  4. Log Meldung von "Something"
    1.0k
errorsomethinglog
10 Beiträge 3 Kommentatoren 943 Aufrufe 3 Beobachtet
    Rushmed
    habe gerade in meinem Log Errormeldungen bekommen. In der Quellspalte steht "Something". Kann mir das jemand erklären?
    Something	2021-01-22 18:47:43.864	error	went wrong: sourceId=sonoff.0.WiFi-Plug11.POWER, sourceObj={"_id":"sonoff.0.WiFi-Plug11.POWER","common":{"type":"boolean","role":"switch","read":true,"write":true,"storeMap":true,"name":"WiFi-Plug11
    Something	2021-01-22 18:47:43.863	error	went wrong: sourceId=mihome-vacuum.0.rooms.275001013648.roomClean, sourceObj={"type":"state","common":{"name":"clean Room","type":"boolean","role":"button","read":false,"write":true,"desc":"Start Roo
    Something	2021-01-22 18:47:43.863	error	went wrong: sourceId=mihome-vacuum.0.rooms.275001013621.roomClean, sourceObj={"type":"state","common":{"name":"clean Room","type":"boolean","role":"button","read":false,"write":true,"desc":"Start Roo
    Something	2021-01-22 18:47:43.862	error	went wrong: sourceId=mihome-vacuum.0.rooms.275001013628.roomClean, sourceObj={"type":"state","common":{"name":"clean Room","type":"boolean","role":"button","read":false,"write":true,"desc":"Start Roo
    Something	2021-01-22 18:47:43.862	error	went wrong: sourceId=zigbee.0.7cb03eaa00a98380.state, sourceObj={"type":"state","common":{"name":"Switch state","type":"boolean","read":true,"write":true,"role":"switch"},"native":{},"from":"system.a
    Something	2021-01-22 18:47:43.862	error	went wrong: sourceId=zigbee.0.7cb03eaa00a98380.colortemp, sourceObj={"type":"state","common":{"name":"Color temperature","type":"number","read":true,"write":true,"role":"level.color.temperature"},"na
    Something	2021-01-22 18:47:43.861	error	went wrong: sourceId=zigbee.0.7cb03eaa00a98380.brightness, sourceObj={"type":"state","common":{"name":"Brightness","type":"number","unit":"","read":true,"write":true,"role":"level.dimmer","min":0,"ma
    Something	2021-01-22 18:47:43.861	error	went wrong: sourceId=sonoff.0.WiFi-Plug13.POWER, sourceObj={"_id":"sonoff.0.WiFi-Plug13.POWER","common":{"type":"boolean","role":"switch","read":true,"write":true,"storeMap":true,"name":"WiFi-Plug13
    Something	2021-01-22 18:47:43.861	error	went wrong: sourceId=zigbee.0.ec1bbdfffeb19154.state, sourceObj={"type":"state","common":{"name":"Switch state","type":"boolean","read":true,"write":true,"role":"switch"},"native":{},"from":"system.a
    Something	2021-01-22 18:47:43.860	error	went wrong: sourceId=zigbee.0.ec1bbdfffeb19154.brightness, sourceObj={"type":"state","common":{"name":"Brightness","type":"number","unit":"","read":true,"write":true,"role":"level.dimmer","min":0,"ma
    Something	2021-01-22 18:47:43.860	error	went wrong: sourceId=shelly.0.SHSW-1#8CAAB54BD7A3#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false,"smartName
    Something	2021-01-22 18:47:43.859	error	went wrong: sourceId=zigbee.0.d0cf5efffe1dc9fc.state, sourceObj={"type":"state","common":{"name":"Switch state","type":"boolean","read":true,"write":true,"role":"switch"},"native":{},"from":"system.a
    Something	2021-01-22 18:47:43.859	error	went wrong: sourceId=zigbee.0.d0cf5efffe1dc9fc.colortemp, sourceObj={"type":"state","common":{"name":"Color temperature","type":"number","read":true,"write":true,"role":"level.color.temperature"},"na
    Something	2021-01-22 18:47:43.858	error	went wrong: sourceId=zigbee.0.d0cf5efffe1dc9fc.brightness, sourceObj={"type":"state","common":{"name":"Brightness","type":"number","unit":"","read":true,"write":true,"role":"level.dimmer","min":0,"ma
    Something	2021-01-22 18:47:43.858	error	went wrong: sourceId=zigbee.0.000b57fffe349293.state, sourceObj={"type":"state","common":{"name":"Switch state","type":"boolean","read":true,"write":true,"role":"switch"},"native":{},"from":"system.a
    Something	2021-01-22 18:47:43.857	error	went wrong: sourceId=zigbee.0.000b57fffe349293.brightness, sourceObj={"type":"state","common":{"name":"Brightness","type":"number","unit":"","read":true,"write":true,"role":"level.dimmer","min":0,"ma
    Something	2021-01-22 18:47:43.857	error	went wrong: sourceId=sonoff.0.WiFi-Plug2.POWER, sourceObj={"_id":"sonoff.0.WiFi-Plug2.POWER","common":{"type":"boolean","role":"switch","read":true,"write":true,"storeMap":true,"name":"WiFi-Plug2 POW
