  4. Hilfe bei Update des gesamten Systems
    1.0k
    6.1k
updateupgradenodejs
86 Beiträge 5 Kommentatoren 12.1k Aufrufe 3 Beobachtet
  • S Stoni
    war nie ein Problem. Habs geändert.
    Problem bleibt bestehen:
    javascript.0	2021-10-25 21:43:51.964	warn	(11093) Terminated (UNCAUGHT_EXCEPTION): Without reason
    javascript.0	2021-10-25 21:43:51.962	info	(11093) terminating
    javascript.0	2021-10-25 21:43:51.880	error	(11093) The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
    javascript.0	2021-10-25 21:43:51.880	error	(11093) Error: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:
    javascript.0	2021-10-25 21:43:51.879	error	(11093) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
    javascript.0	2021-10-25 21:43:51.879	error	(11093) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    javascript.0	2021-10-25 21:43:51.878	error	(11093) The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
    javascript.0	2021-10-25 21:43:51.877	error	(11093) Error: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:
    javascript.0	2021-10-25 21:43:51.877	error	(11093) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
    javascript.0	2021-10-25 21:43:51.876	error	(11093) Unhandled promise rejection. This error originated either by throwing inside of an async function wit
    Hab den Adapter schon wiederholt neu geladen,
    #75
    @stoni sagte in Hilfe bei Update des gesamten Systems:
    zeig mal die Objekte dazu
      Stoni
      #76
      @homoran @Thomas-Braun
      also den fix führe ich morgen mal durch. Da hab ich jetzt irgendwie schiss, dass wieder was passiert.
      Die javascripte mit dem Punkt am Ende lassen sich nicht ändern. Wie kann man die umbenennen?
      • S Stoni
        #77
        Jetzt schaut dir aber jemand dabei über die Schulter.
        • S Stoni
          #78
          Ich hatte irgendwo gelesen, dass das Gefummel ist. Andere user waren auch so 'kreativ' in der Benennung ihrer Skripte.
            Stoni
            #79
            Ich werde dazu mal ein wenig recherchieren. Wichtig ist, es läuft erstmal größtenteils. Nodejs ist etwas aktueller, und der js-controller aktuell.
            Ich möchte mich bei Dir und @Homoran für die Hilfe und die investierte Zeit bedanken.
            Gibt es noch etwas, was ich tun sollte? Oder ist das System nun einigermaßen up2date?
            Ich möchte dann als nächstes die Adapter möglichst aktualisieren. Denke jetzt sollte es ja gehen. Spricht was dagegen, jetzt auch den Admin auf 5 upzudaten?
            • S Stoni
              #80
              @stoni
              Das solltest du machen. Vielleicht immer einen nach dem anderen, dann hast du besser im Blick wo es klemmt.
              Admin5 ist der aktuelle Admin, es gibt auch einige Adapter die den mehr oder weniger unbedingt voraussetzen.
              S 2 Antworten Letzte Antwort
                @stoni
                Stoni
                #81
                @thomas-braun Alles klar. Danke. Ich werde berichten ;-)
                  @stoni
                  Stoni
                  #82
                  @thomas-braun System läuft soweit. Habe jetzt nahezu alle Adapter aktualisiert.
                  Im Log kommen noch so komische Warnungen:
                  yeelight-2.0
                  2021-10-26 20:10:27.194	info	State value to set for "yeelight-2.0.Stehleuchte_Erker.control.ct" has to be type "number" but received type "string"
                  yeelight-2.0
                  2021-10-26 20:10:27.192	info	State value to set for "yeelight-2.0.Stehleuchte_Erker.control.active_bright" has to be type "number" but received type "string"
                  mihome-vacuum.0
                  2021-10-26 20:10:27.032	info	State value to set for "mihome-vacuum.0.info.water_box" has to be type "string" but received type "boolean"
                  Was hat es damit auf sich?
                  • S Stoni
                    yeelight-2.0
                    yeelight-2.0
                    mihome-vacuum.0
                    #83
                    Steht in der Readme zum js-controller drin, wenn ich mich recht erinnere.
                    Hier z. B. auch Thema:
                    https://forum.iobroker.net/topic/46776/meldungen-seit-controller-v3-3-zu-falschem-datentyp
                      Stoni
                      #84
                      Hi, das System läuft soweit stabil seit dem Update. Danke nochmal für Deine Hilfe.
                      Nun steht ein Update für den Admin (5.1.25 auf 5.2.3) und den js-controller (3.3.18 auf 3.3.22) bereit. In welcher Reihenfolge gehe ich da am Besten vor?
                      Ich gehe davon aus, dass die Updates empfohlen werden und man nicht bis zur überübernächsten Version wartet oder?
                      Gruß Stoni
                      • S Stoni
                        Gruß Stoni
                        #85
                        @stoni
                        Mit Updates wartet man nie auf irgendwas. Die spielt man sofort ein.
                        Bei so kleinen Versionssprüngen ist auch die Reihenfolge weniger wichtig.
                        iobroker stop
                        iobroker update
                        iobroker upgrade self
                        iobroker upgrade
                        iobroker start
                          @stoni
                          iobroker stop
                          iobroker update
                          iobroker upgrade
                          iobroker start
                          Stoni
                          #86
                          @thomas-braun danke
