  4. Einrichten Modbus Adapter / Solar X3 Gen4
147 Beiträge 19 Kommentatoren 30.5k Aufrufe 18 Beobachtet
  • McWoolfM McWoolf
    @mcwoolf sagte in Einrichten Modbus Adapter / Solar X3 Gen4:
    @wendy2702
    Also:
    USR 192.168.1.246
    IOB 192.168.1.250
    WR 192.168.1.245 (Lan-Dongle)
    Device ID im SolaxWR habe ich mal auf 2 gestellt, zum testen
    2023-01-18 08:47:04.364 - info: shelly.0 (2744968) [MQTT] Device 192.168.30.41 (shellyht / shellyht-024F7E / SHHT-1#024F7E#1) connected! Polltime set to 5 sec.
    2023-01-18 08:47:10.460 - info: modbus.0 (2274495) Got terminate signal TERMINATE_YOURSELF
    2023-01-18 08:47:10.460 - info: modbus.0 (2274495) terminating
    2023-01-18 08:47:10.461 - info: modbus.0 (2274495) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 08:47:13.697 - debug: modbus.0 (2274856) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-01-18 08:47:13.718 - debug: modbus.0 (2274856) Objects client ready ... initialize now
    2023-01-18 08:47:13.718 - debug: modbus.0 (2274856) Objects create System PubSub Client
    2023-01-18 08:47:13.719 - debug: modbus.0 (2274856) Objects create User PubSub Client
    2023-01-18 08:47:13.746 - debug: modbus.0 (2274856) Objects client initialize lua scripts
    2023-01-18 08:47:13.747 - debug: modbus.0 (2274856) Objects connected to redis: 127.0.0.1:9001
    2023-01-18 08:47:13.807 - debug: modbus.0 (2274856) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-01-18 08:47:13.815 - debug: modbus.0 (2274856) States create System PubSub Client
    2023-01-18 08:47:13.815 - debug: modbus.0 (2274856) States create User PubSub Client
    2023-01-18 08:47:13.872 - debug: modbus.0 (2274856) States connected to redis: 127.0.0.1:9000
    2023-01-18 08:47:13.926 - debug: modbus.0 (2274856) Plugin sentry Initialize Plugin (enabled=true)
    2023-01-18 08:47:13.996 - info: modbus.0 (2274856) starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 08:47:14.065 - debug: modbus.0 (2274856) Initialize Objects for disInputs: []
    2023-01-18 08:47:14.065 - debug: modbus.0 (2274856) Initialize Objects for coils: []
    2023-01-18 08:47:14.065 - debug: modbus.0 (2274856) Initialize Objects for inputRegs: []
    2023-01-18 08:47:14.065 - debug: modbus.0 (2274856) Initialize Objects for holdingRegs: [{"_address":0,"deviceId":2,"name":"Seriennummer","description":"","unit":"","type":"string","len":7,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":0,"id":"holdingRegisters.0_Seriennummer"}]
    2023-01-18 08:47:14.065 - debug: modbus.0 (2274856) Add holdingRegisters.0_Seriennummer: {"_id":"holdingRegisters.0_Seriennummer","type":"state","common":{"name":"","role":"level","type":"string","read":true,"write":true,"def":"","unit":""},"native":{"regType":"holdingRegs","address":0,"deviceId":2,"type":"string","len":7,"offset":0,"factor":1,"poll":true}}
    2023-01-18 08:47:14.168 - error: modbus.0 (2274856) Socket Error
    2023-01-18 08:47:14.168 - error: modbus.0 (2274856) Client in error state.
    2023-01-18 08:47:14.168 - warn: modbus.0 (2274856) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.1.246","port":502}
    2023-01-18 08:47:14.168 - debug: modbus.0 (2274856) Socket closed with error
    2023-01-18 08:47:14.169 - debug: modbus.0 (2274856) Cleaning up request fifo.
    2023-01-18 08:47:15.169 - debug: modbus.0 (2274856) Closing client on purpose.
    McWoolfM Offline
    McWoolfM Offline
    McWoolf
    @wendy2702
    Also:
    USR 192.168.1.246
    IOB 192.168.1.250
    Der zählt übrigens auch, wenn der modbus-Adapter aus ist.
    Lieben Dank an die Helfer hier.
    GLG Wolfi
    Configuration:
    Intel Nuc: 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz (1 Socket)
    RAM: 8 GB
    JS-controler: 5.0.17
    Node.js: 18.19.0
    NPM: 10.2.3
    • wendy2702W Offline
      wendy2702W Offline
      wendy2702
      @mcwoolf
      Ich kenne den WR nicht aber wie sieht der Physikalische Aufbau aus?
