  4. Kann keine Adapter aktualisieren
    apollon77A
75 Beiträge 14 Kommentatoren 16.7k Aufrufe 10 Beobachtet
  • K K 2K
    K K 2K
    K K 2
    #61
    Meine Adapter lassen sich nicht mehr aktualisieren.
    pi@nas:~ $ iobroker update
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.3.5  [Updatable]
    Adapter    "backitup"     : 2.8.1    , installed 2.6.19 [Updatable]
    Adapter    "ble"          : 0.13.4   , installed 0.13.0 [Updatable]
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.8  [Updatable]
    Adapter    "discovery"    : 3.1.0    , installed 3.0.5  [Updatable]
    Adapter    "info"         : 2.0.0    , installed 1.9.19 [Updatable]
    Adapter    "javascript"   : 7.1.4    , installed 6.1.4  [Updatable]
    Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
    Adapter    "lgtv"         : 2.1.1    , installed 1.1.10 [Updatable]
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "ring"         : 3.2.2    , installed 3.4.1
    Adapter    "simple-api"   : 2.7.2    , installed 2.7.0  [Updatable]
    Adapter    "socketio"     : 6.5.5    , installed 4.2.0  [Updatable]
    Adapter    "telegram"     : 1.16.0   , installed 1.15.6 [Updatable]
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "web"          : 6.1.2    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 2.5.5    , installed 1.3.0  [Updatable]
    Adapter    "yahka"        : 1.0.3    , installed 0.17.0 [Updatable]
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Update/Upgrade:
    pi@nas:~ $ iobroker upgrade daswetter --debug
    This upgrade of "daswetter" will at least introduce the following changes:
    -> 3.1.10:
    dependencies updated
    Would you like to upgrade daswetter from @3.1.8 to @3.1.10 now? [(y)es, (n)o]: y
    Update daswetter from @3.1.8 to @3.1.10
    host.nas Adapter "system.adapter.daswetter.0" is stopped.
    NPM version: 9.8.1
    Installing iobroker.daswetter@3.1.10... (System call)
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm ERR! code 1
    npm ERR! git dep preparation failed
    npm ERR! command /usr/local/bin/node /usr/local/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
    npm ERR! npm WARN using --force Recommended protections disabled.
    npm ERR! npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
    npm ERR! npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
    npm ERR! npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
    npm ERR! npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
    npm ERR! npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
    npm ERR! npm ERR! code 1
    npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-cloneUOuQIc/node_modules/sharp
    npm ERR! npm ERR! command failed
    npm ERR! npm ERR! command sh -c (node install/libvips && node install/dll-copy && prebuild-install) || (node install/can-compile && node-gyp rebuild && node install/dll-copy)
    npm ERR! npm ERR! sharp: Using cached /home/iobroker/.npm/_libvips/libvips-8.14.5-linux-armv7.tar.br
    npm ERR! npm ERR! sharp: Integrity check passed for linux-armv7
    npm ERR! npm ERR! make: Verzeichnis �/home/iobroker/.npm/_cacache/tmp/git-cloneUOuQIc/node_modules/sharp/build� wird betreten
    npm ERR! npm ERR!   CC(target) Release/obj.target/nothing/../node-addon-api/nothing.o
    npm ERR! npm ERR! rm -f Release/obj.target/../node-addon-api/nothing.a Release/obj.target/../node-addon-api/nothing.a.ar-file-list; mkdir -p `dirname Release/obj.target/../node-addon-api/nothing.a`
    npm ERR! npm ERR! ar crs Release/obj.target/../node-addon-api/nothing.a @Release/obj.target/../node-addon-api/nothing.a.ar-file-list
    npm ERR! npm ERR!   COPY Release/nothing.a
    npm ERR! npm ERR!   TOUCH Release/obj.target/libvips-cpp.stamp
    npm ERR! npm ERR!   CXX(target) Release/obj.target/sharp-linux-armv7/src/common.o
    npm ERR! npm ERR! make: Verzeichnis �/home/iobroker/.npm/_cacache/tmp/git-cloneUOuQIc/node_modules/sharp/build� wird verlassen
