  4. Zigbee Adapter startet nicht
    6.5k
43 Beiträge 3 Kommentatoren 3.0k Aufrufe 3 Beobachtet
  • W Offline
    W Offline
    WolfgangFB
    schrieb am zuletzt editiert von WolfgangFB
    Ist das sinnvoll mit
    pi@raspberrypi4:/opt/iobroker/log $ more iobroker.current.log | grep zigbee
    oder welche Methode nimmt man, um aus der Logdatei Adaptermeldungen zu filtern?
    pi@raspberrypi4:/opt/iobroker/log $ tail -f /opt/iobroker/log/iobroker.current.log
    2021-08-29 22:56:53.569  - info: host.raspberrypi4 "system.adapter.zigbee.0" enabled
    2021-08-29 22:56:53.585  - warn: zigbee.0 (17489) Got terminate signal. Checking desired PID: 0 vs own PID 17489
    2021-08-29 22:56:53.639  - info: host.raspberrypi4 instance system.adapter.zigbee.0 started with pid 18770
    2021-08-29 22:56:53.587  - info: zigbee.0 (17489) cleaned everything up...
    2021-08-29 22:56:53.595  - info: zigbee.0 (17489) Zigbee: disabling joining new devices.
    2021-08-29 22:56:53.825  - warn: zigbee.0 (17489) Failed to stop zigbee during startup
    2021-08-29 22:56:53.826  - info: zigbee.0 (17489) terminating
    2021-08-29 22:56:53.828  - info: zigbee.0 (17489) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-08-29 22:56:53.866  - warn: zigbee.0 (17489) Got terminate signal. Checking desired PID: 18770 vs own PID 17489
    2021-08-29 22:56:57.147  - error: zigbee.0 (18770) zigbee.0 already running
    2021-08-29 22:56:57.150  - warn: zigbee.0 (18770) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2021-08-29 22:56:57.778  - error: host.raspberrypi4 instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2021-08-29 22:56:57.779  - info: host.raspberrypi4 Restart adapter system.adapter.zigbee.0 because enabled
    pi@raspberrypi4:/opt/iobroker/log $```
    • W WolfgangFB
      @wolfgangfb
      oder
      iobroker logs --watch
      beobachten, Adapter z. B. neustarten.
      W 1 Antwort Letzte Antwort
        @wolfgangfb
        Meldungen im log?
        Eine Instanz nach der nächsten...
        W Offline
        W Offline
        WolfgangFB
        2021-08-29 22:44:53.186  - error: host.raspberrypi202 instance system.adapter.zigbee.2 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2021-08-29 22:44:53.187  - info: host.raspberrypi202 Restart adapter system.adapter.zigbee.2 because enabled
        2021-08-29 22:45:23.256  - info: host.raspberrypi202 instance system.adapter.zigbee.2 started with pid 3012
        2021-08-29 22:45:25.367  - error: host.raspberrypi202 Caught by controller[0]: internal/modules/cjs/loader.js:818
        2021-08-29 22:45:25.369  - error: host.raspberrypi202 Caught by controller[0]:   throw err;
        2021-08-29 22:45:25.369  - error: host.raspberrypi202 Caught by controller[0]:   ^
        2021-08-29 22:45:25.370  - error: host.raspberrypi202 Caught by controller[0]: Error: Cannot find module 'zigbee-herdsman/dist/adapter/serialPortUtils'
        2021-08-29 22:45:25.371  - error: host.raspberrypi202 Caught by controller[0]: Require stack:
        2021-08-29 22:45:25.371  - error: host.raspberrypi202 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js
        2021-08-29 22:45:25.372  - error: host.raspberrypi202 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
        2021-08-29 22:45:25.373  - error: host.raspberrypi202 Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
        2021-08-29 22:45:25.373  - error: host.raspberrypi202 Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:667:27)
        2021-08-29 22:45:25.374  - error: host.raspberrypi202 Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:887:19)
        2021-08-29 22:45:25.375  - error: host.raspberrypi202 Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:74:18)
        2021-08-29 22:45:25.375  - error: host.raspberrypi202 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js:3:25)
        2021-08-29 22:45:25.376  - error: host.raspberrypi202 Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:999:30)
        2021-08-29 22:45:25.376  - error: host.raspberrypi202 Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
        2021-08-29 22:45:25.377  - error: host.raspberrypi202 Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:863:32)