      Das USR RS485 ist mit dem WR bereits verbunden denke ich.
      Wie lauten die Modbus einstellungen im WR? Baudrate, Parität, ID usw.
      Bitte Screenshot der Adapter Einstellungen und Register.
      McWoolfM 1 Antwort Letzte Antwort
      • McWoolfM McWoolf
        @wendy2702
        Also:
        USR 192.168.1.246
        IOB 192.168.1.250
        wendy2702W Offline
        wendy2702W Offline
        wendy2702
        Ja, weil er einfach nur RX/TX Pakete zählt.
        • wendy2702W wendy2702
          @mcwoolf
          McWoolfM Offline
          McWoolfM Offline
          McWoolf
          @wendy2702
          GLG Wolfi
          Configuration:
          RAM: 8 GB
          Node.js: 18.19.0
          NPM: 10.2.3
          • McWoolfM McWoolf
            @wendy2702
            wendy2702W Offline
            wendy2702W Offline
            wendy2702
            @mcwoolf Haken bei "Direkte ...." raus.
            Als Test Register mal Spannung oder Temperatur nehmen.
            Sicher das es ein Holding Register und kein Input Register ist?
            Stimmt die ID 2 mit dem was im WR steht überein?
              McWoolfM Offline
              McWoolfM Offline
              McWoolf
              @wendy2702
              Sowas z.B. ?
              GLG Wolfi
              Configuration:
              RAM: 8 GB
              Node.js: 18.19.0
              NPM: 10.2.3
              • McWoolfM McWoolf
                @wendy2702
                Sowas z.B. ?
                wendy2702W Offline
                wendy2702W Offline
                wendy2702
                @mcwoolf Ja.
                unter Eingangsregister als 16bit, denke auch little endian wobei mit bei der Register Adresse die 0 etwas wundert.
                  @mcwoolf Ja.
                  McWoolfM Offline
                  McWoolfM Offline
                  McWoolf
                  @wendy2702
                  Das ist die offizielle Beschreibung
                  GLG Wolfi
                  Configuration:
                  RAM: 8 GB
                  Node.js: 18.19.0
                  NPM: 10.2.3
                  • McWoolfM McWoolf
                    @wendy2702
                    McWoolfM Offline
                    McWoolfM Offline
                    McWoolf
                    @mcwoolf
                    Mit Hilfe von @klassisch habe ich endlich eine Verbindung herstellen können. Hier die Einstellungen:
                    8e52a5e2-db3c-4d3e-a174-271866743aae-image.png d028ffb4-f543-410a-b472-cdbc40b135d4-image.png
                    GLG Wolfi
                    Configuration:
                    RAM: 8 GB
                    Node.js: 18.19.0
                    NPM: 10.2.3
                    • McWoolfM McWoolf
                      @mcwoolf
                      wendy2702W Offline
                      wendy2702W Offline
                      wendy2702
                      @mcwoolf habt ihr das per Chat gemacht oder gibt es einen weiteren thread?
                        McWoolfM Offline
                        McWoolfM Offline
                        McWoolf
                        @wendy2702 Er hat mir per chat geholfen.
                        Aber ich bekomme noch keine passenden Daten, ich komme mit den Registern noch nicht klar
                        GLG Wolfi
                        Configuration:
                        RAM: 8 GB
                        Node.js: 18.19.0
                        NPM: 10.2.3
                        • McWoolfM McWoolf
                          McWoolfM Offline
                          McWoolfM Offline
                          McWoolf
                          @mcwoolf Ich muss leider alles revidieren, der USR-TCP232-304 kann kein RTU!!!!
                          Kein wunder dass ich keine Daten bekomme.
                          GLG Wolfi
                          Configuration:
                          RAM: 8 GB
                          Node.js: 18.19.0
                          NPM: 10.2.3
                          wendy2702W K 2 Antworten Letzte Antwort
                          • McWoolfM McWoolf
                            wendy2702W Offline
                            wendy2702W Offline
                            wendy2702
                            @mcwoolf OK.
                            Vielleicht ist das was für dich.
                            https://eckstein-shop.de/WaveShare-Industrial-Serial-Server-with-POE
                            Gibt es für einen euro weniger auch ohne POE. Den verwende ich und ich glaube @klassisch auch.
                              @mcwoolf OK.
                              McWoolfM Offline
                              McWoolfM Offline
                              McWoolf
                              schrieb am zuletzt editiert von McWoolf
                              @wendy2702
                              So nun habe ich den PE11 der sollte RTU beherrschen.
