  4. Hilfe bei Update des gesamten Systems
    1.0k
    6.1k
updateupgradenodejs
86 Beiträge 5 Kommentatoren 12.1k Aufrufe 3 Beobachtet
    @stoni
    iobroker status
    Stoni
    #61
    @thomas-braun sagte in Hilfe bei Update des gesamten Systems:
    iobroker status
    internal/modules/cjs/loader.js:905
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
        at Function.Module._load (internal/modules/cjs/loader.js:746:27)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)
        at internal/main/run_main_module.js:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    • S Stoni
      iobroker status
        throw err;
        requireStack: []
      #62
      @stoni
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
        @stoni
        cd /opt/iobroker
        Stoni
        #63
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        > iobroker.js-controller@3.3.18 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.15
        > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
        > node-pre-gyp install --fallback-to-build
        node-pre-gyp WARN Using request for node-pre-gyp https download
        node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v83-linux-glibc-arm.tar.gz
        node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@14.18.1 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
        Package pixman-1 was not found in the pkg-config search path.
        Perhaps you should add the directory containing `pixman-1.pc'
        to the PKG_CONFIG_PATH environment variable
        No package 'pixman-1' found
        gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
        gyp ERR! configure error
        gyp ERR! stack Error: `gyp` failed with exit code: 1
        gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
        gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
        gyp ERR! System Linux 5.10.63-v7l+
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
        gyp ERR! cwd /opt/iobroker/node_modules/canvas
        gyp ERR! node -v v14.18.1
        gyp ERR! node-gyp -v v5.1.0
        gyp ERR! not ok
        node-pre-gyp ERR! build error
        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
        node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
        node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
        node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1058:16)
        node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
        node-pre-gyp ERR! System Linux 5.10.63-v7l+
        node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
        node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
        node-pre-gyp ERR! node -v v14.18.1
        node-pre-gyp ERR! node-pre-gyp -v v0.11.0
        node-pre-gyp ERR! not ok
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the canvas@2.6.1 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR!     /home/iobroker/.npm/_logs/2021-10-25T18_58_11_047Z-debug.log
        • S Stoni
          gyp ERR! not ok
          npm ERR! errno 1
          npm ERR!
          #64
          @stoni sagte in Hilfe bei Update des gesamten Systems:
          pixman-1
          sudo apt update
          sudo apt install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
          Dann nochmal
          cd /opt/iobroker
            pixman-1
            sudo apt update
            Dann nochmal
            cd /opt/iobroker
            Stoni
            #65
            sieht aus, als wäre es ohne Fehler durchgelaufen
            make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
              SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
              COPY Release/canvas-postbuild.node
              CXX(target) Release/obj.target/canvas/src/backend/Backend.o
            In file included from ../src/backend/Backend.h:6,
                             from ../src/backend/Backend.cc:1:
            ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
            ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                 , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
              CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
                             from ../src/backend/ImageBackend.h:3,
                             from ../src/backend/ImageBackend.cc:1:
              CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
                             from ../src/backend/PdfBackend.h:3,
                             from ../src/backend/PdfBackend.cc:1:
              CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                             from ../src/backend/SvgBackend.h:3,
                             from ../src/backend/SvgBackend.cc:1:
              CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
            ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
            ../src/bmp/BMPParser.cc:189:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
               E(ptr - data > imgdOffset, "image data overlaps with another structure");
            ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
             #define E(cond, msg) if(cond) return setErr(msg)
            ../src/bmp/BMPParser.cc:204:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
               E(ptr - data + imgdSize > len, "not enough image data");
              CXX(target) Release/obj.target/canvas/src/Backends.o
                             from ../src/Backends.h:3,
                             from ../src/Backends.cc:1:
              CXX(target) Release/obj.target/canvas/src/Canvas.o
                             from ../src/Canvas.h:5,
