  4. Test Adapter Material Design Widgets v0.5.x
    2.5k
    4.4k
adaptermaterialmaterial design widgetsvisvisualisationwidget
110 Beiträge 22 Kommentatoren 23.4k Aufrufe 38 Beobachtet
  • O Oli
    @scrounger
    Ja habe ich, heute schaffe ich es nicht mehr, liefer es morgen nach
    ScroungerS Offline
    ScroungerS Offline
    Scrounger
    #81
    @oli
    OK da steht leider nix brauchbares drin. Dann bitte Dialog Widget komplett neu erstellen.
    O 1 Antwort Letzte Antwort
    • ScroungerS Scrounger
      @oli
      O Online
      O Online
      Oli
      #82
      @scrounger
      guten Morgen, habe den Fehler gefunden. Ich habe bei der Rahmenfarbe ein Binding hinterlegt, sobald ich das herausnehme funktioniert das Widget wieder
      Hier mal ein Export des Widgets.
      [{"tpl":"tplVis-materialdesign-Vuetify-Dialog-View","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":true,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","showDialogMethod":"button","fullscreenResolutionLower":"360","vibrateOnMobilDevices":"50","buttonStyle":"raised","iconPosition":"left","closingClickOutside":"true","showTitle":"true","buttonPosition":"flex-end","buttonSize":"medium","signals-cond-0":">","signals-val-0":"0","signals-icon-0":"/icons-mfd-png/measure_battery_0.png","signals-icon-size-0":"40","signals-blink-0":false,"signals-horz-0":"7","signals-vert-0":"10","signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"0","signals-icon-1":"/icons-mfd-png/measure_battery_100.png","signals-icon-size-1":"40","signals-blink-1":false,"signals-horz-1":"7","signals-vert-1":"10","signals-hide-edit-1":false,"signals-cond-2":">","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"contains_view":"Startseite_System_Batteriestatus_Dialog","dialogMaxWidth":"85%","viewHeight":"90%","backgroundColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.background","showDivider":true,"dividerColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.divider","titleFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.dialog.title","titleFont":"#mdwTheme:vis-materialdesign.0.fonts.dialog.title","title":"Batteriestatus","titleColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.header_text","buttonFullWidth":true,"buttonText":"Schließen","buttonFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.dialog.button","buttonFont":"#mdwTheme:vis-materialdesign.0.fonts.dialog.button","buttonFontColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_text","pressColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_press","viewDistanceToBorder":"0","signals-oid-2":"","signals-oid-1":"0_userdata.0.Energieverbrauch.Batterie.AkkuAlarm","signals-oid-0":"0_userdata.0.Energieverbrauch.Batterie.AkkuAlarm","class":"","headerBackgroundColor":"linear-gradient(to bottom, #202020, grey, #202020)","textFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.button.default.text","textFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.button.default.text","mdwButtonPrimaryColor":"#mdwTheme:vis-materialdesign.0.colors.button.default.primary","mdwButtonSecondaryColor":"#mdwTheme:vis-materialdesign.0.colors.button.default.secondary","fullscreenCloseIcon":"{mode:vis-materialdesign.0.colors.darkTheme;light:vis-materialdesign.0.colors.light.dialog.close_button_icon;dark:vis-materialdesign.0.colors.dark.dialog.close_button_icon; mode === \"true\" ? dark : light}","imageColor":"#mdwTheme:vis-materialdesign.0.colors.button.icon.icon_off","footerBackgroundColor":"linear-gradient(to bottom, #202020, grey, #202020)","overlayColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.overlay","fullscreenCloseIconColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_icon","fullscreenCloseIconPressColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_fullscreen_press","debug":true},"style":{"left":"calc(66% - 35px)","top":"45px","height":"50px","width":"50px","z-index":"1","background":"#2e2e2e","box-shadow":"2px 2px 3px rgba(20, 20, 20, 50)","border-radius":"5px","border-color":"{wert:0_userdata.0.Energieverbrauch.Batterie.AkkuAlarm; wert==0 ? \"green\" :: \"red\"}","border-style":"solid","border-width":"2px"},"widgetSet":"materialdesign"}]
      Oliver
      Stephan SchleichS 1 Antwort Letzte Antwort
      • O Oli
        @scrounger
        Stephan SchleichS Offline
        Stephan Schleich
        #83
        @Scrounger Welcher Punkte wäre das in deinem Adapter wenn ich die Beschreibung in weiß ändern möchte? Ist nun ja direkt in deinem Adapter zu setzten wenn ich mich nicht irre
        ScroungerS 1 Antwort Letzte Antwort
        • Stephan SchleichS Stephan Schleich
          ScroungerS Offline
          ScroungerS Offline
          Scrounger
          #84
          @stephan-schleich
          Du kannst es nach wie vor per vis Editor konfigurieren.
