  4. Hilfe bei Update des gesamten Systems
    1.0k
    6.1k
updateupgradenodejs
86 Beiträge 5 Kommentatoren 12.1k Aufrufe 3 Beobachtet
  • S Stoni
    sieht aus, als wäre es ohne Fehler durchgelaufen
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    > iobroker.js-controller@3.3.18 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.15
    > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp WARN Using request for node-pre-gyp https download
    node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v83-linux-glibc-arm.tar.gz
    node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@14.18.1 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
    make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
      SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
      COPY Release/canvas-postbuild.node
      CXX(target) Release/obj.target/canvas/src/backend/Backend.o
    In file included from ../src/backend/Backend.h:6,
                     from ../src/backend/Backend.cc:1:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
      CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
                     from ../src/backend/ImageBackend.h:3,
                     from ../src/backend/ImageBackend.cc:1:
      CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
                     from ../src/backend/PdfBackend.h:3,
                     from ../src/backend/PdfBackend.cc:1:
      CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                     from ../src/backend/SvgBackend.h:3,
                     from ../src/backend/SvgBackend.cc:1:
      CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
    ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
    ../src/bmp/BMPParser.cc:189:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
       E(ptr - data > imgdOffset, "image data overlaps with another structure");
    ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
     #define E(cond, msg) if(cond) return setErr(msg)
    ../src/bmp/BMPParser.cc:204:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
       E(ptr - data + imgdSize > len, "not enough image data");
      CXX(target) Release/obj.target/canvas/src/Backends.o
                     from ../src/Backends.h:3,
                     from ../src/Backends.cc:1:
      CXX(target) Release/obj.target/canvas/src/Canvas.o
                     from ../src/Canvas.h:5,
                     from ../src/Canvas.cc:3:
    ../src/Canvas.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Canvas::ToBuffer(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/Canvas.cc:415:26: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘unsigned int’} [-Wsign-compare]
         if (canvas->nBytes() > node::Buffer::kMaxLength) {
    ../src/Canvas.cc:479:79: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
     ue_work(uv_default_loop(), req, ToPngBufferAsync, (uv_after_work_cb)ToBufferAsyncAfter);
    ../src/Canvas.cc:520:80: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
     e_work(uv_default_loop(), req, ToJpegBufferAsync, (uv_after_work_cb)ToBufferAsyncAfter);
    In file included from ../../nan/nan.h:2884,
    ../../nan/nan_typedarray_contents.h: In instantiation of ‘Nan::TypedArrayContents<T>::TypedArrayContents(v8::Local<v8::Value>) [with T = unsigned char]’:
    ../src/Canvas.cc:274:65:   required from here
    ../../nan/nan_typedarray_contents.h:34:54: warning: ‘v8::ArrayBuffer::Contents v8::ArrayBuffer::GetContents()’ is deprecated: Use GetBackingStore. See http://crbug.com/v8/9908. [-Wdeprecated-declarations]
           data   = static_cast<char*>(buffer->GetContents().Data()) + byte_offset;
    In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67,
                     from ../../nan/nan.h:54,
    /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:5273:12: note: declared here
       Contents GetContents();
      CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
    In file included from ../src/CanvasGradient.h:5,
                     from ../src/CanvasGradient.cc:3:
      CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
    In file included from ../src/CanvasPattern.h:6,
                     from ../src/CanvasPattern.cc:3:
      CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                     from ../src/CanvasRenderingContext2d.h:6,
                     from ../src/CanvasRenderingContext2d.cc:3:
    ../src/CanvasRenderingContext2d.cc:1027:64:   required from here
    ../../nan/nan_typedarray_contents.h: In instantiation of ‘Nan::TypedArrayContents<T>::TypedArrayContents(v8::Local<v8::Value>) [with T = double]’:
