  4. Stromausfall > ioBroker startet nicht richtig
34 Beiträge 3 Kommentatoren 3.3k Aufrufe 4 Beobachtet
    @marschel Und jetzt ein
    iobroker start
    iobroker status
    iobroker list adapters
    iobroker list instances
    MarschelM Offline
    MarschelM Offline
    Marschel
    ES LÄUFT!!! :)
    Zumindest zeigt das iPad wieder die Vis 👏 💪
    • MarschelM Marschel
      @thomas-braun said in Stromausfall > ioBroker startet nicht richtig:
      pi@raspberrypi:~ $ iobroker start
      pi@raspberrypi:~ $ iobroker status
      Objects type: file
      States  type: file
      pi@raspberrypi:~ $ iobroker list adapters
      system.adapter.admin                   : admin          - v4.2.1
      system.adapter.daswetter               : daswetter      - v3.0.4
      system.adapter.discovery               : discovery      - v2.5.0
      system.adapter.dwd                     : dwd            - v2.5.2
      system.adapter.flot                    : flot           - v1.10.6
      system.adapter.harmony                 : harmony        - v1.2.2
      system.adapter.history                 : history        - v1.9.10
      system.adapter.homee                   : homee          - v1.1.0
      system.adapter.hue                     : hue            - v3.3.8
      system.adapter.ical                    : ical           - v1.7.4
      system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.1
      system.adapter.icons-icons8            : icons-icons8   - v0.0.1
      system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
      system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
      system.adapter.info                    : info           - v1.7.14
      system.adapter.javascript              : javascript     - v4.8.4
      system.adapter.node-red                : node-red       - v2.0.3
      system.adapter.openweathermap          : openweathermap - v0.1.0
      system.adapter.scenes                  : scenes         - v2.3.3
      system.adapter.simple-api              : simple-api     - v2.5.2
      system.adapter.socketio                : socketio       - v3.1.4
      system.adapter.vis                     : vis            - v1.3.4
      system.adapter.vis-google-fonts        : vis-google-fonts - v1.0.0
      system.adapter.vis-icontwo             : vis-icontwo    - v0.40.0
      system.adapter.vis-inventwo            : vis-inventwo   - v2.7.4
      system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
      system.adapter.vis-weather             : vis-weather    - v2.5.2
      system.adapter.weatherunderground      : weatherunderground - v3.2.2
      system.adapter.web                     : web            - v3.2.3
      pi@raspberrypi:~ $ iobroker list instances
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.homee.0                  : homee                 : raspberrypi                              -  enabled
      + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
        system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
      + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
      + instance is alive
      pi@raspberrypi:~ $
      @marschel
      Okay, dann aktivier den X-Server jetzt wieder, damit dein Mäuschen was zu gucken bekommt...
      sudo raspi-config
      • 1
      • S5
      • B3 oder B4
      MarschelM 2 Antworten Letzte Antwort
        @marschel
        sudo raspi-config
        • 1
        • S5
        • B3 oder B4
        MarschelM Offline
        MarschelM Offline
        Marschel
        Hab ich.
        Jetzt ist ioBroker auf dem iPad wieder raus ... ich häng die Eingabegeräte wieder ran!
          @marschel
          sudo raspi-config
          • 1
          • S5
          • B3 oder B4
          MarschelM Offline
          MarschelM Offline
          Marschel
          Es ist alles wieder da!
          DANKE!!!! Fantastisch, so schnell und so gute Hilfe zu bekommen!!!
          Ganz großen Respekt und vielen vielen Dank!!!!
            @marschel
            Um das ganze Rund zu machen würde ich an deiner Stelle noch flugs node12 installieren:
            https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
            Läuft die vis dauerhaft über ein am Raspi hängendes Display?
              @marschel
              MarschelM Offline
              MarschelM Offline
              Marschel
              Werde ich heute Abend machen!
              Das Display am Raspi ist abgeschaltet. Sonst läuft alles dauherhaft ..
                @marschel
                Wenn das Display nicht dauerhaft im Einsatz ist, dann würde ich den Server halt auch, wie es 'richtig' ist, komplett ohne Desktop / GUI betreiben.
                MarschelM 1 Antwort Letzte Antwort
                  @marschel
                  MarschelM Offline
                  MarschelM Offline
                  Marschel
                  Okay. Bin nur leider mit der Vis noch lange nicht fertig ... ist man das jemals?? ;)
                  Aber habe den Hintergrund verstanden. Wenn es absehbar ist, stell ich das um :)
                    @marschel @thomas-braun
                    Das Problem eines Einzelnen wurde richtig toll gelöst. Ganz tolle Arbeit.
                    (das musste ich jetzt mal sagen!)
                      @marschel
                      MarschelM Offline
                      MarschelM Offline
                      Marschel
                      @thomas-braun erledigt und immer noch dankbar für Deine schnelle und kompetente Hilfe! 😳
                      @qwerty1896 so sieht es definitiv aus!! :)