          Oder über die Adapter Einstellungen. Hier gibt's ein Filter Feld, dort den Namen des Widget eingeben oder auswählen und dann werden dir alle Einstellung für dieses Widget angezeigt. Die Beschreibung ist gleich wie im vis Editor.
          • D Online
            D Online
            darkiop
            #85
            @Scrounger Hast du für vis-materialdesign.0.colors.darkTheme eine globale CSS ID/Class vorgsehen damit man auch über die CSS drauf reagieren kann? Suche mir grad den Wolf :D
            • D darkiop
              ScroungerS Offline
              ScroungerS Offline
              Scrounger
              #86
              @darkiop
              Ne das ist ein Datenpunkt, da geht nix per CSS. Was hast denn vor?
                @darkiop
                D Online
                D Online
                darkiop
                schrieb am zuletzt editiert von darkiop
                #87
                @scrounger
                Ich nutze eine Mischung aus Uhula's Framework und deinen Widgets.
                Grundsätzlich ist meine aktuelle Fragestellung:
                Wie setze ich in Abhängigkeit von dem Theme-DP die Hintergrund-Grafik. Mit einer <body id="dark-mode-on"> / <body id="dark-mode-off"> wäre das simpel.
                Oder übersehe ich gerade etwas?
                • D darkiop
                  @scrounger
                  ScroungerS Offline
                  ScroungerS Offline
                  Scrounger
                  schrieb am zuletzt editiert von Scrounger
                  #88
                  @darkiop
                  puhhhh...
                  Wahrscheinlich müsstest du direkt im VIS Editor ein Skript schreiben, dass den Datenpunkt liest und in Abhängigkeit dann jedem Widget eine Klasse zu weist. Für diese beiden Klassen kannst dann css regeln erstellen.
                  Wenn du nur den Hintergrund anpassen willst, würd ich nen html Widget in den Hintergrund legen und dann per binding die hintergrundfarbe in Abhängigkeit des Datenpunktes setzen.
                  Kannst du nicht den Uhula Widgets die Layout datenpunkte des Theme Editors per binding zuweisen?
                  B D 2 Antworten Letzte Antwort
                    @darkiop
                    puhhhh...
                    BobBruni
                    #89
                    Dank der "generate HTML Element" lassen sich super Widgets basteln 👍
                    Gibt es auch eine Möglichkeit aus dem generierten HTML-Code das ursprüngliche Widget wieder herzustellen?
                    • B BobBruni
                      ScroungerS Offline
                      ScroungerS Offline
                      Scrounger
                      #90
                      @bobbruni sagte in Test Adapter Material Design Widgets v0.5.x:
                      Zeig doch Mal was du so gebastelt hast, würde mich sehr interessieren.
                      Ja manuelle Eingabe der Daten im Editor ;-)
                      Warum sollte man das brauchen?
                      • ice987I Offline
                        ice987I Offline
                        ice987
                        schrieb am zuletzt editiert von ice987
                        #91
                        @Scrounger
                        Ich möchte z. B. den Batterieladestand und die WiFi Qualität grafisch ausgeben. Gibt‘s ein Widget, bei welchem je nach Wert eine andere/s Grafik/Symbol angezeigt werden kann?
