  3. Einsteigerfragen
  4. Installation
  5. BackItUp Copy auf USB-Stick
Geplant Angeheftet Gesperrt Verschoben Installation
37 Beiträge 6 Kommentatoren 6.6k Aufrufe 4 Beobachtet
    TT-Tom
    ich habe das Problem beim erstellen der Backups, das sie nicht auf den USB-Stick kopiert werden. Es ist ein 16GB Stick, ich binde in mit diesem Befehl ein.
    sudo mount /dev/sda1 /mnt/sda1
    sudo mount
    /dev/sda1 on /mnt/sda1 type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
    Das sind die Einstellungen im Adapter
    [DEBUG] [iobroker] - host.IoBroker 2528 states saved
    [DEBUG] [iobroker] - host.IoBroker 2894 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_03_14-09_57_22_IOBrocker_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [historyDB] - compress from historyDB started ...
    [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2022_03_14-09_57_29_IOBrocker_backupiobroker.tar.gz
    [DEBUG] [historyDB] - done
    [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - found Script: ical_Umwandlung
    [DEBUG] [javascripts] - found Script: Kelvin_in_Grad
    [DEBUG] [javascripts] - found Script: WMA_fertig
    [DEBUG] [javascripts] - found Script: test_WMA
    [DEBUG] [javascripts] - found Script: alias_mit_funktion_erzeugen
    [DEBUG] [javascripts] - found Script: Füllstand
    [DEBUG] [javascripts] - found Script: Convert_RGB_HUE
    [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_03_14-09_57_31_IOBrocker_backupiobroker.tar.gz
    [DEBUG] [javascripts] - done
    [DEBUG] [yahka] - found yahka database: yahka.0,yahka.1
    [DEBUG] [yahka] - done
    [DEBUG] [cifs] - Copy iobroker_2022_03_14-09_57_22_IOBrocker_backupiobroker.tar.gz...
    [ERROR] [cifs] - Error: EACCES: permission denied, open '/mnt/sda1/iobroker_2022_03_14-09_57_22_IOBrocker_backupiobroker.tar.gz'
    [DEBUG] [cifs] - Copy historyDB_2022_03_14-09_57_29_IOBrocker_backupiobroker.tar.gz...
    [ERROR] [cifs] - Error: EACCES: permission denied, open '/mnt/sda1/historyDB_2022_03_14-09_57_29_IOBrocker_backupiobroker.tar.gz'
    [DEBUG] [cifs] - Copy javascripts_2022_03_14-09_57_31_IOBrocker_backupiobroker.tar.gz...
    [ERROR] [cifs] - Error: EACCES: permission denied, open '/mnt/sda1/javascripts_2022_03_14-09_57_31_IOBrocker_backupiobroker.tar.gz'
    [DEBUG] [cifs] - Copy yahka.0_2022_03_14-09_57_31_IOBrocker_backupiobroker.tar.gz...
    [ERROR] [cifs] - Error: EACCES: permission denied, open '/mnt/sda1/yahka.0_2022_03_14-09_57_31_IOBrocker_backupiobroker.tar.gz'
    [DEBUG] [cifs] - Copy yahka.1_2022_03_14-09_57_31_IOBrocker_backupiobroker.tar.gz...
    [ERROR] [cifs] - Error: EACCES: permission denied, open '/mnt/sda1/yahka.1_2022_03_14-09_57_31_IOBrocker_backupiobroker.tar.gz'
    [DEBUG] [cifs] - done
    [DEBUG] [cifs] start with {"mountType":"Copy","type":"storage","source":"cifs","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/sda1","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false,"deleteBackupAfter":0}
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    Wenn ich das Log richtig lese sind es Rechteprobleme. CiFS habe ich geprüft, es ist aktuell. Binde ich den Stick falsch ein oder wo ist mein Fehler?
    Danke für eure Hilfe
    Gruß Tom
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    J 1 Antwort Letzte Antwort
    • T TT-Tom
      sudo mount
      Gruß Tom
      Jan1
      @tt-tom
      Du hast doch NAS als Speicherort gewählt.
      • J Jan1
        @tt-tom
        TT-Tom
        @jan1 damit ich den Reiter "NAS / Kopieren" bekomme und dort auf Verbindungstyp "Copy" stellen kann. Gibt es denn eine andere Einstellung zum Sichern auf andere Medien?
