  4. Hilfe bei Update des gesamten Systems
    1.0k
    6.1k
updateupgradenodejs
86 Beiträge 5 Kommentatoren 12.1k Aufrufe 3 Beobachtet
  • S Stoni
    @thomas-braun @Homoran
    kann jetzt nicht mehr auf ioBroker zugreifen...
    @stoni
    ls -la /opt/iobroker/
      @stoni
      Stoni
      insgesamt 588
      drwxrwxr-x+   9 iobroker iobroker   4096 Jan 19  2021 .
      drwxr-xr-x    4 root     root       4096 Nov 27  2019 ..
      drwxrwxr-x+   2 pi       pi         4096 Okt 24 20:51 backups
      drwxrwxr-x+   2 iobroker iobroker   4096 Feb  4  2021 cache
      -rw-rwxr--+   1 iobroker iobroker   1049 Nov 27  2019 CHANGELOG_FIXER_LINUX.md
      -rw-rwxr--+   1 iobroker iobroker   3556 Nov 27  2019 CHANGELOG_INSTALLER_LINUX.md
      -rw-rwxr--+   1 iobroker iobroker  23988 Nov 27  2019 fix_installation.sh
      drwxrwxr-x+   3 iobroker iobroker   4096 Nov 27  2019 install
      -rwxrwxrwx+   1 iobroker iobroker    163 Nov 27  2019 INSTALLER_INFO.txt
      lrwxrwxrwx    1 iobroker iobroker     22 Nov 27  2019 iob -> /opt/iobroker/iobroker
      -rwxrwxr-x+   1 iobroker iobroker    303 Nov 27  2019 iobroker
      drwxrwxr-x+   7 iobroker iobroker   4096 Okt 25 20:17 iobroker-data
      drwxrwxr-x+   2 iobroker iobroker   4096 Nov 27  2019 lib
      -rw-rwxr--+   1 iobroker iobroker   1137 Nov 27  2019 LICENSE
      drwxrwxr-x+   2 iobroker iobroker  36864 Okt 25 20:03 log
      drwxrwxr-x+ 600 iobroker iobroker  36864 Okt 25 20:03 node_modules
      -rw-rwxr--+   1 iobroker iobroker     42 Nov 27  2019 .npmrc
      -rw-rwxr--+   1 iobroker iobroker   2556 Jan 19  2021 package.json
      -rw-rwxr--+   1 iobroker iobroker 419598 Jan 19  2021 package-lock.json
      -rw-rwxr--+   1 iobroker iobroker   6101 Nov 27  2019 README.md
      -rw-rwxr--+   1 iobroker iobroker   5738 Nov 27  2019 reinstall.js
      • S Stoni
        insgesamt 588
        @stoni
        iobroker status
          @stoni
          iobroker status
          Stoni
          @thomas-braun sagte in Hilfe bei Update des gesamten Systems:
          iobroker status
          internal/modules/cjs/loader.js:905
            throw err;
          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
              at Function.Module._load (internal/modules/cjs/loader.js:746:27)
              at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)
              at internal/main/run_main_module.js:17:47 {
            code: 'MODULE_NOT_FOUND',
            requireStack: []
          • S Stoni
            iobroker status
              throw err;
              requireStack: []
            @stoni
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.js-controller
              @stoni
              cd /opt/iobroker
              Stoni
              npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
              > iobroker.js-controller@3.3.18 preinstall /opt/iobroker/node_modules/iobroker.js-controller
              > node lib/preinstallCheck.js
              NPM version: 6.14.15
              > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
              > node-pre-gyp install --fallback-to-build
              node-pre-gyp WARN Using request for node-pre-gyp https download
              node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v83-linux-glibc-arm.tar.gz
              node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@14.18.1 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
              Package pixman-1 was not found in the pkg-config search path.
              Perhaps you should add the directory containing `pixman-1.pc'
              to the PKG_CONFIG_PATH environment variable
              No package 'pixman-1' found
              gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
              gyp ERR! configure error
              gyp ERR! stack Error: `gyp` failed with exit code: 1
              gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
              gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
              gyp ERR! System Linux 5.10.63-v7l+
              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
              gyp ERR! cwd /opt/iobroker/node_modules/canvas
              gyp ERR! node -v v14.18.1
              gyp ERR! node-gyp -v v5.1.0
              gyp ERR! not ok
              node-pre-gyp ERR! build error
              node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
              node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
              node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
              node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1058:16)
              node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
              node-pre-gyp ERR! System Linux 5.10.63-v7l+
              node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
              node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
              node-pre-gyp ERR! node -v v14.18.1
              node-pre-gyp ERR! node-pre-gyp -v v0.11.0
              node-pre-gyp ERR! not ok
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the canvas@2.6.1 install script.
              npm ERR!     /home/iobroker/.npm/_logs/2021-10-25T18_58_11_047Z-debug.log
              • S Stoni
                gyp ERR! not ok
                npm ERR! errno 1
                npm ERR!
