  4. Einrichten Modbus Adapter / Solar X3 Gen4
147 Beiträge 19 Kommentatoren 30.5k Aufrufe 18 Beobachtet
  • McWoolfM McWoolf
    @wendy2702
    Also:
    USR 192.168.1.246
    IOB 192.168.1.250
    WR 192.168.1.245 (Lan-Dongle)
    Device ID im SolaxWR habe ich mal auf 2 gestellt, zum testen
    McWoolfM Offline
    McWoolfM Offline
    McWoolf
    @mcwoolf sagte in Einrichten Modbus Adapter / Solar X3 Gen4:
    @wendy2702
    Also:
    USR 192.168.1.246
    IOB 192.168.1.250
    2023-01-18 08:47:04.364 - info: shelly.0 (2744968) [MQTT] Device 192.168.30.41 (shellyht / shellyht-024F7E / SHHT-1#024F7E#1) connected! Polltime set to 5 sec.
    2023-01-18 08:47:10.460 - info: modbus.0 (2274495) Got terminate signal TERMINATE_YOURSELF
    2023-01-18 08:47:10.460 - info: modbus.0 (2274495) terminating
    2023-01-18 08:47:10.461 - info: modbus.0 (2274495) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-18 08:47:13.697 - debug: modbus.0 (2274856) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-01-18 08:47:13.718 - debug: modbus.0 (2274856) Objects client ready ... initialize now
    2023-01-18 08:47:13.718 - debug: modbus.0 (2274856) Objects create System PubSub Client
    2023-01-18 08:47:13.719 - debug: modbus.0 (2274856) Objects create User PubSub Client
    2023-01-18 08:47:13.746 - debug: modbus.0 (2274856) Objects client initialize lua scripts
    2023-01-18 08:47:13.747 - debug: modbus.0 (2274856) Objects connected to redis: 127.0.0.1:9001
    2023-01-18 08:47:13.807 - debug: modbus.0 (2274856) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-01-18 08:47:13.815 - debug: modbus.0 (2274856) States create System PubSub Client
    2023-01-18 08:47:13.815 - debug: modbus.0 (2274856) States create User PubSub Client
    2023-01-18 08:47:13.872 - debug: modbus.0 (2274856) States connected to redis: 127.0.0.1:9000
    2023-01-18 08:47:13.926 - debug: modbus.0 (2274856) Plugin sentry Initialize Plugin (enabled=true)
    2023-01-18 08:47:13.996 - info: modbus.0 (2274856) starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.0, js-controller: 4.0.24
    2023-01-18 08:47:14.065 - debug: modbus.0 (2274856) Initialize Objects for disInputs: []
    2023-01-18 08:47:14.065 - debug: modbus.0 (2274856) Initialize Objects for coils: []
    2023-01-18 08:47:14.065 - debug: modbus.0 (2274856) Initialize Objects for inputRegs: []
    2023-01-18 08:47:14.065 - debug: modbus.0 (2274856) Initialize Objects for holdingRegs: [{"_address":0,"deviceId":2,"name":"Seriennummer","description":"","unit":"","type":"string","len":7,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":0,"id":"holdingRegisters.0_Seriennummer"}]
    2023-01-18 08:47:14.065 - debug: modbus.0 (2274856) Add holdingRegisters.0_Seriennummer: {"_id":"holdingRegisters.0_Seriennummer","type":"state","common":{"name":"","role":"level","type":"string","read":true,"write":true,"def":"","unit":""},"native":{"regType":"holdingRegs","address":0,"deviceId":2,"type":"string","len":7,"offset":0,"factor":1,"poll":true}}
    2023-01-18 08:47:14.168 - error: modbus.0 (2274856) Socket Error
    2023-01-18 08:47:14.168 - error: modbus.0 (2274856) Client in error state.
    2023-01-18 08:47:14.168 - warn: modbus.0 (2274856) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.1.246","port":502}
    2023-01-18 08:47:14.168 - debug: modbus.0 (2274856) Socket closed with error
    2023-01-18 08:47:14.169 - debug: modbus.0 (2274856) Cleaning up request fifo.
    2023-01-18 08:47:15.169 - debug: modbus.0 (2274856) Closing client on purpose.
    Lieben Dank an die Helfer hier.
