  4. Test Adapter minuvis 2.x
    6.5k
visualisationvisualisierung
125 Beiträge 15 Kommentatoren 25.0k Aufrufe 15 Beobachtet
  • mcm1957M mcm1957
    @flisse said in Test Adapter minuvis 2.x:
    Ich bekomme grad leider gar nicht erst eine Instanz installiert von dem Adapter. Ich hatte die Instanz damals, als es Probleme gab wieder entfernt.
    Hier mal die Logs:
    $ iobroker add minuaru auto --host ioBroker --debug
    NPM version: 10.7.0
    Installing iobroker.minuaru@1.1.0... (System call)
    npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
    > better-sqlite3@7.6.2 install
    > prebuild-install || npm run build-release
    prebuild-install warn install No prebuilt binaries found (target=20.15.0 runtime=node arch=x64 libc= platform=linux)
    > better-sqlite3@7.6.2 build-release> node-gyp rebuild --release
    gyp info it worked if it ends with ok
    gyp info using node-gyp@10.1.0gyp info using node@20.15.0 | linux | x64
    gyp info find Python using Python version 3.10.12 found at "/usr/bin/python3"
    gyp info spawn /usr/bin/python3
    gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/better-sqlite3/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.15.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.15.0',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.15.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/better-sqlite3',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
    gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
    ACTION deps_sqlite3_gyp_locate_sqlite3_target_copy_builtin_sqlite3 ba23eeee118cd63e16015df367567cb043fed872.intermediate
    TOUCH Release/obj.target/deps/locate_sqlite3.stamp
    CC(target) Release/obj.target/sqlite3/gen/sqlite3/sqlite3.o
    rm -f Release/obj.target/deps/sqlite3.a Release/obj.target/deps/sqlite3.a.ar-file-list; mkdir -p `dirname Release/obj.target/deps/sqlite3.a`
    CXX(target) Release/obj.target/better_sqlite3/src/better_sqlite3.o
    In file included from ./src/better_sqlite3.lzz:11,
    ./src/util/macros.lzz: In function 'void SetPrototypeGetter(v8::Isolate*, v8::Local<v8::External>, v8::Local<v8::FunctionTemplate>, const char*, v8::AccessorGetterCallback)':./src/util/macros.lzz:157:21: error: 'v8::AccessorSignature' has not been declared
    ./src/util/binder.lzz: In static member function 'static bool Binder::IsPlainObject(v8::Isolate*, v8::Local<v8::Object>)':./src/util/binder.lzz:37:51: error: 'class v8::Object' has no member named 'CreationContext'; did you mean 'GetCreationContext'?
    ./src/util/data.lzz: In function 'v8::Local<v8::Value> Data::GetValueJS(v8::Isolate*, sqlite3_stmt*, int, bool)':./src/util/data.lzz:73:92: warning: this statement may fall through [-Wimplicit-fallthrough=]./src/util/data.lzz:73:197: note: here
    ./src/util/data.lzz: In function 'v8::Local<v8::Value> Data::GetValueJS(v8::Isolate*, sqlite3_value*, bool)':./src/util/data.lzz:77:81: warning: this statement may fall through [-Wimplicit-fallthrough=]./src/util/data.lzz:77:175: note: here
    make: *** [better_sqlite3.target.mk:120: Release/obj.target/better_sqlite3/src/better_sqlite3.o] Error 1rm ba23eeee118cd63e16015df367567cb043fed872.intermediatemake: Leaving directory '/opt/iobroker/node_modules/better-sqlite3/build'
    gyp ERR! not ok
    npm error code 1npm error path /opt/iobroker/node_modules/better-sqlite3
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-07-08T18_41_17_515Z-debug-0.log
    npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fsprebuild-install warn install No prebuilt binaries found (target=20.15.0 runtime=node arch=x64 libc= platform=linux)gyp info it worked if it ends with okgyp info using node-gyp@10.1.0gyp info using node@20.15.0 | linux | x64gyp info find Python using Python version 3.10.12 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/better-sqlite3/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.15.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.15.0',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.15.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/better-sqlite3',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]In file included from ./src/better_sqlite3.lzz:11, from ../src/better_sqlite3.cpp:4:/home/iobroker/.cache/node-gyp/20.15.0/include/node/node.h:1248:7: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Context>)' to 'node::addon_context_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Context>, void*)'} [-Wcast-function-type] 1248 | (node::addon_context_register_func) (regfunc), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/20.15.0/include/node/node.h:1266:3: note: in expansion of macro 'NODE_MODULE_CONTEXT_AWARE_X' 1266 | NODE_MODULE_CONTEXT_AWARE_X(modname, regfunc, NULL, 0) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/20.15.0/include/node/node.h:1297:3: note: in expansion