  4. Zigbee Adapter startet nicht
    6.5k
43 Beiträge 3 Kommentatoren 3.0k Aufrufe 3 Beobachtet
    @wolfgangfb
    tail -f /opt/iobroker/log/iobroker.current.log
    oder
    iobroker logs --watch
    beobachten, Adapter z. B. neustarten.
    W Offline
    W Offline
    WolfgangFB
    pi@raspberrypi204:~ $ tail -f /opt/iobroker/log/iobroker.current.log
    2021-08-29 22:39:00.854  - info: host.raspberrypi204 "system.adapter.zigbee.1" disabled
    2021-08-29 22:39:00.875  - info: host.raspberrypi204 stopInstance system.adapter.zigbee.1 (force=false, process=true)
    2021-08-29 22:39:00.903  - info: zigbee.1 (10389) Got terminate signal TERMINATE_YOURSELF
    2021-08-29 22:39:00.909  - info: host.raspberrypi204 stopInstance system.adapter.zigbee.1 send kill signal
    2021-08-29 22:39:00.907  - info: zigbee.1 (10389) cleaned everything up...
    2021-08-29 22:39:00.918  - info: zigbee.1 (10389) Zigbee: disabling joining new devices.
    2021-08-29 22:39:00.922  - warn: zigbee.1 (10389) Failed to stop zigbee during startup
    2021-08-29 22:39:00.924  - info: zigbee.1 (10389) terminating
    2021-08-29 22:39:00.927  - info: zigbee.1 (10389) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-08-29 22:39:00.931  - error: zigbee.1 (10389) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-08-29 22:39:00.932  - error: zigbee.1 (10389) unhandled promise rejection: Cannot read property 'getEntries' of null
    2021-08-29 22:39:00.937  - error: zigbee.1 (10389) TypeError: Cannot read property 'getEntries' of null
        at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
        at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
        at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
        at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49)
        at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
        at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42)
        at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
        at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
        at runMicrotasks (<anonymous>)
        at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2021-08-29 22:39:00.938  - error: zigbee.1 (10389) Cannot read property 'getEntries' of null
    2021-08-29 22:39:01.762  - info: host.raspberrypi204 instance system.adapter.zigbee.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-08-29 22:39:03.038  - info: host.raspberrypi204 "system.adapter.zigbee.1" enabled
    2021-08-29 22:39:03.102  - info: host.raspberrypi204 instance system.adapter.zigbee.1 started with pid 12219
    2021-08-29 22:39:10.733  - info: zigbee.1 (12219) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.2.16
    2021-08-29 22:39:10.901  - info: zigbee.1 (12219) Starting Zigbee  npm ...
    2021-08-29 22:39:12.190  - info: zigbee.1 (12219) Installed Version: iobroker.zigbee@1.5.6
    2021-08-29 22:39:13.889  - warn: zigbee.1 (12219) Extended PAN ID is reversed (expected=d1dddddddddddddd, actual=ddddddddddddddd1)
    2021-08-29 22:39:23.906  - error: zigbee.1 (12219) Starting zigbee-herdsman problem : "AREQ - ZDO - activeEpRsp after 10000ms"
    2021-08-29 22:39:23.909  - error: zigbee.1 (12219) Failed to start Zigbee
    2021-08-29 22:39:23.910  - error: zigbee.1 (12219) Error herdsman start
    2021-08-29 22:39:33.913  - info: zigbee.1 (12219) Try to reconnect. 1 attempts left
    2021-08-29 22:39:33.915  - info: zigbee.1 (12219) Starting Zigbee  npm ...
    2021-08-29 22:39:33.960  - info: zigbee.1 (12219) Installed Version: iobroker.zigbee@1.5.6
    2021-08-29 22:39:34.442  - error: zigbee.1 (12219) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    2021-08-29 22:39:34.445  - error: zigbee.1 (12219) Failed to start Zigbee
    2021-08-29 22:39:34.448  - error: zigbee.1 (12219) Error herdsman start
    • W WolfgangFB
      Thomas BraunT Offline
      @wolfgangfb sagte in Zigbee Adapter startet nicht:
      Pass die mal an.
      Kann auch sein, dass die Firmware von dem Stick zu alt ist. Ich meine da war was unlängst.
      W 2 Antworten Letzte Antwort
        Pass die mal an.
