  4. iob startet nach nodejs-Update nicht mehr
    5.8k
35 Beiträge 4 Kommentatoren 3.2k Aufrufe 3 Beobachtet
    @caskstrengther
    systemctl status iobroker
    CaskstrengtherC Offline
    Caskstrengther
    pi@raspberrypi:/opt/iobroker/iobroker-data $ systemctl status iobroker
    ● iobroker.service - ioBroker Server
       Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
       Active: active (running) since Sat 2022-07-16 14:11:00 CEST; 22s ago
         Docs: http://iobroker.net
     Main PID: 16965 (iobroker.js-con)
        Tasks: 11 (limit: 4915)
       CGroup: /system.slice/iobroker.service
               └─16965 iobroker.js-controller
    Jul 16 14:11:00 raspberrypi systemd[1]: Started ioBroker Server.
    CaskstrengtherC Thomas BraunT 2 Antworten Letzte Antwort
    • CaskstrengtherC Caskstrengther
      Caskstrengther
      @caskstrengther
      Ich habe mir mal die Dateien im iobroker-Verzeichnis angesehen.
      Ist es normal, das "objects.jsonl" sooooo groß ist?
      pi@raspberrypi:/opt/iobroker/iobroker-data $ ls -lisa
      insgesamt 1112584
      395214       4 drwxrwxr-x+  7 iobroker iobroker       4096 Jul 16 14:12 .
      130047       4 drwxrwxr-x+  6 iobroker iobroker       4096 Jul 15 16:52 ..
      390150       4 drwxrwxr-x+  2 iobroker iobroker       4096 Jul 15 02:45 backitup
      395217      12 drwxrwxr-x+  2 iobroker iobroker      12288 Jul 15 14:11 backup-objects
      395265       4 drwxrwxr-x+ 16 iobroker iobroker       4096 Feb 23 11:41 files
      395215       8 -rw-rwxr--+  1 iobroker iobroker       4718 Mai 10 20:18 iobroker.json
      395366       4 -rw-rwxr--+  1 iobroker iobroker          3 Jul 15 14:21 notifications.json
      391718    5432 -rw-rwxr--+  1 iobroker iobroker    5558617 Feb  7 13:11 objects.json.bak.migrated
      391766 1097960 -rw-rwxr--+  1 iobroker iobroker 1124304666 Jul 15 16:39 objects.jsonl
      525495       4 drwxrwxr-x+  2 iobroker iobroker       4096 Jul 16 14:13 objects.jsonl.lock
      389882    5432 -rw-rwxr--+  1 iobroker iobroker    5558617 Feb  7 13:11 objects.json.migrated
      393958     412 -rw-rwxr--+  1 iobroker iobroker     420176 Feb  7 13:10 states.json.bak.migrated
      388621       0 -rw-rwxr--+  1 iobroker iobroker          0 Aug 27  2021 states.json.broken
      388908    2888 -rw-rwxr--+  1 iobroker iobroker    2956555 Jul 15 16:39 states.jsonl
      388622     412 -rw-rwxr--+  1 iobroker iobroker     420205 Feb  7 13:11 states.json.migrated
      396939       4 drwxrwxr-x+  2 iobroker iobroker       4096 Mär 12  2021 yahka.0.hapdata
        @caskstrengther sagte in iob startet nach nodejs-Update nicht mehr:
        Nicht mehr?
        Das sollte eigentlich mehr ausspucken. Bei mir:
             Active: active (running) since Thu 2022-07-14 01:39:03 CEST; 2 days ago
           Main PID: 535 (iobroker.js-con)
              Tasks: 370 (limit: 8986)
                CPU: 12h 54min 54.233s
                     ├─   535 iobroker.js-controller
                     ├─   754 io.history.0
                     ├─   968 io.whatsapp-cmb.0
                     ├─  1013 io.mihome-vacuum.0
                     ├─  1028 io.mihome.0
                     ├─  1056 io.rpi2.0
                     ├─  1116 io.tr-064.0
                     ├─  1131 io.zigbee.0
                     ├─  1142 io.backitup.0
                     ├─  1188 io.ble.0
                     ├─  1203 /usr/bin/node /opt/iobroker/node_modules/iobroker.ble/build/scanProcess -s
                     ├─  1210 io.echarts.0
                     ├─  1225 io.followthesun.0
                     ├─  1247 io.govee.0
                     ├─  1262 io.info.0
                     ├─  1285 io.iot.0
                     ├─  1371 io.miio.0
                     ├─  1556 io.nina.0
                     ├─  1877 io.pi-hole.0
                     ├─  1903 io.sainlogic.0
                     ├─  1918 io.simple-api.0
                     ├─  1974 io.socketio.0
                     ├─  1989 io.switchbot-hub.0
                     ├─  2004 io.tado.0
                     ├─  2044 io.tradfri.0
                     ├─  2098 io.web.0
                     ├─  2117 io.ws.0
                     ├─  2132 io.tankerkoenig.0
                     ├─  2256 io.nuki-extended.0
                     ├─ 44628 io.trashschedule.0
                     ├─ 52883 io.admin.0
                     ├─ 60253 io.alexa2.0
                     ├─136025 io.javascript.0
                     └─202094 io.parcel.0
        Jul 16 03:43:00 chet sudo[172541]: iobroker : PWD=/opt/iobroker/node_modules/iobroker.backitup ; USER=root ; COMMAND=/usr/bin/umount /opt/iobroker/backups
        Jul 16 03:43:00 chet sudo[172541]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
        Jul 16 03:43:00 chet sudo[172541]: pam_unix(sudo:session): session closed for user root
        Und das ist nicht mal die komplette Ausgabe.
