  4. [Frage] Internetradio - wie geht das ?
    5.3k
107 Beiträge 22 Kommentatoren 39.3k Aufrufe 12 Beobachtet
  • a200A a200
    @Jey-Cee Das stimmt!
    2019-06-14 20:11:41.891  - warn: upnp.0 Unexpected answer from upnp service:
    "statusCode":500,
    "body":"<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Body>\n<s:Fault>\n<faultcode>s:Client</faultcode>\n<faultstring>UPnPError</faultstring>\n<detail>\n<UPnPError xmlns=\"urn:schemas-upnp-org:control-1-0\">\n<errorCode>402</errorCode>\n<errorDescription>Missing InstanceID</errorDescription>\n</UPnPError>\n</detail>\n</s:Fault>\n</s:Body>\n</s:Envelope>\n",
    "headers":{
    	"content-length":"416",
    	"content-type":"text/xml;charset=\"utf-8\"",
    	"date":"Fri, 14 Jun 2019 18:11:42 GMT",
    	"ext":"",
    	"server":"Linux/2.6.36+, UPnP/1.0, Portable SDK for UPnP devices/1.6.17"},
    	"request":{
    		"uri":{
    			"protocol":"http:",
    			"slashes":true,
    			"auth":null,
    			"host":"192.168.10.121:49152",
    			"port":"49152",
    			"hostname":"192.168.10.121",
    			"hash":null,
    			"search":null,
    			"query":null,
    			"pathname":"/upnp/control/rendercontrol1",
    			"path":"/upnp/control/rendercontrol1",
    			"href":"http://192.168.10.121:49152/upnp/control/rendercontrol1"},
    			"method":"POST",
    			"headers":{
    				"Content-Type":"text/xml; charset=\"utf-8\"",
    				"SOAPAction":"\"urn:schemas-upnp-org:service:RenderingControl:1#SetVolume\"",
    				"USER-AGENT":"UPnP/1.0, ioBroker.upnp",
    				"content-length":246
    	Sent message: {
    		"uri":"http://192.168.10.121:49152/upnp/control/rendercontrol1",
    		"headers":{
    		"method":"POST",
    		"body":"\n<s:Envelope s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\" xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\">\n    <s:Body><u:SetVolume xmlns:u=\"urn:schemas-upnp-org:service:RenderingControl:1\"></u:SetVolume></s:Body>\n</s:Envelope>"
    hmm, "Missing InstanceID" aber die ist gesetzt...
    abgesehen von der Warnung:
    warn: javascript.0 Wrong type of upnp.0.WS300_664C.MediaRenderer.RenderingControl.SetVolume.InstanceID: "number". Please fix, while deprecated and will not work in next versions.
    Jey CeeJ Online
    Jey CeeJ Online
    Jey Cee
    #81
    @a200 die instanceID wird nicht mit gesendet und da liegt das Problem. Das ist wohl ein Resultat daraus dass das Objekt number sein müsste, aber string oder was anderes ist.
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
    a200A 1 Antwort Letzte Antwort
    • Jey CeeJ Jey Cee
      a200A Offline
      a200A Offline
      a200
      schrieb am zuletzt editiert von a200
      #82
      @Jey-Cee
      1. Die Datenpunkte:
        "upnp.0.WS300_664C.MediaRenderer.RenderingControl.SetVolume.InstanceID",
        "upnp.0.WS300_664C.MediaRenderer.RenderingControl.SetVolume.Channel",
        "upnp.0.WS300_664C.MediaRenderer.RenderingControl.SetVolume.DesiredVolume"
      sind alle vom typ string.
      aber sowohl die übergabe von int, auch als string funktionieren nicht.
      setState("upnp.0.WS300_664C.MediaRenderer.RenderingControl.SetVolume.InstanceID", "0");
      setState("upnp.0.WS300_664C.MediaRenderer.RenderingControl.SetVolume.Channel", "Master");
      setState("upnp.0.WS300_664C.MediaRenderer.RenderingControl.SetVolume.DesiredVolume", "58");
      setState("upnp.0.WS300_664C.MediaRenderer.RenderingControl.SetVolume.request", true);
      setState("upnp.0.WS300_664C.MediaRenderer.RenderingControl.SetVolume.InstanceID", 0);
      setState("upnp.0.WS300_664C.MediaRenderer.RenderingControl.SetVolume.DesiredVolume", 58);
      Irgendwo in der InstanceID muss ein Unterschied zwischen den Versionen <1 und >1 geben.
