  4. [gelöst] Min /Max Temperatursensor
43 Beiträge 12 Kommentatoren 15.6k Aufrufe 1 Beobachtet
  • F Offline
    Farmer-cb
    Servus
    function GetResults (dpoint) {
      var end_time = new Date().getTime();
      var start_time = new Date().getTime() - dt;
      log('startzeit: '+start_time);
      log('endzeit: '+end_time);
      log(JSON.stringify(dpoint.result));
      log('id: '+dpoint.result[0].name);
      //log(JSON.stringify(dpoint.result)+'//'+start_time);
      //log(dpoint.result[0].id + '---//---' + dpoint.result[0].name);
      sendTo('sql.0', 'query', 'SELECT Round(Min(val),1) As MinVal FROM ts_number WHERE ts >= ' + start_time + ' AND id=' + dpoint.result[0].id + ' GROUP BY id',minimum);
      sendTo('sql.0', 'query', 'SELECT Round(Max(val),1) As MaxVal FROM ts_number WHERE ts >= ' + start_time + ' AND id=' + dpoint.result[0].id + ' GROUP BY id',maximum);
    00:05:04.263	[info]	javascript.0 Stop script script.js.common.minmax.Aussentemp
    00:05:04.301	[info]	javascript.0 Start javascript script.js.common.minmax.Aussentemp
    00:05:04.301	[info]	javascript.0 script.js.common.minmax.Aussentemp: schedule(cron=*/5 * * * *)
    00:05:04.308	[info]	javascript.0 script.js.common.minmax.Aussentemp: 1 Name: s7.0.DBs.DB100.Aussentemp
    00:05:04.308	[info]	javascript.0 script.js.common.minmax.Aussentemp: sendTo(adapter=sql.0, cmd=query, msg="SELECT id as id FROM datapoints WHERE name = 's7.0.DBs.DB100.Aussentemp'")
    00:05:04.309	[info]	javascript.0 script.js.common.minmax.Aussentemp: registered 0 subscriptions and 1 schedule
    00:05:04.320	[info]	javascript.0 script.js.common.minmax.Aussentemp: startzeit: 1514847904311
    00:05:04.320	[info]	javascript.0 script.js.common.minmax.Aussentemp: endzeit: 1514934304311
    00:05:04.321	[info]	javascript.0 script.js.common.minmax.Aussentemp: undefined
    00:05:04.321	[error]	javascript.0 TypeError: Cannot read property '0' of undefined at Object.GetResults [as cb] (script.js.common.minmax.Aussentemp:42:27) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3151:71) at RedisClient. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:104:25) at emitThree (events.js:116:13) at RedisClient.emit (events.js:194:7) at return_pub_sub (/opt/iobroker/node_modules/redis/index.js:794:18) at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:833:9) at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18) at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12) at Socket. (/opt/iobroker/node_modules/redis/index.js:274:27)
    smartes Haus durch Digitalstrom, enocean, SPS S7-1215, Homematik, Shelly, Alexa, iobroker auf einem HP-mini mit Proxmox
    • ThisoftT Offline
      ThisoftT Offline
      Thisoft
      Dat Ding wehrt sich aber auch - müssen wir uns rantasten… Ändere mal bitte das Codestück wie folgt:
      function SQLAbfrage (id) {
        sendTo('sql.0', 'query', 'SELECT id, name FROM datapoints WHERE name = \'' + id + '\'', function(result){
          log(JSON.stringify(result));
          //GetResults(result);
      • F Offline
        Farmer-cb
        ergebnis
        08:51:29.085	[info]	javascript.0 Stop script script.js.common.minmax.Aussentemp
        08:51:29.128	[info]	javascript.0 Start javascript script.js.common.minmax.Aussentemp
        08:51:29.129	[info]	javascript.0 script.js.common.minmax.Aussentemp: schedule(cron=*/5 * * * *)