of macro 'NODE_MODULE_CONTEXT_AWARE' 1297 | NODE_MODULE_CONTEXT_AWARE(NODE_GYP_MODULE_NAME, \ | ^~~~~~~~~~~~~~~~~~~~~~~~~./src/better_sqlite3.lzz:67:1: note: in expansion of macro 'NODE_MODULE_INIT'./src/util/macros.lzz: In function 'void SetPrototypeGetter(v8::Isolate*, v8::Local<v8::External>, v8::Local<v8::FunctionTemplate>, const char*, v8::AccessorGetterCallback)':./src/util/macros.lzz:157:21: error: 'v8::AccessorSignature' has not been declared./src/util/binder.lzz: In static member function 'static bool Binder::IsPlainObject(v8::Isolate*, v8::Local<v8::Object>)':./src/util/binder.lzz:37:51: error: 'class v8::Object' has no member named 'CreationContext'; did you mean 'GetCreationContext'?./src/util/data.lzz: In function 'v8::Local<v8::Value> Data::GetValueJS(v8::Isolate*, sqlite3_stmt*, int, bool)':./src/util/data.lzz:73:92: warning: this statement may fall through [-Wimplicit-fallthrough=]./src/util/data.lzz:73:197: note: here./src/util/data.lzz: In function 'v8::Local<v8::Value> Data::GetValueJS(v8::Isolate*, sqlite3_value*, bool)':./src/util/data.lzz:77:81: warning: this statement may fall through [-Wimplicit-fallthrough=]./src/util/data.lzz:77:175: note: heremake: *** [better_sqlite3.target.mk:120: Release/obj.target/better_sqlite3/src/better_sqlite3.o] Error 1gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)gyp ERR! System Linux 6.8.8-1-pvegyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" "--release"gyp ERR! cwd /opt/iobroker/node_modules/better-sqlite3gyp ERR! node -v v20.15.0gyp ERR! node-gyp -v v10.1.0gyp ERR! not ok npm error code 1npm error path /opt/iobroker/node_modules/better-sqlite3npm error command failednpm error command sh -c prebuild-install || npm run build-releasenpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-07-08T18_41_17_515Z-debug-0.log
    host.ioBroker Cannot install iobroker.minuaru@1.1.0: 1
    ERROR: Process exited with code 25
    Bist du auf Windows?
    Dann fehlen dir wahrscheinlich die build Tools.
    Hab im Moment nur Handy .. hoff es können andere bei Bedarf genauer helfen. Sonst bitte im Forum od auf Google suchen
    flisse
    #115
    @mcm1957
    Andere Adapter oder Instanzen kann ich problemlos installieren.
    Mein ioBroker läuft als lxc-Container auf Proxmox.
    • F flisse
      @mcm1957
      mcm1957M Online
      mcm1957M Online
      mcm1957
      #116
      @flisse
      Ok
      Dann vergiss mal meinen Input.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • F flisse
        Hier mal die Logs:
        NPM version: 10.7.0
        gyp ERR! not ok
        #117
        @flisse
        Hier baut es auch nicht.
        Da scheint sqlite aus den Sourcen gebaut zu werden, ich kapier aber gerade nicht was da alles fehlt. Und ein aktuelles python 3.12 wird wohl auch empfohlen.
        Es springt hier jedenfalls mit diesen Meldungen aus dem Gleis:
        iobroker add minuaru auto --debug
        NPM version: 10.7.0
        prebuild-install warn install No prebuilt binaries found (target=20.15.0 runtime=node arch=arm64 libc= platform=linux)
        gyp info using node@20.15.0 | linux | arm64
        gyp info find Python using Python version 3.12.4 found at "/usr/bin/python3"
        gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
        gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',
        gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
        gyp info spawn make
        make: Entering directory '/opt/iobroker/node_modules/better-sqlite3/build'
          TOUCH ba23eeee118cd63e16015df367567cb043fed872.intermediate
        ar crs Release/obj.target/deps/sqlite3.a @Release/obj.target/deps/sqlite3.a.ar-file-list
          COPY Release/sqlite3.a
        /home/iobroker/.cache/node-gyp/20.15.0/include/node/node.h:1248:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Context>)’ to ‘node::addon_context_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Context>, void*)’} [-Wcast-function-type]
        /home/iobroker/.cache/node-gyp/20.15.0/include/node/node.h:1266:3: note: in expansion of macro ‘NODE_MODULE_CONTEXT_AWARE_X’
        /home/iobroker/.cache/node-gyp/20.15.0/include/node/node.h:1297:3: note: in expansion of macro ‘NODE_MODULE_CONTEXT_AWARE’
        ./src/better_sqlite3.lzz:67:1: note: in expansion of macro ‘NODE_MODULE_INIT’
        ./src/util/macros.lzz: In function ‘void SetPrototypeGetter(v8::Isolate*, v8::Local<v8::External>, v8::Local<v8::FunctionTemplate>, const char*, v8::AccessorGetterCallback)’:
        ./src/util/macros.lzz:157:21: error: ‘v8::AccessorSignature’ has not been declared
        ./src/util/binder.lzz: In static member function ‘static bool Binder::IsPlainObject(v8::Isolate*, v8::Local<v8::Object>)’:
        ./src/util/binder.lzz:37:51: error: ‘class v8::Object’ has no member named ‘CreationContext’; did you mean ‘GetCreationContext’?