                @stoni sagte in Hilfe bei Update des gesamten Systems:
                pixman-1
                sudo apt update
                sudo apt install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                Dann nochmal
                cd /opt/iobroker
                  pixman-1
                  sudo apt update
                  Dann nochmal
                  cd /opt/iobroker
                  Stoni
                  sieht aus, als wäre es ohne Fehler durchgelaufen
                  make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
                    SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
                    COPY Release/canvas-postbuild.node
                    CXX(target) Release/obj.target/canvas/src/backend/Backend.o
                  In file included from ../src/backend/Backend.h:6,
                                   from ../src/backend/Backend.cc:1:
                  ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                  ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                       , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                    CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
                                   from ../src/backend/ImageBackend.h:3,
                                   from ../src/backend/ImageBackend.cc:1:
                    CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
                                   from ../src/backend/PdfBackend.h:3,
                                   from ../src/backend/PdfBackend.cc:1:
                    CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                                   from ../src/backend/SvgBackend.h:3,
                                   from ../src/backend/SvgBackend.cc:1:
                    CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
                  ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
                  ../src/bmp/BMPParser.cc:189:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
                     E(ptr - data > imgdOffset, "image data overlaps with another structure");
                  ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
                   #define E(cond, msg) if(cond) return setErr(msg)
                  ../src/bmp/BMPParser.cc:204:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
                     E(ptr - data + imgdSize > len, "not enough image data");
                    CXX(target) Release/obj.target/canvas/src/Backends.o
                                   from ../src/Backends.h:3,
                                   from ../src/Backends.cc:1:
                    CXX(target) Release/obj.target/canvas/src/Canvas.o
                                   from ../src/Canvas.h:5,
                                   from ../src/Canvas.cc:3:
                  ../src/Canvas.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Canvas::ToBuffer(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/Canvas.cc:415:26: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘unsigned int’} [-Wsign-compare]
                       if (canvas->nBytes() > node::Buffer::kMaxLength) {
                  ../src/Canvas.cc:479:79: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                   ue_work(uv_default_loop(), req, ToPngBufferAsync, (uv_after_work_cb)ToBufferAsyncAfter);
                  ../src/Canvas.cc:520:80: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                   e_work(uv_default_loop(), req, ToJpegBufferAsync, (uv_after_work_cb)ToBufferAsyncAfter);
                  In file included from ../../nan/nan.h:2884,
                  ../../nan/nan_typedarray_contents.h: In instantiation of ‘Nan::TypedArrayContents<T>::TypedArrayContents(v8::Local<v8::Value>) [with T = unsigned char]’:
                  ../src/Canvas.cc:274:65:   required from here
                  ../../nan/nan_typedarray_contents.h:34:54: warning: ‘v8::ArrayBuffer::Contents v8::ArrayBuffer::GetContents()’ is deprecated: Use GetBackingStore. See http://crbug.com/v8/9908. [-Wdeprecated-declarations]
                         data   = static_cast<char*>(buffer->GetContents().Data()) + byte_offset;
                  In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67,
                                   from ../../nan/nan.h:54,
                  /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:5273:12: note: declared here
                     Contents GetContents();
                    CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
                  In file included from ../src/CanvasGradient.h:5,
                                   from ../src/CanvasGradient.cc:3:
                    CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
                  In file included from ../src/CanvasPattern.h:6,
                                   from ../src/CanvasPattern.cc:3:
                    CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                                   from ../src/CanvasRenderingContext2d.h:6,
                                   from ../src/CanvasRenderingContext2d.cc:3:
                  ../src/CanvasRenderingContext2d.cc:1027:64:   required from here
                  ../../nan/nan_typedarray_contents.h: In instantiation of ‘Nan::TypedArrayContents<T>::TypedArrayContents(v8::Local<v8::Value>) [with T = double]’:
                  ../src/CanvasRenderingContext2d.cc:1752:43:   required from here
                    CXX(target) Release/obj.target/canvas/src/closure.o
                                   from ../src/closure.h:5,
