  4. BWM liefert Fehlermeldung mit dem Zigbee Adapter 1.7.5
    5.8k
25 Beiträge 2 Kommentatoren 1.9k Aufrufe 1 Beobachtet
  • W Wolhem
    @wolhem
    zigbee.0
    2022-07-24 02:35:16.082 error No converter available for 'RTCGQ11LM' with key 'occupancy'
    javascript.0
    2022-07-24 02:35:16.056 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
    zigbee.0
    2022-07-24 02:35:06.063 error No converter available for 'RTCGQ11LM' with key 'occupancy'
    javascript.0
    2022-07-24 02:35:06.051 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
    zigbee.0
    2022-07-24 02:34:56.083 error No converter available for 'RTCGQ11LM' with key 'occupancy'
    javascript.0
    2022-07-24 02:34:56.055 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
    zigbee.0
    2022-07-24 02:34:46.080 error No converter available for 'RTCGQ11LM' with key 'occupancy'
    javascript.0
    2022-07-24 02:34:46.055 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
    zigbee.0
    2022-07-24 02:34:36.079 error No converter available for 'RTCGQ11LM' with key 'occupancy'
    javascript.0
    2022-07-24 02:34:36.055 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
    zigbee.0
    2022-07-24 02:34:26.080 error No converter available for 'RTCGQ11LM' with key 'occupancy'
    javascript.0
    2022-07-24 02:34:26.055 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
    zigbee.0
    2022-07-24 02:34:16.080 error No converter available for 'RTCGQ11LM' with key 'occupancy'
    javascript.0
    2022-07-24 02:34:16.056 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
    zigbee.0
    2022-07-24 02:34:06.065 error No converter available for 'RTCGQ11LM' with key 'occupancy'
    javascript.0
    2022-07-24 02:34:06.050 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
    zigbee.0
    2022-07-24 02:33:56.072 error No converter available for 'RTCGQ11LM' with key 'occupancy'
    javascript.0
    2022-07-24 02:33:56.060 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
    zigbee.0
    2022-07-24 02:33:46.081 error No converter available for 'RTCGQ11LM' with key 'occupancy'
    javascript.0
    2022-07-24 02:33:46.057 warn Read-only state "zigbee.0.00158d00075a71aa.occupancy" has been written without ack-flag with value "false"
    W Offline
    W Offline
    Wolhem
    @wolhem
    • W Wolhem
      Re: BWM liefert Fehlermeldung mit dem Zigbee Adapter
      sobald Blockly aktiv ist kommen die Fehlermeldungen.
      @wolhem sagte: sobald Blockly aktiv ist kommen die Fehlermeldungen.
      Kein Wunder:
      W 1 Antwort Letzte Antwort
        Kein Wunder:
        W Offline
        W Offline
        Wolhem
        Sorry, ist für mich noch Neuland.
        Was muss ich ändern?
        • W Wolhem
          @wolhem sagte: Was muss ich ändern?
          Weshalb schreibst Du falsch in den Datenpunkt "Occupancy", der vom Gerät gesetzt wird?
          Die Warnungen sind weg, wenn die beiden Blöcke "steuere Occupancy" gelöscht werden.
          W 2 Antworten Letzte Antwort
            W Offline
            W Offline
            Wolhem
            Danke für die schnelle Antwort.
            Werde Morgen berichten.
              W Offline
              W Offline
              Wolhem
              hab mal an der Uhr gedreht...
              • W Wolhem
                @wolhem sagte: hab mal an der Uhr gedreht...
                Gleiches Problem mit dem Datenpunkt "Time from last motion". Der Wert wird vom Adapter geliefert und ist "read only".
                  W Offline
                  W Offline
                  Wolhem
                  aber trotz Fehlermeldungen funktionierte es zu 90%
                  Wenn ich die Blöcke lösche geht nichts mehr 😢
                  • W Wolhem
                    @wolhem sagte: geht nichts mehr
                    Was möchtest Du erreichen, außer dass nachts der BWM das Licht einschaltet?
                      W Offline
                      W Offline
                      Wolhem
                      Bei Bewegung für 90 Sekunden Licht einschalten.
                      • W Wolhem
                        @wolhem sagte: Bei Bewegung für 90 Sekunden Licht einschalten.
                        Immer nur für 90 s oder 90 s nachdem keine Bewegung mehr erkannt wurde?
                          W Offline
                          W Offline
                          Wolhem
                          Immer nur 90 Sek
                            W Offline
                            W Offline
                            Wolhem
                            zwischen Sonnenuntergang und Sonnenaufgang
                            • W Wolhem
                              Immer nur 90 Sek
                              @wolhem sagte: Immer nur 90 Sek
                              Dafür nimmt man Timer:
                                W Offline
                                W Offline
                                Wolhem
                                warum -ist größer als letztes?
                                • W Wolhem
                                  @wolhem sagte: warum -ist größer als letztes?
                                  Triggert nur bei "Bewegung erkannt" (Änderung false --> true).
                                  W 4 Antworten Letzte Antwort
                                    W Offline
                                    W Offline
                                    Wolhem
                                      W Offline
                                      W Offline
                                      Wolhem
                                        W Offline
                                        W Offline
                                        Wolhem
                                        So scheint es jetzt zu funktionieren! 👍
                                          W Offline
                                          W Offline
                                          Wolhem
                                          mit größer als letztes kamen noch die Fehlermeldungen.