      Die Fehlemeldung ist immer die gleiche: "Missing InstanceID"
      • a200A a200
        @Jey Cee - Vielen Dank für den Adapter. Damit steuere ich meinen WLAN-Lautsprecher (August WS300) an.
        Habe dein Skript auf meine Bedürfnisse leicht angepasst. Aber Senderwahl, start, stop, pause, mute, lauter und leiser funktioniert bestens. Leider werden keine Status-Infos von meiner Box gesetzt, so dass ich darüber hinaus nicht viel machen kann.
        Super Arbeit. Danke!
        s200.
        Mein Menu ist noch nicht fertig. :roll:
        Meine Änderungen:
        • Wird ein Sender angeklickt, dann wird dieser automatisch abgespielt.
        • Leuter/Leiser geht nur im Bereich zwischen 0 und 100.
        SegwayS Offline
        SegwayS Offline
        Segway
        #83
        @a200 sagte in [Frage] Internetradio - wie geht das ?:
        s200.
        Meine Änderungen:
        Hi @a200
        Suche genau diese Anwendung.
        Wie hast du deinen WLan Lautsprecher angesteuert --> das geht schon bei mir. Ich brauche nur die richtigen Widgets für
        Laut / Leiser
        Stream Urls !
        Was nimmst du da ?
        Gruß Dirk
        • bahnuhrB bahnuhr
          MOD-Edit by eric2905; 12.05.2017 / 10;55; Betreff geändert
          ich möchte eine view erstellen wo ich Internetradiosender auswählen kann und dann am tablet hören kann.
          Dazu noch einen slider um die lautstärke zu verhindern.
          Soviel zum Wunsch.
          Nur wie realisiere ich das.
          Gefunden habe ich adapter wie "kodi" als auch "foobar".
          Nur wie funktionieren diese.
          Wie und wo werden da die Internetradio links eingestellt, etc.
          Könnt ihr mir mal schreiben wie das funktioniert bzw. einen link wo das genauer beschrieben steht.
          Die ? mit dem russischen Text; damit komm ich nicht weiter.
          mfg
          Dieter
          MaxxJ
          schrieb am zuletzt editiert von MaxxJ
          #84
          Online radio is either pre-recorded MP3 files or live, via-a-microphone broadcasts that are streamed over the Internet. ... The listener, because without listeners there really isn't any point in broadcasting. The listener connects to your server and can hear anything you're streaming.
          https://quickpaymydoctor.com/
          • SegwayS Segway
            s200.
            Meine Änderungen:
            Hi @a200
            Laut / Leiser
            Stream Urls !
            Was nimmst du da ?
            a200A Offline
            a200A Offline
            a200
            #85
            @Segway ich habe folgendes Skript am Laufen:
            var device = "upnp.0.WS300_664C"; //Hier das upnp Gerät eintragen das gesteuert werden soll.