                             from ../src/Canvas.cc:3:
            ../src/Canvas.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Canvas::ToBuffer(Nan::NAN_METHOD_ARGS_TYPE)’:
            ../src/Canvas.cc:415:26: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘unsigned int’} [-Wsign-compare]
                 if (canvas->nBytes() > node::Buffer::kMaxLength) {
            ../src/Canvas.cc:479:79: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
             ue_work(uv_default_loop(), req, ToPngBufferAsync, (uv_after_work_cb)ToBufferAsyncAfter);
            ../src/Canvas.cc:520:80: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
             e_work(uv_default_loop(), req, ToJpegBufferAsync, (uv_after_work_cb)ToBufferAsyncAfter);
            In file included from ../../nan/nan.h:2884,
            ../../nan/nan_typedarray_contents.h: In instantiation of ‘Nan::TypedArrayContents<T>::TypedArrayContents(v8::Local<v8::Value>) [with T = unsigned char]’:
            ../src/Canvas.cc:274:65:   required from here
            ../../nan/nan_typedarray_contents.h:34:54: warning: ‘v8::ArrayBuffer::Contents v8::ArrayBuffer::GetContents()’ is deprecated: Use GetBackingStore. See http://crbug.com/v8/9908. [-Wdeprecated-declarations]
                   data   = static_cast<char*>(buffer->GetContents().Data()) + byte_offset;
            In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67,
                             from ../../nan/nan.h:54,
            /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:5273:12: note: declared here
               Contents GetContents();
              CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
            In file included from ../src/CanvasGradient.h:5,
                             from ../src/CanvasGradient.cc:3:
              CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
            In file included from ../src/CanvasPattern.h:6,
                             from ../src/CanvasPattern.cc:3:
              CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                             from ../src/CanvasRenderingContext2d.h:6,
                             from ../src/CanvasRenderingContext2d.cc:3:
            ../src/CanvasRenderingContext2d.cc:1027:64:   required from here
            ../../nan/nan_typedarray_contents.h: In instantiation of ‘Nan::TypedArrayContents<T>::TypedArrayContents(v8::Local<v8::Value>) [with T = double]’:
            ../src/CanvasRenderingContext2d.cc:1752:43:   required from here
              CXX(target) Release/obj.target/canvas/src/closure.o
                             from ../src/closure.h:5,
                             from ../src/closure.cc:1:
              CXX(target) Release/obj.target/canvas/src/color.o
              CXX(target) Release/obj.target/canvas/src/Image.o
            In file included from ../src/Image.h:8,
                             from ../src/Image.cc:3:
              CXX(target) Release/obj.target/canvas/src/ImageData.o
            In file included from ../src/ImageData.h:5,
                             from ../src/ImageData.cc:3:
            ../src/ImageData.cc:116:53:   required from here
              CXX(target) Release/obj.target/canvas/src/init.o
                             from ../src/init.cc:17:
            In file included from ../../nan/nan.h:54,
            ../src/init.cc: At global scope:
            /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:787:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                   (node::addon_register_func) (regfunc),                          \
            /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’
               NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
            ../src/init.cc:88:1: note: in expansion of macro ‘NODE_MODULE’
             NODE_MODULE(canvas, init);
              CXX(target) Release/obj.target/canvas/src/register_font.o
              SOLINK_MODULE(target) Release/obj.target/canvas.node
              COPY Release/canvas.node
            make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
            > iobroker.js-controller@3.3.18 install /opt/iobroker/node_modules/iobroker.js-controller
            > node iobroker.js setup first
            object system.certificates updated
            object _design/custom updated
            object _design/system updated
            ioBroker configuration updated
            + iobroker.js-controller@3.3.18
            added 10 packages from 8 contributors and updated 1 package in 94.632s
            21 packages are looking for funding
              run `npm fund` for details
            • S Stoni
              #66
              @stoni
              iobroker restart
              iobroker status
              S 2 Antworten Letzte Antwort
                @stoni
                iobroker restart
                iobroker status
                Stoni
                #67
                Objects type: file
                States  type: redis
                  @stoni
                  iobroker restart
                  iobroker status
                  Stoni
                  schrieb am zuletzt editiert von Stoni
                  #68
                  also ioBroker läuft wieder, der LOG ist auch kräftig am schaffen.
                  Die Adapter sind weitesgehend wieder grün, nur der javascript und der WLED sind noch rot.
                  EDIT: WLED grün, Javascript weiter rot
                  EDIT2: Javascript springt immer von rot auf grün und zurück
                  • S Stoni
                    #69
                    @stoni
                    Dann starte den javaskript-Adapter mal neu, Ausgabe aus dem LogFile posten.
