Test Adapter minuvis 2.x
Ich bekomme grad leider gar nicht erst eine Instanz installiert von dem Adapter. Ich hatte die Instanz damals, als es Probleme gab wieder entfernt.
Hier mal die Logs:
$ iobroker add minuaru auto --host ioBroker --debug NPM version: 10.7.0 Installing iobroker.minuaru@1.1.0... (System call) npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs > better-sqlite3@7.6.2 install > prebuild-install || npm run build-release prebuild-install warn install No prebuilt binaries found (target=20.15.0 runtime=node arch=x64 libc= platform=linux) > better-sqlite3@7.6.2 build-release> node-gyp rebuild --release gyp info it worked if it ends with ok gyp info using node-gyp@10.1.0gyp info using node@20.15.0 | linux | x64 gyp info find Python using Python version 3.10.12 found at "/usr/bin/python3" gyp info spawn /usr/bin/python3 gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/better-sqlite3/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.15.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.15.0',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.15.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/better-sqlite3',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ] gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ] ACTION deps_sqlite3_gyp_locate_sqlite3_target_copy_builtin_sqlite3 ba23eeee118cd63e16015df367567cb043fed872.intermediate TOUCH Release/obj.target/deps/locate_sqlite3.stamp CC(target) Release/obj.target/sqlite3/gen/sqlite3/sqlite3.o rm -f Release/obj.target/deps/sqlite3.a Release/obj.target/deps/sqlite3.a.ar-file-list; mkdir -p `dirname Release/obj.target/deps/sqlite3.a` CXX(target) Release/obj.target/better_sqlite3/src/better_sqlite3.o In file included from ./src/better_sqlite3.lzz:11, ./src/util/macros.lzz: In function 'void SetPrototypeGetter(v8::Isolate*, v8::Local<v8::External>, v8::Local<v8::FunctionTemplate>, const char*, v8::AccessorGetterCallback)':./src/util/macros.lzz:157:21: error: 'v8::AccessorSignature' has not been declared ./src/util/binder.lzz: In static member function 'static bool Binder::IsPlainObject(v8::Isolate*, v8::Local<v8::Object>)':./src/util/binder.lzz:37:51: error: 'class v8::Object' has no member named 'CreationContext'; did you mean 'GetCreationContext'? ./src/util/data.lzz: In function 'v8::Local<v8::Value> Data::GetValueJS(v8::Isolate*, sqlite3_stmt*, int, bool)':./src/util/data.lzz:73:92: warning: this statement may fall through [-Wimplicit-fallthrough=]./src/util/data.lzz:73:197: note: here ./src/util/data.lzz: In function 'v8::Local<v8::Value> Data::GetValueJS(v8::Isolate*, sqlite3_value*, bool)':./src/util/data.lzz:77:81: warning: this statement may fall through [-Wimplicit-fallthrough=]./src/util/data.lzz:77:175: note: here make: *** [better_sqlite3.target.mk:120: Release/obj.target/better_sqlite3/src/better_sqlite3.o] Error 1rm ba23eeee118cd63e16015df367567cb043fed872.intermediatemake: Leaving directory '/opt/iobroker/node_modules/better-sqlite3/build' gyp ERR! not ok npm error code 1npm error path /opt/iobroker/node_modules/better-sqlite3 npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-07-08T18_41_17_515Z-debug-0.log npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fsprebuild-install warn install No prebuilt binaries found (target=20.15.0 runtime=node arch=x64 libc= platform=linux)gyp info it worked if it ends with okgyp info using node-gyp@10.1.0gyp info using node@20.15.0 | linux | x64gyp info find Python using Python version 3.10.12 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/better-sqlite3/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.15.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.15.0',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.15.