            var control = 'javascript.0.Tab2'; //Hier das Objekt eintragen wo die Steuerobjekte angelegt werden sollen
            var oldVol;
            var outURL;
            var newVol;
            var debug = true;
            // Array mit mp3-Streams
            var sender = ["https://wdr-1live-live.icecastssl.wdr.de/wdr/1live/live/mp3/128/stream.mp3",
                "http://mp3.ffh.de/radioffh/hqlivestream.mp3",
                "http://swr-swr3-live.cast.addradio.de/swr/swr3/live/mp3/128/stream.mp3",
                "http://109.199.61.243:80/4784/live.mp3",
                "http://mp3.ffh.de/ffhchannels/hq80er.mp3",
                "https://stream.rockland.de/rockland_ludwigshafen.mp3",
                "http://streamhq.top100station.com/top100station-high.mp3",
                "http://st01.dlf.de/dlf/01/128/mp3/stream.mp3",
                "http://hr-hrinfo-live.cast.addradio.de/hr/hrinfo/live/mp3/128/stream.mp3",
                "http://ndr-ndr2-niedersachsen.cast.addradio.de/ndr/ndr2/niedersachsen/mp3/128/stream.mp3",
                "http://mp3channels.webradio.rockantenne.de/heavy-metal",
                "http://streams.radiobob.de/bob-kuschelrock/mp3-192/mediaplayer",
                "http://mp3.radiorsg.c.nmdn.net/radiorsg/livestream.mp3",
                "http://ice912.echo.msk.ru:9120/stream",
                "http://mp3channels.webradio.antenne.de/80er-kulthits",
                "https://streams.regenbogen.de/rr-mannheim-128-mp3",
                "http://st03.dlf.de/dlf/03/128/mp3/stream.mp3",
                "http://tuner.m1.fm/charts.mp3"];
            // Array mit mp3-Sendern passend zu Streams
            var sname = ["1 Live",
                "Hit Radio FFH",
                "SWR 3",
                "1 Live - Diggi",
                "Hit Radio FFH - 80er",
                "Rockland Radio - MH & LU",
                "Top 100 - Station",
                "Deutschlandfunk",
                "hr info",
                "NDR 2",
                "Rock Antenne - Heavy Metal",
                "Kuschelrock",
                "Radio RSG",
                "Echo of Moscow",
                "ANTENNE BAYERN - 80er Kulthits",
                "Radio Regenbogen",
                "Deutschlandfunk Nova",
                "Top Of The Charts"];
            //createState(name, initialValue, forceCreation, common, native, callback);
            createState(control + '.MediaControl.Play', false, {type: 'boolean', read: 'true', write: 'true', role: 'button.play'});
            createState(control + '.MediaControl.Pause', false, {type: 'boolean', read: 'true', write: 'true', role: 'button.pause'});
            createState(control + '.MediaControl.Stop', false, {type: 'boolean', read: 'true', write: 'true', role: 'button.stop'});
            createState(control + '.AudioControl.Vol_UP', false, {type: 'boolean', read: 'true', write: 'true', role: 'button.volume_up'});
            createState(control + '.AudioControl.Vol_Down', false, {type: 'boolean', read: 'true', write: 'true', role: 'button.volume_down'});
            createState(control + '.AudioControl.Mute', false, {type: 'boolean', read: 'true', write: 'true', role: 'button.mute'});
            createState(control + '.MediaControl.MediaURL', '', {type: 'string', read: 'true', write: 'true'});
            createState(control + '.Num2URL', '', {type: 'string', read: 'true', write: 'true'});
            createState(control + '.SenderName', '', {type: 'string', read: 'true', write: 'true'});
            on({id: control + '.Num2URL', change: "ne"}, function (obj) {
                var tmpnr = getState(control + '.Num2URL').val;
                setState(control + '.MediaControl.MediaURL', sender[tmpnr], true);
                setState(control + '.SenderName', sname[tmpnr], true);
            on({id: control + '.MediaControl.Play', val: true
                }, function(obj){
                    if(debug) log("PLAY gedrückt");
                    //Wiedergabe starten
                    setState(device + '.MediaRenderer.AVTransport.Play.InstanceID', 0);
                    setState(device + '.MediaRenderer.AVTransport.Play.Speed', 1);
                    setState(device + '.MediaRenderer.AVTransport.Play', 'send');
                    setTimeout(function(){setState(obj.id, false);}, 150);
            on({id: control + '.MediaControl.Pause', val: true
                }, function(obj){
                    if(debug) log("PAUSE gedrückt");
                    //Wiedergabe pausieren
                    setState(device +  '.MediaRenderer.AVTransport.Pause.InstanceID', 0);
                    setState(device + '.MediaRenderer.AVTransport.Pause', 'send');
            on({id: control + '.MediaControl.Stop', val: true