    ../src/CanvasRenderingContext2d.cc:1752:43:   required from here
      CXX(target) Release/obj.target/canvas/src/closure.o
                     from ../src/closure.h:5,
                     from ../src/closure.cc:1:
      CXX(target) Release/obj.target/canvas/src/color.o
      CXX(target) Release/obj.target/canvas/src/Image.o
    In file included from ../src/Image.h:8,
                     from ../src/Image.cc:3:
      CXX(target) Release/obj.target/canvas/src/ImageData.o
    In file included from ../src/ImageData.h:5,
                     from ../src/ImageData.cc:3:
    ../src/ImageData.cc:116:53:   required from here
      CXX(target) Release/obj.target/canvas/src/init.o
                     from ../src/init.cc:17:
    In file included from ../../nan/nan.h:54,
    ../src/init.cc: At global scope:
    /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:787:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/init.cc:88:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(canvas, init);
      CXX(target) Release/obj.target/canvas/src/register_font.o
      SOLINK_MODULE(target) Release/obj.target/canvas.node
      COPY Release/canvas.node
    make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
    > iobroker.js-controller@3.3.18 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    object system.certificates updated
    object _design/custom updated
    object _design/system updated
    ioBroker configuration updated
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    + iobroker.js-controller@3.3.18
    added 10 packages from 8 contributors and updated 1 package in 94.632s
    21 packages are looking for funding
      run `npm fund` for details
    #66
    @stoni
    iobroker restart
    iobroker status
    S 2 Antworten Letzte Antwort
      @stoni
      iobroker restart
      iobroker status
      Stoni
      #67
      Objects type: file
      States  type: redis
        @stoni
        iobroker restart
        iobroker status
        Stoni
        schrieb am zuletzt editiert von Stoni
        #68
        also ioBroker läuft wieder, der LOG ist auch kräftig am schaffen.
        Die Adapter sind weitesgehend wieder grün, nur der javascript und der WLED sind noch rot.
        EDIT: WLED grün, Javascript weiter rot
        EDIT2: Javascript springt immer von rot auf grün und zurück
        • S Stoni
          #69
          @stoni
          Dann starte den javaskript-Adapter mal neu, Ausgabe aus dem LogFile posten.
            @stoni
            Stoni
            #70
            avascript.0	2021-10-25 21:32:09.769	warn	(3661) Terminated (UNCAUGHT_EXCEPTION): Without reason
            javascript.0	2021-10-25 21:32:09.768	info	(3661) terminating
            javascript.0	2021-10-25 21:32:09.683	error	(3661) The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
            javascript.0	2021-10-25 21:32:09.682	error	(3661) Error: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
            javascript.0	2021-10-25 21:32:09.682	error	(3661) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
            javascript.0	2021-10-25 21:32:09.682	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            javascript.0	2021-10-25 21:32:09.680	error	(3661) The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
            javascript.0	2021-10-25 21:32:09.680	error	(3661) Error: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
            javascript.0	2021-10-25 21:32:09.680	error	(3661) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
            javascript.0	2021-10-25 21:32:09.679	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            javascript.0	2021-10-25 21:32:09.676	info	(3661) Stop script script.js.Heizung.WP_WW_aufbereiten
            javascript.0	2021-10-25 21:32:09.676	info	(3661) Stop script script.js.Heizung.WP_Betrieb_WW
            javascript.0	2021-10-25 21:32:09.675	info	(3661) Stop script script.js.Heizung.WP_Betrieb_HZ_WW
            javascript.0	2021-10-25 21:32:09.675	info	(3661) Stop script script.js.Heizung.WP_ein
            javascript.0	2021-10-25 21:32:09.675	info	(3661) Stop script script.js.Heizung.WP_aus
            javascript.0	2021-10-25 21:32:09.674	info	(3661) Stop script script.js.Heizung.WP_Betrieb_Heizen
            javascript.0	2021-10-25 21:32:09.673	info	(3661) Stop script script.js.Heizung.Entkeimung_Taster
            javascript.0	2021-10-25 21:32:09.673	info	(3661) Stop script script.js.Kellerfenster_Einbruch.Fenster_Hobbykeller
            javascript.0	2021-10-25 21:32:09.673	info	(3661) Stop script script.js.Beleuchtung.Urlaubsbeleuchtung