                                   from ../src/closure.cc:1:
                    CXX(target) Release/obj.target/canvas/src/color.o
                    CXX(target) Release/obj.target/canvas/src/Image.o
                  In file included from ../src/Image.h:8,
                                   from ../src/Image.cc:3:
                    CXX(target) Release/obj.target/canvas/src/ImageData.o
                  In file included from ../src/ImageData.h:5,
                                   from ../src/ImageData.cc:3:
                  ../src/ImageData.cc:116:53:   required from here
                    CXX(target) Release/obj.target/canvas/src/init.o
                                   from ../src/init.cc:17:
                  In file included from ../../nan/nan.h:54,
                  ../src/init.cc: At global scope:
                  /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:787:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                         (node::addon_register_func) (regfunc),                          \
                  /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’
                     NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                  ../src/init.cc:88:1: note: in expansion of macro ‘NODE_MODULE’
                   NODE_MODULE(canvas, init);
                    CXX(target) Release/obj.target/canvas/src/register_font.o
                    SOLINK_MODULE(target) Release/obj.target/canvas.node
                    COPY Release/canvas.node
                  make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
                  > iobroker.js-controller@3.3.18 install /opt/iobroker/node_modules/iobroker.js-controller
                  > node iobroker.js setup first
                  object system.certificates updated
                  object _design/custom updated
                  object _design/system updated
                  ioBroker configuration updated
                  + iobroker.js-controller@3.3.18
                  added 10 packages from 8 contributors and updated 1 package in 94.632s
                  21 packages are looking for funding
                    run `npm fund` for details
                  • S Stoni
                    #66
                    @stoni
                    iobroker restart
                    iobroker status
                    S 2 Antworten Letzte Antwort
                      @stoni
                      iobroker restart
                      iobroker status
                      Stoni
                      #67
                      Objects type: file
                      States  type: redis
                        @stoni
                        iobroker restart
                        iobroker status
                        Stoni
                        schrieb am zuletzt editiert von Stoni
                        #68
                        also ioBroker läuft wieder, der LOG ist auch kräftig am schaffen.
                        Die Adapter sind weitesgehend wieder grün, nur der javascript und der WLED sind noch rot.
                        EDIT: WLED grün, Javascript weiter rot
                        EDIT2: Javascript springt immer von rot auf grün und zurück
                        • S Stoni
                          #69
                          @stoni
                          Dann starte den javaskript-Adapter mal neu, Ausgabe aus dem LogFile posten.
                            @stoni
                            Stoni
                            #70
                            avascript.0	2021-10-25 21:32:09.769	warn	(3661) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            javascript.0	2021-10-25 21:32:09.768	info	(3661) terminating
                            javascript.0	2021-10-25 21:32:09.683	error	(3661) The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                            javascript.0	2021-10-25 21:32:09.682	error	(3661) Error: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
                            javascript.0	2021-10-25 21:32:09.682	error	(3661) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                            javascript.0	2021-10-25 21:32:09.682	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            javascript.0	2021-10-25 21:32:09.680	error	(3661) The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                            javascript.0	2021-10-25 21:32:09.680	error	(3661) Error: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
                            javascript.0	2021-10-25 21:32:09.680	error	(3661) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                            javascript.0	2021-10-25 21:32:09.679	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            javascript.0	2021-10-25 21:32:09.676	info	(3661) Stop script script.js.Heizung.WP_WW_aufbereiten
                            javascript.0	2021-10-25 21:32:09.676	info	(3661) Stop script script.js.Heizung.WP_Betrieb_WW
                            javascript.0	2021-10-25 21:32:09.675	info	(3661) Stop script script.js.Heizung.WP_Betrieb_HZ_WW
                            javascript.0	2021-10-25 21:32:09.675	info	(3661) Stop script script.js.Heizung.WP_ein
                            javascript.0	2021-10-25 21:32:09.675	info	(3661) Stop script script.js.Heizung.WP_aus
                            javascript.0	2021-10-25 21:32:09.674	info	(3661) Stop script script.js.Heizung.WP_Betrieb_Heizen
                            javascript.0	2021-10-25 21:32:09.673	info	(3661) Stop script script.js.Heizung.Entkeimung_Taster
