  4. BWM liefert Fehlermeldung mit dem Zigbee Adapter 1.7.5
    5.8k
25 Beiträge 2 Kommentatoren 1.9k Aufrufe 1 Beobachtet
  • W Offline
    W Offline
    Wolhem
    Re: BWM liefert Fehlermeldung mit dem Zigbee Adapter
    sobald Blockly aktiv ist kommen die Fehlermeldungen.
    W paul53P 2 Antworten Letzte Antwort
    • W Wolhem
      W Offline
      W Offline
      Wolhem
      @wolhem
      zigbee.0
      2022-07-24 02:35:16.082 error No converter available for 'RTCGQ11LM' with key 'occupancy'
      javascript.0
      2022-07-24 02:35:16.056 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
      zigbee.0
      2022-07-24 02:35:06.063 error No converter available for 'RTCGQ11LM' with key 'occupancy'
      javascript.0
      2022-07-24 02:35:06.051 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
      zigbee.0
      2022-07-24 02:34:56.083 error No converter available for 'RTCGQ11LM' with key 'occupancy'
      javascript.0
      2022-07-24 02:34:56.055 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
      zigbee.0
      2022-07-24 02:34:46.080 error No converter available for 'RTCGQ11LM' with key 'occupancy'
      javascript.0
      2022-07-24 02:34:46.055 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
      zigbee.0
      2022-07-24 02:34:36.079 error No converter available for 'RTCGQ11LM' with key 'occupancy'
      javascript.0
      2022-07-24 02:34:36.055 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
      zigbee.0
      2022-07-24 02:34:26.080 error No converter available for 'RTCGQ11LM' with key 'occupancy'
      javascript.0
      2022-07-24 02:34:26.055 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
      zigbee.0
      2022-07-24 02:34:16.080 error No converter available for 'RTCGQ11LM' with key 'occupancy'
      javascript.0
      2022-07-24 02:34:16.056 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
      zigbee.0
      2022-07-24 02:34:06.065 error No converter available for 'RTCGQ11LM' with key 'occupancy'
      javascript.0
      2022-07-24 02:34:06.050 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
      zigbee.0
      2022-07-24 02:33:56.072 error No converter available for 'RTCGQ11LM' with key 'occupancy'
      javascript.0
      2022-07-24 02:33:56.060 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
      zigbee.0
      2022-07-24 02:33:46.081 error No converter available for 'RTCGQ11LM' with key 'occupancy'
      javascript.0
      2022-07-24 02:33:46.057 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
      W 1 Antwort Letzte Antwort
      • W Wolhem
        @wolhem
        zigbee.0
        javascript.0
        zigbee.0
        javascript.0
        zigbee.0
        javascript.0
        zigbee.0
        javascript.0
        zigbee.0
        javascript.0
        zigbee.0
        javascript.0
        zigbee.0
        javascript.0
        zigbee.0
        javascript.0
        zigbee.0
        javascript.0
        zigbee.0
        javascript.0
        W Offline
        W Offline
        Wolhem
        @wolhem
        • W Wolhem
          @wolhem sagte: sobald Blockly aktiv ist kommen die Fehlermeldungen.
          Kein Wunder:
            Kein Wunder:
            W Offline
            W Offline
            Wolhem
            Sorry, ist für mich noch Neuland.
            Was muss ich ändern?
            • W Wolhem
              @wolhem sagte: Was muss ich ändern?
              Weshalb schreibst Du falsch in den Datenpunkt "Occupancy", der vom Gerät gesetzt wird?
              Die Warnungen sind weg, wenn die beiden Blöcke "steuere Occupancy" gelöscht werden.
              W 2 Antworten Letzte Antwort
                W Offline
                W Offline
                Wolhem
                Danke für die schnelle Antwort.
                Werde Morgen berichten.
                  W Offline
                  W Offline
                  Wolhem
                  hab mal an der Uhr gedreht...
                  • W Wolhem
                    @wolhem sagte: hab mal an der Uhr gedreht...
                    Gleiches Problem mit dem Datenpunkt "Time from last motion". Der Wert wird vom Adapter geliefert und ist "read only".
                      W Offline
                      W Offline
                      Wolhem
                      aber trotz Fehlermeldungen funktionierte es zu 90%
                      Wenn ich die Blöcke lösche geht nichts mehr 😢
                      • W Wolhem
                        @wolhem sagte: geht nichts mehr
                        Was möchtest Du erreichen, außer dass nachts der BWM das Licht einschaltet?
                          W Offline
                          W Offline
                          Wolhem
                          Bei Bewegung für 90 Sekunden Licht einschalten.
                          • W Wolhem
                            @wolhem sagte: Bei Bewegung für 90 Sekunden Licht einschalten.
                            Immer nur für 90 s oder 90 s nachdem keine Bewegung mehr erkannt wurde?
                              W Offline
                              W Offline
                              Wolhem
                              Immer nur 90 Sek
                                W Offline
                                W Offline
                                Wolhem
                                zwischen Sonnenuntergang und Sonnenaufgang
                                • W Wolhem
                                  Immer nur 90 Sek
                                  @wolhem sagte: Immer nur 90 Sek
                                  Dafür nimmt man Timer:
                                    W Offline
                                    W Offline
                                    Wolhem
                                    warum -ist größer als letztes?
                                    • W Wolhem
                                      @wolhem sagte: warum -ist größer als letztes?
                                      Triggert nur bei "Bewegung erkannt" (Änderung false --> true).
                                      W 4 Antworten Letzte Antwort
                                        W Offline
                                        W Offline
                                        Wolhem
                                          W Offline
                                          W Offline
                                          Wolhem