                        Für die Batterie gienge evtl. Progress für WiFi passt jedoch das Symbol nicht so richtig…
                        husqvarna-automower, meteoblue, wiserbyfeller, spritmonitor
                        • ice987I ice987
                          @Scrounger
                          ScroungerS Offline
                          ScroungerS Offline
                          Scrounger
                          #92
                          @ice987
                          Ja geht mit dem value Widget. Da kannst du einfach im das Feld fürs Icon eine Bedingung schreiben. Wie das mit den Bedingungen geht ist in der Doku zum value Widget beschrieben.
                          ice987I 1 Antwort Letzte Antwort
                            @ice987
                            ice987I Offline
                            ice987I Offline
                            ice987
                            #93
                            @scrounger
                            das value Widget habe ich mir auch angekuckt und noch gedacht, irgendwie könnte das das richtige Widget sein 😎
                            auf jeden Fall funktioniert das wie gewünscht bis auf einen kleinen Schönheitsfehler: in der Runtime aktualisiert sich die Grafik wie gewünscht, im Editor aktualisiert es die Grafik nicht auf Anhieb. Beim Anklicken dauert es immer eine Weile bis das Widget aktiv wird (Bedienung/Eingabe insgesamt sehr träge):
                            Hier einen Export:
                            [{"tpl":"tplVis-materialdesign-value","data":{"oid":"0_userdata.0.test.wert27","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","targetType":"auto","image":"#value == 0 ? \"home\" : (#value > 0 and #value <= 10 ? \"abacus\" : \"account\")","imageColor":"","iconPosition":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_changeEffect":false,"effectFontColor":"#mdwTheme:vis-materialdesign.0.colors.value.effect","effectFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.value.effect","effectDuration":"750","overrideText":"","g_layout":false,"textAlign":"start","valueLabelWidth":"4","valuesFontColor":"#mdwTheme:vis-materialdesign.0.colors.value.text","valuesFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.value.text","valuesFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.value.text","prepandTextColor":"#mdwTheme:vis-materialdesign.0.colors.value.prepand","prepandTextFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.value.prepand","prepandTextFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.value.prepand","appendTextColor":"#mdwTheme:vis-materialdesign.0.colors.value.append","appendTextFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.value.append","appendTextFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.value.append","g_formatNumber":false,"g_formatBoolean":false,"iconHeight":"25"},"style":{"left":"173px","top":"665px"},"widgetSet":"materialdesign"}]
                            Versions:
                            Adapter version: material design widgets v0.5.9
                            JS-Controller version: v3.2.16
                            Node version: v12.22.1
                            VIS Adapter version: v1.3.9
                            • ice987I ice987
                              @scrounger
                              Hier einen Export:
                              Versions:
                              ScroungerS Offline
                              ScroungerS Offline
                              Scrounger
                              #94
                              @ice987
                              Das ist aber normal im Editor. Die States werden da nur beim laden aktualisiert und wenn man an den Einstellungen des Widgets etwas ändert.
                              ice987I D3ltoroxpD O 3 Antworten Letzte Antwort
                                @ice987
                                ice987I Offline
                                ice987I Offline
                                ice987
                                #95
                                @scrounger
                                ah ok, dann ist alles i.O. Ich dachte nur, da das Widget Button Toggle vertikal auch direkt im Editor aktualisiert wird.
