  5. [Vorlage] HP Drucker Füllstände (Javascript).
52 Beiträge 9 Kommentatoren 7.7k Aufrufe 12 Beobachtet
  • C Clown007
    @dolomiti Okay, dann entfernen wir diese Zeichen einfach:
     * Read informations from HP Printers;
     * 2021-04-16 @ TheAlphaGhost;
    var url = 'http://HP983B82.fritz.box/DevMgmt/ConsumableConfigDyn.xml';
    var parseString = require('xml2js').parseString;
    // Create datapoints;
    createState('Drucker.HP.983B82.Black.ConsumableFamilyName');
    createState('Drucker.HP.983B82.Black.ConsumableLabelCode');
    createState('Drucker.HP.983B82.Black.ConsumablePercentageLevelRemaining');
    createState('Drucker.HP.983B82.Black.ProductNumber');
    createState('Drucker.HP.983B82.Cyan.ConsumableFamilyName');
    createState('Drucker.HP.983B82.Cyan.ConsumableLabelCode');
    createState('Drucker.HP.983B82.Cyan.ConsumablePercentageLevelRemaining');
    createState('Drucker.HP.983B82.Cyan.ProductNumber');
    createState('Drucker.HP.983B82.Magenta.ConsumableFamilyName');
    createState('Drucker.HP.983B82.Magenta.ConsumableLabelCode');
    createState('Drucker.HP.983B82.Magenta.ConsumablePercentageLevelRemaining');
    createState('Drucker.HP.983B82.Magenta.ProductNumber');
    createState('Drucker.HP.983B82.Yellow.ConsumableFamilyName');
    createState('Drucker.HP.983B82.Yellow.ConsumableLabelCode');
    createState('Drucker.HP.983B82.Yellow.ConsumablePercentageLevelRemaining');
    createState('Drucker.HP.983B82.Yellow.ProductNumber');
    createState('Drucker.HP.983B82.CMY.ConsumableFamilyName');
    createState('Drucker.HP.983B82.CMY.ConsumableLabelCode');
    createState('Drucker.HP.983B82.CMY.ConsumablePercentageLevelRemaining');
    createState('Drucker.HP.983B82.CMY.ProductNumber');
    function GetData() {
        request(url, function (error, response, body) {
            var xml, result;
            parseString(body, function (err, result) {
                xml = JSON.stringify(result);
                var json = JSON.parse(xml);
                for (var i in json['ccdyn:ConsumableConfigDyn']['ccdyn:ConsumableInfo']) {
                    let node = json['ccdyn:ConsumableConfigDyn']['ccdyn:ConsumableInfo'][i];
                    let ConsumableFamilyName = node['dd:ConsumableFamilyName']
                    let ConsumableLabelCode = node['dd:ConsumableLabelCode'];
                    let ConsumablePercentageLevelRemaining = node['dd:ConsumablePercentageLevelRemaining'];
                    let ProductNumber = node['dd:ProductNumber'];
                    var ColorDataPoint = "";
                    switch (String(ConsumableLabelCode)) {
                        case "K":
                            ColorDataPoint = "Black";
                            break;
                        case "C":
                            ColorDataPoint = "Cyan";
                            break;
                        case "M":
                            ColorDataPoint = "Magenta";
                            break;
                        case "Y":
                            ColorDataPoint = "Yellow";
                            break;
                        case "CMY":
                            ColorDataPoint = "CMY";
                            break;
                        case "CMYK":
                            continue;
                            break;
                        default:
                            continue;
                            log("[ERROR] ColorDataPoint not found for " + ConsumableLabelCode + "!");
                    ConsumableFamilyName = String(ConsumableFamilyName).replace((/[^*a-zA-Z0-9]/g), "");
                    setState('javascript.0.Drucker.HP.983B82.' + ColorDataPoint + '.ConsumableFamilyName', String(ConsumableFamilyName).replace((/[^*a-zA-Z0-9]/g), ""));
                    setState('javascript.0.Drucker.HP.983B82.' + ColorDataPoint + '.ConsumableLabelCode', String(ConsumableLabelCode).replace((/[^*a-zA-Z0-9]/g), ""));
                    setState('javascript.0.Drucker.HP.983B82.' + ColorDataPoint + '.ConsumablePercentageLevelRemaining', String(ConsumablePercentageLevelRemaining).replace((/[^*a-zA-Z0-9]/g), ""));
                    setState('javascript.0.Drucker.HP.983B82.' + ColorDataPoint + '.ProductNumber', String(ProductNumber).replace((/[^*a-zA-Z0-9]/g), ""));
    schedule("42 23 * * *", function () {
        GetData();
    DolomitiD Offline
    DolomitiD Offline
    Dolomiti
    #41
    @clown007
    Danke für die Anpassung. Ich hatte mir das auch schon überlegt. Meiner Meinung nach konvertiert xml2js nicht richtig.