                            javascript.0	2021-10-25 21:32:09.673	info	(3661) Stop script script.js.Kellerfenster_Einbruch.Fenster_Hobbykeller
                            javascript.0	2021-10-25 21:32:09.673	info	(3661) Stop script script.js.Beleuchtung.Urlaubsbeleuchtung
                            javascript.0	2021-10-25 21:32:09.672	info	(3661) Stop script script.js.Garage___Garten___Carport.Carporttor_Abwesend
                            javascript.0	2021-10-25 21:32:09.672	info	(3661) Stop script script.js.Garage___Garten___Carport.Carportlicht_BWM
                            javascript.0	2021-10-25 21:32:09.671	info	(3661) Stop script script.js.Garage___Garten___Carport.Bewegung_Abwesenheit(1)
                            javascript.0	2021-10-25 21:32:09.671	info	(3661) Stop script script.js.Garage___Garten___Carport.Bewegung_Dunkelheit
                            javascript.0	2021-10-25 21:32:09.670	info	(3661) Stop script script.js.Garage___Garten___Carport.Garagenlicht
                            javascript.0	2021-10-25 21:32:09.670	info	(3661) Stop script script.js.Garage___Garten___Carport.Gartenlicht
                            javascript.0	2021-10-25 21:32:09.670	info	(3661) Stop script script.js.Garage___Garten___Carport.Licht_Gartenhaus
                            javascript.0	2021-10-25 21:32:09.669	info	(3661) Stop script script.js.Garage___Garten___Carport.WLED_Garage_Beginner
                            javascript.0	2021-10-25 21:32:09.669	info	(3661) Stop script script.js.Garage___Garten___Carport.Garagentor_Schalter
                            javascript.0	2021-10-25 21:32:09.668	info	(3661) Stop script script.js.Rollläden.Rollläden_Urlaub
                            javascript.0	2021-10-25 21:32:09.668	info	(3661) Stop script script.js.common.Batteriestand_Haustür
                            javascript.0	2021-10-25 21:32:09.667	info	(3661) Stop script script.js.Anwesenheit.Zisternenpumpe
                            javascript.0	2021-10-25 21:32:09.667	info	(3661) Stop script script.js.Anwesenheit.Bewegung_Flur
                            javascript.0	2021-10-25 21:32:09.667	info	(3661) Stop script script.js.Anwesenheit.IP_Cams
                            javascript.0	2021-10-25 21:32:09.666	info	(3661) Stop script script.js.Rollläden.Beschattung_Süden_OPPLE
                            javascript.0	2021-10-25 21:32:09.666	info	(3661) Stop script script.js.Rollläden.Beschattung_Osten_OPPLE
                            javascript.0	2021-10-25 21:32:09.665	info	(3661) Stop script script.js.Beleuchtung.OPPLE_3-fach_Wohnzimmer
                            javascript.0	2021-10-25 21:32:09.665	info	(3661) Stop script script.js.Sayit.Erinnerung_Tabletten
                            javascript.0	2021-10-25 21:32:09.664	info	(3661) Stop script script.js.Rollläden.Rollläden_auf
                            javascript.0	2021-10-25 21:32:09.664	info	(3661) Stop script script.js.Kellerfenster_Einbruch.Gästezimmer
                            javascript.0	2021-10-25 21:32:09.663	info	(3661) Stop script script.js.Rollläden.Rollladen_Terrasse_ab
                            javascript.0	2021-10-25 21:32:09.663	info	(3661) Stop script script.js.Rollläden.Rollläden_EG_ab
                            javascript.0	2021-10-25 21:32:09.662	info	(3661) Stop script script.js.Rollläden.Wohnzimmerfenster
                            javascript.0	2021-10-25 21:32:09.662	info	(3661) Stop script script.js.Beleuchtung.Nachtlicht-Schlafzimmer
                            javascript.0	2021-10-25 21:32:09.661	info	(3661) Stop script script.js.Beleuchtung.Sternenlicht
                            javascript.0	2021-10-25 21:32:09.660	info	(3661) Stop script script.js.common.Batterie_iPad_Air
                            javascript.0	2021-10-25 21:32:09.660	info	(3661) Stop script script.js.common.Anruf_Nachricht_Pushover
                            javascript.0	2021-10-25 21:32:09.659	info	(3661) Stop script script.js.Beleuchtung.Terrassenbeleuchtung(1)
                            javascript.0	2021-10-25 21:32:09.659	info	(3661) Stop script script.js.Beleuchtung.indirekte_Beleuchtung(1)
                            javascript.0	2021-10-25 21:32:09.658	info	(3661) Stop script script.js.Sayit.Wassermelder_Küche
                            javascript.0	2021-10-25 21:32:09.658	info	(3661) Stop script script.js.Sayit.Wassermelder_Keller
                            javascript.0	2021-10-25 21:32:09.657	info	(3661) Stop script script.js.Sayit.Rasenmäher_error
                            javascript.0	2021-10-25 21:32:09.656	info	(3661) Stop script script.js.Sayit.Bad_OG
                            javascript.0	2021-10-25 21:32:09.655	info	(3661) Stop script script.js.Sayit.Hobbykeller_10_Min
                            javascript.0	2021-10-25 21:32:09.653	info	(3661) Stop script script.js.Sayit.Gästebad_10_Min
                            javascript.0	2021-10-25 21:32:09.651	info	(3661) Stop script script.js.Sayit.Gästebad_5_Min
                            javascript.0	2021-10-25 21:32:09.650	info	(3661) Stop script script.js.Sayit.Kinderzimmer_Lea_Sophie
                            javascript.0	2021-10-25 21:32:09.649	info	(3661) Stop script script.js.Sayit.Gästezimmer
                            javascript.0	2021-10-25 21:32:09.649	info	(3661) Stop script script.js.Sayit.Kinderzimmer_Maximilian
                            javascript.0	2021-10-25 21:32:09.645	info	(3661) Stop script script.js.common.PV-Tagesertrag
                            javascript.0	2021-10-25 21:32:09.643	info	(3661) Stop script script.js.Sayit.Gefrierschrank_3_Min.
