  4. Test Alpha Homekit-Controller 0.0.x
    2.8k
    4.8k
    4.1k
260 Beiträge 27 Kommentatoren 59.2k Aufrufe 24 Beobachtet
    @fortune95 Nein, eigentlich nicht.
    Ich wollte nur sehen, ob da vielleicht ein Block reinspringt.
    Das System ist aber auf Stand?
    sudo apt update
    Fortune95
    #81
    Es waren 5 Aktualisierungen verfügbar aber nichts was auf bluetooth verweist.
    pi@IoBroker:~ $ sudo systemctl status bluetooth.service
    ● bluetooth.service - Bluetooth service
         Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
         Active: active (running) since Sat 2021-12-11 11:04:09 CET; 5 days ago
           Docs: man:bluetoothd(8)
       Main PID: 13358 (bluetoothd)
         Status: "Running"
          Tasks: 1 (limit: 8986)
            CPU: 226ms
         CGroup: /system.slice/bluetooth.service
                 └─13358 /usr/libexec/bluetooth/bluetoothd --noplugin=sap
    Dez 16 05:58:47 IoBroker bluetoothd[13358]: Endpoint registered: sender=:1.162 path=/MediaEndpoint/A2DPSink/sbc
    Dez 16 05:58:47 IoBroker bluetoothd[13358]: Endpoint registered: sender=:1.162 path=/MediaEndpoint/A2DPSource/sbc
    Dez 16 06:29:08 IoBroker bluetoothd[13358]: Endpoint unregistered: sender=:1.162 path=/MediaEndpoint/A2DPSink/sbc
    Dez 16 06:29:08 IoBroker bluetoothd[13358]: Endpoint unregistered: sender=:1.162 path=/MediaEndpoint/A2DPSource/sbc
    Dez 16 06:33:34 IoBroker bluetoothd[13358]: Endpoint registered: sender=:1.185 path=/MediaEndpoint/A2DPSink/sbc
    Dez 16 06:33:34 IoBroker bluetoothd[13358]: Endpoint registered: sender=:1.185 path=/MediaEndpoint/A2DPSource/sbc
    Dez 16 06:33:43 IoBroker bluetoothd[13358]: Endpoint unregistered: sender=:1.185 path=/MediaEndpoint/A2DPSink/sbc
    Dez 16 06:33:43 IoBroker bluetoothd[13358]: Endpoint unregistered: sender=:1.185 path=/MediaEndpoint/A2DPSource/sbc
    Dez 16 17:21:17 IoBroker bluetoothd[13358]: Endpoint registered: sender=:1.212 path=/MediaEndpoint/A2DPSink/sbc
    Dez 16 17:21:17 IoBroker bluetoothd[13358]: Endpoint registered: sender=:1.212 path=/MediaEndpoint/A2DPSource/sbc
    F 1 Antwort Letzte Antwort
    • F Fortune95
           Status: "Running"
              CPU: 226ms
      Fortune95
      #82
      @fortune95
      Hab mal in der shell einen Scan gemacht und der Eve Degree hat schon wieder eine neue MAC / ID ohne das ich ihn resettet hatte:
      pi@IoBroker:~ $  bluetoothctl
      Agent registered
      [CHG] Controller DC:A6:32:C5:C7:A3 Pairable: yes
      [bluetooth]# scan on
      Discovery started
      [CHG] Controller DC:A6:32:C5:C7:A3 Discovering: yes
      [NEW] Device 42:44:5A:66:3A:E8 42-44-5A-66-3A-E8
      [NEW] Device 7E:3F:40:40:12:A6 7E-3F-40-40-12-A6
      [NEW] Device 44:82:C0:5F:44:BD 44-82-C0-5F-44-BD
      [NEW] Device 42:88:76:5F:D3:01 42-88-76-5F-D3-01
      [NEW] Device 61:EE:B0:2B:D6:3F 61-EE-B0-2B-D6-3F
      [NEW] Device 08:7F:14:63:58:14 08-7F-14-63-58-14
      [CHG] Device 44:82:C0:5F:44:BD RSSI: -61
      [NEW] Device 61:DB:6A:65:19:41 61-DB-6A-65-19-41
      [CHG] Device 42:44:5A:66:3A:E8 RSSI: -45
      [NEW] Device D9:58:61:08:E7:D9 Eve Degree 053B
      [CHG] Device 42:44:5A:66:3A:E8 RSSI: -55
      [CHG] Device 42:44:5A:66:3A:E8 RSSI: -47
      [NEW] Device ED:FA:08:0F:72:FD Eve Room 632D
      • F Fortune95
        @fortune95
        Agent registered
        Discovery started
        #83
        @fortune95 Und wird bestimmt wenn du adapter startest wieder als "ready topair/unpaired" berichtet oder? Das ist das was ich nicht kapiere ...
        F 2 Antworten Letzte Antwort
        • apollon77A apollon77
          Fortune95
          #84
          @apollon77
          Habe den PI runtergefahren und einmal vom Strom genommen und wieder gestartet, aber es tut sich weiterhin nix...😢
          Er zeigt nur den Room als pairbar an, welcher auch noch wirklich nicht gepaired wurden ist.
          • F Fortune95
            @apollon77
            Fortune95
            #85
            @fortune95
            Liegt es evtl. an bullseye?
              Fortune95
              #86
              @apollon77
              Um einzugrenzen ob der BLE Controller funktioniert, habe ich mir einen Eve Energy organisiert...
              und den bekomme ich auch gepaired.
