Test Adapter renault v0.0.x für myRenault und myDacia
Hat sich wieder etwas mit dem Kamereon ApiKey getan?
bekomme auch mit zoe2 Probleme.beim Renault Adapter steht im log.
renault.0 2022-07-01 19:18:37.010 info {"type":"FUNCTIONAL","messages":[{"code":"err.func.403","message":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"errors":[{"errorCode":"err.func.403","errorMessage":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"error_reference":"FUNCTIONAL"} renault.0 2022-07-01 19:18:37.010 info Error: Request failed with status code 403 renault.0 2022-07-01 19:18:37.009 info Feature not found. Ignore res-state for updates. renault.0 2022-07-01 19:18:36.810 info {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"} renault.0 2022-07-01 19:18:36.810 info Error: Request failed with status code 502 renault.0 2022-07-01 19:18:36.809 info Feature not found. Ignore lock-status for updates. renault.0 2022-07-01 19:18:32.618 info {"type":"TECHNICAL","messages":[{"code":"err.tech.wired.kamereon-proxy","message":"Failed to forward request to remote service."}],"errors":[{"errorCode":"err.tech.wired.kamereon-proxy","errorMessage":"Failed to forward request to remote service."}],"error_reference":"TECHNICAL"} renault.0 2022-07-01 19:18:32.618 info Error: Request failed with status code 500 renault.0 2022-07-01 19:18:32.618 info Feature not found. Ignore charge-history for updates. renault.0 2022-07-01 19:18:13.350 info starting. Version 0.0.13 in /opt/iobroker/node_modules/iobroker.renault, node: v14.19.2, js-controller: 3.3.22ich hatte immer nur einen Adapter zur Zeit laufen, seit gestern abend sogar beide abgestellt.
eben nochmal probiert, da kam das
gestern nur der Teil mit Kamereon -
Moin,
ich habe jetzt ganz frisch einen Twingo Electric und habe den Adapter in Betrieb genommen.
Bis auf ein paar 403-Errors läuft er soweit.Befehle wie "Sofort laden" und "klimatisierung starten" werden an das Fahrzeug übertragen und ausgeführt.
Was mir fehlt, ist eine Möglichkeit, die Ladung zu stoppen.
Der Befehl "Charge/pause-resume" wird beispielsweise mit "404/Not found" quittiert.
Ich hab mal gelesen, dass das vom Twingo nicht unterstützt wird.Was wohl geht ist, wenn man vom Modus "sofort laden" in den Modus "Ladetimer" wechselt. Dann wird die Ladung unterbrochen.
Im Adapter selbst habe ich allerdings keine Möglichkeit gesehen, den Lademodus zu ändern.
Der Datenpunkt "renault.0.VF1xxxx.charging-settings.mode", wo bei aktiviertem Ladetimer "Scheduled" drin steht (und in Modus "sofort laden" "always" drin steht) ist read-only.
Aus der Renault-App lässt sich der Ladetimer aktivieren, von daher müsste es da ja eigentlich eine Möglichkeit geben, den Lademodus zu ändern.
Übersehe ich da etwas?
Oder wäre es möglich, den Adapter dahingehend anzupassen?Edit: Sollte keine Antwort auf @Homoran sein, hab mich da wohl verklickt
Habe aktuell auch das Problem, dass ich das Laden remote nicht stoppen.. kann
Alle Werte lesen, kann der Adapter prima... gibt es da schon ne Lösung? -
wir haben eine neue Zoe bekommen und rufe über den Renault Adapter den Ladestand ab, um beim PV Überschussladen ein Ladelimit zu realisieren. Die Voreinstellung ist ja bei einem Update Intervall von 10 Minuten. Von meinem Ioniq weiß ich, daß bei jeder Abfrage im Auto das System hochfährt und mit der Zeit die 12V Batterie leer zieht. Besteht die Gefahr bei der Zoe auch, oder wie ist das dort realisiert?
Gruß Christoph
Alle Werte lesen, kann der Adapter prima... gibt es da schon ne Lösung?@thomas-kohb
Ich vermute, Du meinst das Steuern der Ladung an einer privaten Wallbox?
An einer öffentlichen macht das keinen Sinn, da man dort ja das Auto nach der Beendigung des Ladens wegfährt, und damit sowieso vor Ort ist.
Welche Wallbox hast Du?
Bei meiner Easee steuere ich das über die Box, und nicht über das Fahrzeug. -
@thomas-kohb
@warp-it sagte in Test Adapter renault v0.0.x für myRenault und myDacia:
und die kennt den Ladezustand des Fahrzeugs?