                            javascript.0	2021-10-25 21:32:09.642	info	(3661) Stop script script.js.Sayit.Gefrierschrank_2_Min.
                            javascript.0	2021-10-25 21:32:09.639	info	(3661) script.js.Heizung.WP_WW_aufbereiten: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.635	info	(3661) Start javascript script.js.Heizung.WP_WW_aufbereiten
                            javascript.0	2021-10-25 21:32:09.634	info	(3661) script.js.Heizung.WP_Betrieb_WW: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.630	info	(3661) Start javascript script.js.Heizung.WP_Betrieb_WW
                            javascript.0	2021-10-25 21:32:09.629	info	(3661) script.js.Heizung.WP_Betrieb_HZ_WW: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.625	info	(3661) Start javascript script.js.Heizung.WP_Betrieb_HZ_WW
                            javascript.0	2021-10-25 21:32:09.624	info	(3661) script.js.Heizung.WP_ein: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.620	info	(3661) Start javascript script.js.Heizung.WP_ein
                            javascript.0	2021-10-25 21:32:09.619	info	(3661) script.js.Heizung.WP_aus: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.615	info	(3661) Start javascript script.js.Heizung.WP_aus
                            javascript.0	2021-10-25 21:32:09.614	info	(3661) script.js.Heizung.WP_Betrieb_Heizen: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.610	info	(3661) Start javascript script.js.Heizung.WP_Betrieb_Heizen
                            javascript.0	2021-10-25 21:32:09.609	info	(3661) script.js.Heizung.Entkeimung_Taster: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.605	info	(3661) Start javascript script.js.Heizung.Entkeimung_Taster
                            javascript.0	2021-10-25 21:32:09.604	info	(3661) script.js.Kellerfenster_Einbruch.Fenster_Hobbykeller: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.600	info	(3661) Start javascript script.js.Kellerfenster_Einbruch.Fenster_Hobbykeller
                            javascript.0	2021-10-25 21:32:09.599	info	(3661) script.js.Beleuchtung.Urlaubsbeleuchtung: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.595	info	(3661) Start javascript script.js.Beleuchtung.Urlaubsbeleuchtung
                            javascript.0	2021-10-25 21:32:09.594	info	(3661) script.js.Garage___Garten___Carport.Carporttor_Abwesend: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.590	info	(3661) Start javascript script.js.Garage___Garten___Carport.Carporttor_Abwesend
                            javascript.0	2021-10-25 21:32:09.590	info	(3661) script.js.Garage___Garten___Carport.Carportlicht_BWM: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.586	info	(3661) Start javascript script.js.Garage___Garten___Carport.Carportlicht_BWM
                            javascript.0	2021-10-25 21:32:09.585	info	(3661) script.js.Garage___Garten___Carport.Bewegung_Abwesenheit(1): registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.581	info	(3661) Start javascript script.js.Garage___Garten___Carport.Bewegung_Abwesenheit(1)
                            javascript.0	2021-10-25 21:32:09.580	info	(3661) script.js.Garage___Garten___Carport.Bewegung_Dunkelheit: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.576	info	(3661) Start javascript script.js.Garage___Garten___Carport.Bewegung_Dunkelheit
                            javascript.0	2021-10-25 21:32:09.576	info	(3661) script.js.Garage___Garten___Carport.Garagenlicht: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.572	info	(3661) Start javascript script.js.Garage___Garten___Carport.Garagenlicht
                            javascript.0	2021-10-25 21:32:09.571	info	(3661) script.js.Garage___Garten___Carport.Gartenlicht: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.567	info	(3661) Start javascript script.js.Garage___Garten___Carport.Gartenlicht
                            javascript.0	2021-10-25 21:32:09.566	info	(3661) script.js.Garage___Garten___Carport.Licht_Gartenhaus: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.563	info	(3661) Start javascript script.js.Garage___Garten___Carport.Licht_Gartenhaus
                            javascript.0	2021-10-25 21:32:09.562	info	(3661) script.js.Garage___Garten___Carport.WLED_Garage_Beginner: registered 4 subscriptions and 0 schedules
                            javascript.0	2021-10-25 21:32:09.557	info	(3661) Start javascript script.js.Garage___Garten___Carport.WLED_Garage_Beginner
                            javascript.0	2021-10-25 21:32:09.557	info	(3661) script.js.Garage___Garten___Carport.Garagentor_Schalter: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.553	info	(3661) Start javascript script.js.Garage___Garten___Carport.Garagentor_Schalter