                }, function(obj){
                    if(debug) log("STOP gedrückt");
                    //Wiedergabe stoppen
                    setState(device +  '.MediaRenderer.AVTransport.Stop.InstanceID', 0);
                    setState(device + '.MediaRenderer.AVTransport.Stop', 'send');
            on({id: control + '.AudioControl.Vol_UP', val: true
                }, function(obj){
                    oldVol = getState(device + '.MediaRenderer.RenderingControl.Volume').val;
                    if(debug) log("old: " + oldVol);
                    if(oldVol != "" && oldVol != null) {
                        if(parseInt(oldVol) < 96) newVol = parseInt(oldVol) + 5; //der Wert um den die Lautstärke geändert wird, kann beliebig geändert werden
                    else
                        newVol = 50;
                    if(debug) log("new: " + newVol);
                    //neue Lautstärke senden
                    setState(device + '.MediaRenderer.RenderingControl.SetVolume.Channel', 'Master');
                    setState(device + '.MediaRenderer.RenderingControl.SetVolume.DesiredVolume', newVol);
                    setState(device +  '.MediaRenderer.RenderingControl.SetVolume.InstanceID', 0);
                    setState(device + '.MediaRenderer.RenderingControl.SetVolume', 'send');
                    setState(device + '.MediaRenderer.RenderingControl.Volume', newVol);
            on({id: control + '.AudioControl.Vol_Down', val: true
                }, function(obj){
                        if(parseInt(oldVol) > 4) newVol = parseInt(oldVol) - 5; //der Wert um den die Lautstärke geändert wird, kann beliebig geändert werden
                    else
                        newVol = 50;
            on({id: control + '.AudioControl.Mute', val: true
                }, function(){
                    var oldMute = getState(device + '.MediaRenderer.RenderingControl.Mute').val;
                    if(debug) log("MUTE gedrückt");
                    if(!oldMute){
                        setState(device + '.MediaRenderer.RenderingControl.SetMute.InstanceID', 0);
                        setState(device + '.MediaRenderer.RenderingControl.SetMute.Channel', 'Master');
                        setState(device + '.MediaRenderer.RenderingControl.SetMute.DesiredMute', 1);
                        setState(device + '.MediaRenderer.RenderingControl.SetMute', 'send');
                        setState(device + '.MediaRenderer.RenderingControl.Mute', true);
                    }else{
                        setState(device + '.MediaRenderer.RenderingControl.SetMute.DesiredMute', 0);
                        setState(device + '.MediaRenderer.RenderingControl.Mute', false);
                    //setTimeout(function(){setState(obj.id, false);}, 150);
            on({id: control + '.MediaControl.MediaURL'
                }, function(obj){
                if(debug) log("NEUER SENDER gedrückt");
                setState(device + '.MediaRenderer.AVTransport.SetAVTransportURI.CurrentURI', obj.newState.val);
                setState(device + '.MediaRenderer.AVTransport.SetAVTransportURI.InstanceID', 0);
                setState(device + '.MediaRenderer.AVTransport.SetAVTransportURI', 'send');
                setTimeout(function () {setState('javascript.0.Tab2.MediaControl.Play', true,true)}, 10000);
            Damit werden Datenpunkte erzeugt über die der Player gesteuert wird.
            Hier ein Bespiel für ein Widget:
            [{"tpl":"tplIconState","data":{"oid":"javascript.0.Tab2.MediaControl.Play","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"text":"","value":"true","src":"/vis.0/main/Images/ButtonIcons/audio_play.png"},"style":{"left":"80px","top":"362px","width":"150px","height":"150px","background":"transparent","border-radius":"75px","border-width":"2px","border-style":"solid","border-color":"#777","padding-bottom":"","z-index":"10","box-shadow":"0 0 20px grey"},"widgetSet":"jqui"}]
            Weitere Buttons kannst du erstellen indem du die Object ID des Widgets an die Datenpunkte anpasst:
            javascript.0.Tab2.MediaControl.Play für PLAY
            javascript.0.Tab2.MediaControl.Stop für STOP
            javascript.0.Tab2.AudioControl.Vol_Down für LEISER
            javascript.0.Tab2.AudioControl.Vol_UP für LAUTER
            und in
            javascript.0.Tab2.Num2URL wird eine Zahl zwischen 0 und 9 angegeben. Die Nummer entspricht der Position in Sender-Array. Wird also in javascript.0.Tab2.Num2URL eine 2 eingetragen, dann wird in javascript.0.Tab2.MediaControl.MediaURL die URL "http://swr-swr3-live.cast.addradio.de/swr/swr3/live/mp3/128/stream.mp3" eingetragen und abgespielt. Gleichzeitig wird in javascript.0.Tab2.SenderName "SWR 3" eingetragen.
