  4. iobroker start unterbricht mit "...is not a function"
    6.5k
24 Beiträge 5 Kommentatoren 1.0k Aufrufe 4 Beobachtet
  • logilutionsL Offline
    logilutions
    Wenn ich meinen iobroker mit
    iobroker start
    starte, wird das Starten mit dem error:
    uncaught exception: tslib_1.__exportStar is not a function
    abgebrochen.
    Vollständiger log:
    2021-05-30 23:53:49.937  - info: host.milos iobroker _restart
    2021-05-30 23:53:49.956  - info: host.milos terminated
    2021-05-30 23:53:50.589  - info: host.milos iobroker Starting node restart.js
    2021-05-30 23:53:50.822  - info: host.milos received SIGTERM
    2021-05-30 23:53:50.824  - info: host.milos terminated
    2021-05-30 23:53:50.830  - info: host.milos iobroker exit null
    2021-05-30 23:53:52.002  - info: host.milos iobroker.js-controller version 3.3.11 js-controller starting
    2021-05-30 23:53:52.008  - info: host.milos Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-05-30 23:53:52.009  - info: host.milos hostname: milos, node: v10.24.1
    2021-05-30 23:53:52.010  - info: host.milos ip addresses: [IP]
    2021-05-30 23:53:52.133  - info: host.milos connected to Objects and States
    2021-05-30 23:53:52.162  - info: host.milos added notifications configuration of host
    2021-05-30 23:53:52.447  - error: host.milos uncaught exception: tslib_1.__exportStar is not a function
    2021-05-30 23:53:52.447  - error: host.milos TypeError: tslib_1.__exportStar is not a function
        at Object.<anonymous> (/opt/iobroker/node_modules/@sentry/utils/dist/index.js:3:9)
        at Module._compile (internal/modules/cjs/loader.js:778:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
        at Module.load (internal/modules/cjs/loader.js:653:32)
        at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
        at Function.Module._load (internal/modules/cjs/loader.js:585:3)
        at Module.require (internal/modules/cjs/loader.js:692:17)
        at require (internal/modules/cjs/helpers.js:25:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@sentry/hub/dist/scope.js:3:15)
    Systemdata
    Hardwaresystem: Pi4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: RaspBian lite (Debian 9 “Stretch”)
    Node-Version: 10.24.1
    Nodejs-Version: 10.24.1
    NPM-Version: 6.14.12
    Image genutzt: Ja
    Ort/Name der Imagedatei: Link
    Ich hoffe ich habe nicht gegen zu viele Forums-Guidelines verstoßen und danke für hilfreiche Antworten.
    BBTownB ? GlasfaserG 3 Antworten Letzte Antwort
    • logilutionsL logilutions
      iobroker start
      abgebrochen.
      Vollständiger log:
      Systemdata
      Hardwaresystem: Pi4
      Image genutzt: Ja
      BBTownB Offline
      BBTownB Offline
      BBTown
      @logilutions
      ich bin nicht sicher ob das dein Problem bereits löst, aber du solltest deine node Version auf v12.x anheben.
      ioBroker auf NUC (VM debian v13 (Trixie ), node v22.22.0 npm v10.9.4, js-controller v7.2.2 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
      logilutionsL 1 Antwort Letzte Antwort
      • BBTownB BBTown
        @logilutions
        logilutions
        @bbtown ich habe node aktualisiert, das konnte aber das Problem leider nicht lösen.
          iobroker start
          abgebrochen.
          Vollständiger log:
          Systemdata
          Hardwaresystem: Pi4
          Image genutzt: Ja
          @logilutions sagte in iobroker start unterbricht mit "...is not a function":
          das ist ein Fehler von einer Depency in Zusammenhang mit Typescript, hast du was extra installiert?
          Nach welcher Änderung ist der Fehler aufgetreten?
            @logilutions
            Das auch mal auf 'Buster' bringen.
              iobroker start
              abgebrochen.
              Vollständiger log:
              Systemdata
              Hardwaresystem: Pi4
              Image genutzt: Ja
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              Du bist im Beta Kanal !
              logilutionsL GlasfaserG 2 Antworten Letzte Antwort
              • GlasfaserG Glasfaser
                logilutions
                @glasfaser was bedeutet "Beta Kanal" und was genau kann ich machen?
                  @logilutions
                  Beta bedeutet, das du da Beta-Versionen testest.
                  Stell den sog. Verwahrort auf 'default / stable' ein.
                    @logilutions
                    logilutions
                    @thomas-braun wenn ich
                    iobroker repo
                    ausführe bekomme ich
                    stable      : http://download.iobroker.net/sources-dist.json
                    beta        : http://download.iobroker.net/sources-dist-latest.json
                    Active repo: stable
                    also scheint es auf stable zu stehen?
                    Wo kann ich das ansonten einstellen?
                    • GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      Jetzt nicht mehr .... eventuell mal umgestellt !?
                      oder
                      mit einem
                      sudo -H -u iobroker npm install iobroker.js-controller
                      aus NPM gezogen ?
                      EDIT:
                      Zeige mal :
                      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                      iobroker status
                      iobroker update
                        oder
                        mit einem
                        aus NPM gezogen ?
                        EDIT:
                        Zeige mal :
                        iobroker status
                        iobroker update
                        logilutions
                        schrieb am zuletzt editiert von logilutions
                        @glasfaser
                        bin mir nicht sicher, aber könnte sein, dass ichs bei den fix-versuchen mal aus npm neu gezogen hab. hat auf jedenfall nichts am log geändert.