            javascript.0	2021-10-25 21:32:09.672	info	(3661) Stop script script.js.Garage___Garten___Carport.Carporttor_Abwesend
            javascript.0	2021-10-25 21:32:09.672	info	(3661) Stop script script.js.Garage___Garten___Carport.Carportlicht_BWM
            javascript.0	2021-10-25 21:32:09.671	info	(3661) Stop script script.js.Garage___Garten___Carport.Bewegung_Abwesenheit(1)
            javascript.0	2021-10-25 21:32:09.671	info	(3661) Stop script script.js.Garage___Garten___Carport.Bewegung_Dunkelheit
            javascript.0	2021-10-25 21:32:09.670	info	(3661) Stop script script.js.Garage___Garten___Carport.Garagenlicht
            javascript.0	2021-10-25 21:32:09.670	info	(3661) Stop script script.js.Garage___Garten___Carport.Gartenlicht
            javascript.0	2021-10-25 21:32:09.670	info	(3661) Stop script script.js.Garage___Garten___Carport.Licht_Gartenhaus
            javascript.0	2021-10-25 21:32:09.669	info	(3661) Stop script script.js.Garage___Garten___Carport.WLED_Garage_Beginner
            javascript.0	2021-10-25 21:32:09.669	info	(3661) Stop script script.js.Garage___Garten___Carport.Garagentor_Schalter
            javascript.0	2021-10-25 21:32:09.668	info	(3661) Stop script script.js.Rollläden.Rollläden_Urlaub
            javascript.0	2021-10-25 21:32:09.668	info	(3661) Stop script script.js.common.Batteriestand_Haustür
            javascript.0	2021-10-25 21:32:09.667	info	(3661) Stop script script.js.Anwesenheit.Zisternenpumpe
            javascript.0	2021-10-25 21:32:09.667	info	(3661) Stop script script.js.Anwesenheit.Bewegung_Flur
            javascript.0	2021-10-25 21:32:09.667	info	(3661) Stop script script.js.Anwesenheit.IP_Cams
            javascript.0	2021-10-25 21:32:09.666	info	(3661) Stop script script.js.Rollläden.Beschattung_Süden_OPPLE
            javascript.0	2021-10-25 21:32:09.666	info	(3661) Stop script script.js.Rollläden.Beschattung_Osten_OPPLE
            javascript.0	2021-10-25 21:32:09.665	info	(3661) Stop script script.js.Beleuchtung.OPPLE_3-fach_Wohnzimmer
            javascript.0	2021-10-25 21:32:09.665	info	(3661) Stop script script.js.Sayit.Erinnerung_Tabletten
            javascript.0	2021-10-25 21:32:09.664	info	(3661) Stop script script.js.Rollläden.Rollläden_auf
            javascript.0	2021-10-25 21:32:09.664	info	(3661) Stop script script.js.Kellerfenster_Einbruch.Gästezimmer
            javascript.0	2021-10-25 21:32:09.663	info	(3661) Stop script script.js.Rollläden.Rollladen_Terrasse_ab
            javascript.0	2021-10-25 21:32:09.663	info	(3661) Stop script script.js.Rollläden.Rollläden_EG_ab
            javascript.0	2021-10-25 21:32:09.662	info	(3661) Stop script script.js.Rollläden.Wohnzimmerfenster
            javascript.0	2021-10-25 21:32:09.662	info	(3661) Stop script script.js.Beleuchtung.Nachtlicht-Schlafzimmer
            javascript.0	2021-10-25 21:32:09.661	info	(3661) Stop script script.js.Beleuchtung.Sternenlicht
            javascript.0	2021-10-25 21:32:09.660	info	(3661) Stop script script.js.common.Batterie_iPad_Air
            javascript.0	2021-10-25 21:32:09.660	info	(3661) Stop script script.js.common.Anruf_Nachricht_Pushover
            javascript.0	2021-10-25 21:32:09.659	info	(3661) Stop script script.js.Beleuchtung.Terrassenbeleuchtung(1)
            javascript.0	2021-10-25 21:32:09.659	info	(3661) Stop script script.js.Beleuchtung.indirekte_Beleuchtung(1)
            javascript.0	2021-10-25 21:32:09.658	info	(3661) Stop script script.js.Sayit.Wassermelder_Küche
            javascript.0	2021-10-25 21:32:09.658	info	(3661) Stop script script.js.Sayit.Wassermelder_Keller
            javascript.0	2021-10-25 21:32:09.657	info	(3661) Stop script script.js.Sayit.Rasenmäher_error
            javascript.0	2021-10-25 21:32:09.656	info	(3661) Stop script script.js.Sayit.Bad_OG
            javascript.0	2021-10-25 21:32:09.655	info	(3661) Stop script script.js.Sayit.Hobbykeller_10_Min
            javascript.0	2021-10-25 21:32:09.653	info	(3661) Stop script script.js.Sayit.Gästebad_10_Min
            javascript.0	2021-10-25 21:32:09.651	info	(3661) Stop script script.js.Sayit.Gästebad_5_Min
            javascript.0	2021-10-25 21:32:09.650	info	(3661) Stop script script.js.Sayit.Kinderzimmer_Lea_Sophie
            javascript.0	2021-10-25 21:32:09.649	info	(3661) Stop script script.js.Sayit.Gästezimmer
            javascript.0	2021-10-25 21:32:09.649	info	(3661) Stop script script.js.Sayit.Kinderzimmer_Maximilian
            javascript.0	2021-10-25 21:32:09.645	info	(3661) Stop script script.js.common.PV-Tagesertrag
            javascript.0	2021-10-25 21:32:09.643	info	(3661) Stop script script.js.Sayit.Gefrierschrank_3_Min.