    Im ersten Beispiel wird der Text angezeigt wie erwartet.
    var xml = "<aaaa>Ein Text</aaaa>"
    parseString(xml, function (err, result) {
        log(result);
    Ergebnis bei mir:
    {'aaaa':'Ein Text'}
    Ab der zweiten Ebene kommen die eckigen Klammern hinzu
    var xml = "<aaaa><bbbb>Ein Text</bbbb></aaaa>"
        log(result);
    Ergebnis
    {'aaaa':{'bbbb':['Ein Text']}}
    Bei einem Onlinekonverter wie z.B. hier ist das Ergebnis wie erwartet.
      "aaaa": {
        "bbbb": "Ein Text"
    Ist dein geparstes Ergebnis auch mit eckigen Klammern? Ich dachte schon, es liegt an meiner ioBroker-Installation mit einer alten oder falschen xml2js, aber in einem neuen Proxmox-Container mit ganz frischem ioBroker ist das Ergebnis das gleiche. Anscheinend macht er bei mir ein Array aus dem einzelnen Wert.
    Mit deiner Version läuft es jetzt jedenfalls, aber ich würde das Problem gerne verstehen und nachvollziehen können.
    Intel N100 (32GB,256GB SSD), Proxmox -> Debian 13 in VM (Master) + Debian 13 in CT (Test) + Debmatic, HM-Aktoren, Wago 750-880, Shelly, Zigbee
    C 1 Antwort Letzte Antwort
    • amg_666A amg_666
      @clown007 Steilvorlage :-)
      Wenn schon SNMP dann aber auch das volle Programm...
      1.3.6.1.2.1.43.11.1.1.9.1.1 Farbe 1 (gibt die Anzahl Seiten an die mit der Farbe 1 noch gedruckt werden können)
      1.3.6.1.2.1.43.11.1.1.9.1.2 Farbe 2
      1.3.6.1.2.1.43.11.1.1.9.1.3 Farbe 3
      1.3.6.1.2.1.43.11.1.1.9.1.4 Farbe 4
      1.3.6.1.2.1.43.11.1.1.6.1.1 Name Farbe 1 (z.B. Black)
      1.3.6.1.2.1.43.11.1.1.6.1.2 Name Farbe 2
      1.3.6.1.2.1.43.11.1.1.6.1.3 Name Farbe 3
      1.3.6.1.2.1.43.11.1.1.6.1.4 Name Farbe 4
      1.3.6.1.2.1.43.11.1.1.8.1.1 Kapazität F1 (Wie viele Seiten können max gedruckt werden)
      1.3.6.1.2.1.43.11.1.1.8.1.2 Kapazität F2
      1.3.6.1.2.1.43.11.1.1.8.1.3 Kapazität F3
      1.3.6.1.2.1.43.11.1.1.8.1.4 Kapazität F4
      Clown007
      #42
      @amg_666 ... Die OIDs für für Farbe 1-4 sind identisch und gibt mir den % Wert (90) ;-)
      Name Farbe 1 gibt es bei mir nicht, Farbe 2 ist dann black, Farbe 3 und Farbe 4 gibt es wieder nicht.
      1.3.6.1.2.1.43.11.1.1.8.1.1 Kapazität F2 ist bei mir 100?
      Kapazität 1,3,4 gibt es bei mir nicht.