    GLG Wolfi
    Configuration:
    Intel Nuc: 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz (1 Socket)
    RAM: 8 GB
    JS-controler: 5.0.17
    Node.js: 18.19.0
    NPM: 10.2.3
    McWoolfM 1 Antwort Letzte Antwort
    • McWoolfM McWoolf
      @wendy2702
      Also:
      USR 192.168.1.246
      IOB 192.168.1.250
      McWoolfM Offline
      McWoolfM Offline
      McWoolf
      @wendy2702
      Also:
      USR 192.168.1.246
      IOB 192.168.1.250
      Der zählt übrigens auch, wenn der modbus-Adapter aus ist.
      GLG Wolfi
      Configuration:
      RAM: 8 GB
      Node.js: 18.19.0
      NPM: 10.2.3
      • wendy2702W Online
        wendy2702W Online
        @mcwoolf
        Ich kenne den WR nicht aber wie sieht der Physikalische Aufbau aus?
        Das USR RS485 ist mit dem WR bereits verbunden denke ich.
        Wie lauten die Modbus einstellungen im WR? Baudrate, Parität, ID usw.
        Bitte Screenshot der Adapter Einstellungen und Register.
        • McWoolfM McWoolf
          @wendy2702
          Also:
          USR 192.168.1.246
          IOB 192.168.1.250
          wendy2702W Online
          wendy2702W Online
          Ja, weil er einfach nur RX/TX Pakete zählt.
          • wendy2702W wendy2702
            @mcwoolf
            McWoolfM Offline
            McWoolfM Offline
            McWoolf
            @wendy2702
            GLG Wolfi
            Configuration:
            RAM: 8 GB
            Node.js: 18.19.0
            NPM: 10.2.3
            • McWoolfM McWoolf
              @wendy2702
              wendy2702W Online
              wendy2702W Online
              @mcwoolf Haken bei "Direkte ...." raus.
              Als Test Register mal Spannung oder Temperatur nehmen.
              Sicher das es ein Holding Register und kein Input Register ist?
              Stimmt die ID 2 mit dem was im WR steht überein?
                McWoolfM Offline
                McWoolfM Offline
                McWoolf
                @wendy2702
                Sowas z.B. ?
                GLG Wolfi
                Configuration:
                RAM: 8 GB
                Node.js: 18.19.0
                NPM: 10.2.3
                • McWoolfM McWoolf
                  @wendy2702
                  Sowas z.B. ?
                  wendy2702W Online
                  wendy2702W Online
                  @mcwoolf Ja.
                  unter Eingangsregister als 16bit, denke auch little endian wobei mit bei der Register Adresse die 0 etwas wundert.
                    @mcwoolf Ja.
                    McWoolfM Offline
                    McWoolfM Offline
                    McWoolf
                    @wendy2702
                    Das ist die offizielle Beschreibung
                    GLG Wolfi
                    Configuration:
                    RAM: 8 GB
                    Node.js: 18.19.0
                    NPM: 10.2.3
                    • McWoolfM McWoolf
                      @wendy2702
                      McWoolfM Offline
                      McWoolfM Offline
                      McWoolf
                      @mcwoolf
                      Mit Hilfe von @klassisch habe ich endlich eine Verbindung herstellen können. Hier die Einstellungen:
                      8e52a5e2-db3c-4d3e-a174-271866743aae-image.png d028ffb4-f543-410a-b472-cdbc40b135d4-image.png
                      GLG Wolfi
                      Configuration:
                      RAM: 8 GB
                      Node.js: 18.19.0
                      NPM: 10.2.3
                      • McWoolfM McWoolf
                        @mcwoolf
                        wendy2702W Online
                        wendy2702W Online
                        @mcwoolf habt ihr das per Chat gemacht oder gibt es einen weiteren thread?
                          McWoolfM Offline
                          McWoolfM Offline
                          McWoolf
                          @wendy2702 Er hat mir per chat geholfen.
                          Aber ich bekomme noch keine passenden Daten, ich komme mit den Registern noch nicht klar
                          GLG Wolfi
                          Configuration:
                          RAM: 8 GB
                          Node.js: 18.19.0
                          NPM: 10.2.3
                          • McWoolfM McWoolf
                            McWoolfM Offline
                            McWoolfM Offline
                            McWoolf
                            @mcwoolf Ich muss leider alles revidieren, der USR-TCP232-304 kann kein RTU!!!!
                            Kein wunder dass ich keine Daten bekomme.
                            GLG Wolfi
                            Configuration:
                            RAM: 8 GB
                            Node.js: 18.19.0
                            NPM: 10.2.3
                            wendy2702W K 2 Antworten Letzte Antwort
                            • McWoolfM McWoolf
                              wendy2702W Online
                              wendy2702W Online
                              @mcwoolf OK.
                              Vielleicht ist das was für dich.