        CaskstrengtherC 1 Antwort Letzte Antwort
          @caskstrengther
          insgesamt 1112584
          @caskstrengther
          Wie groß ist die Datei denn?
          Die lisa heißt besser lisah oder lh
          Dann ist das auch übersichtlicher.
            @caskstrengther
            insgesamt 1112584
            @caskstrengther
            Schau mal hier rein:
            https://forum.iobroker.net/topic/56379/zu-viele-objekte/5
              Nicht mehr?
                           ├─   754 io.history.0
                           ├─  1028 io.mihome.0
                           ├─  1056 io.rpi2.0
                           ├─  1116 io.tr-064.0
                           ├─  1131 io.zigbee.0
                           ├─  1188 io.ble.0
                           ├─  1247 io.govee.0
                           ├─  1262 io.info.0
                           ├─  1285 io.iot.0
                           ├─  1371 io.miio.0
                           ├─  1556 io.nina.0
                           ├─  2004 io.tado.0
                           ├─  2098 io.web.0
                           ├─  2117 io.ws.0
                           ├─ 52883 io.admin.0
              Caskstrengther
              Nein - nochmal:
                 Active: active (running) since Sat 2022-07-16 14:24:04 CEST; 22s ago
               Main PID: 17479 (iobroker.js-con)
                         └─17479 iobroker.js-controller
              Jul 16 14:24:04 raspberrypi systemd[1]: Started ioBroker Server.
                @caskstrengther
                Caskstrengther
                Diese Datei ist 1,1GB groß?!?
                pi@raspberrypi:/opt/iobroker/iobroker-data $ ls -lh
                insgesamt 1,1G
                drwxrwxr-x+  2 iobroker iobroker 4,0K Jul 15 02:45 backitup
                drwxrwxr-x+  2 iobroker iobroker  12K Jul 15 14:11 backup-objects
                drwxrwxr-x+ 16 iobroker iobroker 4,0K Feb 23 11:41 files
                -rw-rwxr--+  1 iobroker iobroker 4,7K Mai 10 20:18 iobroker.json
                -rw-rwxr--+  1 iobroker iobroker 5,4M Feb  7 13:11 objects.json.bak.migrated
                -rw-rwxr--+  1 iobroker iobroker 1,1G Jul 15 16:39 objects.jsonl
                drwxrwxr-x+  2 iobroker iobroker 4,0K Jul 16 14:26 objects.jsonl.lock
                -rw-rwxr--+  1 iobroker iobroker 5,4M Feb  7 13:11 objects.json.migrated
                -rw-rwxr--+  1 iobroker iobroker 411K Feb  7 13:10 states.json.bak.migrated
                -rw-rwxr--+  1 iobroker iobroker 2,9M Jul 15 16:39 states.jsonl
                -rw-rwxr--+  1 iobroker iobroker 411K Feb  7 13:11 states.json.migrated
                drwxrwxr-x+  2 iobroker iobroker 4,0K Mär 12  2021 yahka.0.hapdata
                  insgesamt 1,1G
                  Deutlich zu groß um damit umgehen zu können.
                  iobroker list adapters
                  bitte zeigen. Ist da einer der 'üblichen Verdächtigen' wie ble, fronius, withings oder (da war noch irgendein Adapter...) installiert?
                    Caskstrengther
                    Ich hatte vorher einmal das hier gemacht...
                    pi@raspberrypi:/opt/iobroker/iobroker-data $ iobroker list instances
                    Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                    ... und bei der Größe der Datei ist mir die Fehlermeldung irgendwie auch klar.
                    Jetzt Dein Befehl:
                    pi@raspberrypi:/opt/iobroker/iobroker-data $ iobroker list adapters
                    The same...
                      Jetzt Dein Befehl:
                      The same...
                      Caskstrengther
                      @caskstrengther
                      Ich Verzeichnis "backup-objects" ist das gepackte GZ-File 1000fach kleiner...
                        @caskstrengther
                        @caskstrengther
                        Ja, diese Daten kann man ganz gut komprimieren.
                          @caskstrengther
                          Caskstrengther
                          Soll ich eine Sicherung der Datei aus "backup-objects" einfach mal zurückspielen?
                            @caskstrengther
                            Die wird sich wieder aufblasen.
                            Mach es über die Kommandozeile, wenn das noch funktioniert:
                            https://forum.iobroker.net/topic/56379/zu-viele-objekte/3
                              @caskstrengther
                              Caskstrengther
                              Die Kommandos funktionieren leider nicht - selbe Meldung:
                              pi@raspberrypi:/opt/iobroker/iobroker-data $ iob list instances
                              Was sind das eigentlich für *migrated-Dateien im Verzeichnis? Kann ich die nicht einfach zurückspielen?
                              insgesamt 1,1G
                              -rw-rwxr--+  1 pi       pi       6,7M Jul 16 14:48 2022-07-15_08-11_objects.jsonl
                              drwxrwxr-x+  2 iobroker iobroker  12K Jul 16 14:44 backup-objects
                              Hier sieht man z.B. auch, dass die "objects.jsonl" von vor dem Update (oberste Datei) eine Größe von 6,7MB hatte.
                              Die aktuelle ist 1,1GB groß...
                                insgesamt 1,1G
                                Caskstrengther
                                @caskstrengther
                                ich konnte das Problem nun lösen.
                                Ich habe aus dem Unterverzeichnis "backup-objects" die vor dem Update gesicherten Dateien "objects.jsonl" und "states.jsonl" zurückgespielt, einen "iob fix" laufen lassen - anschließend startete der iobroker wieder.
                                Danach wieder "iob stop", "iob update", "iob upgrade self" und "iob start" - alles sieht gut aus.
                                Ich danke Euch allen, die sich so sehr um die Lösung meines Problems gekümmert haben! 💋