    npm ERR! npm ERR! prebuild-install warn install No prebuilt binaries found (target=7 runtime=napi arch=arm libc= platform=linux)
    npm ERR! npm ERR! gyp info it worked if it ends with ok
    npm ERR! npm ERR! gyp info using node-gyp@9.4.0
    npm ERR! npm ERR! gyp info using node@18.18.2 | linux | arm
    npm ERR! npm ERR! gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3"
    npm ERR! npm ERR! gyp info spawn /usr/bin/python3
    npm ERR! npm ERR! gyp info spawn args [
    npm ERR! npm ERR! gyp info spawn args   '/usr/local/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
    npm ERR! npm ERR! gyp info spawn args   'binding.gyp',
    npm ERR! npm ERR! gyp info spawn args   '-f',
    npm ERR! npm ERR! gyp info spawn args   'make',
    npm ERR! npm ERR! gyp info spawn args   '-I',
    npm ERR! npm ERR! gyp info spawn args   '/home/iobroker/.npm/_cacache/tmp/git-cloneUOuQIc/node_modules/sharp/build/config.gypi',
    npm ERR! npm ERR! gyp info spawn args   '/usr/local/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
    npm ERR! npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
    npm ERR! npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
    npm ERR! npm ERR! gyp info spawn args   '-Dvisibility=default',
    npm ERR! npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
    npm ERR! npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/local/lib/node_modules/npm/node_modules/node-gyp',
    npm ERR! npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
    npm ERR! npm ERR! gyp info spawn args   '-Dmodule_root_dir=/home/iobroker/.npm/_cacache/tmp/git-cloneUOuQIc/node_modules/sharp',
    npm ERR! npm ERR! gyp info spawn args   '-Dnode_engine=v8',
    npm ERR! npm ERR! gyp info spawn args   '--depth=.',
    npm ERR! npm ERR! gyp info spawn args   '--no-parallel',
    npm ERR! npm ERR! gyp info spawn args   '--generator-output',
    npm ERR! npm ERR! gyp info spawn args   'build',
    npm ERR! npm ERR! gyp info spawn args   '-Goutput_dir=.'
    npm ERR! npm ERR! gyp info spawn args ]
    npm ERR! npm ERR! gyp info spawn make
    npm ERR! npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
    npm ERR! npm ERR! g++: error: unrecognized command line option '-std=gnu++17'
    npm ERR! npm ERR! make: *** [sharp-linux-armv7.target.mk:142: Release/obj.target/sharp-linux-armv7/src/common.o] Fehler 1
    npm ERR! npm ERR! gyp ERR! build error
    npm ERR! npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
    npm ERR! npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:203:23)
    npm ERR! npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
    npm ERR! npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
    npm ERR! npm ERR! gyp ERR! System Linux 5.10.103-v7l+
    npm ERR! npm ERR! gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    npm ERR! npm ERR! gyp ERR! cwd /home/iobroker/.npm/_cacache/tmp/git-cloneUOuQIc/node_modules/sharp
    npm ERR! npm ERR! gyp ERR! node -v v18.18.2
    npm ERR! npm ERR! gyp ERR! node-gyp -v v9.4.0
    npm ERR! npm ERR! gyp ERR! not ok
    npm ERR!
    npm ERR! npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-19T06_39_00_484Z-debug-0.log
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-19T06_36_08_244Z-debug-0.log
    Update "system.adapter.daswetter.0"
    Unabhängig vom Adapter sieht es eigentlich immer wie gezeigt aus. Hat jemand eine Idee wie ich das Ding retten kann?
    • K K 2K K K 2
      Update/Upgrade:
      -> 3.1.10:
      NPM version: 9.8.1
      npm ERR! code 1
      npm ERR!
      Thomas BraunT
      Thomas BraunT
      #62
      @k-k-2 sagte in Kann keine Adapter aktualisieren:
      usr/local/bin/node
      Nodejs falsch installiert. Mit
      iob nodejs-update
      gerade biegen.
      https://forum.iobroker.net/topic/69068/neuer-befehl-iob-nodejs-update
      K K 2K 1 Antwort Letzte Antwort
        usr/local/bin/node
        iob nodejs-update
        gerade biegen.
