  4. Stromausfall > ioBroker startet nicht richtig
34 Beiträge 3 Kommentatoren 3.3k Aufrufe 4 Beobachtet
  • MarschelM Marschel
    @thomas-braun said in Stromausfall > ioBroker startet nicht richtig:
    iobroker fix
    pi@raspberrypi:~ $ iobroker fix
    library: loaded
    Library version=2021-01-23
    ioBroker or some processes are still running:
     io.admin.0
     io.discovery.0
     io.info.0
     io.homee.0
     io.web.0
     io.harmony.0
     io.scenes.0
     io.hue.0
     io.history.0
    Please stop them first and try again!
    @marschel
    iobroker stop
    iobroker fix
    MarschelM 1 Antwort Letzte Antwort
      @marschel
      iobroker stop
      iobroker fix
      MarschelM Offline
      MarschelM Offline
      Marschel
      iobroker fix
      library: loaded
       io.admin.0
       io.discovery.0
       io.info.0
       io.homee.0
       io.web.0
       io.harmony.0
       io.scenes.0
       io.hue.0
       io.history.0
      pi@raspberrypi:~ $ iobroker stop
      library: loaded
          Welcome to the ioBroker installation fixer!
          Script version: 2020-12-07
          You might need to enter your password a couple of times.
          Installing prerequisites (1/3)
      OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:2 http://archive.raspberrypi.org/debian buster InRelease
      Holen:3 http://packages.microsoft.com/repos/code stable InRelease [10,4 kB]
      OK:4 https://deb.nodesource.com/node_10.x buster InRelease
      Holen:5 http://packages.microsoft.com/repos/code stable/main arm64 Packages [15,4 kB]
      Holen:6 http://packages.microsoft.com/repos/code stable/main amd64 Packages [14,9 kB]
      Holen:7 http://packages.microsoft.com/repos/code stable/main armhf Packages [15,3 kB]
      Es wurden 56,1 kB in 2 s geholt (35,6 kB/s).
      Installed gcc-c++
      Installed libcairo2-dev
      Installed libpango1.0-dev
      Installed libjpeg-dev
      Installed libgif-dev
      Installed librsvg2-dev
          Checking ioBroker user and directory permissions (2/3)
      Created /etc/sudoers.d/iobroker
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
        iobroker fix
        library: loaded
         io.admin.0
         io.discovery.0
         io.info.0
         io.homee.0
         io.web.0
         io.harmony.0
         io.scenes.0
         io.hue.0
         io.history.0
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        @marschel Und jetzt ein
        iobroker start
        iobroker status
        iobroker list adapters
        iobroker list instances
        MarschelM 2 Antworten Letzte Antwort
          iobroker start
          iobroker status
          MarschelM Offline
          MarschelM Offline
          Marschel
          pi@raspberrypi:~ $ iobroker start
          pi@raspberrypi:~ $ iobroker status
          Objects type: file
          States  type: file
          pi@raspberrypi:~ $ iobroker list adapters
          system.adapter.admin                   : admin          - v4.2.1
          system.adapter.daswetter               : daswetter      - v3.0.4
          system.adapter.discovery               : discovery      - v2.5.0
          system.adapter.dwd                     : dwd            - v2.5.2
          system.adapter.flot                    : flot           - v1.10.6
          system.adapter.harmony                 : harmony        - v1.2.2
          system.adapter.history                 : history        - v1.9.10
          system.adapter.homee                   : homee          - v1.1.0
          system.adapter.hue                     : hue            - v3.3.8
          system.adapter.ical                    : ical           - v1.7.4
          system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.1
          system.adapter.icons-icons8            : icons-icons8   - v0.0.1
          system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
          system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
          system.adapter.info                    : info           - v1.7.14
          system.adapter.javascript              : javascript     - v4.8.4
          system.adapter.node-red                : node-red       - v2.0.3
          system.adapter.openweathermap          : openweathermap - v0.1.0
          system.adapter.scenes                  : scenes         - v2.3.3
          system.adapter.simple-api              : simple-api     - v2.5.2
          system.adapter.socketio                : socketio       - v3.1.4
          system.adapter.vis                     : vis            - v1.3.4
          system.adapter.vis-google-fonts        : vis-google-fonts - v1.0.0
          system.adapter.vis-icontwo             : vis-icontwo    - v0.40.0
          system.adapter.vis-inventwo            : vis-inventwo   - v2.7.4
          system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
          system.adapter.vis-weather             : vis-weather    - v2.5.2
          system.adapter.weatherunderground      : weatherunderground - v3.2.2
          system.adapter.web                     : web            - v3.2.3
          pi@raspberrypi:~ $ iobroker list instances
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
            system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
          + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
          + system.adapter.homee.0                  : homee                 : raspberrypi                              -  enabled
          + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
          + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
            system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
          + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
            system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
          + instance is alive
          pi@raspberrypi:~ $
            iobroker start
            iobroker status
            MarschelM Offline
            MarschelM Offline
            Marschel
            ES LÄUFT!!! :)
            Zumindest zeigt das iPad wieder die Vis 👏 💪
              Objects type: file
              States  type: file
              + instance is alive
              pi@raspberrypi:~ $
              @marschel
              Okay, dann aktivier den X-Server jetzt wieder, damit dein Mäuschen was zu gucken bekommt...
              sudo raspi-config
              • 1
              • S5
              • B3 oder B4
                @marschel
                sudo raspi-config
                • 1
                • S5
                • B3 oder B4
                MarschelM Offline
                MarschelM Offline
                Marschel
                Hab ich.
                Jetzt ist ioBroker auf dem iPad wieder raus ... ich häng die Eingabegeräte wieder ran!
                  @marschel
                  sudo raspi-config
                  • 1
                  • S5
                  • B3 oder B4
                  MarschelM Offline
                  MarschelM Offline
                  Marschel
                  Es ist alles wieder da!
                  DANKE!!!! Fantastisch, so schnell und so gute Hilfe zu bekommen!!!
                  Ganz großen Respekt und vielen vielen Dank!!!!
                    @marschel
                    Um das ganze Rund zu machen würde ich an deiner Stelle noch flugs node12 installieren:
                    Läuft die vis dauerhaft über ein am Raspi hängendes Display?
                      @marschel
                      MarschelM Offline
                      MarschelM Offline
                      Marschel
                      Werde ich heute Abend machen!
                      Das Display am Raspi ist abgeschaltet. Sonst läuft alles dauherhaft ..
                        @marschel
                        Wenn das Display nicht dauerhaft im Einsatz ist, dann würde ich den Server halt auch, wie es 'richtig' ist, komplett ohne Desktop / GUI betreiben.
                          @marschel
                          MarschelM Offline
                          MarschelM Offline
                          Marschel
                          Okay. Bin nur leider mit der Vis noch lange nicht fertig ... ist man das jemals?? ;)
                          Aber habe den Hintergrund verstanden. Wenn es absehbar ist, stell ich das um :)
                          ? 1 Antwort Letzte Antwort
                            @marschel @thomas-braun
                            Das Problem eines Einzelnen wurde richtig toll gelöst. Ganz tolle Arbeit.
                            (das musste ich jetzt mal sagen!)
                              @marschel
                              MarschelM Offline
                              MarschelM Offline
                              Marschel
                              @thomas-braun erledigt und immer noch dankbar für Deine schnelle und kompetente Hilfe! 😳
                              @qwerty1896 so sieht es definitiv aus!! :)