                            javascript.0	2021-10-25 21:32:09.552	info	(3661) script.js.Rollläden.Rollläden_Urlaub: registered 2 subscriptions and 0 schedules
                            javascript.0	2021-10-25 21:32:09.547	info	(3661) Start javascript script.js.Rollläden.Rollläden_Urlaub
                            javascript.0	2021-10-25 21:32:09.546	info	(3661) script.js.common.Batteriestand_Haustür: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.542	info	(3661) Start javascript script.js.common.Batteriestand_Haustür
                            javascript.0	2021-10-25 21:32:09.541	info	(3661) script.js.Anwesenheit.Zisternenpumpe: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.537	info	(3661) Start javascript script.js.Anwesenheit.Zisternenpumpe
                            javascript.0	2021-10-25 21:32:09.536	info	(3661) script.js.Anwesenheit.Bewegung_Flur: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.532	info	(3661) Start javascript script.js.Anwesenheit.Bewegung_Flur
                            javascript.0	2021-10-25 21:32:09.532	info	(3661) script.js.Anwesenheit.IP_Cams: registered 2 subscriptions and 0 schedules
                            javascript.0	2021-10-25 21:32:09.527	info	(3661) Start javascript script.js.Anwesenheit.IP_Cams
                            javascript.0	2021-10-25 21:32:09.527	info	(3661) script.js.Rollläden.Beschattung_Süden_OPPLE: registered 2 subscriptions and 0 schedules
                            javascript.0	2021-10-25 21:32:09.523	info	(3661) Start javascript script.js.Rollläden.Beschattung_Süden_OPPLE
                            javascript.0	2021-10-25 21:32:09.522	info	(3661) script.js.Rollläden.Beschattung_Osten_OPPLE: registered 2 subscriptions and 0 schedules
                            javascript.0	2021-10-25 21:32:09.518	info	(3661) Start javascript script.js.Rollläden.Beschattung_Osten_OPPLE
                            javascript.0	2021-10-25 21:32:09.517	info	(3661) script.js.Beleuchtung.OPPLE_3-fach_Wohnzimmer: registered 3 subscriptions and 0 schedules
                            javascript.0	2021-10-25 21:32:09.513	info	(3661) Start javascript script.js.Beleuchtung.OPPLE_3-fach_Wohnzimmer
                            javascript.0	2021-10-25 21:32:09.512	info	(3661) script.js.Sayit.Erinnerung_Tabletten: registered 0 subscriptions and 1 schedule
                            javascript.0	2021-10-25 21:32:09.506	info	(3661) Start javascript script.js.Sayit.Erinnerung_Tabletten
                            javascript.0	2021-10-25 21:32:09.505	info	(3661) script.js.Rollläden.Rollläden_auf: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.501	info	(3661) Start javascript script.js.Rollläden.Rollläden_auf
                            javascript.0	2021-10-25 21:32:09.501	info	(3661) script.js.Kellerfenster_Einbruch.Gästezimmer: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.497	info	(3661) Start javascript script.js.Kellerfenster_Einbruch.Gästezimmer
                            javascript.0	2021-10-25 21:32:09.496	info	(3661) script.js.Rollläden.Rollladen_Terrasse_ab: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.492	info	(3661) Start javascript script.js.Rollläden.Rollladen_Terrasse_ab
                            javascript.0	2021-10-25 21:32:09.491	info	(3661) script.js.Rollläden.Rollläden_EG_ab: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.487	info	(3661) Start javascript script.js.Rollläden.Rollläden_EG_ab
                            javascript.0	2021-10-25 21:32:09.487	info	(3661) script.js.Rollläden.Wohnzimmerfenster: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.483	info	(3661) Start javascript script.js.Rollläden.Wohnzimmerfenster
                            javascript.0	2021-10-25 21:32:09.482	info	(3661) script.js.Beleuchtung.Nachtlicht-Schlafzimmer: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.478	info	(3661) Start javascript script.js.Beleuchtung.Nachtlicht-Schlafzimmer
                            javascript.0	2021-10-25 21:32:09.477	info	(3661) script.js.Beleuchtung.Sternenlicht: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.473	info	(3661) Start javascript script.js.Beleuchtung.Sternenlicht
                            javascript.0	2021-10-25 21:32:09.473	info	(3661) script.js.common.Batterie_iPad_Air: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.469	info	(3661) Start javascript script.js.common.Batterie_iPad_Air
                            javascript.0	2021-10-25 21:32:09.468	info	(3661) script.js.common.Anruf_Nachricht_Pushover: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.464	info	(3661) Start javascript script.js.common.Anruf_Nachricht_Pushover