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/better-sqlite3',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]In file included from ./src/better_sqlite3.lzz:11, from ../src/better_sqlite3.cpp:4:/home/iobroker/.cache/node-gyp/20.15.0/include/node/node.h:1248:7: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Context>)' to 'node::addon_context_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Context>, void*)'} [-Wcast-function-type] 1248 | (node::addon_context_register_func) (regfunc), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/20.15.0/include/node/node.h:1266:3: note: in expansion of macro 'NODE_MODULE_CONTEXT_AWARE_X' 1266 | NODE_MODULE_CONTEXT_AWARE_X(modname, regfunc, NULL, 0) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/20.15.0/include/node/node.h:1297:3: note: in expansion of macro 'NODE_MODULE_CONTEXT_AWARE' 1297 | NODE_MODULE_CONTEXT_AWARE(NODE_GYP_MODULE_NAME, \ | ^~~~~~~~~~~~~~~~~~~~~~~~~./src/better_sqlite3.lzz:67:1: note: in expansion of macro 'NODE_MODULE_INIT'./src/util/macros.lzz: In function 'void SetPrototypeGetter(v8::Isolate*, v8::Local<v8::External>, v8::Local<v8::FunctionTemplate>, const char*, v8::AccessorGetterCallback)':./src/util/macros.lzz:157:21: error: 'v8::AccessorSignature' has not been declared./src/util/binder.lzz: In static member function 'static bool Binder::IsPlainObject(v8::Isolate*, v8::Local<v8::Object>)':./src/util/binder.lzz:37:51: error: 'class v8::Object' has no member named 'CreationContext'; did you mean 'GetCreationContext'?./src/util/data.lzz: In function 'v8::Local<v8::Value> Data::GetValueJS(v8::Isolate*, sqlite3_stmt*, int, bool)':./src/util/data.lzz:73:92: warning: this statement may fall through [-Wimplicit-fallthrough=]./src/util/data.lzz:73:197: note: here./src/util/data.lzz: In function 'v8::Local<v8::Value> Data::GetValueJS(v8::Isolate*, sqlite3_value*, bool)':./src/util/data.lzz:77:81: warning: this statement may fall through [-Wimplicit-fallthrough=]./src/util/data.lzz:77:175: note: heremake: *** [better_sqlite3.target.mk:120: Release/obj.target/better_sqlite3/src/better_sqlite3.o] Error 1gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)gyp ERR! System Linux 6.8.8-1-pvegyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" "--release"gyp ERR! cwd /opt/iobroker/node_modules/better-sqlite3gyp ERR! node -v v20.15.0gyp ERR! node-gyp -v v10.1.0gyp ERR! not ok npm error code 1npm error path /opt/iobroker/node_modules/better-sqlite3npm error command failednpm error command sh -c prebuild-install || npm run build-releasenpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-07-08T18_41_17_515Z-debug-0.log host.ioBroker Cannot install iobroker.minuaru@1.1.0: 1 ERROR: Process exited with code 25@flisse beim SQL-Adapter https://github.com/ioBroker/ioBroker.sql habe ich das gefunden:
*SQLite DB must not be installed extra. It is just a file on disk, but to install it you require build tools on your system. For linux, just write:
sudo apt-get install build-essential
For windows:
c:>npm install --global --production windows-build-tools*
Vielleicht fehlt dir das ....
For windows:
Nein, das ist es nicht.
Denn:echad@chet:~ $ apt policy build-essential build-essential: Installed: 12.10 Candidate: 12.10 Version table: *** 12.10 500 500 http://deb.debian.org/debian trixie/main arm64 Packages 100 /var/lib/dpkg/status echad@chet:~ $ -
Denn:echad@chet:~ $ apt policy build-essential build-essential: Installed: 12.10 Candidate: 12.10 Version table: *** 12.10 500 500 http://deb.debian.org/debian trixie/main arm64 Packages 100 /var/lib/dpkg/status echad@chet:~ $Der Vollständigkeit halber möchte ich darauf hinweisen dass der Adapter minuvis seit längerem keine Updstes mehr erhalten hat. Weiters hat der Adspter (noch) nicht das minimale Guthub basierte Testing eingebunden.
H Homoran verschob dieses Thema von Tester am
H Homoran verschob dieses Thema von ...nicht in offiziellem Repo am
