  4. [Frage] Xiaomi Vacuum cleaner
    5.8k
2.2k Beiträge 204 Kommentatoren 1.2m Aufrufe 39 Beobachtet
  • KnallochseK Offline
    KnallochseK Offline
    Knallochse
    #521
    Hab gerade unter Host den Controller neu gestartet.
    Da erschienen folgende Fehlermeldungen:
    mihome-vacuum.0	2017-04-09 10:43:04.697	error	at Manager.Emitter.emit (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
    mihome-vacuum.0	2017-04-09 10:43:04.697	error	at Manager. (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-bind\index.js:21:15)
    mihome-vacuum.0	2017-04-09 10:43:04.697	error	at Socket.onpacket (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:236:12)
    mihome-vacuum.0	2017-04-09 10:43:04.697	error	at Socket.onack (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:312:9)
    mihome-vacuum.0	2017-04-09 10:43:04.697	error	at Socket. (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:686:25)
    mihome-vacuum.0	2017-04-09 10:43:04.697	error	at initAdapter (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:4476:18)
    mihome-vacuum.0	2017-04-09 10:43:04.697	error	at Adapter.emit (events.js:185:7)
    mihome-vacuum.0	2017-04-09 10:43:04.697	error	at emitNone (events.js:86:13)
    mihome-vacuum.0	2017-04-09 10:43:04.697	error	at Adapter.main (C:\ioBroker\node_modules\iobroker.mihome-vacuum\main.js:232:12)
    mihome-vacuum.0	2017-04-09 10:43:04.697	error	at Socket.bind (dgram.js:144:11)
    mihome-vacuum.0	2017-04-09 10:43:04.697	error	Error: Socket is already bound
    mihome-vacuum.0	2017-04-09 10:43:04.697	error	uncaught exception: Socket is already bound
    HM&HMIP über 100 Geräte + IoBroker auf DS918+ uvm.
    • MeistertrM Offline
      MeistertrM Offline
      Meistertr
      #522
      @Knallochse:
      • mihome-vacuum.0 2017-04-09 10:43:04.697 error at Manager.Emitter.emit (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
      mihome-vacuum.0 2017-04-09 10:43:04.697 error uncaught exception: Socket is already bound `
      Konntest du dein Problem lösen? falls nicht, versuche einmal die zeile 232 in der main aus zu kommentieren also "//server.bind(adapter.config.ownPort);" und probiere es noch einmal.
      in der Version 0.3.0 ist noch ein kleiner fehler, die Fan_power kann nicht gesendet werden und verursacht eine fehlermeldung im log, die ist nur eine Kleinigkeit und bereits in einem Pull request repariert.
      • BluefoxB Offline
        BluefoxB Offline
        #523
        @Knallochse:
        sagt dir nichts?
          KnallochseK Offline
          Knallochse
          #524
          Bin gestern Abend zurück auf die 0.1.0 gewechselt.
          Adapter wurde sofort grün, keine Fehler im Log aber auch keine Reaktion des Xiaomi auf meine Schaltbefehle.
          Habe dann heute morgen den Adapter komplett deinstalliert, habe den Xiaomi zurückgesetzt (neuer Token)
          und die Version 0.1.0 installiert. Siehe da - er läuft :D
          Habe dann die aktuelle 0.3.1 darüber installiert. Siehe da - läuft auch :D
          Hab keine Ahnung was da nicht funktionierte.
          Fehler "Socket is already bound" wurde wohl durch das manuelle starten über die Konsole verursacht (Vermutung)
          Ich möchte hinzufügen, ich habe keine Programmierkenntnisse,
          aber durch die viel lesen hier im Forum bekommt mann doch alles gut zum laufen.
          Damit von mir einmal - DANKESCHÖN.
          • ruhr70R Offline
            ruhr70R Offline
            ruhr70
            #525
            So… der Robbi hat den Weg von China zu uns gefunden ;-)
            Nur bin ich anscheinen zu blöd. Wie installiere ich denn die 0.3.1?
            Ich bekomme nur die 0.1.0
              #526
              http://forum.iobroker.net/viewtopic.php … 032#p61032
              Rainer
              • ruhr70R Offline
                ruhr70R Offline
                ruhr70
                #527
                @Homoran:
                http://forum.iobroker.net/viewtopic.php … 032#p61032 `
                Danke Rainer. Nur genau diese Link hat bei mir die 0.1.0 installiert :-)
                  MeistertrM Offline
                  Meistertr
                  #528
                  Du musst diesen Link nehmen
                  https://github.com/ioBroker/ioBroker.mihome-vacuum
                  Die Änderungen sind nun alle im Master
                  Gesendet von meinem E5823 mit Tapatalk
                    #529
                    @ruhr70:
                    Danke Rainer. Nur genau diese Link hat bei mir die 0.1.0 installiert `
                    :oops: :oops:
                    Veilleicht hier:
                    https://github.com/MeisterTR/ioBroker.mihome-vacuum/
                    EDIT:
                    Da wusste wohl jemand wo es ist :(
                    ich habe zu lange gesucht.