                                das value Widget kann auch so genutzt werden, was die ganze Geschichte sehr interessant macht (zwei DP's als Binding, ohne Object ID) 😳
                                [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"<div class='vis-widget materialdesign-widget materialdesign-value materialdesign-value-html-element'\n\tstyle='width: 100%; height: 100%; position: relative; display: flex; align-items: center;'\n\tmdw-debug='false'\n\tmdw-oid='nothing_selected'\n\tmdw-targetType='auto'\n\tmdw-overrideText=' '\n\tmdw-textAlign='start'\n\tmdw-valueLabelWidth='4'\n\tmdw-valuesFontColor='#mdwTheme:vis-materialdesign.0.colors.value.text'\n\tmdw-valuesFontFamily='#mdwTheme:vis-materialdesign.0.fonts.value.text'\n\tmdw-valuesFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.value.text'\n\tmdw-prepandTextColor='#mdwTheme:vis-materialdesign.0.colors.value.prepand'\n\tmdw-prepandTextFontFamily='#mdwTheme:vis-materialdesign.0.fonts.value.prepand'\n\tmdw-prepandTextFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.value.prepand'\n\tmdw-appendTextColor='#mdwTheme:vis-materialdesign.0.colors.value.append'\n\tmdw-appendTextFontFamily='#mdwTheme:vis-materialdesign.0.fonts.value.append'\n\tmdw-appendTextFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.value.append'\n\tmdw-image='{wert1:0_userdata.0.test.test26;wert2:0_userdata.0.test.wert27;wert1 === \\\"true\\\" ? \\\"/vis.0/main/img/icon_nowifi.png\\\" : (wert2 >= -50 ? \\\"/vis.0/main/img/icon_wifi_excellent.png\\\" : (wert2 < -50 && wert2 >= -60 ? \\\"/vis.0/main/img/icon_wifi_good.png\\\" : (wert2 < -60 && wert2 >= -70 ? \\\"/vis.0/main/img/icon_wifi_fair.png\\\" : \\\"/vis.0/main/img/icon_wifi_weak.png\\\")))}'\n\tmdw-iconPosition='left'\n\tmdw-iconHeight='25'\n\tmdw-effectFontColor='#mdwTheme:vis-materialdesign.0.colors.value.effect'\n\tmdw-effectFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.value.effect'\n\tmdw-effectDuration='750'\n></div>"},"style":{"left":"659px","top":"116px"},"widgetSet":"basic"}]
                                  @darkiop
                                  puhhhh...
                                  D Online
                                  D Online
                                  darkiop
                                  #96
                                  @scrounger sagte in Test Adapter Material Design Widgets v0.5.x:
                                  @darkiop
                                  puhhhh...
                                  Hatte schon befürchtet das man das evtl. per Skript abfangen muss.
                                  Ja, die Idee hatte ich auch, werd ich demnächst noch Testen.
                                  Ich nutze von Uhulas Framework eigentlich nur den Rahmen - also alles was die Seite Responsiv macht - die Inhalte werden größtenteils mit deinen Widgets dargestellt. Und Uhulas Konzept mit mehreren Page Views habe ich auf eine Page View mit einem View in Widget 8 und deiner TopAppBar angepasst.
                                  Eine Idee war noch, das ganze über ein Bindung der BG-Optionen der Seite selbst zu machen (kein Widget selektiert):
                                  Leider sind hier Bindings ohne Funktion.
                                  • D darkiop
                                    @darkiop
                                    puhhhh...
                                    D Online
                                    D Online
                                    darkiop
                                    #97
                                    @Scrounger
                                    @darkiop sagte in Test Adapter Material Design Widgets v0.5.x:
                                    Ich hab mir jetzt so beholfen wie von dir Vorgeschlagean. Auf meiner page-View liegt ein HTML mit 100% x 100% und das bekommt über ein Binding eine class verpasst:
                                    {x:vis-materialdesign.0.colors.darkTheme;x=='true' ? 'bg-dark-theme' : 'bg-light-theme'}
                                      @ice987
                                      D3ltoroxpD Offline
                                      D3ltoroxpD Offline
                                      D3ltoroxp
                                      #98
                                      @scrounger Gab es Änderungen an der Top App Bar ? Mein seitliches Menü ist weg, das war bei mir über das Top App Bar realisiert. Hatte heute mal neuste Version vom Adapter geupdated.
                                      • GlasfaserG Offline
                                        GlasfaserG Offline
                                        Glasfaser
                                        #99
                                        @d3ltoroxp sagte in Test Adapter Material Design Widgets v0.5.x:
                                        schau mal hier im passenden Thread :
                                        https://forum.iobroker.net/topic/29660/material-design-widgets-top-app-bar-widget/317
                                          saeft_2003
                                          schrieb am zuletzt editiert von saeft_2003
                                          #100
                                          Hallo. Ich habe folgendes Problem ich habe ein Update gemacht von einer uralt Version 0.2.64 auf die aktuelle. Jetzt werden auf meinen iphone und ipad keine material design widgets mehr angezeigt.
                                          Gibt es eine Lösung dafür? Ein downgrade ist nicht möglich!