        08:51:29.130	[info]	javascript.0 script.js.common.minmax.Aussentemp: sendTo(adapter=sql.0, cmd=query, msg="SELECT id, name FROM datapoints WHERE name = 's7.0.DBs.DB100.Aussentemp'")
        08:51:29.131	[info]	javascript.0 script.js.common.minmax.Aussentemp: registered 0 subscriptions and 1 schedule
        08:51:29.167	[info]	javascript.0 script.js.common.minmax.Aussentemp: {"error":"Error: ER_NO_DB_ERROR: No database selected"}
        mir kommt es so vor, als ob die weitergabe des Ergebnisses nicht funktioniert
        • ThisoftT Offline
          ThisoftT Offline
          Thisoft
          Natürlich wird das Ergebnis jetzt nicht weitergegeben - hab ich ja auskommentiert ;)
          Und der springende Punkt ist:
          Jetzt wo ich nochmal auf deine Screenshots schaue fällt es mir auch wie Schuppen aus den Haaren ;)
          Du hast ja gar keinen SQL-Adapter sondern nur die History aktiviert! (Hatte ich auch weiter vorn schon mal danach gefragt…)
          Dann wird das so nix. Kann ich dir aber auch aus dem Stegreif nicht weiterhelfen. History habe und hatte ich nie im Einsatz. Evtl. kann ich heute abend mal schauen was man da umbauen müsste...
          • F Offline
            Farmer-cb
            Mahlzeit
            ich hab doch SQL aktiv!!
            oder versteh ich da was falsch
            • ThisoftT Offline
              ThisoftT Offline
              Thisoft
              Na Prost Mahlzeit ;)
              stimmt auch wieder - du hast ja beides installiert. Jetzt weiß ich aber auf Anhieb aus der Ferne auch nicht mehr zu raten…
              Die Fehlermeldung sagt aber relativ deutlich dass der sendTo-Befehl auf den Adapter "SQL.0" keine Datenbank zuordnen kann :!: :?: :?
              Bekommst du denn Werte angezeigt wenn du im Historien-Fenster auf Tabelle oder Grafik gehst?
              Ansonsten vielleicht mal noch das LogLevel des SQL-Adapters auf "Debug" stellen und schauen ob da beim Ausführen des Scripts noch was aussagekräftiges geloggt wird.
              • F Offline
                Farmer-cb
                da kommt auch nicht mehr raus:
                javascript.0	2018-01-03 15:00:00.226	info	script.js.common.minmax.Aussentemp: {"error":"Error: ER_NO_DB_ERROR: No database selected"}
                javascript.0	2018-01-03 15:00:00.158	info	script.js.common.minmax.Aussentemp: sendTo(adapter=sql.0, cmd=query, msg="SELECT id, name FROM datapoints WHERE name = 's7.0.DBs.DB100.Aussentemp'")
                javascript.0	2018-01-03 14:55:00.184	info	script.js.common.minmax.Aussentemp: {"error":"Error: ER_NO_DB_ERROR: No database selected"}
                javascript.0	2018-01-03 14:55:00.157	info	script.js.common.minmax.Aussentemp: sendTo(adapter=sql.0, cmd=query, msg="SELECT id, name FROM datapoints WHERE name = 's7.0.DBs.DB100.Aussentemp'")
                javascript.0	2018-01-03 14:50:00.221	info	script.js.common.minmax.Aussentemp: {"error":"Error: ER_NO_DB_ERROR: No database selected"}
                javascript.0	2018-01-03 14:50:00.158	info	script.js.common.minmax.Aussentemp: sendTo(adapter=sql.0, cmd=query, msg="SELECT id, name FROM datapoints WHERE name = 's7.0.DBs.DB100.Aussentemp'")
                in der Tabelle steht etwas
                • ThisoftT Offline
                  ThisoftT Offline
                  Thisoft
                  Zeigst Du bitte mal die Einstellungen deines SQL-Adapters?