            Hier ein Beispiel für ein Sender-Button:
            [{"tpl":"tplIconState","data":{"oid":"javascript.0.Tab2.Num2URL","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value":"2","src":"/vis.0/main/Images/Radiosender/swr3.png"},"style":{"left":"1000px","top":"240px","width":"150px","height":"150px","border-radius":"10px","border-width":"5px","border-style":"solid","border-color":"{val:javascript.0.Tab2.Num2URL; val==\"2\"? \"#14ff1f\": \"#777\"}","box-shadow":"{val:javascript.0.Tab2.Num2URL; val==\"2\"? \"0 0 20px grey\": \"\"}","z-index":"5"},"widgetSet":"jqui"}]
            Melde dich, wenn du Fragen hast.
            LG, a200.
            SegwayS Karel PuhliK 3 Antworten Letzte Antwort
            • a200A a200
              var oldVol;
              var outURL;
              var newVol;
              var debug = true;
                  "Hit Radio FFH",
                  "SWR 3",
                  "1 Live - Diggi",
                  "Deutschlandfunk",
                  "hr info",
                  "NDR 2",
                  "Kuschelrock",
                  "Radio RSG",
                  "Echo of Moscow",
                  "Radio Regenbogen",
                  }, function(obj){
                  }, function(obj){
                  }, function(obj){
                  }, function(obj){
                      else
                          newVol = 50;
                  }, function(obj){
                      else
                          newVol = 50;
                  }, function(){
                      if(!oldMute){
                      }else{
                  }, function(obj){
              und in
              LG, a200.
              SegwayS Offline
              SegwayS Offline
              Segway
              #86
              @a200
              Suuuper ! Danke, das hilft mir weiter. Das bastel ich mir mal zusammen. Wenn was ist melde ich mich :-) DANKE
              Gruß Dirk
              • a200A a200
                var oldVol;
                var outURL;
                var newVol;
                var debug = true;
                    "Hit Radio FFH",
                    "SWR 3",
                    "1 Live - Diggi",
                    "Deutschlandfunk",
                    "hr info",
                    "NDR 2",
                    "Kuschelrock",
                    "Radio RSG",
                    "Echo of Moscow",
                    "Radio Regenbogen",
                    }, function(obj){
                    }, function(obj){
                    }, function(obj){
                    }, function(obj){
                        else
                            newVol = 50;
                    }, function(obj){
                        else
                            newVol = 50;
                    }, function(){
                        if(!oldMute){
                        }else{
                    }, function(obj){
                und in
                LG, a200.
                SegwayS Offline
                SegwayS Offline
                Segway
                schrieb am zuletzt editiert von Segway
                #87
                @a200
                Jo soweit habe ich es jetzt implementiert und experimentiert.
                Bei meinem Lautsprecher muss zwangsläufig auch unter
                SetAVTransportURI
                der request gesetzt werden (kleine Klingel / Tastendruck) --> nur dann wird der neue Sender übernommen.
                Habe das versucht in die Rubrik WIEDERGABE STARTEN (im javascript) zu implementieren aber leider geht es nicht :-( Ne Idee ?
                UPDATE:
                es geht jetzt aber ich muss den Datenpunkt anpassen --> .request und dann nicht auf SEND sondern auf TRUE setzen.
