  4. IoBroker.mpd
IoBroker.mpd
103 Beiträge 15 Kommentatoren 29.3k Aufrufe 5 Beobachtet
    rascal
    Hey,
    ich habe die neue Version drauf gespielt, keine Änderung, Ansage 1 = ok, Ansage 2 = nix
    sayit.8	2017-01-05 17:43:58.954	info	Set "mpd.0.say: 100;http://192.168.1.10:8082/state/sayit.8.tts.mp3
    sayit.8	2017-01-05 17:43:58.953	info	saying: Test 3
    sayit.8	2017-01-05 17:43:55.682	info	Set "mpd.0.say: 100;http://192.168.1.10:8082/state/sayit.8.tts.mp3
    sayit.8	2017-01-05 17:43:55.681	info	saying: Test 2
    mpd.0	2017-01-05 17:43:55.025	info	client.sendCommand {"playlistsearch": "any,sayit"} OK! - ""
    mpd.0	2017-01-05 17:43:53.021	info	client.sendCommand {"setvol": "100"} OK! - ""
    mpd.0	2017-01-05 17:43:52.819	info	client.sendCommand {"playid": "8"} OK! - ""
    mpd.0	2017-01-05 17:43:52.815	info	client.sendCommand {"addid": "http://192.168.1.10:8082/state/sayit.8.tts.mp3"} OK! - "Id: 8\n"
    sayit.8	2017-01-05 17:43:52.807	info	Set "mpd.0.say: 100;http://192.168.1.10:8082/state/sayit.8.tts.mp3
    sayit.8	2017-01-05 17:43:52.803	info	saying: Test 1
    sayit.8	2017-01-05 17:43:49.386	info	Upload announce mp3 files
    sayit.8	2017-01-05 17:43:49.383	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.sayit, node: v0.10.33
    host.	2017-01-05 17:43:49.356	info	States connected to redis 127.0.0.1:6379
    host.Mastermind	2017-01-05 17:43:48.688	info	instance system.adapter.sayit.8 started with pid 21706
    host.Mastermind	2017-01-05 17:43:46.184	info	instance system.adapter.sayit.8 terminated with code 0 (OK)
    sayit.8	2017-01-05 17:43:46.179	info	terminating
    sayit.8	2017-01-05 17:43:46.177	info	stopping...
    host.Mastermind	2017-01-05 17:43:46.175	info	stopInstance system.adapter.sayit.8 killing pid 20545
    sayit.8	2017-01-05 17:43:45.181	info	stopping...
    host.Mastermind	2017-01-05 17:43:45.174	info	stopInstance system.adapter.sayit.8
    host.Mastermind	2017-01-05 17:43:45.174	info	object change system.adapter.sayit.8
    mpd.0	2017-01-05 17:43:44.978	info	MPD ready!
    mpd.0	2017-01-05 17:43:44.965	info	starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.mpd, node: v0.10.33
    host.	2017-01-05 17:43:44.937	info	States connected to redis 127.0.0.1:6379
    host.Mastermind	2017-01-05 17:43:44.280	info	instance system.adapter.mpd.0 started with pid 21698
    host.Mastermind	2017-01-05 17:43:41.783	info	instance system.adapter.mpd.0 terminated with code 0 (OK)
    host.Mastermind	2017-01-05 17:43:41.768	info	stopInstance system.adapter.mpd.0 killing pid 21629
    mpd.0	2017-01-05 17:43:41.772	info	terminating
    mpd.0	2017-01-05 17:43:41.769	info	cleaned everything up...