                  • H Offline
                    Haus
                    @Farmer-cb:
                    sql.gif `
                    sendTo('sql.0', 'query', 'SELECT id, name FROM iobroker.datapoints WHERE nam…....
                    js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
                    admin: 3.6.0
                    javascript: 4.1.10
                    web: 2.4.1 vis: 1.1.10
                    cloud: 2.6.2
                    Server: DELL FX170 / linux: Debian 9.5 Stretch
                    Adapter: MegaD-2561, Mega-ES…
                    • ThisoftT Offline
                      ThisoftT Offline
                      Thisoft
                      @Haus:
                      sendTo('sql.0', 'query', 'SELECT id, name FROM iobroker.datapoints WHERE nam….... `
                      JA, das wäre einen Versuch wert. Unter anderem deshalb hatte ich ja (bisher erfolglos ;) ) gefragt welche Db denn der TE im Einsatz hat…
                        mctom
                        jetzt häng ich mich auch noch mal dran…
                        folgenden Code habe ich jetzt als Test im Einsatz:
                        function SQLAbfrage () {
                        log(id);
                          sendTo('sql.0', 'query', 'SELECT id, name FROM iobroker.datapoints WHERE name = \'' + id + '\'', function(result){
                            // GetResults(result);
                        //  sendTo('sql.0', 'query', 'SELECT * FROM iobroker.datapoints WHERE name = \'' + id + '\'', GetResults);
                        und das kommt im LOG:
                        16:50:00.943	[info]	javascript.1 script.js.Test.Test2: hm-rpc.0.IEQ0023353.1.TEMPERATURE
                        16:50:00.947	[info]	javascript.1 script.js.Test.Test2: {"error":null,"result":[{"id":21,"name":"hm-rpc.0.IEQ0023353.1.TEMPERATURE"}]}
                        Woher kommt der Error?
                        Was mach ich falsch ?
                        Michael
                        • H Offline
                          Haus
                          @mctom:
                          log(id);
                          Michael `
                          createState('Statistik.Luft1.Max24', 0);
                          createState('Statistik.Luft1.Min24', 0);
                          var id = "hm-rpc.0.IEQ0023353.1.TEMPERATURE";
                          var maxid = 'javascript.0.Statistik.Luft1.Max24';
                          var minid = 'javascript.0.Statistik.Luft1.Min24';
                          var dt = 24;//Zeitraum in Stunden
                              dt = dt*3600*1000;
                          schedule("*/5 * * * *", function(){
                              SQLAbfrage(id);
                          SQLAbfrage(id);
                          // maximum, minimum
                          function minimum(result) {
                              ///log(JSON.stringify(result.result));
                              setState(minid, result.result[0].MinVal);
                          function maximum(result) {
                              ///log('Fn Max'+ JSON.stringify(result.result));
                              setState(maxid, result.result[0].MaxVal);
                              ///log(id);
                              ///log(JSON.stringify(dpoint.result)+'//'+start_time);
                              ///log(dpoint.result[0].id + '---//---' + dpoint.result[0].name);
                              sendTo('sql.0', 'query', 'SELECT Round(Min(val),1) As MinVal FROM iobroker.ts_number WHERE ts >= ' + start_time + ' AND id=' + dpoint.result[0].id + ' GROUP BY id',minimum);
                              sendTo('sql.0', 'query', 'SELECT Round(Max(val),1) As MaxVal FROM iobroker.ts_number WHERE ts >= ' + start_time + ' AND id=' + dpoint.result[0].id + ' GROUP BY id',maximum);
                          admin: 3.6.0
                          javascript: 4.1.10
                          cloud: 2.6.2
                          • F Offline
                            Farmer-cb
                            juhu
                            so funktioniert es jetzt
                            var id = "s7.0.DBs.DB100.Aussentemp";