            javascript.0	2021-10-25 21:32:09.642	info	(3661) Stop script script.js.Sayit.Gefrierschrank_2_Min.
            javascript.0	2021-10-25 21:32:09.639	info	(3661) script.js.Heizung.WP_WW_aufbereiten: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.635	info	(3661) Start javascript script.js.Heizung.WP_WW_aufbereiten
            javascript.0	2021-10-25 21:32:09.634	info	(3661) script.js.Heizung.WP_Betrieb_WW: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.630	info	(3661) Start javascript script.js.Heizung.WP_Betrieb_WW
            javascript.0	2021-10-25 21:32:09.629	info	(3661) script.js.Heizung.WP_Betrieb_HZ_WW: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.625	info	(3661) Start javascript script.js.Heizung.WP_Betrieb_HZ_WW
            javascript.0	2021-10-25 21:32:09.624	info	(3661) script.js.Heizung.WP_ein: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.620	info	(3661) Start javascript script.js.Heizung.WP_ein
            javascript.0	2021-10-25 21:32:09.619	info	(3661) script.js.Heizung.WP_aus: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.615	info	(3661) Start javascript script.js.Heizung.WP_aus
            javascript.0	2021-10-25 21:32:09.614	info	(3661) script.js.Heizung.WP_Betrieb_Heizen: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.610	info	(3661) Start javascript script.js.Heizung.WP_Betrieb_Heizen
            javascript.0	2021-10-25 21:32:09.609	info	(3661) script.js.Heizung.Entkeimung_Taster: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.605	info	(3661) Start javascript script.js.Heizung.Entkeimung_Taster
            javascript.0	2021-10-25 21:32:09.604	info	(3661) script.js.Kellerfenster_Einbruch.Fenster_Hobbykeller: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.600	info	(3661) Start javascript script.js.Kellerfenster_Einbruch.Fenster_Hobbykeller
            javascript.0	2021-10-25 21:32:09.599	info	(3661) script.js.Beleuchtung.Urlaubsbeleuchtung: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.595	info	(3661) Start javascript script.js.Beleuchtung.Urlaubsbeleuchtung
            javascript.0	2021-10-25 21:32:09.594	info	(3661) script.js.Garage___Garten___Carport.Carporttor_Abwesend: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.590	info	(3661) Start javascript script.js.Garage___Garten___Carport.Carporttor_Abwesend
            javascript.0	2021-10-25 21:32:09.590	info	(3661) script.js.Garage___Garten___Carport.Carportlicht_BWM: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.586	info	(3661) Start javascript script.js.Garage___Garten___Carport.Carportlicht_BWM
            javascript.0	2021-10-25 21:32:09.585	info	(3661) script.js.Garage___Garten___Carport.Bewegung_Abwesenheit(1): registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.581	info	(3661) Start javascript script.js.Garage___Garten___Carport.Bewegung_Abwesenheit(1)
            javascript.0	2021-10-25 21:32:09.580	info	(3661) script.js.Garage___Garten___Carport.Bewegung_Dunkelheit: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.576	info	(3661) Start javascript script.js.Garage___Garten___Carport.Bewegung_Dunkelheit
            javascript.0	2021-10-25 21:32:09.576	info	(3661) script.js.Garage___Garten___Carport.Garagenlicht: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.572	info	(3661) Start javascript script.js.Garage___Garten___Carport.Garagenlicht
            javascript.0	2021-10-25 21:32:09.571	info	(3661) script.js.Garage___Garten___Carport.Gartenlicht: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.567	info	(3661) Start javascript script.js.Garage___Garten___Carport.Gartenlicht
            javascript.0	2021-10-25 21:32:09.566	info	(3661) script.js.Garage___Garten___Carport.Licht_Gartenhaus: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.563	info	(3661) Start javascript script.js.Garage___Garten___Carport.Licht_Gartenhaus
            javascript.0	2021-10-25 21:32:09.562	info	(3661) script.js.Garage___Garten___Carport.WLED_Garage_Beginner: registered 4 subscriptions and 0 schedules
            javascript.0	2021-10-25 21:32:09.557	info	(3661) Start javascript script.js.Garage___Garten___Carport.WLED_Garage_Beginner