    • I Offline
      I Offline
      instalator
      @rascal:
      Hey,
      Bitte Debug-Level and log
      Высокий уровень Децибел вреден для здоровья!
      http://blog.instalator.ru/
        rascal
        debug level auf mpd und sayit.8
        Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
        mpd.0	2017-01-05 17:50:50.410	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:50.181	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:49.410	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:49.179	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:48.432	debug	host. redis publish io.system.adapter.mpd.0.uptime {'val':30,'ack':true,'ts':1483635048430,'q':0,'from':'system.adapter.mpd.0','lc':1483635048430}
        mpd.0	2017-01-05 17:50:48.432	debug	host. redis publish io.system.adapter.mpd.0.memHeapUsed {'val':11.1,'ack':true,'ts':1483635048429,'q':0,'from':'system.adapter.mpd.0','lc':1483635048429}
        mpd.0	2017-01-05 17:50:48.432	debug	host. redis publish io.system.adapter.mpd.0.memHeapTotal {'val':19.73,'ack':true,'ts':1483635048429,'q':0,'from':'system.adapter.mpd.0','lc':1483635033426}
        mpd.0	2017-01-05 17:50:48.432	debug	host. redis publish io.system.adapter.mpd.0.memRss {'val':31.53,'ack':true,'ts':1483635048428,'q':0,'from':'system.adapter.mpd.0','lc':1483635033426}
        mpd.0	2017-01-05 17:50:48.432	debug	host. redis publish io.system.adapter.mpd.0.connected {'val':true,'ack':true,'ts':1483635048428,'q':0,'from':'system.adapter.mpd.0','lc':1483635018429}
        mpd.0	2017-01-05 17:50:48.432	debug	host. redis publish io.system.adapter.mpd.0.alive {'val':true,'ack':true,'ts':1483635048427,'q':0,'from':'system.adapter.mpd.0','lc':1483635018428}
        mpd.0	2017-01-05 17:50:48.407	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:48.177	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:47.406	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:47.174	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:46.403	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:46.172	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:45.403	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:45.172	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:44.403	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:44.170	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:43.402	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:43.169	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:42.400	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:42.166	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:41.400	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:41.166	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:40.398	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:40.163	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:39.397	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:39.161	debug	mpd.0 sayit(command, val)...
        sayit.8	2017-01-05 17:50:38.815	debug	host. redis publish io.system.adapter.sayit.8.uptime {'val':15,'ack':true,'ts':1483635038813,'q':0,'from':'system.adapter.sayit.8','lc':1483635038813}
        sayit.8	2017-01-05 17:50:38.815	debug	host. redis publish io.system.adapter.sayit.8.memHeapUsed {'val':10.96,'ack':true,'ts':1483635038813,'q':0,'from':'system.adapter.sayit.8','lc':1483635038813}
        sayit.8	2017-01-05 17:50:38.815	debug	host. redis publish io.system.adapter.sayit.8.memHeapTotal {'val':18.74,'ack':true,'ts':1483635038812,'q':0,'from':'system.adapter.sayit.8','lc':1483635004484}
        sayit.8	2017-01-05 17:50:38.815	debug	host. redis publish io.system.adapter.sayit.8.memRss {'val':29.89,'ack':true,'ts':1483635038812,'q':0,'from':'system.adapter.sayit.8','lc':1483635038812}
        sayit.8	2017-01-05 17:50:38.815	debug	host. redis publish io.system.adapter.sayit.8.connected {'val':true,'ack':true,'ts':1483635038811,'q':0,'from':'system.adapter.sayit.8','lc':1483635023815}
        sayit.8	2017-01-05 17:50:38.815	debug	host. redis publish io.system.adapter.sayit.8.alive {'val':true,'ack':true,'ts':1483635038810,'q':0,'from':'system.adapter.sayit.8','lc':1483635023814}
        mpd.0	2017-01-05 17:50:38.397	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:38.161	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:37.396	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:37.156	debug	mpd.0 sayit(command, val)...
        mpd.0	2017-01-05 17:50:36.392	debug	sayit(command, val)...
        mpd.0	2017-01-05 17:50:36.154	debug	sayit(command, val)...
        mpd.0	2017-01-05 17:50:35.390	debug	sayit(command, val)...