                      @stoni
                      Stoni
                      #70
                      avascript.0	2021-10-25 21:32:09.769	warn	(3661) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      javascript.0	2021-10-25 21:32:09.768	info	(3661) terminating
                      javascript.0	2021-10-25 21:32:09.683	error	(3661) The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                      javascript.0	2021-10-25 21:32:09.682	error	(3661) Error: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
                      javascript.0	2021-10-25 21:32:09.682	error	(3661) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                      javascript.0	2021-10-25 21:32:09.682	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      javascript.0	2021-10-25 21:32:09.680	error	(3661) The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                      javascript.0	2021-10-25 21:32:09.680	error	(3661) Error: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
                      javascript.0	2021-10-25 21:32:09.680	error	(3661) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                      javascript.0	2021-10-25 21:32:09.679	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      javascript.0	2021-10-25 21:32:09.676	info	(3661) Stop script script.js.Heizung.WP_WW_aufbereiten
                      javascript.0	2021-10-25 21:32:09.676	info	(3661) Stop script script.js.Heizung.WP_Betrieb_WW
                      javascript.0	2021-10-25 21:32:09.675	info	(3661) Stop script script.js.Heizung.WP_Betrieb_HZ_WW
                      javascript.0	2021-10-25 21:32:09.675	info	(3661) Stop script script.js.Heizung.WP_ein
                      javascript.0	2021-10-25 21:32:09.675	info	(3661) Stop script script.js.Heizung.WP_aus
                      javascript.0	2021-10-25 21:32:09.674	info	(3661) Stop script script.js.Heizung.WP_Betrieb_Heizen
                      javascript.0	2021-10-25 21:32:09.673	info	(3661) Stop script script.js.Heizung.Entkeimung_Taster
                      javascript.0	2021-10-25 21:32:09.673	info	(3661) Stop script script.js.Kellerfenster_Einbruch.Fenster_Hobbykeller
                      javascript.0	2021-10-25 21:32:09.673	info	(3661) Stop script script.js.Beleuchtung.Urlaubsbeleuchtung
                      javascript.0	2021-10-25 21:32:09.672	info	(3661) Stop script script.js.Garage___Garten___Carport.Carporttor_Abwesend
                      javascript.0	2021-10-25 21:32:09.672	info	(3661) Stop script script.js.Garage___Garten___Carport.Carportlicht_BWM
                      javascript.0	2021-10-25 21:32:09.671	info	(3661) Stop script script.js.Garage___Garten___Carport.Bewegung_Abwesenheit(1)
                      javascript.0	2021-10-25 21:32:09.671	info	(3661) Stop script script.js.Garage___Garten___Carport.Bewegung_Dunkelheit
                      javascript.0	2021-10-25 21:32:09.670	info	(3661) Stop script script.js.Garage___Garten___Carport.Garagenlicht
                      javascript.0	2021-10-25 21:32:09.670	info	(3661) Stop script script.js.Garage___Garten___Carport.Gartenlicht
                      javascript.0	2021-10-25 21:32:09.670	info	(3661) Stop script script.js.Garage___Garten___Carport.Licht_Gartenhaus
                      javascript.0	2021-10-25 21:32:09.669	info	(3661) Stop script script.js.Garage___Garten___Carport.WLED_Garage_Beginner
                      javascript.0	2021-10-25 21:32:09.669	info	(3661) Stop script script.js.Garage___Garten___Carport.Garagentor_Schalter
                      javascript.0	2021-10-25 21:32:09.668	info	(3661) Stop script script.js.Rollläden.Rollläden_Urlaub
                      javascript.0	2021-10-25 21:32:09.668	info	(3661) Stop script script.js.common.Batteriestand_Haustür