            javascript.0	2021-10-25 21:32:09.557	info	(3661) script.js.Garage___Garten___Carport.Garagentor_Schalter: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.553	info	(3661) Start javascript script.js.Garage___Garten___Carport.Garagentor_Schalter
            javascript.0	2021-10-25 21:32:09.552	info	(3661) script.js.Rollläden.Rollläden_Urlaub: registered 2 subscriptions and 0 schedules
            javascript.0	2021-10-25 21:32:09.547	info	(3661) Start javascript script.js.Rollläden.Rollläden_Urlaub
            javascript.0	2021-10-25 21:32:09.546	info	(3661) script.js.common.Batteriestand_Haustür: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.542	info	(3661) Start javascript script.js.common.Batteriestand_Haustür
            javascript.0	2021-10-25 21:32:09.541	info	(3661) script.js.Anwesenheit.Zisternenpumpe: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.537	info	(3661) Start javascript script.js.Anwesenheit.Zisternenpumpe
            javascript.0	2021-10-25 21:32:09.536	info	(3661) script.js.Anwesenheit.Bewegung_Flur: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.532	info	(3661) Start javascript script.js.Anwesenheit.Bewegung_Flur
            javascript.0	2021-10-25 21:32:09.532	info	(3661) script.js.Anwesenheit.IP_Cams: registered 2 subscriptions and 0 schedules
            javascript.0	2021-10-25 21:32:09.527	info	(3661) Start javascript script.js.Anwesenheit.IP_Cams
            javascript.0	2021-10-25 21:32:09.527	info	(3661) script.js.Rollläden.Beschattung_Süden_OPPLE: registered 2 subscriptions and 0 schedules
            javascript.0	2021-10-25 21:32:09.523	info	(3661) Start javascript script.js.Rollläden.Beschattung_Süden_OPPLE
            javascript.0	2021-10-25 21:32:09.522	info	(3661) script.js.Rollläden.Beschattung_Osten_OPPLE: registered 2 subscriptions and 0 schedules
            javascript.0	2021-10-25 21:32:09.518	info	(3661) Start javascript script.js.Rollläden.Beschattung_Osten_OPPLE
            javascript.0	2021-10-25 21:32:09.517	info	(3661) script.js.Beleuchtung.OPPLE_3-fach_Wohnzimmer: registered 3 subscriptions and 0 schedules
            javascript.0	2021-10-25 21:32:09.513	info	(3661) Start javascript script.js.Beleuchtung.OPPLE_3-fach_Wohnzimmer
            javascript.0	2021-10-25 21:32:09.512	info	(3661) script.js.Sayit.Erinnerung_Tabletten: registered 0 subscriptions and 1 schedule
            javascript.0	2021-10-25 21:32:09.506	info	(3661) Start javascript script.js.Sayit.Erinnerung_Tabletten
            javascript.0	2021-10-25 21:32:09.505	info	(3661) script.js.Rollläden.Rollläden_auf: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.501	info	(3661) Start javascript script.js.Rollläden.Rollläden_auf
            javascript.0	2021-10-25 21:32:09.501	info	(3661) script.js.Kellerfenster_Einbruch.Gästezimmer: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.497	info	(3661) Start javascript script.js.Kellerfenster_Einbruch.Gästezimmer
            javascript.0	2021-10-25 21:32:09.496	info	(3661) script.js.Rollläden.Rollladen_Terrasse_ab: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.492	info	(3661) Start javascript script.js.Rollläden.Rollladen_Terrasse_ab
            javascript.0	2021-10-25 21:32:09.491	info	(3661) script.js.Rollläden.Rollläden_EG_ab: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.487	info	(3661) Start javascript script.js.Rollläden.Rollläden_EG_ab
            javascript.0	2021-10-25 21:32:09.487	info	(3661) script.js.Rollläden.Wohnzimmerfenster: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.483	info	(3661) Start javascript script.js.Rollläden.Wohnzimmerfenster
            javascript.0	2021-10-25 21:32:09.482	info	(3661) script.js.Beleuchtung.Nachtlicht-Schlafzimmer: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.478	info	(3661) Start javascript script.js.Beleuchtung.Nachtlicht-Schlafzimmer
            javascript.0	2021-10-25 21:32:09.477	info	(3661) script.js.Beleuchtung.Sternenlicht: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.473	info	(3661) Start javascript script.js.Beleuchtung.Sternenlicht
            javascript.0	2021-10-25 21:32:09.473	info	(3661) script.js.common.Batterie_iPad_Air: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.469	info	(3661) Start javascript script.js.common.Batterie_iPad_Air
