  4. iobroker start unterbricht mit "...is not a function"
    6.5k
24 Beiträge 5 Kommentatoren 1.0k Aufrufe 4 Beobachtet
  • logilutionsL logilutions
    Wenn ich meinen iobroker mit
    iobroker start
    starte, wird das Starten mit dem error:
    uncaught exception: tslib_1.__exportStar is not a function
    abgebrochen.
    Vollständiger log:
    2021-05-30 23:53:49.937  - info: host.milos iobroker _restart
    2021-05-30 23:53:49.956  - info: host.milos terminated
    2021-05-30 23:53:50.589  - info: host.milos iobroker Starting node restart.js
    2021-05-30 23:53:50.822  - info: host.milos received SIGTERM
    2021-05-30 23:53:50.824  - info: host.milos terminated
    2021-05-30 23:53:50.830  - info: host.milos iobroker exit null
    2021-05-30 23:53:52.002  - info: host.milos iobroker.js-controller version 3.3.11 js-controller starting
    2021-05-30 23:53:52.008  - info: host.milos Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-05-30 23:53:52.009  - info: host.milos hostname: milos, node: v10.24.1
    2021-05-30 23:53:52.010  - info: host.milos ip addresses: [IP]
    2021-05-30 23:53:52.133  - info: host.milos connected to Objects and States
    2021-05-30 23:53:52.162  - info: host.milos added notifications configuration of host
    2021-05-30 23:53:52.447  - error: host.milos uncaught exception: tslib_1.__exportStar is not a function
    2021-05-30 23:53:52.447  - error: host.milos TypeError: tslib_1.__exportStar is not a function
        at Object.<anonymous> (/opt/iobroker/node_modules/@sentry/utils/dist/index.js:3:9)
        at Module._compile (internal/modules/cjs/loader.js:778:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
        at Module.load (internal/modules/cjs/loader.js:653:32)
        at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
        at Function.Module._load (internal/modules/cjs/loader.js:585:3)
        at Module.require (internal/modules/cjs/loader.js:692:17)
        at require (internal/modules/cjs/helpers.js:25:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@sentry/hub/dist/scope.js:3:15)
    Systemdata
    Hardwaresystem: Pi4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: RaspBian lite (Debian 9 “Stretch”)
    Node-Version: 10.24.1
    Nodejs-Version: 10.24.1
    NPM-Version: 6.14.12
    Image genutzt: Ja
    Ort/Name der Imagedatei: Link
    Ich hoffe ich habe nicht gegen zu viele Forums-Guidelines verstoßen und danke für hilfreiche Antworten.
    @logilutions sagte in iobroker start unterbricht mit "...is not a function":
    das ist ein Fehler von einer Depency in Zusammenhang mit Typescript, hast du was extra installiert?
    Nach welcher Änderung ist der Fehler aufgetreten?
      @bbtown ich habe node aktualisiert, das konnte aber das Problem leider nicht lösen.
      @logilutions
      Das auch mal auf 'Buster' bringen.
        iobroker start
        abgebrochen.
        Vollständiger log:
        Systemdata
        Hardwaresystem: Pi4
        Image genutzt: Ja
        GlasfaserG Offline
        GlasfaserG Offline
        Du bist im Beta Kanal !
        logilutionsL GlasfaserG 2 Antworten Letzte Antwort
        • GlasfaserG Glasfaser
          logilutionsL Offline
          logilutions
          @glasfaser was bedeutet "Beta Kanal" und was genau kann ich machen?
            @logilutions
            Beta bedeutet, das du da Beta-Versionen testest.
            Stell den sog. Verwahrort auf 'default / stable' ein.
            logilutionsL 1 Antwort Letzte Antwort
              @logilutions
              logilutions
              @thomas-braun wenn ich
              iobroker repo
              ausführe bekomme ich
              stable      : http://download.iobroker.net/sources-dist.json
              beta        : http://download.iobroker.net/sources-dist-latest.json
              Active repo: stable
              also scheint es auf stable zu stehen?
              Wo kann ich das ansonten einstellen?
              • GlasfaserG Offline
                GlasfaserG Offline
                Jetzt nicht mehr .... eventuell mal umgestellt !?
                oder
                mit einem
                sudo -H -u iobroker npm install iobroker.js-controller
                aus NPM gezogen ?
                EDIT:
                Zeige mal :
                which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                iobroker status
                iobroker update
                  oder
                  mit einem
                  aus NPM gezogen ?
                  EDIT:
                  Zeige mal :
                  iobroker status
                  iobroker update
                  logilutions
                  schrieb am zuletzt editiert von logilutions
                  @glasfaser
                  bin mir nicht sicher, aber könnte sein, dass ichs bei den fix-versuchen mal aus npm neu gezogen hab. hat auf jedenfall nichts am log geändert.
                  Ausgabe deiner Befehle:
                  $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                  /usr/bin/nodejs
                  v10.24.1
                  /usr/local/bin/node
                  v14.17.0
                  /usr/local/bin/npm
                  6.14.13
                  nodejs:
                    Installiert:           10.24.1-1nodesource1
                    Installationskandidat: 10.24.1-1nodesource1
                    Versionstabelle:
                   *** 10.24.1-1nodesource1 500
                          500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                       10.24.0~dfsg-1~deb10u1 500
                  ____________________________
                  $ iobroker status
                  iobroker is not running on this host.
                  No iobroker host is running.