                Frage:
                Kann ich einfach noch ein paar Sender hinzufügen ? Habe das gemacht aber er nimmt den 18.-20igsten Sender NICHT an :-(
                Gruß Dirk
                • SegwayS Segway
                  @a200
                  SetAVTransportURI
                  UPDATE:
                  Frage:
                  a200A Offline
                  a200A Offline
                  a200
                  #88
                  @Segway sagte in [Frage] Internetradio - wie geht das ?:
                  @a200
                  Frage:
                  das sollte problemlos gehen. Du musst die beiden Arrays sender und sname um die neuen Einträge erweitern.
                      "http://tuner.m1.fm/charts.mp3", // Komma nicht vergessen
                      "http://........mp3"];           // neuer Eintrag
                      "Hit Radio FFH",
                      "Top Of The Charts", // Komma nicht vergessen
                      "Sendername"];           // neuer Eintrag
                  Und dann noch ein Button bei dem du die "18" in den Datenpunkt "javascript.0.Tab2.Num2URL" schreibst.
                  • a200A a200
                    @a200
                    Frage:
                        "Hit Radio FFH",
                    SegwayS Offline
                    SegwayS Offline
                    Segway
                    #89
                    @a200
                    Frage:
                        "Hit Radio FFH",
                    Jau habe ich gesehen....nur leider hat Murphis Gesetzt eingeschlagen.
                    Genau den Stream, den ich einfügte wollte er nicht nehmen, warum auch immer !!! Somit blieb der letzte Sender aktiv :-) VLC spielte den problemlos ab.
                    Habe mir nun von surfmusik die playlist des Senders heruntergeladen und in Notepad geöffnet und diese Adresse eingegeben --> siehe da ES GEHT NUN :-)
                    Gruß Dirk
                    • SegwayS Segway
                      @a200
                      Frage:
                          "Hit Radio FFH",
                      a200A Offline
                      a200A Offline
                      a200
                      #90
                      @Segway Cool. Es freut mich, dass es geht. Über eine positive Bewertung würde ich mich freuen.
                      und @Jey-Cee nicht vergessen. Seine Arbeit war die Grundlage für meine Erweiterung.
                      • a200A a200
                        SegwayS Offline
                        SegwayS Offline
                        Segway
                        #91
                        @a200
                        Klar ... wo soll ich bewerten ???
                        P.S.:
                        Ne Idee wie man mit mehreren WLan Lautsprechern in unterschiedlichen Räumen umgehen sollte, dass die Musik auf mehreren abspielt ?
                        Gruß Dirk
                        • kmxakK kmxak
                          HTML Widget
                          <audio controls/autoplay="autoplay"><source src="http://mp3stream7.apasf.apa.at:8000/;stream.mp3" type="audio/mp3">ORF.</audio>
                          Hier das Widget
                          [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"html":"
                          \n
                          <audio controls/autoplay="\&quot;autoplay\&quot;"><source src="\&quot;http://mp3stream7.apasf.apa.at:8000/;stream.mp3\&quot;" type="\&quot;audio/mp3\&quot;">ORF.</audio>
                          "},"style":{"left":"902px","top":"376px","width":"324px","height":"72px"},"widgetSet":"basic"}]
                          Phil87
                          #92
                          @kmxak ich habe eine Frage zu dem HTML Widget, ich möchte gerne https://www.jumpradio.de/musik/livestreamplayer/index.html?channelname=live diesen link in den Widget integrieren. Was muss ich hier beachten? kann ich einfach den http: Punkt wechsel oder sieht der Link anders aus?
                          kmxakK 1 Antwort Letzte Antwort
                          • P Phil87
                            kmxakK Offline
                            kmxakK Offline
                            kmxak
                            #93
                            @Phil87
                            Die URL sollte folgende sein:
                            http://avw.mdr.de/streams/284320-0_mp3_high.m3u
                            Die URL einfach im Widget ändern.
                            Da ich das seit 2017 aber nicht mehr nutze weiß ich nicht ob das klappt.
                            Kannst ja mal probieren.
                            Gruß Alex
                            P 1 Antwort Letzte Antwort
                            • kmxakK kmxak
                              @Phil87
                              Phil87
                              #94
                              @kmxak
                              leider klappt es nicht. Gibt es noch eine andere Idee die ich nutzen kann?