        K K 2K
        K K 2K
        K K 2
        #63
        @thomas-braun danke für die schnelle Antwort. ich habe es ausgeführt, aber leider ohne Erfolg
        iob diag
                                v.2023-10-10
           Static hostname: nas
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.103-v7l+
              Architecture: arm
        Installation:           native
        Kernel:                 armv7l
        Userland:               armhf
        Timezone:               Europe/Berlin (CEST, +0200)
        User-ID:                1000
        X-Server:               true
        Pending OS-Updates:     0
        Pending iob updates:    15
        Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                /usr/bin/node           v18.18.2
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
                                /usr/bin/corepack       0.19.0
        Recommended versions are nodejs  and npm 8.19.4
        MEMORY:
        Mem:           3.8G        897M        1.7G         31M        1.3G        2.7G
        Swap:           99M        9.0M         90M
        Total:         3.9G        906M        1.8G
        Active iob-Instances:   14
        Active repo(s): stable
        ioBroker Core:          js-controller           4.0.24
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : nas                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : nas                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                5484
        States:                 4978
        Size of iob-Database:
        7.9M    /opt/iobroker/iobroker-data/objects.jsonl
        5.6M    /opt/iobroker/iobroker-data/objects.json.migrated
        5.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
        7.5M    /opt/iobroker/iobroker-data/states.jsonl
        1.2M    /opt/iobroker/iobroker-data/states.json.migrated
        1.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
        pi@nas:~ $ iobroker upgrade ble --debug
        This upgrade of "ble" will introduce the following changes:
        -> 0.13.4:
        Very experimental support for scanning on a remote host (#793)
        Another attempt at updating `noble`. Hopefully this version works now...
        -> 0.13.3:
        Updated `noble` again. This should fix the automatic rebuild after Node.js upgrades and the previous performance issues.
        -> 0.13.2:
        Downgraded the `noble` dependency again because of performance issues
        -> 0.13.1:
        Updated the `noble` dependency. This should fix the automatic rebuild after Node.js upgrades.
        Would you like to upgrade ble from @0.13.0 to @0.13.4 now? [(y)es, (n)o]: y
        Update ble from @0.13.0 to @0.13.4
        NPM version: 9.8.1
        Installing iobroker.ble@0.13.4... (System call)
        npm ERR! code 1
        npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
        npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-cloner8Vyuj/node_modules/sharp
        npm ERR! npm ERR! make: Verzeichnis �/home/iobroker/.npm/_cacache/tmp/git-cloner8Vyuj/node_modules/sharp/build� wird betreten
        npm ERR! npm ERR! make: Verzeichnis �/home/iobroker/.npm/_cacache/tmp/git-cloner8Vyuj/node_modules/sharp/build� wird verlassen
        npm ERR! npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
        npm ERR! npm ERR! gyp info spawn args   '/home/iobroker/.npm/_cacache/tmp/git-cloner8Vyuj/node_modules/sharp/build/config.gypi',
        npm ERR! npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
        npm ERR! npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
        npm ERR! npm ERR! gyp info spawn args   '-Dmodule_root_dir=/home/iobroker/.npm/_cacache/tmp/git-cloner8Vyuj/node_modules/sharp',
        npm ERR! npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:203:23)
        npm ERR! npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        npm ERR! npm ERR! gyp ERR! cwd /home/iobroker/.npm/_cacache/tmp/git-cloner8Vyuj/node_modules/sharp
        npm ERR!
        npm ERR! npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-19T08_50_52_112Z-debug-0.log
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-19T08_48_23_921Z-debug-0.log
        upload [5] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/.eslintrc.js .eslintrc.js application/javascript
        upload [4] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/ble.png ble.png image/png
        upload [3] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js build/index.js application/javascript
        upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js.map build/index.js.map application/json
        upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index_m.html index_m.html text/html
        upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/style.css style.css text/css
        • K K 2K K K 2
          iob diag
                                  v.2023-10-10
                   Icon name: computer
                Architecture: arm
          Kernel:                 armv7l
          Userland:               armhf
          User-ID:                1000
          X-Server:               true
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
          MEMORY:
          Swap:           99M        9.0M         90M
                                  admin                   6.3.5
          Objects type: jsonl
          States  type: jsonl
          Objects:                5484
          States:                 4978
          -> 0.13.4:
          -> 0.13.3:
          -> 0.13.2:
          -> 0.13.1:
          NPM version: 9.8.1
          npm ERR! code 1
          npm ERR!