                    • ruhr70R Offline
                      ruhr70R Offline
                      ruhr70
                      #530
                      @Meistertr:
                      Gesendet von meinem E5823 mit Tapatalk `
                      Super! Funktioniert!
                      • Installation
                      • der Token, den ich vorher ausgelesen hatte
                      • und "find"
                      Top :!:
                      Den Rest muss ich testen, wenn meine Frau schlafen geht :lol:
                        mc-hollin
                        #531
                        @ruhr70:
                        So… der Robbi hat den Weg von China zu uns gefunden ;-) `
                        Hast du den Robo ohne Android App am laufen?
                        Oder musstest du vorher die App installieren?
                        • ruhr70R Offline
                          ruhr70R Offline
                          ruhr70
                          #532
                          @mc-hollin:
                          @ruhr70:
                          Oder musstest du vorher die App installieren? `
                          Das Token hatte ich ohne App gezogen, dann aber direkt die original iOS App gezogen.
                          Irgendwo hier stand, wie man ohne APP das WLAN konfiguriert. Da war ich jetzt aber zu faul für :oops:
                            mc-hollin
                            #533
                            Schade.
                            Hatte gehofft , dass einer den Robo ohne Xiaomi App Installation steuern kann.
                            Dann teste ich weiter.
                              martz
                              #534
                              Eigener Port bei einer Instanz ändern.
                              Hallo Bluefox,
                              habe die Version 0.3.1 installiert - funktioniert jetzt mit 2 Saugern einwandfrei !
                                MeistertrM Offline
                                Meistertr
                                #535
                                Da es ruhig geworden ist, gehe ich davon aus, dass bei allen der Adapter läuft und keiner Änderungswünsche hat?
                                  skorpil
                                  #536
                                  Bei mir alles super! Ich habe noch den "alten" Stand. Aber es läuft. Grandios. Vielen Dank!
                                    KnallochseK Offline
                                    Knallochse
                                    #537
                                    Läuft zuverlässig.
                                    System: Iobroker auf Microsoft Surface 3 (win10)
                                    Vacuum Adapeter : 0.3.1
                                    • ruhr70R Offline
                                      ruhr70R Offline
                                      ruhr70
                                      #538
                                      @Meistertr:
                                      Da es ruhig geworden ist, gehe ich davon aus, dass bei allen der Adapter läuft und keiner Änderungswünsche hat? `
                                      Bisher wunschlos glücklich :-)
                                      Ich hatte einmal den Fall, dass der Adapter immer zwischen grün und gelb schwankte. Habe dann Debug eingeschaltet. Nach dem dadurch bedingten Neustart blieb es dann stabil :?
                                      Die Verbrauchswerte gehen recht schnell nach oben.
                                      Kann man die dann über den Adapter auf 0% setzen, wenn man z.B. die erste tauscht oder muss man das über die App erledigen?
                                        markus- 0
                                        #539
                                        FYI: Mir ist heute ein Staubsauger untergekommen, der statt der ID "034c" die "0317" sendet.
                                        Bei Knallochse scheint es "034d" zu sein.
                                        <size size="85">https://forum.fhem.de/index.php?topic=73052</size>
                                        • H Offline
                                          holger
                                          #540
                                          Hat jemand von Euch den Air Purifier 2 laufen?
                                          Könnt Ihr mir bitte ggf. sagen, wie ich den zum Laufen bekomme?
                                          Habe mir python-mirobo installiert. Ich habe verstanden, dass der token über "mirobo discover" für den Air Purifier nicht den richtigen Token liefert.
                                          Ich bekomme auch ein
                                          INFO:mirobo.vacuum:Sending discovery packet to broadcast address..
                                          WARNING:mirobo.protocol:Unable to decrypt, returning raw bytes.
                                          INFO:mirobo.vacuum:  IP 192.168.13.1: 825 - token: b'b57133210b1XXXXXXXXXXXXXXXXX'
                                          Als m.header.value.devtype bekomme ich also 825 - das kann so nicht stimmen, oder?
                                          Wie komme ich denn an den richtigen Token?
                                          Und wie mache ich dann weiter?