                      javascript.0	2021-10-25 21:32:09.667	info	(3661) Stop script script.js.Anwesenheit.Zisternenpumpe
                      javascript.0	2021-10-25 21:32:09.667	info	(3661) Stop script script.js.Anwesenheit.Bewegung_Flur
                      javascript.0	2021-10-25 21:32:09.667	info	(3661) Stop script script.js.Anwesenheit.IP_Cams
                      javascript.0	2021-10-25 21:32:09.666	info	(3661) Stop script script.js.Rollläden.Beschattung_Süden_OPPLE
                      javascript.0	2021-10-25 21:32:09.666	info	(3661) Stop script script.js.Rollläden.Beschattung_Osten_OPPLE
                      javascript.0	2021-10-25 21:32:09.665	info	(3661) Stop script script.js.Beleuchtung.OPPLE_3-fach_Wohnzimmer
                      javascript.0	2021-10-25 21:32:09.665	info	(3661) Stop script script.js.Sayit.Erinnerung_Tabletten
                      javascript.0	2021-10-25 21:32:09.664	info	(3661) Stop script script.js.Rollläden.Rollläden_auf
                      javascript.0	2021-10-25 21:32:09.664	info	(3661) Stop script script.js.Kellerfenster_Einbruch.Gästezimmer
                      javascript.0	2021-10-25 21:32:09.663	info	(3661) Stop script script.js.Rollläden.Rollladen_Terrasse_ab
                      javascript.0	2021-10-25 21:32:09.663	info	(3661) Stop script script.js.Rollläden.Rollläden_EG_ab
                      javascript.0	2021-10-25 21:32:09.662	info	(3661) Stop script script.js.Rollläden.Wohnzimmerfenster
                      javascript.0	2021-10-25 21:32:09.662	info	(3661) Stop script script.js.Beleuchtung.Nachtlicht-Schlafzimmer
                      javascript.0	2021-10-25 21:32:09.661	info	(3661) Stop script script.js.Beleuchtung.Sternenlicht
                      javascript.0	2021-10-25 21:32:09.660	info	(3661) Stop script script.js.common.Batterie_iPad_Air
                      javascript.0	2021-10-25 21:32:09.660	info	(3661) Stop script script.js.common.Anruf_Nachricht_Pushover
                      javascript.0	2021-10-25 21:32:09.659	info	(3661) Stop script script.js.Beleuchtung.Terrassenbeleuchtung(1)
                      javascript.0	2021-10-25 21:32:09.659	info	(3661) Stop script script.js.Beleuchtung.indirekte_Beleuchtung(1)
                      javascript.0	2021-10-25 21:32:09.658	info	(3661) Stop script script.js.Sayit.Wassermelder_Küche
                      javascript.0	2021-10-25 21:32:09.658	info	(3661) Stop script script.js.Sayit.Wassermelder_Keller
                      javascript.0	2021-10-25 21:32:09.657	info	(3661) Stop script script.js.Sayit.Rasenmäher_error
                      javascript.0	2021-10-25 21:32:09.656	info	(3661) Stop script script.js.Sayit.Bad_OG
                      javascript.0	2021-10-25 21:32:09.655	info	(3661) Stop script script.js.Sayit.Hobbykeller_10_Min
                      javascript.0	2021-10-25 21:32:09.653	info	(3661) Stop script script.js.Sayit.Gästebad_10_Min
                      javascript.0	2021-10-25 21:32:09.651	info	(3661) Stop script script.js.Sayit.Gästebad_5_Min
                      javascript.0	2021-10-25 21:32:09.650	info	(3661) Stop script script.js.Sayit.Kinderzimmer_Lea_Sophie
                      javascript.0	2021-10-25 21:32:09.649	info	(3661) Stop script script.js.Sayit.Gästezimmer
                      javascript.0	2021-10-25 21:32:09.649	info	(3661) Stop script script.js.Sayit.Kinderzimmer_Maximilian
                      javascript.0	2021-10-25 21:32:09.645	info	(3661) Stop script script.js.common.PV-Tagesertrag
                      javascript.0	2021-10-25 21:32:09.643	info	(3661) Stop script script.js.Sayit.Gefrierschrank_3_Min.
                      javascript.0	2021-10-25 21:32:09.642	info	(3661) Stop script script.js.Sayit.Gefrierschrank_2_Min.