                        Ausgabe deiner Befehle:
                        $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                        /usr/bin/nodejs
                        v10.24.1
                        /usr/local/bin/node
                        v14.17.0
                        /usr/local/bin/npm
                        6.14.13
                        nodejs:
                          Installiert:           10.24.1-1nodesource1
                          Installationskandidat: 10.24.1-1nodesource1
                          Versionstabelle:
                         *** 10.24.1-1nodesource1 500
                                500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                                100 /var/lib/dpkg/status
                             10.24.0~dfsg-1~deb10u1 500
                        ____________________________
                        $ iobroker status
                        iobroker is not running on this host.
                        No iobroker host is running.
                        Objects type: redis
                        States  type: redis
                        $ iobroker update
                        Used repository: stable
                        hash changed or no sources cached => force download of new sources
                        update done
                        Adapter    "admin"         : 4.2.1    , installed 4.2.1
                        ... alle anderen Adapter (alle aktuell)
                          @glasfaser
                          /usr/bin/nodejs
                          v10.24.1
                          /usr/local/bin/node
                          v14.17.0
                          /usr/local/bin/npm
                          6.14.13
                          nodejs:
                            Versionstabelle:
                          $ iobroker status
                          Objects type: redis
                          States  type: redis
                          $ iobroker update
                          update done
                          @logilutions
                          nodeJS ist krumm.
                          Sauber installieren, am besten node12 oder node14. Siehe Link in meiner Signatur.
                            @logilutions
                            nodeJS ist krumm.
                            logilutions
                            ich habe jetzt node 14 nochmal ordentlich installiert.
                            Dennoch treten nach wie vor die gleichen Symptome auf.
                              @logilutions
                              Was kommt jetzt auf
                              zurück?
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Glasfaser
                                @logilutions
                                @glasfaser sagte in iobroker start unterbricht mit "...is not a function":
                                Ziehe den mal auf Stable .
                                cd /opt/iobroker
                                sudo -H -u iobroker npm install iobroker.js-controller@3.2.16
                                logilutionsL 2 Antworten Letzte Antwort
                                  @logilutions
                                  Was kommt jetzt auf
                                  zurück?
                                  logilutions
                                  /usr/bin/nodejs
                                  v14.17.0
                                  /usr/local/bin/node
                                  v14.17.0
                                  /usr/local/bin/npm
                                  6.14.13
                                  nodejs:
                                    Installiert:           14.17.0-1nodesource1
                                    Installationskandidat: 14.17.0-1nodesource1
                                    Versionstabelle:
                                   *** 14.17.0-1nodesource1 500
                                          500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                    @logilutions
                                    cd /opt/iobroker
                                    logilutions
                                    @glasfaser
                                    keine Änderung
                                      @glasfaser
                                      keine Änderung
                                      @logilutions
                                      Node falsch installiert.
                                      Schau nochmal in meine Signatur.
                                      Die Pfade sind falsch.
                                        @logilutions
                                        logilutions
                                        tut mir echt leid, hab wohl beim Lesen genau die Stelle mit den Pfaden ausgelassen .. Upsi
                                        jetzt steht da
                                        /usr/bin/nodejs
                                        v14.17.0
                                        /usr/bin/node
                                        v14.17.0
                                        /usr/bin/npm
                                        6.14.13
                                        nodejs:
                                          Versionstabelle:
                                        Der Fehler in iobroker logs ist nach wie vor:
                                        2021-06-07 22:55:56.604  - info: host.milos iobroker _restart
                                        2021-06-07 22:55:56.623  - info: host.milos terminated
                                        2021-06-07 22:55:57.266  - info: host.milos iobroker Starting node restart.js
                                        2021-06-07 22:55:58.880  - info: host.milos iobroker.js-controller version 3.2.16 js-controller starting
                                        2021-06-07 22:55:58.887  - info: host.milos Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                        2021-06-07 22:55:58.888  - info: host.milos hostname: milos, node: v14.17.0
                                        2021-06-07 22:55:58.889  - info: host.milos ip addresses: [IP]
                                        2021-06-07 22:55:59.065  - info: host.milos connected to Objects and States
                                        2021-06-07 22:55:59.100  - info: host.milos added notifications configuration of host
                                        2021-06-07 22:55:59.348  - error: host.milos uncaught exception: tslib_1.__exportStar is not a function
                                        2021-06-07 22:55:59.349  - error: host.milos TypeError: tslib_1.__exportStar is not a function
                                           at Module._compile (internal/modules/cjs/loader.js:1068:30)
                                           at Object.Module._extensions..js (internal/modules/cjs/loader.js:1097:10)
                                           at Module.load (internal/modules/cjs/loader.js:933:32)
                                           at Function.Module._load (internal/modules/cjs/loader.js:774:14)
                                           at Module.require (internal/modules/cjs/loader.js:957:19)
                                           at require (internal/modules/cjs/helpers.js:88:18)
                                        2021-06-07 22:55:59.358  - info: host.milos iobroker _restart
                                        2021-06-07 22:55:59.376  - info: host.milos terminated
                                        2021-06-07 22:55:58.889  - info: host.milos ip addresses: 192.168.1.94 fd8c:7d82:f0fc:1:6101:8c40:b126:7097 2003:f3:1706:1600:f36c:2cef:f6c6:1d92 fe80::4c4:fc63:bb4f:e69a
                                          jetzt steht da
                                          /usr/bin/nodejs
                                          v14.17.0
                                          /usr/bin/node
                                          v14.17.0
                                          /usr/bin/npm
                                          6.14.13
                                          nodejs:
                                            Versionstabelle:
                                          @logilutions
                                          cd /opt/iobroker
