                  	2022-08-15 12:49:58.375	debug	Plugin sentry destroyed
                  smartmeter.0
                  	2022-08-15 12:49:58.371	info	terminating
                  smartmeter.0
                  	2022-08-15 12:49:58.369	debug	SERIALPORT CLOSE
                  smartmeter.0
                  	2022-08-15 12:49:58.358	info	Got terminate signal TERMINATE_YOURSELF
                  smartmeter.0
                  	2022-08-15 12:49:58.140	debug	MATCH-RESULT MESSAGE: "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" -> null
                  smartmeter.0
                  	2022-08-15 12:49:58.138	debug	ADD NEW DATA (6510 + NEW 1)
                  Und das wiederholt sich ständig. Habe das Protokoll mit Paussieren angehalten um die anzeige zu bekommen.
                  Ich hoffe ich habe das richtig gemacht.
                  • J JOBI59
                    immer zeigen!
                    BITTE!
                    smartmeter.0
                    smartmeter.0
                    smartmeter.0
                    smartmeter.0
                    smartmeter.0
                    smartmeter.0
                    smartmeter.0
                    @jobi59 jetzt komme ich an meine Grenzen.
                    habe eben noch das hier gefunden
                    https://wiki.volkszaehler.org/hardware/channels/meters/power/edl-ehz/iskraemeco_mt175
                    und bin etwas irritiert.
                    Ist das doch BIDI, also nicht "nur gelesen"?
                    J Ralla66R 2 Antworten Letzte Antwort
                      JOBI59
                      Es gibt von volkszähler ein Image für einen Raspberry Pi Zero W.
                      Das habe ich zum Test mal auf eine SD-Karte geschrieben und mit einem Pi Zero
                      getestet. Hier kommt im vzlogger die Daten an. Aber nur für eine kurze Zeit,
                      dann wird nichts mehr geloggt.
                      Darum bin ich auch zu iobroker und dem smartmeter Adapter gewechselt.
                      Sollte die ganzen Probleme, die ich bis jetzt habe, für mich bedeuten,
                      das ich mit meinem aktuellen Lesekopf keine daten nach iobroker bekomme.
                      So müsste ich überlegen, ob es was bringt einen HICHI Lesekopf mit WLAN zu erwerben.
                      Ich bin mittlerweile schon fast 3 Tag am Einstellen und auch am Verzweifeln.
                        Ralla66R Offline
                        Ralla66R Offline
                        Ralla66
                        mein MT175 gibt alle 5 sec über die IR die Daten preis ohne Anfrage der Daten.
                        J HomoranH 2 Antworten Letzte Antwort
                        • Ralla66R Ralla66
                          JOBI59
                          mein MT175 gibt alle 5 sec über die IR die Daten preis.
                          Hallo ralla66,
                          und wie liest du die Daten?
                          • J JOBI59
                            das ist natürlich jetzt eine wichtige Zusatzinformation!
                            wenn der Kopf einen Schuss hat können wir lange spielen.
                            Bestenfalls sitzt er nur nicht richtig und bekommt Streulicht ab.
                            Mit der Aussage dass du mit minicom alles bekommst bin ich natürlich von einem funktionierenden System ausgegangen.
                            Natürlich kann auch die Schnittstelle im Zähler einen Schlag weg haben. Dann nutzt auch ein neuer Kopf nichts.
                            Grundsätzlich würde ich sagen, dass wenn minicom läuft, auch der Adapter laufen müsste (natürlich nicht parallel!)
                            • Ralla66R Ralla66
                              Danke!
                              wie sind deine Einstellungen?
                              Ralla66R J 2 Antworten Letzte Antwort
                                Danke!
                                Ralla66R Offline
                                Ralla66R Offline
                                Ralla66
                                selbst Geschnitzt mit Tasmota Script
                                  Danke!
                                  JOBI59
                                  Danke!
                                  Also ich versuche über iobroker mit smartmeter Adapter mit folgenden Einstellungen:
                                  Lesekopf und iobroker sind auf demselben Raspberry Pi.
                                  • J JOBI59
                                    Danke!
                                    Danke!
                                    das ist auch in Ordnung, da Kommt ja auch was
                                    VIELLEICHT WEISS @APOLLON77 weiter
                                      Danke!
                                      apollon77A Online
                                      apollon77A Online
                                      @homoran Es sind mal mindestens keine SML Daten ... Also Baudrate und ggf. Serielle settings prüfen
                                        @apollon77 ist alles noch default
                                        @JOBI59 dann trag mal vorsichtig 300 baud ein und die anderen Parameter
                                          Ralla66R Offline
                                          Ralla66R Offline
                                          Ralla66
                                          9600 8n1 wie in deinem Link ?
                                          HomoranH J 2 Antworten Letzte Antwort