                            javascript.0	2021-10-25 21:32:09.463	info	(3661) script.js.Beleuchtung.Terrassenbeleuchtung(1): registered 2 subscriptions and 0 schedules
                            javascript.0	2021-10-25 21:32:09.459	info	(3661) Start javascript script.js.Beleuchtung.Terrassenbeleuchtung(1)
                            javascript.0	2021-10-25 21:32:09.458	info	(3661) script.js.Beleuchtung.indirekte_Beleuchtung(1): registered 2 subscriptions and 0 schedules
                            javascript.0	2021-10-25 21:32:09.454	info	(3661) Start javascript script.js.Beleuchtung.indirekte_Beleuchtung(1)
                            javascript.0	2021-10-25 21:32:09.453	info	(3661) script.js.Sayit.Wassermelder_Küche: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.449	info	(3661) Start javascript script.js.Sayit.Wassermelder_Küche
                            javascript.0	2021-10-25 21:32:09.448	info	(3661) script.js.Sayit.Wassermelder_Keller: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.444	info	(3661) Start javascript script.js.Sayit.Wassermelder_Keller
                            javascript.0	2021-10-25 21:32:09.444	info	(3661) script.js.Sayit.Rasenmäher_error: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.440	info	(3661) Start javascript script.js.Sayit.Rasenmäher_error
                            javascript.0	2021-10-25 21:32:09.439	info	(3661) script.js.Sayit.Bad_OG: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.435	info	(3661) Start javascript script.js.Sayit.Bad_OG
                            javascript.0	2021-10-25 21:32:09.434	info	(3661) script.js.Sayit.Hobbykeller_10_Min: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.430	info	(3661) Start javascript script.js.Sayit.Hobbykeller_10_Min
                            javascript.0	2021-10-25 21:32:09.430	info	(3661) script.js.Sayit.Gästebad_10_Min: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.426	info	(3661) Start javascript script.js.Sayit.Gästebad_10_Min
                            javascript.0	2021-10-25 21:32:09.425	info	(3661) script.js.Sayit.Gästebad_5_Min: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.421	info	(3661) Start javascript script.js.Sayit.Gästebad_5_Min
                            javascript.0	2021-10-25 21:32:09.420	info	(3661) script.js.Sayit.Kinderzimmer_Lea_Sophie: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.416	info	(3661) Start javascript script.js.Sayit.Kinderzimmer_Lea_Sophie
                            javascript.0	2021-10-25 21:32:09.415	info	(3661) script.js.Sayit.Gästezimmer: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.411	info	(3661) Start javascript script.js.Sayit.Gästezimmer
                            javascript.0	2021-10-25 21:32:09.410	info	(3661) script.js.Sayit.Kinderzimmer_Maximilian: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.406	info	(3661) Start javascript script.js.Sayit.Kinderzimmer_Maximilian
                            javascript.0	2021-10-25 21:32:09.406	info	(3661) script.js.common.PV-Tagesertrag: registered 0 subscriptions and 1 schedule
                            javascript.0	2021-10-25 21:32:09.387	info	(3661) Start javascript script.js.common.PV-Tagesertrag
                            javascript.0	2021-10-25 21:32:09.384	error	(3661) The id "scriptProblem.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                            javascript.0	2021-10-25 21:32:09.384	error	(3661) Error: The id "scriptProblem.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
                            javascript.0	2021-10-25 21:32:09.383	error	(3661) unhandled promise rejection: The id "scriptProblem.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                            javascript.0	2021-10-25 21:32:09.383	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            javascript.0	2021-10-25 21:32:09.382	error	(3661) The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                            javascript.0	2021-10-25 21:32:09.381	error	(3661) Error: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
                            javascript.0	2021-10-25 21:32:09.381	error	(3661) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                            javascript.0	2021-10-25 21:32:09.380	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            javascript.0	2021-10-25 21:32:09.379	info	(3661) script.js.Sayit.Gefrierschrank_3_Min.: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.370	info	(3661) Start javascript script.js.Sayit.Gefrierschrank_3_Min.