        Gruß Tom
        Public Transport
        J Thomas BraunT 2 Antworten Letzte Antwort
        • T TT-Tom
          Jan1
          @tt-tom
          Na wenn Du nur auf USB sichern möchtest, dann nimm doch FTP.
          Ich bin mir hier selber nicht sicher, aber ich denke, das bezieht sich dann doch auf die Art, wie das Backup auf das NAS kommt.
          Du willst schlicht ne Kopie des Backup auf dem Stick haben und das würde ich dann auch mit FTP machen. Normal wird der Stick auch automatisch gemountet und Du gibst schlicht den Pfad dorthin an.
          • T TT-Tom
            @tt-tom
            Copy legt Backups immer in /opt/iobroker/backups ab, der Pfad zum Mountpunkt bleibt dann leer.
            Die Backups müsstest du dann von Hand / oder einem separaten Skript dann auf den gemounteten Stick schieben.
            • J Jan1
              @tt-tom
              @jan1 sagte in BackItUp Copy auf USB-Stick:
              FTP auf das eigene Medium??
              neee, dirket das Backup darauf
                Jan1
                OK, stimmt auch auch wieder, ist ja nix im Netz, wobei das sogar geht LOL
                  @tt-tom
                  TT-Tom
                  @thomas-braun sagte in BackItUp Copy auf USB-Stick:
                  @tt-tom
                  Das die in diesem Verzeichnis angelegt werden, kann ich im Log nachvollziehen und dann sollen sie kopiert werden. Siehe Zeile 25 -35 im Log und da kommen Fehlermeldungen, wegen Rechte. Ich vermute das ich den Stick nicht richtig einbinde, aber wie ist richtig?
                  Gruß Tom
                  Public Transport
                  • T TT-Tom
                    @tt-tom
                    @tt-tom
                    Das läuft aber falsch. Nicht per cifs, da läuft ja kein SMB-Server.
                    Ein Umkopieren als Dateioperation vom Backup-Verzeichnis auf den USB-Stick ist nicht im Adapter vorgesehen.
                    T HomoranH 2 Antworten Letzte Antwort
                      @tt-tom
                      TT-Tom
                      Ah, alles klar. Kann ich den Stick dann direkt auf /opt/iobroker/backups mounten?
                      Gruß Tom
                      Public Transport
                        @tt-tom
                        ich habe gerade mal bei mir gesucht, aber nichts gefunden.
                        kann man den gar nicht den "normalen" Speicherpfad eingeben?
                        oder per mount auslagern?
                        • T TT-Tom
                          @tt-tom
                          Ja. Aber ich würde da kein vfat einhängen. Das kann keine Datei-Attribute von ext4 verwalten.
                            @tt-tom
                            TT-Tom
                            @tt-tom
                            okay, dann werde ich ihn ext4 formatieren und neu einbinden. danke bis hier
                            Tom
                            Gruß Tom
                            Public Transport
                            • T TT-Tom
                              @tt-tom
                              Tom
                              TT-Tom
                              @tt-tom sagte in BackItUp Copy auf USB-Stick:
                              funktioniert jetzt, danke nochmal an alle.
                              Gruß Tom
                              Public Transport
                                @homoran sagte in BackItUp Copy auf USB-Stick:
                                Soweit ich weiß nicht. Du kannst natürlich /opt/iobroker/backups als mountpunkt verwenden. Macht @TT-Tom ja jetzt offenbar.
                                  TT-Tom
                                  nach dem "mount" muss "iobroker fix" durchgeführt werden, damit die Rechte auf backups wieder stimmen.
                                  Gruß Tom
                                  Gruß Tom
                                  Public Transport
                                  • T TT-Tom
                                    Gruß Tom
                                    @tt-tom
                                    Nicht wenn gleich mit den richtigen Rechten gemounted wird.
                                      @tt-tom
                                      TT-Tom
                                      wie müsste der Befehl dann aussehen?
                                      Gruß Tom
                                      Public Transport
                                      • T TT-Tom
                                        @tt-tom
                                        Gegenfrage:
                                        Wie sieht er denn jetzt aus?
                                          @tt-tom
                                          Gegenfrage:
                                          TT-Tom
                                          sudo mount /dev/sda1 /opt/iobroker/backups
                                          Gruß Tom
                                          Public Transport