                            //var maxid = 'javascript.0.Statistik.Luft1.Max24';
                            //var minid = 'javascript.0.Statistik.Luft1.Min24';
                            var maxid = "javascript.0.scriptEnabled.common.minmax.Statistik.Aussentemp.max24";/*max24*/
                            var minid = "javascript.0.scriptEnabled.common.minmax.Statistik.Aussentemp.min24";/*min24*/
                              dt = dt*3600*1000;
                            schedule("*/5 * * * *", function(){SQLAbfrage(id);});
                            SQLAbfrage(id);
                            // minimum
                                  log('Fn Min'+JSON.stringify(result.result));
                            // maximum
                                log('Name: '+id);
                            meldung im Log:
                            18:26:27.313	[info]	javascript.0 Stop script script.js.common.minmax.Aussentemp
                            18:26:27.352	[info]	javascript.0 Start javascript script.js.common.minmax.Aussentemp
                            18:26:27.353	[info]	javascript.0 script.js.common.minmax.Aussentemp: schedule(cron=*/5 * * * *)
                            18:26:27.354	[info]	javascript.0 script.js.common.minmax.Aussentemp: Name: s7.0.DBs.DB100.Aussentemp
                            18:26:27.354	[info]	javascript.0 script.js.common.minmax.Aussentemp: sendTo(adapter=sql.0, cmd=query, msg="SELECT * FROM iobroker.datapoints WHERE name = 's7.0.DBs.DB100.Aussentemp'")
                            18:26:27.355	[info]	javascript.0 script.js.common.minmax.Aussentemp: registered 0 subscriptions and 1 schedule
                            18:26:27.472	[info]	javascript.0 script.js.common.minmax.Aussentemp: startzeit: 1514913987450
                            18:26:27.472	[info]	javascript.0 script.js.common.minmax.Aussentemp: endzeit: 1515000387450
                            18:26:27.473	[info]	javascript.0 script.js.common.minmax.Aussentemp: [{"id":11,"name":"s7.0.DBs.DB100.Aussentemp","type":0}]
                            18:26:27.474	[info]	javascript.0 script.js.common.minmax.Aussentemp: id: s7.0.DBs.DB100.Aussentemp
                            18:26:27.475	[info]	javascript.0 script.js.common.minmax.Aussentemp: sendTo(adapter=sql.0, cmd=query, msg="SELECT Round(Min(val),1) As MinVal FROM iobroker.ts_number WHERE ts >= 1514913987450 AND id=11 GROUP BY id")
                            18:26:27.475	[info]	javascript.0 script.js.common.minmax.Aussentemp: sendTo(adapter=sql.0, cmd=query, msg="SELECT Round(Max(val),1) As MaxVal FROM iobroker.ts_number WHERE ts >= 1514913987450 AND id=11 GROUP BY id")
                            18:26:28.007	[info]	javascript.0 script.js.common.minmax.Aussentemp: Fn Max[{"MaxVal":6.2}]
                            18:26:28.008	[info]	javascript.0 script.js.common.minmax.Aussentemp: setForeignState(id=javascript.0.scriptEnabled.common.minmax.Statistik.Aussentemp.max24, state=6.2)
                            18:26:28.029	[info]	javascript.0 script.js.common.minmax.Aussentemp: Fn Min[{"MinVal":1.5}]
                            18:26:28.030	[info]	javascript.0 script.js.common.minmax.Aussentemp: setForeignState(id=javascript.0.scriptEnabled.common.minmax.Statistik.Aussentemp.min24, state=1.5)
                            finde keine error ausgabe, sollte also funzn
                            Vielen Dank bis hierhin schon mal und für die Geduld :D
                            hab jetzt nur noch diese Fehlermeldung in der Log 😢 :
                            admin.0	2018-01-03 18:26:28.047	error	change ID is empty: {"common":{"enabled":1.5},"from":"system.adapter.javascript.0","ts":1515000388026,"_id":null}
                            cloud.0	2018-01-03 18:26:28.037	error	change ID is empty: {"common":{"enabled":1.5},"from":"system.adapter.javascript.0","ts":1515000388026,"_id":null}
                            sql.0	2018-01-03 18:26:28.036	error	change ID is empty: {"common":{"enabled":1.5},"from":"system.adapter.javascript.0","ts":1515000388026,"_id":null}
                            javascript.0	2018-01-03 18:26:28.035	error	change ID is empty: {"common":{"enabled":1.5},"from":"system.adapter.javascript.0","ts":1515000388026,"_id":null}