              Einiges wurde leider Aufgrund der Datenflut in der Shell beim debuggen überschrieben.
              Shell_Debug_Eve_Energy.txt
              • F Fortune95
                @apollon77
                #87
                @fortune95 Der Energy sieht so aus wie meiner ... da ist alles ok ...
                Also von daher wäre ich grad dabei das irgendwas mit dem Device "matchig" ist ... wenns für das "Room"-Teil aber mit Apple Home geht zu pairen und alles da ist und auch stabil dann habe ich aktuell ehrlich keine Idee mehr :-(
                Ein zweites solches Room" hast Du nicht per Zufall? ;-)
                  Fortune95
                  #88
                  @apollon77
                  Room leider nicht da habe ich nur den einen, Degree wäre kein Problem. Room müsste ich sonst noch einen kaufen.
                  • F Fortune95
                    @apollon77
                    #89
                    @fortune95 ääähhmm nee warte mal ... war doch ein Degree der spinnt oder? Wäre die Frage ob ein andere auch spinnt ...
                      Fortune95
                      #90
                      @apollon77
                      die machen beide die gleichen Probleme...
                      Über den Extend laufen sie alle... prinzipiell. Beim Degree fehlt beispielsweise nur der Luftdruck.
                      Einen Thermo hab ich auch noch im Einsatz, den müsste ich mal über BLE testen.
                      Schön wäre es wenn sie über beide Schnittstellen gehen würden, einige stehen ja in ausreichender Reichweite.
                      Den Degree könnte ich sofort eintüten...😬
                      • F Fortune95
                        @apollon77
                        #91
                        @fortune95 Ich kann jetzt nur mal den Eve support anschreiben und schauen ob die irgendwas sagen - wenn ich da jemanden kriege der kompetent antworten kann
                          Fortune95
                          #92
                          @apollon77
                          😳 Wie gesagt das Angebot steht!
                          Bin begeistert wie ihr die Dinge supported und immer wieder weiterentwickelt!
                          DANKE!
                          • F Fortune95
                            @apollon77
                            DANKE!
                            #93
                            @fortune95 Ahh du meintest mir zuschicken ... jetzt hab ichs kapiert :-) ich schreib dir ne PN ...können wir versuchen
                            • StrathColeS Offline
                              StrathColeS Offline
                              StrathCole
                              #94
                              Hat jemand schon ein Nuki Smart Lock mit dem Adapter genutzt? Scheinbar findet der Adapter das Gerät nicht, obwohl es einen Sticker mit Homekit QR und PIN hat.
                              SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
                              • StrathColeS StrathCole
                                #95
                                @strathcole auch hier wie oben gesagt mal debug log aktivieren. Dann siehst du genau was er findet. Und bei wlan bedenke gleiches Netzwerk wegen UDP bzw bei BLE die Entfernung.
                                StrathColeS 1 Antwort Letzte Antwort
                                  StrathColeS Offline
                                  StrathColeS Offline
                                  StrathCole
                                  #96
                                  @apollon77 Ja, das ist ja das Komische daran. WLan ist dasselbe, Bluetooth-Entfernung < 3 Meter. Er findet das Gerät gar nicht. Nur ein Gardena Gateway und Tahoma Box.
                                  Gibt es irgendwie die Möglichkeit, eine Geräte-IP manuell anzugeben?
                                  apollon77A 2 Antworten Letzte Antwort
                                    #97
                                    @strathcole ne reicht nicht weil in der UDP Message wichtige Infos stehen wenn’s um das pairing und so geht. Ohne die ist pairing nur bedingt möglich. Udp muss gehen. Muss man es vllt manuell irgendwie einschalten?
                                      #98
                                      @strathcole so: wenn ich Infos richtig lese ist Nuki per Bluetooth zu pairen.
                                      Also nicht wlan. Bluetooth aktiviert im Adapter? Bluetooth gerät im Host nicht durch Radar2 oder singt belegt?
                                        StrathColeS Offline
                                        StrathColeS Offline
                                        StrathCole
                                        #99
                                        @apollon77
                                        @apollon77 sagte in Test Alpha Homekit-Controller 0.0.x:
                                        Ja. das scheint so zu sein.
                                        Ja.
                                        Nein, habe ich beides gar nicht als Instanzen.
                                        Übrigens, wenn ich auf der Linux-Konsole (ioBroker-Host) via bluetoothctl ein scan on mache, dann findet er dort Device XX:XX:XX:XX:XX:XX Nuki_12345678
                                        Ein info XX:XX:XX:XX:XX:XX bringt dann:
                                        Device XX:XX:XX:XX:XX:XX (public)
                                        	Alias: Nuki_1234567
                                        	Paired: no
                                        	Trusted: no
                                        	Blocked: no
                                        	Connected: no
                                        	LegacyPairing: no
                                        	ManufacturerData Key: 0x004c
                                        	ManufacturerData Value:
                                          xxxxxxxxxxxxxxxxxxxxxxxxxx
                                        	RSSI: -65
                                          @apollon77
                                          Ja.
                                          	Alias: Nuki_1234567
                                          	Paired: no
                                          	Trusted: no
                                          	Blocked: no
                                          	Connected: no
                                          	LegacyPairing: no
                                          	RSSI: -65
                                          #100
                                          @strathcole also dann zeig mal debug log.