            javascript.0	2021-10-25 21:32:09.468	info	(3661) script.js.common.Anruf_Nachricht_Pushover: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.464	info	(3661) Start javascript script.js.common.Anruf_Nachricht_Pushover
            javascript.0	2021-10-25 21:32:09.463	info	(3661) script.js.Beleuchtung.Terrassenbeleuchtung(1): registered 2 subscriptions and 0 schedules
            javascript.0	2021-10-25 21:32:09.459	info	(3661) Start javascript script.js.Beleuchtung.Terrassenbeleuchtung(1)
            javascript.0	2021-10-25 21:32:09.458	info	(3661) script.js.Beleuchtung.indirekte_Beleuchtung(1): registered 2 subscriptions and 0 schedules
            javascript.0	2021-10-25 21:32:09.454	info	(3661) Start javascript script.js.Beleuchtung.indirekte_Beleuchtung(1)
            javascript.0	2021-10-25 21:32:09.453	info	(3661) script.js.Sayit.Wassermelder_Küche: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.449	info	(3661) Start javascript script.js.Sayit.Wassermelder_Küche
            javascript.0	2021-10-25 21:32:09.448	info	(3661) script.js.Sayit.Wassermelder_Keller: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.444	info	(3661) Start javascript script.js.Sayit.Wassermelder_Keller
            javascript.0	2021-10-25 21:32:09.444	info	(3661) script.js.Sayit.Rasenmäher_error: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.440	info	(3661) Start javascript script.js.Sayit.Rasenmäher_error
            javascript.0	2021-10-25 21:32:09.439	info	(3661) script.js.Sayit.Bad_OG: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.435	info	(3661) Start javascript script.js.Sayit.Bad_OG
            javascript.0	2021-10-25 21:32:09.434	info	(3661) script.js.Sayit.Hobbykeller_10_Min: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.430	info	(3661) Start javascript script.js.Sayit.Hobbykeller_10_Min
            javascript.0	2021-10-25 21:32:09.430	info	(3661) script.js.Sayit.Gästebad_10_Min: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.426	info	(3661) Start javascript script.js.Sayit.Gästebad_10_Min
            javascript.0	2021-10-25 21:32:09.425	info	(3661) script.js.Sayit.Gästebad_5_Min: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.421	info	(3661) Start javascript script.js.Sayit.Gästebad_5_Min
            javascript.0	2021-10-25 21:32:09.420	info	(3661) script.js.Sayit.Kinderzimmer_Lea_Sophie: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.416	info	(3661) Start javascript script.js.Sayit.Kinderzimmer_Lea_Sophie
            javascript.0	2021-10-25 21:32:09.415	info	(3661) script.js.Sayit.Gästezimmer: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.411	info	(3661) Start javascript script.js.Sayit.Gästezimmer
            javascript.0	2021-10-25 21:32:09.410	info	(3661) script.js.Sayit.Kinderzimmer_Maximilian: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.406	info	(3661) Start javascript script.js.Sayit.Kinderzimmer_Maximilian
            javascript.0	2021-10-25 21:32:09.406	info	(3661) script.js.common.PV-Tagesertrag: registered 0 subscriptions and 1 schedule
            javascript.0	2021-10-25 21:32:09.387	info	(3661) Start javascript script.js.common.PV-Tagesertrag
            javascript.0	2021-10-25 21:32:09.384	error	(3661) The id "scriptProblem.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
            javascript.0	2021-10-25 21:32:09.384	error	(3661) Error: The id "scriptProblem.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
            javascript.0	2021-10-25 21:32:09.383	error	(3661) unhandled promise rejection: The id "scriptProblem.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
            javascript.0	2021-10-25 21:32:09.383	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            javascript.0	2021-10-25 21:32:09.382	error	(3661) The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
            javascript.0	2021-10-25 21:32:09.381	error	(3661) Error: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
            javascript.0	2021-10-25 21:32:09.381	error	(3661) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
            javascript.0	2021-10-25 21:32:09.380	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            javascript.0	2021-10-25 21:32:09.379	info	(3661) script.js.Sayit.Gefrierschrank_3_Min.: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.370	info	(3661) Start javascript script.js.Sayit.Gefrierschrank_3_Min.