                            web.0	2018-01-03 18:26:28.033	error	change ID is empty: {"common":{"enabled":1.5},"from":"system.adapter.javascript.0","ts":1515000388026,"_id":null}
                            sql.0	2018-01-03 18:26:28.021	error	change ID is empty: {"common":{"enabled":6.2},"from":"system.adapter.javascript.0","ts":1515000388010,"_id":null}
                            javascript.0	2018-01-03 18:26:28.023	error	change ID is empty: {"common":{"enabled":6.2},"from":"system.adapter.javascript.0","ts":1515000388010,"_id":null}
                            cloud.0	2018-01-03 18:26:28.022	error	change ID is empty: {"common":{"enabled":6.2},"from":"system.adapter.javascript.0","ts":1515000388010,"_id":null}
                            web.0	2018-01-03 18:26:28.018	error	change ID is empty: {"common":{"enabled":6.2},"from":"system.adapter.javascript.0","ts":1515000388010,"_id":null}
                            die Werte stehen aber im Datenpunkt
                            mach ich da noch etwas verkehrt
                            hab die error-meldungen mal in ein eigenen Thread gesetzt
                            http://forum.iobroker.net/viewtopic.php?f=8&t=10313
                              der_Auge
                              super
                              nun habe ich es verstanden.
                              der Datenbankname der im Adapter hinterlegt wurde muss mit angegeben werden.
                              // ----- Abfragen von Werten aus der Datenbank (SQL) ---------------------------
                              // ----- Datenpunkt der ausgelesen werden soll ---------------------------------
                              var id = "javascript.0.eBus.Temperatur.FlowTemp"/*Vorlauf */;
                              // ----- Datenpunkte in die gespeichert werden soll ----------------------------
                              var maxid = 'javascript.0.Statistik.FlowTemp.Max24';
                              var minid = 'javascript.0.Statistik.FlowTemp.Min24';
                              var dt = 24;                // Zeitraum in Stunden
                                 dt = dt*3600*1000;      // Zeitraum umrechnen in ??
                              // ----- Datenpunkte anlegen ---------------------------------------------------
                              createState(maxid, " ");
                              createState(minid, " ");
                              log('1\. ) Datenpunkte angelegt ');
                              SQLAbfrage(id);
                              //-----  SQL-Abfrage durchführen
                                 log('2\. ) Datenpunkt => ' + id);
                                 log('2a.) Abfrage    => SELECT * FROM datapoints WHERE name = \'' + id + '\'');
                                 sendTo('sql.0', 'query', 'SELECT * FROM ioBmaster.datapoints WHERE name = \'' + id + '\'', GetResults);
                                 log('3\. ) Funktion -> GetResults aufrufen');
                                 log('3a.) Startzeit : ' + start_time);
                                 log('3b.) Endzeit   : ' + end_time);
                                 log('     Datenpunkt: ' + dpoint.result);
                                 log('3c.) result    : ' + JSON.stringify(dpoint.result) + ' -//- ' + start_time);
                                 log('     Datenpunkt: ' + dpoint.result[0].id + ' ---//--- ' + dpoint.result[0].name);
                                 sendTo('sql.0', 'query', 'SELECT Round(Min(val),1) As MinVal FROM ioBmaster.ts_number WHERE ts >= ' + start_time + ' AND id=' + dpoint.result[0].id + ' GROUP BY id',minimum);
                                 sendTo('sql.0', 'query', 'SELECT Round(Max(val),1) As MaxVal FROM ioBmaster.ts_number WHERE ts >= ' + start_time + ' AND id=' + dpoint.result[0].id + ' GROUP BY id',maximum);
                              //-----  Werte schreiben (maximum, minimum)
                              //-----  minimum
                               log('min )Funktion -> ' + JSON.stringify(result.result));
                              //-----  maximum
                                 log('max )Funktion -> ' + JSON.stringify(result.result));