                              • a200A a200
                                var oldVol;
                                var outURL;
                                var newVol;
                                var debug = true;
                                    "Hit Radio FFH",
                                    "SWR 3",
                                    "1 Live - Diggi",
                                    "Deutschlandfunk",
                                    "hr info",
                                    "NDR 2",
                                    "Kuschelrock",
                                    "Radio RSG",
                                    "Echo of Moscow",
                                    "Radio Regenbogen",
                                    }, function(obj){
                                    }, function(obj){
                                    }, function(obj){
                                    }, function(obj){
                                        else
                                            newVol = 50;
                                    }, function(obj){
                                        else
                                            newVol = 50;
                                    }, function(){
                                        if(!oldMute){
                                        }else{
                                    }, function(obj){
                                und in
                                LG, a200.
                                Karel PuhliK Offline
                                Karel Puhli
                                #95
                                @a200
                                Nabend!
                                Eine Frage, funktionieren die Skripte / Widgets noch?
                                Sitze zurzeit an einer neuen VIS und sammle Ideen...
                                Danke und beste Grüße!
                                • Karel PuhliK Karel Puhli
                                  @a200
                                  Nabend!
                                  a200A Offline
                                  a200A Offline
                                  a200
                                  #96
                                  @karel-puhli werde ich heute prüfen und berichten!
                                  Karel PuhliK 1 Antwort Letzte Antwort
                                  • a200A a200
                                    Karel Puhli
                                    #97
                                    @a200
                                    Schon ein Ergebnis?
                                    Beste Grüße!
                                      @a200
                                      Schon ein Ergebnis?
                                      Beste Grüße!
                                      a200A Offline
                                      a200A Offline
                                      a200
                                      #98
                                      @karel-puhli out of the box geht es nicht. Ich schau mal ob was angepasst werden muss.
                                      • metaxaM metaxa
                                        Hallo Schubi!
                                        Wunschgemäße Übersiedelung hierher, da http://forum.iobroker.net/viewtopic.php?f=17&t=6352&e=1&view=unread#p66543 ein Anderes war
                                        @Schubi:
                                        @metaxa: Schaut super aus das Webradio, kannst du bitte genauer erklären wie du das gemacht hast?
                                        MPD und IoBroker laufen auf dem Raspi? Der Raspi spielt dann die Musi über die integrierte Buchse?
                                        Würde es da nicht reichen wenn nur MPD auf dem RASPI im Badezimmer läuft?
                                        Vielleicht könnte man das in diesen Thread - edit metaxa: eben hier - weiterdiskutieren.
                                        Danke schon mal.LG Schubi. `
                                        <u>Meine Ausgangslage:</u>
                                        Raspi3 für iOBroker, vis und bissi Umfeld, läuft inaktiv seit ca. 6 Monaten im Hintergrund im Testbetrieb
                                        Raspi2 (ehem. LXCCU, war echt ein toller Start in die neue Welt) sollte fürs BadRadio reichen
                                        <u>Was wollte ich</u> (wir machen unser Bad und WC neu)<u>:</u>
                                        Keine Sonoslösung, sondern eine ausbaufähige Lowbudgetlösung mit weitgehend vorhandenem Equipment.
