  3. Einsteigerfragen
  4. Problem mit Adapter updates
    5.6k
22 Beiträge 7 Kommentatoren 2.9k Aufrufe 5 Beobachtet
  • Marcus HamburgM Marcus Hamburg
    pi@raspberrypi:~ $ iobroker upgrade javascript --debug
    This upgrade of "javascript" will at least introduce the following changes:
    -> 5.7.0:
    Allow sending of messages to scripts also from adapters and CLI by sending "toScript" message (see [onMessage Documentation](https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#onmessage))
    Lists returned by $-selector are now unified and do not contain double entries
    Fix subscribe multiple object ID lists in blockly
    -> 5.6.1:
    Allow to subscribe multiple object ID lists in blockly
    -> 5.6.0:
    Make state properties c(omment) and user available to scripts too
    make sure values of new or changed alias objects are initialized properly
    Enhance scheduler logic and astro events offered by wizard
    Respect expected value changes when determining if a value is changed
    Fix remembering intermediate state values when state values are subscribed
    fix setState logic when states are not subscribed
    -> 5.5.4:
    Tried to solve problem with the font
    -> 5.5.3:
    Fixed getObjectAsync function if object does not exist
    -> 5.5.2:
    Added new rules action block: sum two states (or minus)
    -> 5.5.1:
    Would you like to upgrade javascript from @5.2.13 to @5.7.0 now? [(y)es, (n)o]: y
    Update javascript from @5.2.13 to @5.7.0
    NPM version: 8.11.0
    Installing iobroker.javascript@5.7.0... (System call)
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
    npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
    npm ERR!     /home/iobroker/.npm/_logs/2022-08-10T18_29_21_627Z-debug-0.log
    host.raspberrypi Cannot install iobroker.javascript@5.7.0: 217
    pi@raspberrypi:~ $
    GlasfaserG Offline
    GlasfaserG Offline
    Glasfaser
    @marcus-hamburg sagte in Problem mit Adapter updates:
    Du kannst das hier nutzen
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2
    cd /opt/iobroker/node_modules
    for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
    Zitat aus dem Thread :
    WICHTIG .
    (Bitte Befehl KOPIEREN, nicht eintippen, ein Vertipper kann und wird da 'tödlich' sein).
      -> 5.7.0:
      -> 5.6.1:
      -> 5.6.0:
      -> 5.5.4:
      -> 5.5.3:
      -> 5.5.2:
      -> 5.5.1:
      NPM version: 8.11.0
      npm ERR! errno -39
      pi@raspberrypi:~ $
      oha, dazu gibt es einige Threads
      lösung hier suchen
      https://forum.iobroker.net/post/460759