                  Objects type: redis
                  States  type: redis
                  $ iobroker update
                  Used repository: stable
                  hash changed or no sources cached => force download of new sources
                  update done
                  Adapter    "admin"         : 4.2.1    , installed 4.2.1
                  ... alle anderen Adapter (alle aktuell)
                    @glasfaser
                    /usr/bin/nodejs
                    v10.24.1
                    /usr/local/bin/node
                    v14.17.0
                    /usr/local/bin/npm
                    6.14.13
                    nodejs:
                      Versionstabelle:
                    $ iobroker status
                    Objects type: redis
                    States  type: redis
                    $ iobroker update
                    update done
                    @logilutions
                    nodeJS ist krumm.
                    Sauber installieren, am besten node12 oder node14. Siehe Link in meiner Signatur.
                      @logilutions
                      nodeJS ist krumm.
                      logilutions
                      ich habe jetzt node 14 nochmal ordentlich installiert.
                      Dennoch treten nach wie vor die gleichen Symptome auf.
                        @logilutions
                        Was kommt jetzt auf
                        zurück?
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @logilutions
                          @glasfaser sagte in iobroker start unterbricht mit "...is not a function":
                          Ziehe den mal auf Stable .
                          cd /opt/iobroker
                          sudo -H -u iobroker npm install iobroker.js-controller@3.2.16
                          logilutionsL 2 Antworten Letzte Antwort
                            @logilutions
                            Was kommt jetzt auf
                            zurück?
                            logilutions
                            /usr/bin/nodejs
                            v14.17.0
                            /usr/local/bin/node
                            v14.17.0
                            /usr/local/bin/npm
                            6.14.13
                            nodejs:
                              Installiert:           14.17.0-1nodesource1
                              Installationskandidat: 14.17.0-1nodesource1
                              Versionstabelle:
                             *** 14.17.0-1nodesource1 500
                                    500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                              @logilutions
                              cd /opt/iobroker
                              logilutions
                              @glasfaser
                              keine Änderung
                                @glasfaser
                                keine Änderung
                                @logilutions
                                Node falsch installiert.
                                Schau nochmal in meine Signatur.
                                Die Pfade sind falsch.
                                  @logilutions
                                  logilutions
                                  tut mir echt leid, hab wohl beim Lesen genau die Stelle mit den Pfaden ausgelassen .. Upsi
                                  jetzt steht da
                                  /usr/bin/nodejs
                                  v14.17.0
                                  /usr/bin/node
                                  v14.17.0
                                  /usr/bin/npm
                                  6.14.13
                                  nodejs:
                                    Versionstabelle:
                                  Der Fehler in iobroker logs ist nach wie vor:
                                  2021-06-07 22:55:56.604  - info: host.milos iobroker _restart
                                  2021-06-07 22:55:56.623  - info: host.milos terminated
                                  2021-06-07 22:55:57.266  - info: host.milos iobroker Starting node restart.js
                                  2021-06-07 22:55:58.880  - info: host.milos iobroker.js-controller version 3.2.16 js-controller starting
                                  2021-06-07 22:55:58.887  - info: host.milos Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                  2021-06-07 22:55:58.888  - info: host.milos hostname: milos, node: v14.17.0
                                  2021-06-07 22:55:58.889  - info: host.milos ip addresses: [IP]
                                  2021-06-07 22:55:59.065  - info: host.milos connected to Objects and States
                                  2021-06-07 22:55:59.100  - info: host.milos added notifications configuration of host
                                  2021-06-07 22:55:59.348  - error: host.milos uncaught exception: tslib_1.__exportStar is not a function
                                  2021-06-07 22:55:59.349  - error: host.milos TypeError: tslib_1.__exportStar is not a function
                                     at Module._compile (internal/modules/cjs/loader.js:1068:30)
                                     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1097:10)
                                     at Module.load (internal/modules/cjs/loader.js:933:32)
                                     at Function.Module._load (internal/modules/cjs/loader.js:774:14)
                                     at Module.require (internal/modules/cjs/loader.js:957:19)
                                     at require (internal/modules/cjs/helpers.js:88:18)
                                  2021-06-07 22:55:59.358  - info: host.milos iobroker _restart
                                  2021-06-07 22:55:59.376  - info: host.milos terminated
                                  2021-06-07 22:55:58.889  - info: host.milos ip addresses: 192.168.1.94 fd8c:7d82:f0fc:1:6101:8c40:b126:7097 2003:f3:1706:1600:f36c:2cef:f6c6:1d92 fe80::4c4:fc63:bb4f:e69a
                                    jetzt steht da
                                    /usr/bin/nodejs
                                    v14.17.0
                                    /usr/bin/node
                                    v14.17.0
                                    /usr/bin/npm
                                    6.14.13
                                    nodejs:
                                      Versionstabelle:
                                    @logilutions
                                    cd /opt/iobroker
                                      @logilutions
                                      cd /opt/iobroker
                                      logilutions
                                      @glasfaser said in iobroker start unterbricht mit "...is not a function":
                                      cd /opt/iobroker
                                      @Thomas-Braun Das hatte ich hier schon gemacht, hab es jetzt nochmals ausgeführt, hat aber nichts geändert.
                                        cd /opt/iobroker
                                        @logilutions
                                        Dann zück dein Backup.
                                          @logilutions
                                          logilutions
                                          @thomas-braun zück dein Backup aka neu installieren und backup drauf?