                                 log('---- fertig -----------------------------------------');
                              // ----- Funktion jede Minute aufrufen
                              schedule("*/1 * * * *", function(){SQLAbfrage(id);});
                              Nun kann ich weiter versuchen die Tages, Wochen, Jahres-Werte aus der Datenbank abzufragen
                              Jürgen
                              Master: DN2820FYKH (4GB) Linux NUC 4.4.0-22-generic #40-Ubuntu x86_64
                              Slave: Linux RPi2-1 4.1.19-v7+ #858 v4.4.3 # 2.15.1
                              SQL-DB : Linux DS 3.10.77 #7321 x86_64 synology412+
                              Test : DS916+ VM Debian
                              Test : Tinker mit piVCCU
                              • ThisoftT Offline
                                ThisoftT Offline
                                Thisoft
                                @der_Auge:
                                der Datenbankname der im Adapter hinterlegt wurde muss mit angegeben werden. `
                                Könnt Ihr mir bitte noch verraten welche Db ihr verwendet? Bei meiner (MSSQL) darf ich den nämlich nicht mit angeben sonst sagt er mir die Tabelle sei unbekannt.
                                  der_Auge
                                  @Thisoft:
                                  @der_Auge:
                                  Könnt Ihr mir bitte noch verraten welche Db ihr verwendet? Bei meiner (MSSQL) darf ich den nämlich nicht mit angeben sonst sagt er mir die Tabelle sei unbekannt. `
                                  • F Offline
                                    Farmer-cb
                                    Mahlzeit
                                    ich nutze mysql, da gehts
                                    • Q Offline
                                      Q Offline
                                      Qlink
                                      @der_Auge:
                                      Jürgen `
                                      Hi Jürgen,
                                      könntest du dein Script hier reinstellen, sobald du es um die Tages, Wochen und Jahres Werte erweitert hast ?
                                      Das wäre toll.
                                      Beste Grüße
                                        der_Auge
                                        @Qlink:
                                        @der_Auge:
                                        Jürgen `
                                        Hi Jürgen,
                                        Das wäre toll.
                                        Beste Grüße `
                                        Das werde ich machen.
                                        Habe aber bereits festgestellt, das es nicht so einfach ist mit den SQL Befehlen.
                                        sendTo('sql.0', 'query', 'SELECT * As MinVal FROM ioBmaster.ts_number WHERE ts >= ' + start_time + ' AND id=' + dpoint.result[0].id + ' GROUP BY id',minimum);
                                        sendTo('sql.0', 'query', 'SELECT * As MaxVal FROM ioBmaster.ts_number WHERE ts >= ' + start_time + ' AND id=' + dpoint.result[0].id + ' GROUP BY id',maximum);
                                        Hiermit muss ich ja die Werte "von" / "bis" abfragen
                                        Vielleicht hat ja jemand eine Idee?
                                        Werde es aber weiter versuchen.
                                        Jürgen
                                        • ThisoftT Offline
                                          ThisoftT Offline
                                          Thisoft
                                          Tja, also im SQL ist's eigentlich einfach:
                                          sendTo('sql.0', 'query', 'SELECT * As MinVal FROM ioBmaster.ts_number WHERE ts >= ' + start_time + ' AND ts <= ' + end_time + ' AND id=' + dpoint.result[0].id + ' GROUP BY id',minimum);
                                          Du mußt dann nur die beiden Variablen "start_time" und "end_time" vorher korrekt befüllen.