            javascript.0	2021-10-25 21:32:09.369	error	(3661) The id "scriptProblem.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
            javascript.0	2021-10-25 21:32:09.368	error	(3661) Error: The id "scriptProblem.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
            javascript.0	2021-10-25 21:32:09.368	error	(3661) unhandled promise rejection: The id "scriptProblem.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
            javascript.0	2021-10-25 21:32:09.367	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            javascript.0	2021-10-25 21:32:09.366	error	(3661) The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
            javascript.0	2021-10-25 21:32:09.365	error	(3661) Error: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
            javascript.0	2021-10-25 21:32:09.365	error	(3661) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
            javascript.0	2021-10-25 21:32:09.364	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            javascript.0	2021-10-25 21:32:09.359	info	(3661) script.js.Sayit.Gefrierschrank_2_Min.: registered 1 subscription and 0 schedules
            javascript.0	2021-10-25 21:32:09.341	info	(3661) Start javascript script.js.Sayit.Gefrierschrank_2_Min.
            javascript.0	2021-10-25 21:32:09.199	warn	(3661) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
            javascript.0	2021-10-25 21:32:09.196	info	(3661) received all objects
            javascript.0	2021-10-25 21:32:08.351	info	(3661) received all states
            javascript.0	2021-10-25 21:32:07.566	warn	(3661) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
            javascript.0	2021-10-25 21:32:07.565	info	(3661) requesting all objects
            javascript.0	2021-10-25 21:32:07.563	info	(3661) requesting all states
            javascript.0	2021-10-25 21:32:07.515	info	(3661) starting. Version 4.1.12 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.18.1, js-controller: 3.3.18
            • S Stoni
              #71
              @stoni sagte in Hilfe bei Update des gesamten Systems:
              Skripte dürfen nicht auf einen Punkt enden.
              Warum macht man sowas überhaupt? Ist auch z. B. unter Windows keine gute Idee für Dateinamen.
                Stoni
                #72
                war nie ein Problem. Habs geändert.
                Problem bleibt bestehen:
                javascript.0	2021-10-25 21:43:51.964	warn	(11093) Terminated (UNCAUGHT_EXCEPTION): Without reason
                javascript.0	2021-10-25 21:43:51.962	info	(11093) terminating
                javascript.0	2021-10-25 21:43:51.880	error	(11093) The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                javascript.0	2021-10-25 21:43:51.880	error	(11093) Error: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:
                javascript.0	2021-10-25 21:43:51.879	error	(11093) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                javascript.0	2021-10-25 21:43:51.879	error	(11093) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                javascript.0	2021-10-25 21:43:51.878	error	(11093) The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                javascript.0	2021-10-25 21:43:51.877	error	(11093) Error: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:
                javascript.0	2021-10-25 21:43:51.877	error	(11093) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                javascript.0	2021-10-25 21:43:51.876	error	(11093) Unhandled promise rejection. This error originated either by throwing inside of an async function wit
                Hab den Adapter schon wiederholt neu geladen,
                  Stoni
                  #73
                  für den JS-Adapter ist ein Update verfügbar. 4.1.12 auf 5.2.8. Soll ich das mal durchführen?
                  • S Stoni
                    #74
                    Doch, aber es wurde bislang nicht angemeckert.