Woher? -
Uber den Renault Adapter: renault.0.VF1Axxxxxxxxxx.battery-status.batteryLevel
Ist für mich aber nicht interessant, da ich wegen des Balancings immer voll auflade.@warp-it sagte in Test Adapter renault v0.0.x für myRenault und myDacia:
und genau darauf zielt die Frage von @thomas-kohb.
Er möchte eine Zielladung auf x% realisieren
Kann es sein, dass die Renault-Seite nicht mehr geht?
Ich kann mich nicht mehr dort einloggen und der Adapter hat auch keine Verbindung! -
@guergen said in Test Adapter renault v0.0.x für myRenault und myDacia:
Ich kann mich nicht mehr dort einloggen und der Adapter hat auch keine Verbindung!Ich bekomme Daten:
Hi ich habe ein neuen Adapter für Renault/Dacia Fahrzeug die mit der my Renault oder myDacia App gesteuert werden können
geschrieben.Datenpunkt zum Lade Status werden erst beim ersten Laden angezeigt
Steuerung über renault.0.id.remote
Zum Installieren:
https://github.com/TA2k/ioBroker.renaultFür die aktuelle Version
bitte das latest Repo auswählen:
Loginablauf:
Die myRenault/myDacia App Mail und Passwort eingeben.@tombox Hallo,
auch mit der neuesten Version 0.0.14 läuft das Log bei mir mit Fehlermeldungen voll. Die Daten zum 'battery-status' scheinen zu passen, die 'charge-history' verblüfft mich immer wieder. Woran kann es liegen, dass so viele Fehler geworfen werden? -
Zum Installieren:
Loginablauf:
Die myRenault/myDacia App Mail und Passwort eingeben. -
@tombox Hi, die History Fehler zeigen sich auch bei mir, beim alten Adapter konnte man diese denke ich deaktivieren? wäre ein Setting ev. möglich, ich brauch das auch nicht :)
dieses dann noch:
Vielen Dank für den tollen Adapter
. Ich verwende ihn mit einem Dacia Spring, den wir seit wenigen Tagen haben.In der myDacia-App kann ich die Klimatisierung ein- und ausschalten sowie das Aufladen anhalten. Vermute ich es richtig, dass dies über dies eigentlich über unter iobroker - Objekts - remote gesteuert werden sollen könnte? Dort haben allerdings alle Objekte den Wert "null". Bei Eingaben werden die Parameter angezeigt, haben aber keine Auswirkung (siehe charge/pause-resume und refesh).
Deshalb meine Frage: Wie kann ich denn die Klimatisierung ein- und ausschalten, sowie das Aufladen beenden bzw. pausieren?
In den Logs erhalte ich folgende Rückmeldungen. Hat das "Feature not found" etwas mit meinem Problem zu tun?
renault.0 2022-11-01 12:29:04.644 info Feature not found for UU1DBG009NU085390. Ignore res-state for updates. renault.0 2022-11-01 12:29:04.395 info Feature not found for UU1DBG009NU085390. Ignore lock-status for updates. renault.0 2022-11-01 12:29:03.810 info Feature not found for UU1DBG009NU085390. Ignore charges for updates. renault.0 2022-11-01 12:29:03.546 info Feature not found for UU1DBG009NU085390. Ignore charge-history for updates. renault.0 2022-11-01 12:29:02.561 info Feature not found for UU1DBG009NU085390. Ignore charging-settings for updates. renault.0 2022-11-01 12:29:02.301 info Feature not found for UU1DBG009NU085390. Ignore hvac-settings for updates. renault.0 2022-11-01 12:29:01.186 info Feature not found for UU1DBG009NU085390. Ignore charge-mode for updates. renault.0 2022-11-01 12:28:59.678 info Feature not found for UU1DBG009NU085390. Ignore battery-inhibition-status for updates. renault.0 2022-11-01 12:28:57.172 info starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.renault, node: v16.18.0, js-controller: 4.0.23 renault.0 2022-11-01 12:28:57.081 info Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system renault.0 2022-11-01 12:28:53.549 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason renault.0 2022-11-01 12:28:53.548 info terminating renault.0 2022-11-01 12:28:53.548 info Got terminate signal TERMINATE_YOURSELF renault.0 2022-11-01 12:25:57.623 