                              https://eckstein-shop.de/WaveShare-Industrial-Serial-Server-with-POE
                              Gibt es für einen euro weniger auch ohne POE. Den verwende ich und ich glaube @klassisch auch.
                                @mcwoolf OK.
                                McWoolfM Offline
                                McWoolfM Offline
                                McWoolf
                                schrieb am zuletzt editiert von McWoolf
                                @wendy2702
                                So nun habe ich den PE11 der sollte RTU beherrschen.
                                Naja was soll ich sagen, bekomme dennoch keine Daten.
                                Verbindung habe ich aber nur, wenn PE11 und iobroker auf Server eingestellt werden, was mich ein wenig irretiert, es heißt ja, bei modbus gibt es Server und Clients?? Oder verstehe ich hier auch was falsch?
                                2023-01-20 08:01:39.317 - error: modbus.0 (21212) Error response: ff
                                2023-01-20 08:01:40.369 - error: modbus.0 (21212) Error response: 5f
                                2023-01-20 08:01:41.469 - error: modbus.0 (21212) Error response: ff
                                2023-01-20 08:01:42.568 - error: modbus.0 (21212) Error response: ff
                                2023-01-20 08:01:43.617 - error: modbus.0 (21212) Error response: ff
                                2023-01-20 08:01:44.667 - error: modbus.0 (21212) unknown function code: 0x7e, 0xd5
                                2023-01-20 08:01:45.666 - error: modbus.0 (21212) Error response: ff
                                2023-01-20 08:01:46.715 - error: modbus.0 (21212) unknown function code: 0x7e, 0xd5
                                2023-01-20 08:01:47.713 - error: modbus.0 (21212) Error response: ff
                                2023-01-20 08:01:48.765 - error: modbus.0 (21212) Error response: 7e
                                2023-01-20 08:01:49.748 - error: modbus.0 (21212) Error response: ff
                                2023-01-20 08:01:50.797 - error: modbus.0 (21212) Error response: f2
                                2023-01-20 08:01:51.797 - error: modbus.0 (21212) unknown function code: 0x5f, 0xfd
                                2023-01-20 08:01:52.872 - error: modbus.0 (21212) Error response: ff
                                2023-01-20 08:01:54.023 - error: modbus.0 (21212) Error response: ff
                                2023-01-20 08:01:55.071 - error: modbus.0 (21212) Error response: ff
                                2023-01-20 08:01:56.120 - error: modbus.0 (21212) Error response: 7e
                                2023-01-20 08:01:57.120 - error: modbus.0 (21212) Error response: ff
                                2023-01-20 08:01:58.142 - error: modbus.0 (21212) Error response: ff
                                Kann mir jemand verraten was das hier zu bedeuten hat??
                                GLG Wolfi
                                Configuration:
                                RAM: 8 GB
                                Node.js: 18.19.0
                                NPM: 10.2.3
                                • wendy2702W Online
                                  wendy2702W Online
                                  PE11
                                  Das Gerät kenne ich nicht. Aber zweimal Server ist eigentlich falsch.
                                  Man hat immer einen Server und mindestens einen Client.
                                    PE11
                                    McWoolfM Offline
                                    McWoolfM Offline
                                    McWoolf
                                    @wendy2702
                                    Ja das denke ich auch, aber anders bekomme ich keine Verbindung.
                                    GLG Wolfi
                                    Configuration:
                                    RAM: 8 GB
                                    Node.js: 18.19.0
                                    NPM: 10.2.3
                                    • McWoolfM McWoolf
                                      @wendy2702
                                      wendy2702W Online
                                      wendy2702W Online
                                      @mcwoolf Mit dem Device kann ich dir leider nicht helfen.
                                      Sorry
                                        Sorry
                                        McWoolfM Offline
                                        McWoolfM Offline
                                        McWoolf
                                        @wendy2702
                                        Die Verbindung ist auch nicht wirklich mehr das Problem, nur eben dass ich keine Daten aus dem Solax raus bekommen. Sobald ich ein Eingangsregister in den Modbus-Adapter eintrage, kommen diese Meldungen. s.O.
                                        GLG Wolfi
                                        Configuration:
                                        RAM: 8 GB
                                        Node.js: 18.19.0
                                        NPM: 10.2.3
                                        • McWoolfM McWoolf
                                          @wendy2702
                                          wendy2702W Online
                                          wendy2702W Online
                                          @mcwoolf Kannst du mal im Adapter auf TCP stellen. Die Umsetzung RTU --> TCP sollte doch das Gateway schon machen.