          Thomas BraunT
          Thomas BraunT
          #64
          @k-k-2
          Schalt den Desktop aus.
          Und lösche den npm Cache
          sudo -H -u iobrokee nom cache clear --force
          [Edit:]
          Ach, sehe ich ja gerade erst: buster
          Ist tot und muss ersetzt werden. Dann funktioniert vermutlich auch dein gcc wieder.
          Nawah tschaindsch ä runnink süstem...
          Mal wieder. Leute, haltet die Kisten auf einem aktuellen Stand!!
            @k-k-2
            [Edit:]
            K K 2K
            K K 2K
            K K 2
            #65
            @thomas-braun danke wieder für die schnelle Antwort, aber leider auch diesmal ohne Erfolg.
            per Raspi-config auf Console und den pi neugestartet, anschließen das npm clear.
            -> 0.13.4:
            -> 0.13.3:
            -> 0.13.2:
            -> 0.13.1:
            NPM version: 9.8.1
            npm ERR! code 1
            npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-cloneDEg5tT/node_modules/sharp
            npm ERR! npm ERR! make: Verzeichnis �/home/iobroker/.npm/_cacache/tmp/git-cloneDEg5tT/node_modules/sharp/build� wird betreten
            npm ERR! npm ERR! make: Verzeichnis �/home/iobroker/.npm/_cacache/tmp/git-cloneDEg5tT/node_modules/sharp/build� wird verlassen
            npm ERR! npm ERR! gyp info spawn args   '/home/iobroker/.npm/_cacache/tmp/git-cloneDEg5tT/node_modules/sharp/build/config.gypi',
            npm ERR! npm ERR! gyp info spawn args   '-Dmodule_root_dir=/home/iobroker/.npm/_cacache/tmp/git-cloneDEg5tT/node_modules/sharp',
            npm ERR! npm ERR! gyp ERR! cwd /home/iobroker/.npm/_cacache/tmp/git-cloneDEg5tT/node_modules/sharp
            npm ERR!
            npm ERR! npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-19T09_45_21_571Z-debug-0.log
            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-19T09_42_41_438Z-debug-0.log
            • K K 2K K K 2
              -> 0.13.4:
              -> 0.13.3:
              -> 0.13.2:
              -> 0.13.1:
              NPM version: 9.8.1
              npm ERR! code 1
              npm ERR!
              Thomas BraunT
              Thomas BraunT
              #66
              @k-k-2
              Siehe Edit oben. Die Kiste ist zu alt. Aktualisieren, am besten gleich mit Bookworm neuaufsetzen. Ohne Desktop.
                @k-k-2
                K K 2K
                K K 2K
                K K 2
                #67
                @thomas-braun ok danke, hab ein schnelles upgrade auf bullseye gemacht und iobroker re-installiert, sowie backup übernommen. Jetzt sieht es gut aus.
                • K K 2K K K 2
                  Thomas BraunT
                  Thomas BraunT
                  #68
                  @k-k-2
                  Ich sag ja: Zu alt. Ich wäre allerdings bis Bookworm gegangen. 'Bullseye' läuft ja auch schon wieder aus, im Sommer '24 ist da auch Schicht.
                    @k-k-2
                    K K 2K
                    K K 2K
                    K K 2
                    #69
                    @thomas-braun ein schritt nach den anderen. so kann ich davon jetzt erstmal ein image ziehen und dann weiter machen
                    madjack84M 1 Antwort Letzte Antwort
                    • K K 2K K K 2
                      madjack84M
                      madjack84M
                      madjack84
                      schrieb am zuletzt editiert von madjack84
                      #70
                      Hello,
                      ich hab kürzlich aufgrund eines Zigbee Themas das Beta repo benutzt. Nach der Rückstellung auf stable sehe ich keine Adapter Updates mehr.