                    Ich weiß nicht, ob und wo die ids der skripte geführt werden und ggf. noch angepasst werden müssen. Das muss vielleicht mal jemand mit mehr Einblick in den javaskript-Adapter anschauen.
                    So nebenher:
                    Probier mal aus, ob der Fixer jetzt funtioniert.
                    iobroker stop
                    iobroker fix
                    iobroker start
                    • S Stoni
                      #75
                      zeig mal die Objekte dazu
                        Stoni
                        #76
                        @homoran @Thomas-Braun
                        also den fix führe ich morgen mal durch. Da hab ich jetzt irgendwie schiss, dass wieder was passiert.
                        Die javascripte mit dem Punkt am Ende lassen sich nicht ändern. Wie kann man die umbenennen?
                        • S Stoni
                          #77
                          Jetzt schaut dir aber jemand dabei über die Schulter.
                          • S Stoni
                            #78
                            Ich hatte irgendwo gelesen, dass das Gefummel ist. Andere user waren auch so 'kreativ' in der Benennung ihrer Skripte.
                              Stoni
                              #79
                              Ich werde dazu mal ein wenig recherchieren. Wichtig ist, es läuft erstmal größtenteils. Nodejs ist etwas aktueller, und der js-controller aktuell.
                              Ich möchte mich bei Dir und @Homoran für die Hilfe und die investierte Zeit bedanken.
                              Gibt es noch etwas, was ich tun sollte? Oder ist das System nun einigermaßen up2date?
                              Ich möchte dann als nächstes die Adapter möglichst aktualisieren. Denke jetzt sollte es ja gehen. Spricht was dagegen, jetzt auch den Admin auf 5 upzudaten?
                              • S Stoni
                                #80
                                @stoni
                                Das solltest du machen. Vielleicht immer einen nach dem anderen, dann hast du besser im Blick wo es klemmt.
                                Admin5 ist der aktuelle Admin, es gibt auch einige Adapter die den mehr oder weniger unbedingt voraussetzen.
                                  @stoni
                                  Stoni
                                  #81
                                  @thomas-braun Alles klar. Danke. Ich werde berichten ;-)
                                    @stoni
                                    Stoni
                                    #82
                                    @thomas-braun System läuft soweit. Habe jetzt nahezu alle Adapter aktualisiert.
                                    Im Log kommen noch so komische Warnungen:
                                    yeelight-2.0
                                    2021-10-26 20:10:27.194	info	State value to set for "yeelight-2.0.Stehleuchte_Erker.control.ct" has to be type "number" but received type "string"
                                    yeelight-2.0
                                    2021-10-26 20:10:27.192	info	State value to set for "yeelight-2.0.Stehleuchte_Erker.control.active_bright" has to be type "number" but received type "string"
                                    mihome-vacuum.0
                                    2021-10-26 20:10:27.032	info	State value to set for "mihome-vacuum.0.info.water_box" has to be type "string" but received type "boolean"
                                    Was hat es damit auf sich?
                                    • S Stoni
                                      yeelight-2.0
                                      yeelight-2.0
                                      mihome-vacuum.0
                                      #83
                                      Steht in der Readme zum js-controller drin, wenn ich mich recht erinnere.
                                      Hier z. B. auch Thema:
                                      https://forum.iobroker.net/topic/46776/meldungen-seit-controller-v3-3-zu-falschem-datentyp
                                        Stoni
                                        #84
                                        Hi, das System läuft soweit stabil seit dem Update. Danke nochmal für Deine Hilfe.
                                        Nun steht ein Update für den Admin (5.1.25 auf 5.2.3) und den js-controller (3.3.18 auf 3.3.22) bereit. In welcher Reihenfolge gehe ich da am Besten vor?
                                        Ich gehe davon aus, dass die Updates empfohlen werden und man nicht bis zur überübernächsten Version wartet oder?
                                        Gruß Stoni
                                        • S Stoni
                                          Gruß Stoni
                                          #85
                                          @stoni
                                          Mit Updates wartet man nie auf irgendwas. Die spielt man sofort ein.
                                          Bei so kleinen Versionssprüngen ist auch die Reihenfolge weniger wichtig.
                                          iobroker stop
                                          iobroker update
                                          iobroker upgrade self
                                          iobroker upgrade
                                          iobroker start