                      javascript.0	2021-10-25 21:32:09.639	info	(3661) script.js.Heizung.WP_WW_aufbereiten: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.635	info	(3661) Start javascript script.js.Heizung.WP_WW_aufbereiten
                      javascript.0	2021-10-25 21:32:09.634	info	(3661) script.js.Heizung.WP_Betrieb_WW: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.630	info	(3661) Start javascript script.js.Heizung.WP_Betrieb_WW
                      javascript.0	2021-10-25 21:32:09.629	info	(3661) script.js.Heizung.WP_Betrieb_HZ_WW: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.625	info	(3661) Start javascript script.js.Heizung.WP_Betrieb_HZ_WW
                      javascript.0	2021-10-25 21:32:09.624	info	(3661) script.js.Heizung.WP_ein: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.620	info	(3661) Start javascript script.js.Heizung.WP_ein
                      javascript.0	2021-10-25 21:32:09.619	info	(3661) script.js.Heizung.WP_aus: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.615	info	(3661) Start javascript script.js.Heizung.WP_aus
                      javascript.0	2021-10-25 21:32:09.614	info	(3661) script.js.Heizung.WP_Betrieb_Heizen: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.610	info	(3661) Start javascript script.js.Heizung.WP_Betrieb_Heizen
                      javascript.0	2021-10-25 21:32:09.609	info	(3661) script.js.Heizung.Entkeimung_Taster: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.605	info	(3661) Start javascript script.js.Heizung.Entkeimung_Taster
                      javascript.0	2021-10-25 21:32:09.604	info	(3661) script.js.Kellerfenster_Einbruch.Fenster_Hobbykeller: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.600	info	(3661) Start javascript script.js.Kellerfenster_Einbruch.Fenster_Hobbykeller
                      javascript.0	2021-10-25 21:32:09.599	info	(3661) script.js.Beleuchtung.Urlaubsbeleuchtung: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.595	info	(3661) Start javascript script.js.Beleuchtung.Urlaubsbeleuchtung
                      javascript.0	2021-10-25 21:32:09.594	info	(3661) script.js.Garage___Garten___Carport.Carporttor_Abwesend: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.590	info	(3661) Start javascript script.js.Garage___Garten___Carport.Carporttor_Abwesend
                      javascript.0	2021-10-25 21:32:09.590	info	(3661) script.js.Garage___Garten___Carport.Carportlicht_BWM: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.586	info	(3661) Start javascript script.js.Garage___Garten___Carport.Carportlicht_BWM
                      javascript.0	2021-10-25 21:32:09.585	info	(3661) script.js.Garage___Garten___Carport.Bewegung_Abwesenheit(1): registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.581	info	(3661) Start javascript script.js.Garage___Garten___Carport.Bewegung_Abwesenheit(1)
                      javascript.0	2021-10-25 21:32:09.580	info	(3661) script.js.Garage___Garten___Carport.Bewegung_Dunkelheit: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.576	info	(3661) Start javascript script.js.Garage___Garten___Carport.Bewegung_Dunkelheit
                      javascript.0	2021-10-25 21:32:09.576	info	(3661) script.js.Garage___Garten___Carport.Garagenlicht: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.572	info	(3661) Start javascript script.js.Garage___Garten___Carport.Garagenlicht
                      javascript.0	2021-10-25 21:32:09.571	info	(3661) script.js.Garage___Garten___Carport.Gartenlicht: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.567	info	(3661) Start javascript script.js.Garage___Garten___Carport.Gartenlicht
                      javascript.0	2021-10-25 21:32:09.566	info	(3661) script.js.Garage___Garten___Carport.Licht_Gartenhaus: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.563	info	(3661) Start javascript script.js.Garage___Garten___Carport.Licht_Gartenhaus
                      javascript.0	2021-10-25 21:32:09.562	info	(3661) script.js.Garage___Garten___Carport.WLED_Garage_Beginner: registered 4 subscriptions and 0 schedules
                      javascript.0	2021-10-25 21:32:09.557	info	(3661) Start javascript script.js.Garage___Garten___Carport.WLED_Garage_Beginner
                      javascript.0	2021-10-25 21:32:09.557	info	(3661) script.js.Garage___Garten___Carport.Garagentor_Schalter: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.553	info	(3661) Start javascript script.js.Garage___Garten___Carport.Garagentor_Schalter
                      javascript.0	2021-10-25 21:32:09.552	info	(3661) script.js.Rollläden.Rollläden_Urlaub: registered 2 subscriptions and 0 schedules
                      javascript.0	2021-10-25 21:32:09.547	info	(3661) Start javascript script.js.Rollläden.Rollläden_Urlaub
                      javascript.0	2021-10-25 21:32:09.546	info	(3661) script.js.common.Batteriestand_Haustür: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.542	info	(3661) Start javascript script.js.common.Batteriestand_Haustür