                      Ich nutze Ubuntu LTS 20.04, v20.19.0
                      Was ist hier die richtige Maßnahme? einen iobroker fix?
                      Was erwartet ihr wenn ich Ubuntu auf 22.04. update um das System zu pflegen? juckt das iobroker in irgendeiner Abhängigkeit? Ich möchte nicht 2 Fehler gleichzeitig konstruieren, aber laut diesem Thread hier könnte das ein Thema sein. Ich tippe aber, dass bei der Beta Umstellung was hängen geblieben ist. Nen Stromausfall (siehe Thread hier) gab es zwischendurch auch :/
                      nuc i3, Proxmox, raspimatic (PI3), 15 shellies, shelly 4pro/25/RGB, wled sonoff, 7x xiaomi sensoren, 4xEchos, 4 Tasmota Steckdosen, motionEye, nspanel, Ring, hoymiles usw
                      wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
                      • madjack84M madjack84
                        Hello,
                        wendy2702W
                        wendy2702W
                        wendy2702
                        #71
                        @madjack84 Zeig doch mal die Ausgabe von
                        iob diag
                          Hello,
                          Thomas BraunT
                          Thomas BraunT
                          #72
                          @madjack84
                          deconz sagt doch ein Update an?
                          Dann wird es höchste Zeit zu upgraden.
                          Ich würde allerdings eher zum Original raten: Debian.
                            @madjack84
                            madjack84M
                            madjack84M
                            madjack84
                            #73
                            @thomas-braun Ja das ist seit geraumer Zeit der einzige Adapter.
                            ich hatte oben in den Benachrichtigungen eine ganze Latte an updatebaren Adaptern gelesen und daher drauf geschlossen, dass keine Updates rein kamen.... Gerade hab ich aber fest gestellt, dass ich 2 weitere Update sehe und die Benachrichtigungen weniger sind.
                            Grund: Die Benachrichtigungen waren noch aus dem BETA repo :( und ich hatte schon auf stable umgestellt.
                            Daher: Vielleicht die Benachrichtigungen nach jeder Installation neu laden um sowas zu vermeiden. Und ja, den timestamp hab ich gesehen. Beispielsweise hatte ich aber hier den Admin vor dem Neustart installiert.
                            @wendy2702 : Danke für den Tip. Diag kannte ich bisher nicht. hab ich gemacht. Fix durchgeführt und neu gestartet.
                            Da stehen mir zu viel Details und IPs grade drin :/ da das System zu laufen scheint, freue ich mich erstmal und lass den log weg, wenns ok ist.
                            Aber nochmals DANKE!
                            Thomas BraunT CodierknechtC 2 Antworten Letzte Antwort
                              Thomas BraunT
                              Thomas BraunT
                              #74
                              @madjack84 sagte in Kann keine Adapter aktualisieren:
                              Da steht höchstens in den letzten 25 Zeilen je nachdem irgendwas persönliches drin.
                              IPs aus deinem eigenen Netz sind z. B. komplett egal. Private IPs werden nicht geroutet. Und wer ohnehin schon in deinem Netz ist, der kann sich per nmap eh alles anschauen.
                              Das sind wieder die typischen 'Lügen' einer GUI. Die Ausgaben im Terminal sind immer richtig.
                                CodierknechtC
                                CodierknechtC
                                Codierknecht
                                #75
                                @thomas-braun sagte in Kann keine Adapter aktualisieren:
                                Um es etwas einfacher auszudrücken: Die IP's sehen bei uns allen gleich oder zumindest ähnlich aus. In der Regel sowas wie 192.168.178.xxx.
                                An diese IP's kommst Du nur aus Deinem privaten Netz. Damit kann niemand etwas anfangen. Es sei denn, da ist schon jemand in Deinem Netz. Aber dann hast Du ganz andere Probleme ;-)
                                Und genau auf die Details kommt es an, um ein System beurteilen zu können.
                                da das System zu laufen scheint ... und lass den log weg
                                Ob da künftig Probleme zu erwarten sind, könnte man im Log erkennen.
                                HmIP|ZigBee|Tasmota|Unifi
                                Zabbix Certified Specialist
                                83.9k
                                1.4m