        W Offline
        W Offline
        WolfgangFB
        Ich habe auf dem pi4 DDDDDDDDDDDDDDD0, auf dem 204 DDDDDDDDDDDDDDD1 und auf dem 202 DDDDDDDDDDDDDDDD eingestellt.
        Soll ich da jetzt auf dem 204 D1DDDDDDDDDDDDDD nehmen?
        Verstehen würde ich das nicht denn die 3 IDs sind verschieden und das ganze ist ja auch lange Zeit problemlos gelaufen.
          Pass die mal an.
          W Offline
          W Offline
          WolfgangFB
          Und das mit der Firmware, ich weiß nicht, wenn die gleiche Firmware vor 20 Minuten noch lief, dann aber mit einer älteren node-js Version auf einmal nicht mehr, wie soll das zusammenpassen?
          • W WolfgangFB
            @wolfgangfb
            Der aktuelle herdsman stellt da einiges um. Ich würde da auch 'bessere' hex-Werte nehmen. Gibt da Generatoren für im Web, wenn du nicht selber frickeln willst.
            Und du hast insgesamt 3 Sticks laufen? Weil oben schreibst du nur von einem.
            W 1 Antwort Letzte Antwort
            • W WolfgangFB
              Das hat mit nodeJS nichts zu tun sondern mit den aktuellen Versionen vom herdsman.
              Du kannst auch mal probieren wieder auf die 1.4er-Version vom zigbee-Adapter zu gehen. Die schleppt eine alte Version vom herdsman an. Kann sein das die wieder geht.
                @wolfgangfb
                W Offline
                W Offline
                WolfgangFB
                @thomas-braun said in Zigbee Adapter startet nicht:
                @wolfgangfb
                Vor ein paar Tagen hat ein Freund einen noch älteren C2531 auf seinem neu aufgesetzten System installiert und der lief mit meinen Einstellungen problemlos
                3 Raspberry PI (1 Master 2 Slave) und auf jedem ein CC2531
                Ich habe beim ersten Post gedacht, dass wenn ich den Grund für den einen nicht startenden herausbekomme, ich den zweiten auch zum laufen bringe (und der dritte lief ja zu dem Zeitpunkt noch)
                • W WolfgangFB
                  @wolfgangfb
                  @wolfgangfb
                  Hast du mal eine 1.4er-Version installiert?
                    W Offline
                    W Offline
                    WolfgangFB
                    Vor dem Verschlimmbessern lief ja auch dem funktionierenden die 1.4.4. und auf einem nicht funktionierenden auch die 1.4.4.
                    Wie downgrade ich denn auch eione ältere Verstion?
                    • W WolfgangFB
                      @wolfgangfb
                      iobroker upgrade zigbee@1.4.1
                      Oder im Admin unter den Experteneinstellungen:
                      • W Offline
                        W Offline
                        WolfgangFB
                        Was will mir das jetzt schon wieder sagen? (auf dem Pi4 hat der Downgrade, allerdings geklappt, aber der Adapter startet trotzdem nicht)
                        pi@raspberrypi202:/opt/iobroker/log $ iobroker upgrade zigbee@1.4.4
                        This downgrade of "zigbee" will at least remove the following changes:
                        -> 1.5.0
                        Dashboard
                        Would you like to downgrade zigbee from @1.5.6 to @1.4.4 now? [(y)es, (n)o]: y
                        Update zigbee from @1.5.6 to @1.4.4
                        host.raspberrypi202 Adapter "system.adapter.zigbee.2" is stopped.
                        NPM version: 6.14.14
                        npm install iobroker.zigbee@1.4.4 --loglevel error --prefix "/opt/iobroker" (System call)
                        The authenticity of host 'github.com (140.82.121.4)' can't be established.
                        RSA key fingerprint is SHA256:nThbg6kXUpJWGl7E1IGOCspRomTxdCARLviKw6E5SY8.
                        Are you sure you want to continue connecting (yes/no)? The authenticity of host 'github.com (140.82.121.4)' can't be established.
                        Are you sure you want to continue connecting (yes/no)? yes
                        Please type 'yes' or 'no': YES
                        Please type 'yes' or 'no': yes
                        npm ERR! Error while executing:
                        npm ERR! /usr/bin/git ls-remote -h -t ssh://git@github.com/ioBroker/ioBroker.onkyo.git
                        npm ERR!