                      javascript.0	2021-10-25 21:32:09.541	info	(3661) script.js.Anwesenheit.Zisternenpumpe: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.537	info	(3661) Start javascript script.js.Anwesenheit.Zisternenpumpe
                      javascript.0	2021-10-25 21:32:09.536	info	(3661) script.js.Anwesenheit.Bewegung_Flur: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.532	info	(3661) Start javascript script.js.Anwesenheit.Bewegung_Flur
                      javascript.0	2021-10-25 21:32:09.532	info	(3661) script.js.Anwesenheit.IP_Cams: registered 2 subscriptions and 0 schedules
                      javascript.0	2021-10-25 21:32:09.527	info	(3661) Start javascript script.js.Anwesenheit.IP_Cams
                      javascript.0	2021-10-25 21:32:09.527	info	(3661) script.js.Rollläden.Beschattung_Süden_OPPLE: registered 2 subscriptions and 0 schedules
                      javascript.0	2021-10-25 21:32:09.523	info	(3661) Start javascript script.js.Rollläden.Beschattung_Süden_OPPLE
                      javascript.0	2021-10-25 21:32:09.522	info	(3661) script.js.Rollläden.Beschattung_Osten_OPPLE: registered 2 subscriptions and 0 schedules
                      javascript.0	2021-10-25 21:32:09.518	info	(3661) Start javascript script.js.Rollläden.Beschattung_Osten_OPPLE
                      javascript.0	2021-10-25 21:32:09.517	info	(3661) script.js.Beleuchtung.OPPLE_3-fach_Wohnzimmer: registered 3 subscriptions and 0 schedules
                      javascript.0	2021-10-25 21:32:09.513	info	(3661) Start javascript script.js.Beleuchtung.OPPLE_3-fach_Wohnzimmer
                      javascript.0	2021-10-25 21:32:09.512	info	(3661) script.js.Sayit.Erinnerung_Tabletten: registered 0 subscriptions and 1 schedule
                      javascript.0	2021-10-25 21:32:09.506	info	(3661) Start javascript script.js.Sayit.Erinnerung_Tabletten
                      javascript.0	2021-10-25 21:32:09.505	info	(3661) script.js.Rollläden.Rollläden_auf: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.501	info	(3661) Start javascript script.js.Rollläden.Rollläden_auf
                      javascript.0	2021-10-25 21:32:09.501	info	(3661) script.js.Kellerfenster_Einbruch.Gästezimmer: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.497	info	(3661) Start javascript script.js.Kellerfenster_Einbruch.Gästezimmer
                      javascript.0	2021-10-25 21:32:09.496	info	(3661) script.js.Rollläden.Rollladen_Terrasse_ab: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.492	info	(3661) Start javascript script.js.Rollläden.Rollladen_Terrasse_ab
                      javascript.0	2021-10-25 21:32:09.491	info	(3661) script.js.Rollläden.Rollläden_EG_ab: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.487	info	(3661) Start javascript script.js.Rollläden.Rollläden_EG_ab
                      javascript.0	2021-10-25 21:32:09.487	info	(3661) script.js.Rollläden.Wohnzimmerfenster: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.483	info	(3661) Start javascript script.js.Rollläden.Wohnzimmerfenster
                      javascript.0	2021-10-25 21:32:09.482	info	(3661) script.js.Beleuchtung.Nachtlicht-Schlafzimmer: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.478	info	(3661) Start javascript script.js.Beleuchtung.Nachtlicht-Schlafzimmer
                      javascript.0	2021-10-25 21:32:09.477	info	(3661) script.js.Beleuchtung.Sternenlicht: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.473	info	(3661) Start javascript script.js.Beleuchtung.Sternenlicht
                      javascript.0	2021-10-25 21:32:09.473	info	(3661) script.js.common.Batterie_iPad_Air: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.469	info	(3661) Start javascript script.js.common.Batterie_iPad_Air
                      javascript.0	2021-10-25 21:32:09.468	info	(3661) script.js.common.Anruf_Nachricht_Pushover: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.464	info	(3661) Start javascript script.js.common.Anruf_Nachricht_Pushover
                      javascript.0	2021-10-25 21:32:09.463	info	(3661) script.js.Beleuchtung.Terrassenbeleuchtung(1): registered 2 subscriptions and 0 schedules
                      javascript.0	2021-10-25 21:32:09.459	info	(3661) Start javascript script.js.Beleuchtung.Terrassenbeleuchtung(1)
                      javascript.0	2021-10-25 21:32:09.458	info	(3661) script.js.Beleuchtung.indirekte_Beleuchtung(1): registered 2 subscriptions and 0 schedules
                      javascript.0	2021-10-25 21:32:09.454	info	(3661) Start javascript script.js.Beleuchtung.indirekte_Beleuchtung(1)
                      javascript.0	2021-10-25 21:32:09.453	info	(3661) script.js.Sayit.Wassermelder_Küche: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.449	info	(3661) Start javascript script.js.Sayit.Wassermelder_Küche