    Something	2021-01-22 18:47:43.856	error	went wrong: sourceId=zigbee.0.ec1bbdfffed4493f.state, sourceObj={"type":"state","common":{"name":"Switch state","type":"boolean","read":true,"write":true,"role":"switch"},"native":{},"from":"system.a
    Something	2021-01-22 18:47:43.845	error	went wrong: sourceId=zigbee.0.ec1bbdfffed4493f.brightness, sourceObj={"type":"state","common":{"name":"Brightness","type":"number","unit":"","read":true,"write":true,"role":"level.dimmer","min":0,"ma
    Something	2021-01-22 18:47:43.844	error	went wrong: sourceId=sonoff.0.WiFi-Plug12.POWER, sourceObj={"_id":"sonoff.0.WiFi-Plug12.POWER","common":{"type":"boolean","role":"switch","read":true,"write":true,"storeMap":true,"name":"WiFi-Plug12
    Something	2021-01-22 18:47:43.843	error	went wrong: sourceId=ping.0.192_168_178_41, sourceObj={"type":"state","common":{"name":"Alive S9-Katy","def":false,"type":"boolean","read":true,"write":false,"role":"indicator.reachable","desc":"Ping
    Something	2021-01-22 18:47:43.830	error	went wrong: sourceId=ping.0.192_168_178_59, sourceObj={"type":"state","common":{"name":"Alive S20u-Achmed","def":false,"type":"boolean","read":true,"write":false,"role":"indicator.reachable","desc":"
    Host 3.2.8
    • R Rushmed
      Host 3.2.8
      UncleSamU Offline
      UncleSamU Offline
      UncleSam
      @rushmed Poste das mal im js-controller 3.2 Thema. Das ist eine Fehlermeldung, die meiner Meinung nach so eigentlich nicht vorkommen sollte.
      • UncleSamU Offline
        UncleSamU Offline
        UncleSam
        schrieb am zuletzt editiert von UncleSam
        Da sich @Rushmed noch nicht auf dem anderen Thema gemeldet hat, mal ein Ping an @apollon77 : ist das etwas, worüber ihr euch sorgen machen solltet? Sieht aus, als würde etwas ins Log gelangen ohne eine Adapter Instanz davor.
        • apollon77A Offline
          Ok, das ist ein Log wo der Host namespace fehlt und der passiert wenn Alias definiert ist aber hier irgendwas falsch ist.
          Hilft das weiter?
          Ich kann für das nächste Update die Meldung verbessern ...
          R 1 Antwort Letzte Antwort
          • apollon77A apollon77
            Hilft das weiter?
            Rushmed
            @apollon77 Hier ist mal beispielhaft der RAW Auszug eines Alias DP dessen Ziel auch im Log auftaucht:
              "from": "system.adapter.javascript.0",
              "user": "system.user.admin",
              "ts": 1582405800631,
              "common": {
                "name": "Robi Essbereich",
                "type": "boolean",
                "role": "button",
                "read": false,
                "write": true,
                "smartName": {
                  "de": "Robi Essbereich",
                  "smartType": "BUTTON"
                "alias": {
                  "id": "mihome-vacuum.0.rooms.275001013628.roomClean"
              "native": {},
              "acl": {
                "object": 1636,
                "owner": "system.user.admin",
                "state": 1636
              "_id": "alias.0.Robi Essbereich",
              "type": "state"
            Habe ich hier vll. schon einen offensichtlichen Fehler eingebaut.
            In dem oben geposteten Errorlog sthen tatsächlich genau all meine Aliase.
            • R Rushmed
                "common": {
                  "type": "boolean",
                  "role": "button",
                  "read": false,
                  "write": true,
                  "smartName": {
                  "alias": {
                "native": {},
                "acl": {
                  "object": 1636,
                  "state": 1636
                "type": "state"
              @rushmed und wenn du mal den js Controller und so alles neu startest kommen die Meldungen dann wieder?
                Rushmed
                @apollon77 Nein
                • R Rushmed
                  @apollon77 Nein
                  @rushmed OK, da hatte sich scheinbar was verschluckt.
                    Rushmed
                    @apollon77 Ok danke, ich melde mich falls es wieder auftaucht.
                    Könntest du mal nen Blick auf meinen Alias werfen?
                      Das Alias ist ok