error {"type":"FUNCTIONAL","messages":[{"code":"err.func.404","message":"{\"timestamp\":\"2022-11-01T11:25:57.568+0000\",\"status\":404,\"error\":\"Not Found\",\"message\":\"No message available\",\"path\":\"/car-adapter/v1/cars/UU1DBG009NU073290/charge/pause-resume\"}"}],"errors":[{"errorCode":"err.func.404","errorMessage":"{\"timestamp\":\"2022-11-01T11:25:57.568+0000\",\"status\":404,\"error\":\"Not Found\",\"message\":\"No message available\",\"path\":\"/car-adapter/v1/cars/UU1DBG009NU073290/charge/pause-resume\"}"}],"error_reference":"FUNCTIONAL"} renault.0 2022-11-01 12:25:57.623 error AxiosError: Request failed with status code 404 renault.0 2022-11-01 12:25:35.452 error {"type":"FUNCTIONAL","messages":[{"code":"err.func.404","message":"{\"timestamp\":\"2022-11-01T11:25:35.396+0000\",\"status\":404,\"error\":\"Not Found\",\"message\":\"No message available\",\"path\":\"/car-adapter/v1/cars/UU1DBG009NU073290/charge/pause-resume\"}"}],"errors":[{"errorCode":"err.func.404","errorMessage":"{\"timestamp\":\"2022-11-01T11:25:35.396+0000\",\"status\":404,\"error\":\"Not Found\",\"message\":\"No message available\",\"path\":\"/car-adapter/v1/cars/UU1DBG009NU073290/charge/pause-resume\"}"}],"error_reference":"FUNCTIONAL"} renault.0 2022-11-01 12:25:35.452 error AxiosError: Request failed with status code 404Es wäre echt klasse, wenn ich über den Adapter und iobroker die Möglichkeit schaffen könnte, dass der Dacia Spring nur bis 80 % lädt. Die myDacia-App kann das leider nicht.
Vielen Dank!
Tony
Vielen Dank!
Tony
@tony-blue also wenn es nicht geht den remote state auf true oder false ohne Bestätigung zu setzen bräuchte ich nochmal ein account um zu sehen was die app anders machen
@tombox sagte in Test Adapter renault v0.0.x für myRenault und myDacia:
Das habe ich gemacht.
Alle Werte unter iobroker - objects - renault - remote - ...
- actions/charging-start
- actions/hvac-start
- charge/pause-resume
- charge/start
- hvac-temperature
- refresh
sind bei meinem Dacia Spring nicht schaltbar
.Wenn ich actions/charging-start auf true setze erhalte ich im Log:
renault.0 2022-11-16 21:51:52.426 error {"type":"FUNCTIONAL","messages":[{"code":"err.func.403","message":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"errors":[{"errorCode":"err.func.403","errorMessage":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"error_reference":"FUNCTIONAL"} renault.0 2022-11-16 21:51:52.426 error AxiosError: Request failed with status code 403Wenn ich charge/start auf true setze erhalte ich im Log:
renault.0 2022-11-16 21:53:54.381 error {"type":"FUNCTIONAL","messages":[{"code":"err.func.404","message":"{\"timestamp\":\"2022-11-16T20:53:54.332+0000\",\"status\":404,\"error\":\"Not Found\",\"message\":\"No message available\",\"path\":\"/car-adapter/v1/cars/UU1DBG009NU073290/charge/start\"}"}],"errors":[{"errorCode":"err.func.404","errorMessage":"{\"timestamp\":\"2022-11-16T20:53:54.332+0000\",\"status\":404,\"error\":\"Not Found\",\"message\":\"No message available\",\"path\":\"/car-adapter/v1/cars/UU1DBG009NU073290/charge/start\"}"}],"error_reference":"FUNCTIONAL"} renault.0 2022-11-16 21:53:54.380 error AxiosError: Request failed with status code 404Was kann ich den tun, um bei meinem Dacia Spring die Werte unter renault - remote zu schalten? In der Dacia App ist der Ladevorgang und auch die Klimatisierung ein- und ausschaltbar.
Viele Grüße
tony
- charge/start
- hvac-temperature
- refresh
Viele Grüße
tony
@tony-blue Konnte jetzt in der App sehen was da passiert die GitHub version sollte jetzt charge/pause-resume können
Vielen lieben Dank - pause-resume geht mit der GitHub-Version.
Wenn möglich, wäre es klasse, wenn auch die Klimatisierung noch gehen würde.
Schönen Abend!
Tony
Schönen Abend!
Tony