                      javascript.0	2021-10-25 21:32:09.448	info	(3661) script.js.Sayit.Wassermelder_Keller: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.444	info	(3661) Start javascript script.js.Sayit.Wassermelder_Keller
                      javascript.0	2021-10-25 21:32:09.444	info	(3661) script.js.Sayit.Rasenmäher_error: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.440	info	(3661) Start javascript script.js.Sayit.Rasenmäher_error
                      javascript.0	2021-10-25 21:32:09.439	info	(3661) script.js.Sayit.Bad_OG: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.435	info	(3661) Start javascript script.js.Sayit.Bad_OG
                      javascript.0	2021-10-25 21:32:09.434	info	(3661) script.js.Sayit.Hobbykeller_10_Min: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.430	info	(3661) Start javascript script.js.Sayit.Hobbykeller_10_Min
                      javascript.0	2021-10-25 21:32:09.430	info	(3661) script.js.Sayit.Gästebad_10_Min: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.426	info	(3661) Start javascript script.js.Sayit.Gästebad_10_Min
                      javascript.0	2021-10-25 21:32:09.425	info	(3661) script.js.Sayit.Gästebad_5_Min: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.421	info	(3661) Start javascript script.js.Sayit.Gästebad_5_Min
                      javascript.0	2021-10-25 21:32:09.420	info	(3661) script.js.Sayit.Kinderzimmer_Lea_Sophie: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.416	info	(3661) Start javascript script.js.Sayit.Kinderzimmer_Lea_Sophie
                      javascript.0	2021-10-25 21:32:09.415	info	(3661) script.js.Sayit.Gästezimmer: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.411	info	(3661) Start javascript script.js.Sayit.Gästezimmer
                      javascript.0	2021-10-25 21:32:09.410	info	(3661) script.js.Sayit.Kinderzimmer_Maximilian: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.406	info	(3661) Start javascript script.js.Sayit.Kinderzimmer_Maximilian
                      javascript.0	2021-10-25 21:32:09.406	info	(3661) script.js.common.PV-Tagesertrag: registered 0 subscriptions and 1 schedule
                      javascript.0	2021-10-25 21:32:09.387	info	(3661) Start javascript script.js.common.PV-Tagesertrag
                      javascript.0	2021-10-25 21:32:09.384	error	(3661) The id "scriptProblem.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                      javascript.0	2021-10-25 21:32:09.384	error	(3661) Error: The id "scriptProblem.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
                      javascript.0	2021-10-25 21:32:09.383	error	(3661) unhandled promise rejection: The id "scriptProblem.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                      javascript.0	2021-10-25 21:32:09.383	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      javascript.0	2021-10-25 21:32:09.382	error	(3661) The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                      javascript.0	2021-10-25 21:32:09.381	error	(3661) Error: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
                      javascript.0	2021-10-25 21:32:09.381	error	(3661) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                      javascript.0	2021-10-25 21:32:09.380	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      javascript.0	2021-10-25 21:32:09.379	info	(3661) script.js.Sayit.Gefrierschrank_3_Min.: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.370	info	(3661) Start javascript script.js.Sayit.Gefrierschrank_3_Min.
                      javascript.0	2021-10-25 21:32:09.369	error	(3661) The id "scriptProblem.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                      javascript.0	2021-10-25 21:32:09.368	error	(3661) Error: The id "scriptProblem.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
                      javascript.0	2021-10-25 21:32:09.368	error	(3661) unhandled promise rejection: The id "scriptProblem.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                      javascript.0	2021-10-25 21:32:09.367	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      javascript.0	2021-10-25 21:32:09.366	error	(3661) The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                      javascript.0	2021-10-25 21:32:09.365	error	(3661) Error: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
                      javascript.0	2021-10-25 21:32:09.365	error	(3661) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                      javascript.0	2021-10-25 21:32:09.364	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      javascript.0	2021-10-25 21:32:09.359	info	(3661) script.js.Sayit.Gefrierschrank_2_Min.: registered 1 subscription and 0 schedules
                      javascript.0	2021-10-25 21:32:09.341	info	(3661) Start javascript script.js.Sayit.Gefrierschrank_2_Min.