        ./src/util/data.lzz: In function ‘v8::Local<v8::Value> Data::GetValueJS(v8::Isolate*, sqlite3_stmt*, int, bool)’:
        ./src/util/data.lzz: In function ‘v8::Local<v8::Value> Data::GetValueJS(v8::Isolate*, sqlite3_value*, bool)’:
        make: *** [better_sqlite3.target.mk:118: Release/obj.target/better_sqlite3/src/better_sqlite3.o] Error 1
        gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-gyp/lib/build.js:209:23)
        gyp ERR! System Linux 6.6.31+rpt-rpi-v8
        gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild" "--release"
        gyp ERR! not ok
        npm error code 1
        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-07-08T19_10_46_128Z-debug-0.log
        gyp info spawn make
        gyp ERR! not ok
        npm error code 1
        host.chet Cannot install iobroker.minuaru@1.1.0: 1
          @flisse
          NPM version: 10.7.0
          gyp info spawn make
          gyp ERR! not ok
          npm error code 1
          gyp info spawn make
          gyp ERR! not ok
          npm error code 1
          mcm1957M Online
          mcm1957M Online
          mcm1957
          #118
          @Homoran
          Kann eigentlich wer erklären warum der Adapter.minuaru im topic zu minuvis diskutiert wird???
          Ev wär da Abspaltung angesagt..
          HomoranH SVallantS 2 Antworten Letzte Antwort
          • mcm1957M mcm1957
            @Homoran
            #119
            @mcm1957 sagte in Test Adapter minuvis 2.x:
            ist etwa hier https://forum.iobroker.net/post/1156123 reingerutscht.
            ich hatte den Eindruck das gehört zusammen
            • mcm1957M mcm1957
              @Homoran
              SVallantS Offline
              SVallantS Offline
              SVallant
              #120
              @mcm1957 Gibt es dafür eine Funktion oder einfach neuer Thread ?
              • F flisse
                Hier mal die Logs:
                NPM version: 10.7.0
                gyp ERR! not ok
                SVallantS Offline
                SVallantS Offline
                SVallant
                #121
                @flisse beim SQL-Adapter https://github.com/ioBroker/ioBroker.sql habe ich das gefunden:
                *SQLite DB must not be installed extra. It is just a file on disk, but to install it you require build tools on your system. For linux, just write:
                sudo apt-get install build-essential
                For windows:
                c:>npm install --global --production windows-build-tools*
                Vielleicht fehlt dir das ....
                • SVallantS SVallant
                  For windows:
                  #122
                  @svallant
                  Nein, das ist es nicht.
                  Denn:
                  echad@chet:~ $ apt policy build-essential
                  build-essential:
                    Installed: 12.10
                    Candidate: 12.10
                    Version table:
                   *** 12.10 500
                          500 http://deb.debian.org/debian trixie/main arm64 Packages
                  echad@chet:~ $
                    @svallant
                    Denn:
                    build-essential:
                      Installed: 12.10
                      Candidate: 12.10
                      Version table:
                     *** 12.10 500
                    echad@chet:~ $
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    #123
                    Der Vollständigkeit halber möchte ich darauf hinweisen dass der Adapter minuvis seit längerem keine Updstes mehr erhalten hat. Weiters hat der Adspter (noch) nicht das minimale Guthub basierte Testing eingebunden.
                    • F Offline
                      flisse
                      #124
                      @SVallant
                      Wir der Adapter denn noch weiterentwickelt?
                      SVallantS 1 Antwort Letzte Antwort
                      • F flisse
                        @SVallant
                        SVallantS Offline
                        SVallantS Offline
                        SVallant
                        #125
                        @flisse Moin, ja. Aber derzeit funktioniert bei minuvis alles ohne Probleme. Ein Update der Abhängigkeiten und der Tests wird es diesen Winter geben