                                        <u>Was habe ich zusätzlich gekauft:</u>
                                        https://www.amazon.de/gp/product/B003MTTJOY/ref=od_aui_detailpages01?ie=UTF8&psc=1 ~€10,–
                                        https://www.amazon.de/Soundkarte-UGREEN-Kopfh%C3%B6rer-Mikrofonanschluss-kompatibel/dp/B016CU2PEU/ref=sr_1_1?ie=UTF8&qid=1494528924&sr=8-1&keywords=USB+Soundkarte+UGREEN+Externe+USB+Soundkarte+Adapter+Wei%C3%9F+mit+3%2C5mm+Kopfh%C3%B6rer+und+Mikrofonanschluss%2C+Plug+%26+Play+Sound+Card+geeignet+f%C3%BCr+Computer%2C+Notebook%2C (die integrierte Buchse taugt beim Raspi3 halbwegs, beim Raspi2 kriegte ich es nicht hin) ~€9,–
                                        https://www.amazon.de/LEPY-LP-808-Silver-Digital-Verst%C3%A4rker-Stereo-Audio-20-Stromversorgung/dp/B013UCBW8I/ref=sr_1_1?s=automotive&ie=UTF8&qid=1494529295&sr=1-1&keywords=LEPY+LP-808-Silver+Digital-Verst%C3%A4rker+Stereo-Audio-20+W%2C+3+A-Stromversorgung%2C+Silber (das gleiche Ding bespielt seit 2 Jahren zufriedenstellend mein "Sommerkino" auf der Terrasse) ~€20,–
                                        2x Deckeneinbauspeaker á ~15,-- hatte ich schon
                                        <u>Jetzt-Ziel:</u>
                                        Mein Raspi3 mit vis soll auf den HM Bewegungsmeder reagieren und den Raspi2 im Badezimmer sagen er soll jetzt so und so lange diesen oder jenen Sender abspielen und über vis am Tablet anzeigen.
                                        <u>Zukunfts-Ziel:</u>
                                        Im Badezimmer soll in der Früh der Radio den Lieblingssender meiner Frau spielen (funkt schon :D ), am Abend vielleicht eine gut sortierte Jazzplaylist. In der Nacht soll er grundsätzlich schweigen, auch wenn Bewegung erkannt.
                                        So, das meine Ausführungen. Worüber genau möchtest du diskutieren, bzw. wo kann ich dir versuchen zu helfen?
                                        LG aus Wien
                                        mxa
                                        Lueghi
                                        schrieb am zuletzt editiert von Lueghi
                                        #99
                                        @metaxa sagte in [Frage] Internetradio - wie geht das ?:
                                        Hallo metaxa, da ich auch mit der Überlegung eines Badradios spiele, bin ich über Deinen Beitrag gestolpert 😁 .
                                        Mir ist aber eine Sache noch nicht so ganz klar daher hoffe ich auf eine Erklärung:
                                        Läuft auf dem Bad-Raspi auch ein iobroker? Und wenn ja ist der nur dafür da, damit man ihn vom Master-iobroker aus steuern kann?
                                        Hatte das bisher so verstanden, das der mpd-Adapter auf dem Master-iobroker einen mpd-client (in dem Fall der Bad-Raspi) DIREKT ansteuern kann.
                                        Gruß Lueghi
                                        (iobroker unter proxmox)
                                        metaxaM 1 Antwort Letzte Antwort
                                        • L Lueghi
                                          metaxaM Offline
                                          metaxaM Offline
                                          metaxa
                                          schrieb am zuletzt editiert von metaxa
                                          #100
                                          @lueghi sagte in [Frage] Internetradio - wie geht das ?:
                                          Bin mittlerweile auf ein anderes System erfolgreich umgestiegen --> LMS. Warum? Damit "erreiche" ich sämtliche Player im Haus und kann diese direkt, oder in Gruppen für Durchsagen oder Radio, oder ..... direkt aus iO steuern.
                                          Google Suchbegriffe:
                                          Sqeezebox --> moOde --> https://moodeaudio.org/
                                          LMS --> Logitech Media Server
                                          Ich habe vor ca. 2 Jahren
                                          • mir einen NUC geleistet und darauf Proxmox installiert.
                                          • darauf (unter Anderen) einen Container eingereichtet und den LogitechMediaServer installiert
                                          • auf meinem alten RPI2 das MoOde Image aufgespielt
                                          • danach am LMS die UpnP/DLNA bridge installiert
                                          • auf miner iO Hauptinstallation den SqueezeboxRPC Adapter installiert
                                          Seitdem steuere ich meinen Mediaplayer auf der Terrasse, im Bad, 2 IKEA Sonos Lautsprecher alle direkt aus dem iO an.
                                          Funktioniert prächtig!
                                          LG, mxa
                                          L 1 Antwort Letzte Antwort