                      javascript.0	2021-10-25 21:32:09.199	warn	(3661) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
                      javascript.0	2021-10-25 21:32:09.196	info	(3661) received all objects
                      javascript.0	2021-10-25 21:32:08.351	info	(3661) received all states
                      javascript.0	2021-10-25 21:32:07.566	warn	(3661) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                      javascript.0	2021-10-25 21:32:07.565	info	(3661) requesting all objects
                      javascript.0	2021-10-25 21:32:07.563	info	(3661) requesting all states
                      javascript.0	2021-10-25 21:32:07.515	info	(3661) starting. Version 4.1.12 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.18.1, js-controller: 3.3.18
                      • S Stoni
                        #71
                        Skripte dürfen nicht auf einen Punkt enden.
                        Warum macht man sowas überhaupt? Ist auch z. B. unter Windows keine gute Idee für Dateinamen.
                          Stoni
                          #72
                          war nie ein Problem. Habs geändert.
                          Problem bleibt bestehen:
                          javascript.0	2021-10-25 21:43:51.964	warn	(11093) Terminated (UNCAUGHT_EXCEPTION): Without reason
                          javascript.0	2021-10-25 21:43:51.962	info	(11093) terminating
                          javascript.0	2021-10-25 21:43:51.880	error	(11093) The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                          javascript.0	2021-10-25 21:43:51.880	error	(11093) Error: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:
                          javascript.0	2021-10-25 21:43:51.879	error	(11093) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                          javascript.0	2021-10-25 21:43:51.879	error	(11093) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          javascript.0	2021-10-25 21:43:51.878	error	(11093) The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                          javascript.0	2021-10-25 21:43:51.877	error	(11093) Error: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:
                          javascript.0	2021-10-25 21:43:51.877	error	(11093) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                          javascript.0	2021-10-25 21:43:51.876	error	(11093) Unhandled promise rejection. This error originated either by throwing inside of an async function wit
                          Hab den Adapter schon wiederholt neu geladen,
                            Stoni
                            #73
                            für den JS-Adapter ist ein Update verfügbar. 4.1.12 auf 5.2.8. Soll ich das mal durchführen?
                            • S Stoni
                              #74
                              Doch, aber es wurde bislang nicht angemeckert.
                              Ich weiß nicht, ob und wo die ids der skripte geführt werden und ggf. noch angepasst werden müssen. Das muss vielleicht mal jemand mit mehr Einblick in den javaskript-Adapter anschauen.
                              So nebenher:
                              Probier mal aus, ob der Fixer jetzt funtioniert.
                              iobroker stop
                              iobroker fix
                              iobroker start
                              • S Stoni
                                #75
                                zeig mal die Objekte dazu
                                  Stoni
                                  #76
                                  @homoran @Thomas-Braun
                                  also den fix führe ich morgen mal durch. Da hab ich jetzt irgendwie schiss, dass wieder was passiert.
                                  Die javascripte mit dem Punkt am Ende lassen sich nicht ändern. Wie kann man die umbenennen?
                                  • S Stoni
                                    #77
                                    Jetzt schaut dir aber jemand dabei über die Schulter.
                                    • S Stoni
                                      #78
                                      Ich hatte irgendwo gelesen, dass das Gefummel ist. Andere user waren auch so 'kreativ' in der Benennung ihrer Skripte.
                                        Stoni
                                        #79
                                        Ich werde dazu mal ein wenig recherchieren. Wichtig ist, es läuft erstmal größtenteils. Nodejs ist etwas aktueller, und der js-controller aktuell.
                                        Ich möchte mich bei Dir und @Homoran für die Hilfe und die investierte Zeit bedanken.
                                        Gibt es noch etwas, was ich tun sollte? Oder ist das System nun einigermaßen up2date?
                                        Ich möchte dann als nächstes die Adapter möglichst aktualisieren. Denke jetzt sollte es ja gehen. Spricht was dagegen, jetzt auch den Admin auf 5 upzudaten?
                                        • S Stoni
                                          #80
                                          @stoni
                                          Das solltest du machen. Vielleicht immer einen nach dem anderen, dann hast du besser im Blick wo es klemmt.
                                          Admin5 ist der aktuelle Admin, es gibt auch einige Adapter die den mehr oder weniger unbedingt voraussetzen.