                        npm ERR! Warning: Permanently added 'github.com,140.82.121.4' (RSA) to the list of known hosts.
                        npm ERR! Permission denied (publickey).
                        npm ERR! fatal: Konnte nicht vom Remote-Repository lesen.
                        npm ERR!
                        npm ERR! Bitte stellen Sie sicher, dass die korrekten Zugriffsberechtigungen bestehen
                        npm ERR! und das Repository existiert.
                        npm ERR!
                        npm ERR! exited with error code: 128
                        • W WolfgangFB
                          -> 1.5.0
                          Dashboard
                          npm ERR!
                          npm ERR!
                          npm ERR!
                          @wolfgangfb
                          Ich vermute die 1.4.4 gibt es nicht mehr. Nimm die 1.4.1.
                            @wolfgangfb
                            W Offline
                            W Offline
                            WolfgangFB
                            Auf dem Pi4 hjat der Downgrade auf 1.4.4. geklappt.
                            Ich gebe jetzt ziemlich frustriert für heute auf.
                            Ich glaube das einzige was wirklich hilft ist "never touch a running system" (auch wenn die Experten dann immer über die hoffnungslos veralteten Versionen schimpfen) und wenn es wirklich sein muss, dann vorher ein Komplettclone der SD Karte machen um wieder zurückkehren zu können.
                            Ich werde wohl morgen eine neue SD Karte nehmen und von 0 an ein neues System hochziehen.
                            Wirklich ärgert mich, dass durch die Updaterei meine ganzen ESP-Home yaml Dateien weg sind (die meisten habe ich vorher, nach entsprechender Erfahrung, händisch gesichert, aber was ich letzte Woche gemacht habe, ist wohl weg)
                            Trotzdem Danke für die versuchte Hilfe
                            • W WolfgangFB
                              Oder keine Hardware verwenden, die ausdrücklich 'not recommended' ist.
                                W Offline
                                W Offline
                                WolfgangFB
                                Was meinst Du damit?
                                • W WolfgangFB
                                  @wolfgangfb
                                  Damit meine ich, das die CC2531/CC2530 Dinger ziemlicher Elektroschrott sind.
                                  https://www.zigbee2mqtt.io/information/supported_adapters.html
                                  Texas Instruments CC2531 (not recommended)
                                  Texas Instruments CC2530 (not recommended)
                                  Die wissen schon warum.
                                    @wolfgangfb
                                    W Offline
                                    W Offline
                                    WolfgangFB
                                    @wolfgangfb
                                    Aber was hat eine noch so schlechte Hardware damit zu tun, dass ein IO-Broker Update eine ESP-Home Installation zerstört und eine Software die schon einmal gestartet ist, auf einmal nicht mehr startet?
                                    • W WolfgangFB
                                      @wolfgangfb
                                      @wolfgangfb
                                      Zu ESP kann ich nix sagen.
                                      Und aktuelle Versionen des zigbee-Adapters und der darin enthaltenen library 'herdsman' funktionieren nicht mehr mit den alten Sticks bzw. deren Firmware. Hat sich weiter bzw. davon wegentwickelt.
                                        @wolfgangfb
                                        Nicht mit more und grep da hantieren. Da fehlen Zeilen.
                                        Elkja
                                        @thomas-braun ```
                                        Hallo, ich habe auch dieses Problem dass der Zigbee nicht mehr auf grün geht.
                                        aus diesem Grund setzt ich seit Tagen das komplette System immer und immer wieder neu auf.....ohne Erfolg!
                                        Ich verwende einen CC2538 .....irgendwie denke ich, dass durch das eingespielte alte Backup noch was vom alten Stick CC2531 parallel drauf ist und dass das Problem sein könnte.
                                        Wie gesagt ich weiss nicht mehr weiter und hoffe das mir hierbei von euch jemand weiterhelfen kann.
                                        so sieht der Log beim Starten aus
                                        vielen Dank im Voraus für eure Unterstützung
                                        Elkja
                                        • E Elkja
                                          @thomas-braun ```
                                          Elkja
                                          @elkja
                                          Bitte keine Screenshots von LogFiles.
                                          Und eigenes Thema eröffnen.
                                          E 1 Antwort Letzte Antwort