                              Naja was soll ich sagen, bekomme dennoch keine Daten.
                              Verbindung habe ich aber nur, wenn PE11 und iobroker auf Server eingestellt werden, was mich ein wenig irretiert, es heißt ja, bei modbus gibt es Server und Clients?? Oder verstehe ich hier auch was falsch?
                              2023-01-20 08:01:39.317 - error: modbus.0 (21212) Error response: ff
                              2023-01-20 08:01:40.369 - error: modbus.0 (21212) Error response: 5f
                              2023-01-20 08:01:41.469 - error: modbus.0 (21212) Error response: ff
                              2023-01-20 08:01:42.568 - error: modbus.0 (21212) Error response: ff
                              2023-01-20 08:01:43.617 - error: modbus.0 (21212) Error response: ff
                              2023-01-20 08:01:44.667 - error: modbus.0 (21212) unknown function code: 0x7e, 0xd5
                              2023-01-20 08:01:45.666 - error: modbus.0 (21212) Error response: ff
                              2023-01-20 08:01:46.715 - error: modbus.0 (21212) unknown function code: 0x7e, 0xd5
                              2023-01-20 08:01:47.713 - error: modbus.0 (21212) Error response: ff
                              2023-01-20 08:01:48.765 - error: modbus.0 (21212) Error response: 7e
                              2023-01-20 08:01:49.748 - error: modbus.0 (21212) Error response: ff
                              2023-01-20 08:01:50.797 - error: modbus.0 (21212) Error response: f2
                              2023-01-20 08:01:51.797 - error: modbus.0 (21212) unknown function code: 0x5f, 0xfd
                              2023-01-20 08:01:52.872 - error: modbus.0 (21212) Error response: ff
                              2023-01-20 08:01:54.023 - error: modbus.0 (21212) Error response: ff
                              2023-01-20 08:01:55.071 - error: modbus.0 (21212) Error response: ff
                              2023-01-20 08:01:56.120 - error: modbus.0 (21212) Error response: 7e
                              2023-01-20 08:01:57.120 - error: modbus.0 (21212) Error response: ff
                              2023-01-20 08:01:58.142 - error: modbus.0 (21212) Error response: ff
                              Kann mir jemand verraten was das hier zu bedeuten hat??
                              GLG Wolfi
                              Configuration:
                              RAM: 8 GB
                              Node.js: 18.19.0
                              NPM: 10.2.3
                                wendy2702W Offline
                                wendy2702
                                PE11
                                Das Gerät kenne ich nicht. Aber zweimal Server ist eigentlich falsch.
                                Man hat immer einen Server und mindestens einen Client.
                                  PE11
                                  McWoolfM Offline
                                  McWoolfM Offline
                                  McWoolf
                                  @wendy2702
                                  Ja das denke ich auch, aber anders bekomme ich keine Verbindung.
                                  GLG Wolfi
                                  Configuration:
                                  RAM: 8 GB
                                  Node.js: 18.19.0
                                  NPM: 10.2.3
                                  • McWoolfM McWoolf
                                    @wendy2702
                                    wendy2702W Offline
                                    wendy2702W Offline
                                    wendy2702
                                    @mcwoolf Mit dem Device kann ich dir leider nicht helfen.
                                    Sorry
                                      Sorry
                                      McWoolfM Offline
                                      McWoolfM Offline
                                      McWoolf
                                      @wendy2702
                                      Die Verbindung ist auch nicht wirklich mehr das Problem, nur eben dass ich keine Daten aus dem Solax raus bekommen. Sobald ich ein Eingangsregister in den Modbus-Adapter eintrage, kommen diese Meldungen. s.O.
                                      GLG Wolfi
                                      Configuration:
                                      RAM: 8 GB
                                      Node.js: 18.19.0
                                      NPM: 10.2.3
                                      • McWoolfM McWoolf
                                        @wendy2702
                                        wendy2702W Offline
                                        wendy2702W Offline
                                        wendy2702
                                        @mcwoolf Kannst du mal im Adapter auf TCP stellen. Die Umsetzung RTU --> TCP sollte doch das Gateway schon machen.
                                          McWoolfM Offline
                                          McWoolfM Offline
                                          McWoolf
                                          @wendy2702
                                          Verbindung steht --> dennoch keine Daten.
                                          Kannst du bitte mal meine Einstellungen kontrollieren?
                                          stimmt das so??
                                          GLG Wolfi
                                          Configuration:
                                          RAM: 8 GB
                                          Node.js: 18.19.0
                                          NPM: 10.2.3