        2021-08-29 22:45:25.378  - error: host.raspberrypi202 Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:708:14)
        2021-08-29 22:45:25.378  - error: host.raspberrypi202 Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:887:19) {
        2021-08-29 22:45:25.379  - error: host.raspberrypi202 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
        2021-08-29 22:45:25.380  - error: host.raspberrypi202 Caught by controller[0]:   requireStack: [
        2021-08-29 22:45:25.380  - error: host.raspberrypi202 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js',
        2021-08-29 22:45:25.381  - error: host.raspberrypi202 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
        2021-08-29 22:45:25.382  - error: host.raspberrypi202 Caught by controller[0]:   ]
        2021-08-29 22:45:25.382  - error: host.raspberrypi202 Caught by controller[0]: }
        2021-08-29 22:45:25.383  - error: host.raspberrypi202 instance system.adapter.zigbee.2 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2021-08-29 22:45:25.384  - info: host.raspberrypi202 Restart adapter system.adapter.zigbee.2 because enabled
        ^C
        pi@raspberrypi202:/opt/iobroker/log $
        • W WolfgangFB
          ^C
          @wolfgangfb
          Nicht mit more und grep da hantieren. Da fehlen Zeilen.
          E 1 Antwort Letzte Antwort
            @wolfgangfb
            oder
            W Offline
            W Offline
            WolfgangFB
            pi@raspberrypi204:~ $ tail -f /opt/iobroker/log/iobroker.current.log
            2021-08-29 22:39:00.854  - info: host.raspberrypi204 "system.adapter.zigbee.1" disabled
            2021-08-29 22:39:00.875  - info: host.raspberrypi204 stopInstance system.adapter.zigbee.1 (force=false, process=true)
            2021-08-29 22:39:00.903  - info: zigbee.1 (10389) Got terminate signal TERMINATE_YOURSELF
            2021-08-29 22:39:00.909  - info: host.raspberrypi204 stopInstance system.adapter.zigbee.1 send kill signal
            2021-08-29 22:39:00.907  - info: zigbee.1 (10389) cleaned everything up...
            2021-08-29 22:39:00.918  - info: zigbee.1 (10389) Zigbee: disabling joining new devices.
            2021-08-29 22:39:00.922  - warn: zigbee.1 (10389) Failed to stop zigbee during startup
            2021-08-29 22:39:00.924  - info: zigbee.1 (10389) terminating
            2021-08-29 22:39:00.927  - info: zigbee.1 (10389) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2021-08-29 22:39:00.931  - error: zigbee.1 (10389) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2021-08-29 22:39:00.932  - error: zigbee.1 (10389) unhandled promise rejection: Cannot read property 'getEntries' of null
            2021-08-29 22:39:00.937  - error: zigbee.1 (10389) TypeError: Cannot read property 'getEntries' of null
                at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
                at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
                at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
                at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49)
                at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
                at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42)
                at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
                at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
                at runMicrotasks (<anonymous>)
                at processTicksAndRejections (internal/process/task_queues.js:97:5)
            2021-08-29 22:39:00.938  - error: zigbee.1 (10389) Cannot read property 'getEntries' of null
            2021-08-29 22:39:01.762  - info: host.raspberrypi204 instance system.adapter.zigbee.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2021-08-29 22:39:03.038  - info: host.raspberrypi204 "system.adapter.zigbee.1" enabled
            2021-08-29 22:39:03.102  - info: host.raspberrypi204 instance system.adapter.zigbee.1 started with pid 12219
            2021-08-29 22:39:10.733  - info: zigbee.1 (12219) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.2.16
            2021-08-29 22:39:10.901  - info: zigbee.1 (12219) Starting Zigbee  npm ...
