  4. iobroker start unterbricht mit "...is not a function"
    2.0k
24 Beiträge 5 Kommentatoren 766 Aufrufe 4 Beobachtet
  • logilutionsL Offline
    logilutions
    Wenn ich meinen iobroker mit
    iobroker start
    starte, wird das Starten mit dem error:
    uncaught exception: tslib_1.__exportStar is not a function
    abgebrochen.
    Vollständiger log:
    2021-05-30 23:53:49.937  - info: host.milos iobroker _restart
    2021-05-30 23:53:49.956  - info: host.milos terminated
    2021-05-30 23:53:50.589  - info: host.milos iobroker Starting node restart.js
    2021-05-30 23:53:50.822  - info: host.milos received SIGTERM
    2021-05-30 23:53:50.824  - info: host.milos terminated
    2021-05-30 23:53:50.830  - info: host.milos iobroker exit null
    2021-05-30 23:53:52.002  - info: host.milos iobroker.js-controller version 3.3.11 js-controller starting
    2021-05-30 23:53:52.008  - info: host.milos Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-05-30 23:53:52.009  - info: host.milos hostname: milos, node: v10.24.1
    2021-05-30 23:53:52.010  - info: host.milos ip addresses: [IP]
    2021-05-30 23:53:52.133  - info: host.milos connected to Objects and States
    2021-05-30 23:53:52.162  - info: host.milos added notifications configuration of host
    2021-05-30 23:53:52.447  - error: host.milos uncaught exception: tslib_1.__exportStar is not a function
    2021-05-30 23:53:52.447  - error: host.milos TypeError: tslib_1.__exportStar is not a function
        at Object.<anonymous> (/opt/iobroker/node_modules/@sentry/utils/dist/index.js:3:9)
        at Module._compile (internal/modules/cjs/loader.js:778:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
        at Module.load (internal/modules/cjs/loader.js:653:32)
        at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
        at Function.Module._load (internal/modules/cjs/loader.js:585:3)
        at Module.require (internal/modules/cjs/loader.js:692:17)
        at require (internal/modules/cjs/helpers.js:25:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@sentry/hub/dist/scope.js:3:15)
    Systemdata
    Hardwaresystem: Pi4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: RaspBian lite (Debian 9 “Stretch”)
    Node-Version: 10.24.1
    Nodejs-Version: 10.24.1
    NPM-Version: 6.14.12
    Image genutzt: Ja
    Ort/Name der Imagedatei: Link
    Ich hoffe ich habe nicht gegen zu viele Forums-Guidelines verstoßen und danke für hilfreiche Antworten.
    BBTownB ? GlasfaserG 3 Antworten Letzte Antwort
    • logilutionsL logilutions
      iobroker start
      abgebrochen.
      Vollständiger log:
      Systemdata
      Hardwaresystem: Pi4
      Image genutzt: Ja
      BBTownB Offline
      BBTownB Offline
      BBTown
      @logilutions
      ich bin nicht sicher ob das dein Problem bereits löst, aber du solltest deine node Version auf v12.x anheben.
      logilutionsL 1 Antwort Letzte Antwort
      • BBTownB BBTown
        @logilutions
        logilutions
        @bbtown ich habe node aktualisiert, das konnte aber das Problem leider nicht lösen.
          iobroker start
          abgebrochen.
          Vollständiger log:
          Systemdata
          Hardwaresystem: Pi4
          Image genutzt: Ja
          @logilutions sagte in iobroker start unterbricht mit "...is not a function":
          das ist ein Fehler von einer Depency in Zusammenhang mit Typescript, hast du was extra installiert?
          Nach welcher Änderung ist der Fehler aufgetreten?
            @logilutions
            Das auch mal auf 'Buster' bringen.
              iobroker start
              abgebrochen.
              Vollständiger log:
              Systemdata
              Hardwaresystem: Pi4
              Image genutzt: Ja
              GlasfaserG Offline
              GlasfaserG Offline
              Du bist im Beta Kanal !
              logilutionsL GlasfaserG 2 Antworten Letzte Antwort
              • GlasfaserG Glasfaser
                logilutions
                @glasfaser was bedeutet "Beta Kanal" und was genau kann ich machen?
                  @logilutions
                  Beta bedeutet, das du da Beta-Versionen testest.
                  Stell den sog. Verwahrort auf 'default / stable' ein.
                    @logilutions
                    logilutions
                    @thomas-braun wenn ich
                    iobroker repo
                    ausführe bekomme ich
                    stable      : http://download.iobroker.net/sources-dist.json
                    beta        : http://download.iobroker.net/sources-dist-latest.json
                    Active repo: stable
                    also scheint es auf stable zu stehen?
                    Wo kann ich das ansonten einstellen?
                    • GlasfaserG Offline
                      GlasfaserG Offline
                      Jetzt nicht mehr .... eventuell mal umgestellt !?
                      oder
                      mit einem
                      sudo -H -u iobroker npm install iobroker.js-controller
                      aus NPM gezogen ?
                      EDIT:
                      Zeige mal :
                      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                      iobroker status
                      iobroker update
                        oder
                        mit einem
                        aus NPM gezogen ?
                        EDIT:
                        Zeige mal :
                        iobroker status
                        iobroker update
                        logilutions
                        schrieb am zuletzt editiert von logilutions
                        @glasfaser
                        bin mir nicht sicher, aber könnte sein, dass ichs bei den fix-versuchen mal aus npm neu gezogen hab. hat auf jedenfall nichts am log geändert.