      Damit bleibt es bei mir bei den o.g. OIDs ;-)
      • DolomitiD Dolomiti
        @clown007
            log(result);
        Ergebnis bei mir:
        {'aaaa':'Ein Text'}
            log(result);
        Ergebnis
          "aaaa": {
            "bbbb": "Ein Text"
        Clown007
        #43
        @dolomiti sagte in [Vorlage] HP Drucker Füllstände (Javascript).:
        xml2js
        Ich gebe zu, dass ich es mir einfach gemacht habe, und darüber nicht weiter nachgedacht habe. Eventuell hilft Dir das weiter?
        https://www.npmjs.com/package/xml2js
        • C Clown007
          amg_666A Offline
          amg_666A Offline
          amg_666
          #44
          @clown007 Hab meinen Post korrigiert, da waren copy&paste Fehler drin :-(
          Die OID habe ich aus meinem snmp Adapter rauskopiert, damit lese ich meinen Drucker aus, es ist ein Samsung C48x und die Samsung haben normalerweise gleiche OID wie HP, in den Objekten sieht das dann so aus:
          Die Werte bei Kapazität z.B. 1000 oder 1500 sagen aus wieviele Kapazität die Farbkartusche hat (wieviele Seiten er in der Farbe drucken kann).
          "Name Farbe 1 gibt es bei mir nicht, Farbe 2 ist dann black, Farbe 3 und Farbe 4 gibt es wieder nicht."
          Hast du einen Schwarzweiß-Drucker? Dann hast du natürlich nur 1* Farbe und 1* Kapazität
          • amg_666A amg_666
            Clown007
            #45
            @amg_666 Ich habe einen Farbdrucker mit einer SW und einer Farbpatrone. Kapazität gibt es aber anscheinend bei HP nicht, nur die Füllstände in %.
            • J Offline
              jwedenig
              #46
              Hi!
              Gibt es eine Möglichkeit das Abo Modell von HP Instant Ink auszulesen um zu sehen, wieviele Seiten man pro Monat noch drucken kann?
              Liebe Grüße
              Jürgen
              • J jwedenig
                Hi!
                Liebe Grüße
                Jürgen
                amg_666A Offline
                amg_666A Offline
                amg_666
                #47
                @jwedenig sagte in [Vorlage] HP Drucker Füllstände (Javascript).:
                ich denke mal, nein. Die Füllstände liest du ja aus dem Drucker aus und der Drucker kennt dein Abo-Modell ja nicht. Du kannst höchstens am Drucker die Anzahl gedruckter Seiten auslesen und die Veränderungen auswerten, das Abo-Modell hängt ja von der Anzahl Seiten ab und dann könntest du es abschätzen.
                J 1 Antwort Letzte Antwort
                • amg_666A amg_666
                  jwedenig
                  #48
                  @amg_666
                  ah, ok alles klar!
                  Dann lese ich mich mal hier ein, dh ich brauche ein Skript und die IP des Druckers, richtig?
                  Liebe Grüße
                  • J jwedenig
                    @amg_666
                    ah, ok alles klar!
                    Liebe Grüße
                    amg_666A Offline
                    amg_666A Offline
                    amg_666
                    #49
                    @jwedenig Du brauchst den snmp-Adapter. Da trägst du unter "Geräte" den Drucker mit IP ein und unter "OID Sets" den Parameter.
                    Bei meinem Drucker ist das die OID 1.3.6.1.2.1.43.10.2.1.4.1.1 für Anzahl gedruckter Seiten (keine Ahnung ob das bei deinem Drucker passt, einfach mal ausprobieren).
                    Dann hast du den Wert als Datenpunkt im iobroker und dann kannst du ein Skript basteln, was die Anzahl gedruckter Seiten pro Tag oder pro Wocher oder oder oder ermittelt.
                    Welche OID bei Deinem Drucker für welchen Wert steht musst du ausprobieren. Du kannst mal hier schaun, was so Standard OID sind: oidref.com oder du lädst dir den Free MIB Browser runter, den fand ich aber vorsichtig ausgedrückt etwas gewöhnungsbedürftig http://www.ireasoning.com/mibbrowser.shtml
                    J 2 Antworten Letzte Antwort
                    • amg_666A amg_666
                      jwedenig
                      #50
                      @amg_666
                      ja danke dir, ich check mal
                      • amg_666A amg_666
                        jwedenig
                        #51
                        @amg_666
                        Das hätte ich gemacht. ich kann aber nicht SPeichern:
                        Bildschirmfoto 2023-05-12 um 14.50.57.png Bildschirmfoto 2023-05-12 um 14.50.48.png
                        • J jwedenig
                          @amg_666
                          jwedenig
                          #52
                          @jwedenig
                          War ein Browser Problem, funktioniert!!
                          DankeDir