                            javascript.0	2021-10-25 21:32:09.369	error	(3661) The id "scriptProblem.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                            javascript.0	2021-10-25 21:32:09.368	error	(3661) Error: The id "scriptProblem.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
                            javascript.0	2021-10-25 21:32:09.368	error	(3661) unhandled promise rejection: The id "scriptProblem.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                            javascript.0	2021-10-25 21:32:09.367	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            javascript.0	2021-10-25 21:32:09.366	error	(3661) The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                            javascript.0	2021-10-25 21:32:09.365	error	(3661) Error: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:2
                            javascript.0	2021-10-25 21:32:09.365	error	(3661) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                            javascript.0	2021-10-25 21:32:09.364	error	(3661) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            javascript.0	2021-10-25 21:32:09.359	info	(3661) script.js.Sayit.Gefrierschrank_2_Min.: registered 1 subscription and 0 schedules
                            javascript.0	2021-10-25 21:32:09.341	info	(3661) Start javascript script.js.Sayit.Gefrierschrank_2_Min.
                            javascript.0	2021-10-25 21:32:09.199	warn	(3661) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
                            javascript.0	2021-10-25 21:32:09.196	info	(3661) received all objects
                            javascript.0	2021-10-25 21:32:08.351	info	(3661) received all states
                            javascript.0	2021-10-25 21:32:07.566	warn	(3661) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                            javascript.0	2021-10-25 21:32:07.565	info	(3661) requesting all objects
                            javascript.0	2021-10-25 21:32:07.563	info	(3661) requesting all states
                            javascript.0	2021-10-25 21:32:07.515	info	(3661) starting. Version 4.1.12 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.18.1, js-controller: 3.3.18
                            • S Stoni
                              #71
                              Skripte dürfen nicht auf einen Punkt enden.
                              Warum macht man sowas überhaupt? Ist auch z. B. unter Windows keine gute Idee für Dateinamen.
                                Stoni
                                #72
                                war nie ein Problem. Habs geändert.
                                Problem bleibt bestehen:
                                javascript.0	2021-10-25 21:43:51.964	warn	(11093) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                javascript.0	2021-10-25 21:43:51.962	info	(11093) terminating
                                javascript.0	2021-10-25 21:43:51.880	error	(11093) The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                                javascript.0	2021-10-25 21:43:51.880	error	(11093) Error: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:
                                javascript.0	2021-10-25 21:43:51.879	error	(11093) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_3_Min." is invalid. Ids are not allowed to end in "."
                                javascript.0	2021-10-25 21:43:51.879	error	(11093) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                javascript.0	2021-10-25 21:43:51.878	error	(11093) The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                                javascript.0	2021-10-25 21:43:51.877	error	(11093) Error: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "." at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:537:
                                javascript.0	2021-10-25 21:43:51.877	error	(11093) unhandled promise rejection: The id "scriptEnabled.Sayit.Gefrierschrank_2_Min." is invalid. Ids are not allowed to end in "."
                                javascript.0	2021-10-25 21:43:51.876	error	(11093) Unhandled promise rejection. This error originated either by throwing inside of an async function wit
                                Hab den Adapter schon wiederholt neu geladen,
                                  Stoni
                                  #73
                                  für den JS-Adapter ist ein Update verfügbar. 4.1.12 auf 5.2.8. Soll ich das mal durchführen?
                                  • S Stoni
                                    #74
                                    Doch, aber es wurde bislang nicht angemeckert.
                                    Ich weiß nicht, ob und wo die ids der skripte geführt werden und ggf. noch angepasst werden müssen. Das muss vielleicht mal jemand mit mehr Einblick in den javaskript-Adapter anschauen.
                                    So nebenher:
                                    Probier mal aus, ob der Fixer jetzt funtioniert.
                                    iobroker stop
                                    iobroker fix
                                    iobroker start
                                    • S Stoni
                                      #75
                                      zeig mal die Objekte dazu
                                        Stoni
                                        #76
                                        @homoran @Thomas-Braun
                                        also den fix führe ich morgen mal durch. Da hab ich jetzt irgendwie schiss, dass wieder was passiert.
                                        Die javascripte mit dem Punkt am Ende lassen sich nicht ändern. Wie kann man die umbenennen?
                                        • S Stoni
                                          #77
                                          Jetzt schaut dir aber jemand dabei über die Schulter.