                        Ausgabe deiner Befehle:
                        $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                        /usr/bin/nodejs
                        v10.24.1
                        /usr/local/bin/node
                        v14.17.0
                        /usr/local/bin/npm
                        6.14.13
                        nodejs:
                          Installiert:           10.24.1-1nodesource1
                          Installationskandidat: 10.24.1-1nodesource1
                          Versionstabelle:
                         *** 10.24.1-1nodesource1 500
                                500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                             10.24.0~dfsg-1~deb10u1 500
                        ____________________________
                        $ iobroker status
                        iobroker is not running on this host.
                        No iobroker host is running.
                        Objects type: redis
                        States  type: redis
                        $ iobroker update
                        Used repository: stable
                        hash changed or no sources cached => force download of new sources
                        update done
                        Adapter    "admin"         : 4.2.1    , installed 4.2.1
                        ... alle anderen Adapter (alle aktuell)
                          @glasfaser
                          /usr/bin/nodejs
                          v10.24.1
                          /usr/local/bin/node
                          v14.17.0
                          /usr/local/bin/npm
                          6.14.13
                          nodejs:
                            Versionstabelle:
                          $ iobroker status
                          Objects type: redis
                          States  type: redis
                          $ iobroker update
                          update done
                          @logilutions
                          nodeJS ist krumm.
                          Sauber installieren, am besten node12 oder node14. Siehe Link in meiner Signatur.
                            @logilutions
                            nodeJS ist krumm.
                            logilutions
                            ich habe jetzt node 14 nochmal ordentlich installiert.
                            Dennoch treten nach wie vor die gleichen Symptome auf.
                              @logilutions
                              Was kommt jetzt auf
                              zurück?
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @logilutions
                                @glasfaser sagte in iobroker start unterbricht mit "...is not a function":
                                Ziehe den mal auf Stable .
                                cd /opt/iobroker
                                sudo -H -u iobroker npm install iobroker.js-controller@3.2.16
                                logilutionsL 2 Antworten Letzte Antwort
                                  @logilutions
                                  Was kommt jetzt auf
                                  zurück?
                                  logilutions
                                  /usr/bin/nodejs
                                  v14.17.0
                                  /usr/local/bin/node
                                  v14.17.0
                                  /usr/local/bin/npm
                                  6.14.13
                                  nodejs:
                                    Installiert:           14.17.0-1nodesource1
                                    Installationskandidat: 14.17.0-1nodesource1
                                    Versionstabelle:
                                   *** 14.17.0-1nodesource1 500
                                          500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                    @logilutions
                                    cd /opt/iobroker
                                    logilutions
                                    @glasfaser
                                    keine Änderung
                                      @glasfaser
                                      keine Änderung
                                      @logilutions
                                      Node falsch installiert.
                                      Schau nochmal in meine Signatur.
                                      Die Pfade sind falsch.
                                        @logilutions
                                        logilutions
                                        tut mir echt leid, hab wohl beim Lesen genau die Stelle mit den Pfaden ausgelassen .. Upsi
                                        jetzt steht da
                                        /usr/bin/nodejs
                                        v14.17.0
                                        /usr/bin/node
                                        v14.17.0
                                        /usr/bin/npm
                                        6.14.13
                                        nodejs:
                                          Versionstabelle:
                                        Der Fehler in iobroker logs ist nach wie vor:
                                        2021-06-07 22:55:56.604  - info: host.milos iobroker _restart
                                        2021-06-07 22:55:56.623  - info: host.milos terminated
                                        2021-06-07 22:55:57.266  - info: host.milos iobroker Starting node restart.js
                                        2021-06-07 22:55:58.880  - info: host.milos iobroker.js-controller version 3.2.16 js-controller starting
                                        2021-06-07 22:55:58.887  - info: host.milos Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                        2021-06-07 22:55:58.888  - info: host.milos hostname: milos, node: v14.17.0
                                        2021-06-07 22:55:58.889  - info: host.milos ip addresses: [IP]
                                        2021-06-07 22:55:59.065  - info: host.milos connected to Objects and States
                                        2021-06-07 22:55:59.100  - info: host.milos added notifications configuration of host
                                        2021-06-07 22:55:59.348  - error: host.milos uncaught exception: tslib_1.__exportStar is not a function
                                        2021-06-07 22:55:59.349  - error: host.milos TypeError: tslib_1.__exportStar is not a function
                                           at Module._compile (internal/modules/cjs/loader.js:1068:30)
                                           at Object.Module._extensions..js (internal/modules/cjs/loader.js:1097:10)
                                           at Module.load (internal/modules/cjs/loader.js:933:32)
                                           at Function.Module._load (internal/modules/cjs/loader.js:774:14)
                                           at Module.require (internal/modules/cjs/loader.js:957:19)
                                           at require (internal/modules/cjs/helpers.js:88:18)
                                        2021-06-07 22:55:59.358  - info: host.milos iobroker _restart
                                        2021-06-07 22:55:59.376  - info: host.milos terminated
                                        2021-06-07 22:55:58.889  - info: host.milos ip addresses: 192.168.1.94 fd8c:7d82:f0fc:1:6101:8c40:b126:7097 2003:f3:1706:1600:f36c:2cef:f6c6:1d92 fe80::4c4:fc63:bb4f:e69a
                                          jetzt steht da
                                          /usr/bin/nodejs
                                          v14.17.0
                                          /usr/bin/node
                                          v14.17.0
                                          /usr/bin/npm
                                          6.14.13
                                          nodejs:
                                            Versionstabelle:
                                          @logilutions
                                          cd /opt/iobroker