            2021-08-29 22:39:12.190  - info: zigbee.1 (12219) Installed Version: iobroker.zigbee@1.5.6
            2021-08-29 22:39:13.889  - warn: zigbee.1 (12219) Extended PAN ID is reversed (expected=d1dddddddddddddd, actual=ddddddddddddddd1)
            2021-08-29 22:39:23.906  - error: zigbee.1 (12219) Starting zigbee-herdsman problem : "AREQ - ZDO - activeEpRsp after 10000ms"
            2021-08-29 22:39:23.909  - error: zigbee.1 (12219) Failed to start Zigbee
            2021-08-29 22:39:23.910  - error: zigbee.1 (12219) Error herdsman start
            2021-08-29 22:39:33.913  - info: zigbee.1 (12219) Try to reconnect. 1 attempts left
            2021-08-29 22:39:33.915  - info: zigbee.1 (12219) Starting Zigbee  npm ...
            2021-08-29 22:39:33.960  - info: zigbee.1 (12219) Installed Version: iobroker.zigbee@1.5.6
            2021-08-29 22:39:34.442  - error: zigbee.1 (12219) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
            2021-08-29 22:39:34.445  - error: zigbee.1 (12219) Failed to start Zigbee
            2021-08-29 22:39:34.448  - error: zigbee.1 (12219) Error herdsman start
            • W WolfgangFB
              @wolfgangfb sagte in Zigbee Adapter startet nicht:
              Pass die mal an.
              Kann auch sein, dass die Firmware von dem Stick zu alt ist. Ich meine da war was unlängst.
              W 2 Antworten Letzte Antwort
                Pass die mal an.
                W Offline
                W Offline
                WolfgangFB
                Ich habe auf dem pi4 DDDDDDDDDDDDDDD0, auf dem 204 DDDDDDDDDDDDDDD1 und auf dem 202 DDDDDDDDDDDDDDDD eingestellt.
                Soll ich da jetzt auf dem 204 D1DDDDDDDDDDDDDD nehmen?
                Verstehen würde ich das nicht denn die 3 IDs sind verschieden und das ganze ist ja auch lange Zeit problemlos gelaufen.
                  Pass die mal an.
                  W Offline
                  W Offline
                  WolfgangFB
                  Und das mit der Firmware, ich weiß nicht, wenn die gleiche Firmware vor 20 Minuten noch lief, dann aber mit einer älteren node-js Version auf einmal nicht mehr, wie soll das zusammenpassen?
                  • W WolfgangFB
                    @wolfgangfb
                    Der aktuelle herdsman stellt da einiges um. Ich würde da auch 'bessere' hex-Werte nehmen. Gibt da Generatoren für im Web, wenn du nicht selber frickeln willst.
                    Und du hast insgesamt 3 Sticks laufen? Weil oben schreibst du nur von einem.
                    • W WolfgangFB
                      Das hat mit nodeJS nichts zu tun sondern mit den aktuellen Versionen vom herdsman.
                      Du kannst auch mal probieren wieder auf die 1.4er-Version vom zigbee-Adapter zu gehen. Die schleppt eine alte Version vom herdsman an. Kann sein das die wieder geht.
                        @wolfgangfb
                        W Offline
                        W Offline
                        WolfgangFB
                        @thomas-braun said in Zigbee Adapter startet nicht:
                        @wolfgangfb
                        Vor ein paar Tagen hat ein Freund einen noch älteren C2531 auf seinem neu aufgesetzten System installiert und der lief mit meinen Einstellungen problemlos
                        3 Raspberry PI (1 Master 2 Slave) und auf jedem ein CC2531
                        Ich habe beim ersten Post gedacht, dass wenn ich den Grund für den einen nicht startenden herausbekomme, ich den zweiten auch zum laufen bringe (und der dritte lief ja zu dem Zeitpunkt noch)
                        • W WolfgangFB
                          @wolfgangfb
                          @wolfgangfb
                          Hast du mal eine 1.4er-Version installiert?
                            W Offline
                            W Offline
                            WolfgangFB
                            Vor dem Verschlimmbessern lief ja auch dem funktionierenden die 1.4.4. und auf einem nicht funktionierenden auch die 1.4.4.
                            Wie downgrade ich denn auch eione ältere Verstion?
                            • W WolfgangFB
                              @wolfgangfb
                              iobroker upgrade zigbee@1.4.1
                              Oder im Admin unter den Experteneinstellungen:
                              • W Offline
                                W Offline
                                WolfgangFB
                                Was will mir das jetzt schon wieder sagen? (auf dem Pi4 hat der Downgrade, allerdings geklappt, aber der Adapter startet trotzdem nicht)
                                pi@raspberrypi202:/opt/iobroker/log $ iobroker upgrade zigbee@1.4.4
                                This downgrade of "zigbee" will at least remove the following changes:
                                -> 1.5.0
                                Dashboard
                                Would you like to downgrade zigbee from @1.5.6 to @1.4.4 now? [(y)es, (n)o]: y
                                Update zigbee from @1.5.6 to @1.4.4
                                host.raspberrypi202 Adapter "system.adapter.zigbee.2" is stopped.
                                NPM version: 6.14.14
                                npm install iobroker.zigbee@1.4.4 --loglevel error --prefix "/opt/iobroker" (System call)
                                The authenticity of host 'github.com (140.82.121.4)' can't be established.
                                RSA key fingerprint is SHA256:nThbg6kXUpJWGl7E1IGOCspRomTxdCARLviKw6E5SY8.
                                Are you sure you want to continue connecting (yes/no)? The authenticity of host 'github.com (140.82.121.4)' can't be established.
                                Are you sure you want to continue connecting (yes/no)? yes
                                Please type 'yes' or 'no': YES
                                Please type 'yes' or 'no': yes
                                npm ERR! Error while executing:
                                npm ERR! /usr/bin/git ls-remote -h -t ssh://git@github.com/ioBroker/ioBroker.onkyo.git
                                npm ERR!
                                npm ERR! Warning: Permanently added 'github.com,140.82.121.4' (RSA) to the list of known hosts.
                                npm ERR! Permission denied (publickey).
                                npm ERR! fatal: Konnte nicht vom Remote-Repository lesen.
                                npm ERR!
                                npm ERR! Bitte stellen Sie sicher, dass die korrekten Zugriffsberechtigungen bestehen
                                npm ERR! und das Repository existiert.
                                npm ERR!
                                npm ERR! exited with error code: 128
                                • W WolfgangFB
                                  -> 1.5.0
                                  Dashboard
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  @wolfgangfb
                                  Ich vermute die 1.4.4 gibt es nicht mehr. Nimm die 1.4.1.
                                    @wolfgangfb
                                    W Offline
                                    W Offline
                                    WolfgangFB
                                    Auf dem Pi4 hjat der Downgrade auf 1.4.4. geklappt.
                                    Ich gebe jetzt ziemlich frustriert für heute auf.
                                    Ich glaube das einzige was wirklich hilft ist "never touch a running system" (auch wenn die Experten dann immer über die hoffnungslos veralteten Versionen schimpfen) und wenn es wirklich sein muss, dann vorher ein Komplettclone der SD Karte machen um wieder zurückkehren zu können.
                                    Ich werde wohl morgen eine neue SD Karte nehmen und von 0 an ein neues System hochziehen.
                                    Wirklich ärgert mich, dass durch die Updaterei meine ganzen ESP-Home yaml Dateien weg sind (die meisten habe ich vorher, nach entsprechender Erfahrung, händisch gesichert, aber was ich letzte Woche gemacht habe, ist wohl weg)
                                    Trotzdem Danke für die versuchte Hilfe
                                    • W WolfgangFB
                                      Oder keine Hardware verwenden, die ausdrücklich 'not recommended' ist.
                                        W Offline
                                        W Offline
                                        WolfgangFB
                                        Was meinst Du damit?
                                        • W WolfgangFB
                                          @wolfgangfb
                                          Damit meine ich, das die CC2531/CC2530 Dinger ziemlicher Elektroschrott sind.
                                          https://www.zigbee2mqtt.io/information/supported_adapters.html
                                          Texas Instruments CC2531 (not recommended)
                                          Texas Instruments CC2530 (not recommended)
                                          Die wissen schon warum.