        mpd.0	2017-01-05 17:50:35.152	debug	stateChange mpd.0.say {'val':'100;http://192.168.1.10:8082/state/sayit.8.tts.mp3','ack':false,'ts':1483635035148,'q':0,'from':'system.adapter.sayit.8','lc':1483633093521}
        host.	2017-01-05 17:50:35.149	debug	redis pmessage io.mpd.0.* io.mpd.0.say {'val':'100;http://192.168.1.10:8082/state/sayit.8.tts.mp3','ack':false,'ts':1483635035148,'q':0,'from':'system.adapter.sayit.8','lc':1483633093521}
        host.	2017-01-05 17:50:35.148	debug	redis publish io.mpd.0.say {'val':'100;http://192.168.1.10:8082/state/sayit.8.tts.mp3','ack':false,'ts':1483635035148,'q':0,'from':'system.adapter.sayit.8','lc':1483633093521}
        sayit.8	2017-01-05 17:50:35.147	debug	Duration 'Test 3': 1
        sayit.8	2017-01-05 17:50:35.147	info	Set 'mpd.0.say: 100;http://192.168.1.10:8082/state/sayit.8.tts.mp3
        sayit.8	2017-01-05 17:50:35.147	info	saying: Test 3
        host.	2017-01-05 17:50:35.145	debug	redis pmessage io.sayit.8.* io.sayit.8.tts.text {'val':'Test 3','ack':false,'ts':1483635035144,'q':0,'from':'system.adapter.admin.0','lc':1483635035144}
        mpd.0	2017-01-05 17:50:34.389	debug	sayit(command, val)...
        host.	2017-01-05 17:50:33.427	debug	redis publish io.system.adapter.mpd.0.uptime {'val':15,'ack':true,'ts':1483635033427,'q':0,'from':'system.adapter.mpd.0','lc':1483635033427}
        host.	2017-01-05 17:50:33.427	debug	redis publish io.system.adapter.mpd.0.memHeapUsed {'val':9.96,'ack':true,'ts':1483635033427,'q':0,'from':'system.adapter.mpd.0','lc':1483635033427}
        host.	2017-01-05 17:50:33.427	debug	redis publish io.system.adapter.mpd.0.memHeapTotal {'val':19.73,'ack':true,'ts':1483635033426,'q':0,'from':'system.adapter.mpd.0','lc':1483635033426}
        host.	2017-01-05 17:50:33.426	debug	redis publish io.system.adapter.mpd.0.memRss {'val':31.53,'ack':true,'ts':1483635033426,'q':0,'from':'system.adapter.mpd.0','lc':1483635033426}
        host.	2017-01-05 17:50:33.425	debug	redis publish io.system.adapter.mpd.0.connected {'val':true,'ack':true,'ts':1483635033425,'q':0,'from':'system.adapter.mpd.0','lc':1483635018429}
        host.	2017-01-05 17:50:33.425	debug	redis publish io.system.adapter.mpd.0.alive {'val':true,'ack':true,'ts':1483635033425,'q':0,'from':'system.adapter.mpd.0','lc':1483635018428}
        mpd.0	2017-01-05 17:50:33.388	debug	sayit(command, val)...
        mpd.0	2017-01-05 17:50:32.388	debug	sayit(command, val)...
        mpd.0	2017-01-05 17:50:31.385	debug	stateChange mpd.0.say {'val':'100;http://192.168.1.10:8082/state/sayit.8.tts.mp3','ack':false,'ts':1483635031384,'q':0,'from':'system.adapter.sayit.8','lc':1483633093521}
        host.	2017-01-05 17:50:31.384	debug	redis publish io.mpd.0.say {'val':'100;http://192.168.1.10:8082/state/sayit.8.tts.mp3','ack':false,'ts':1483635031384,'q':0,'from':'system.adapter.sayit.8','lc':1483633093521}
        host.	2017-01-05 17:50:31.385	debug	redis pmessage io.mpd.0.* io.mpd.0.say {'val':'100;http://192.168.1.10:8082/state/sayit.8.tts.mp3','ack':false,'ts':1483635031384,'q':0,'from':'system.adapter.sayit.8','lc':1483633093521}
        sayit.8	2017-01-05 17:50:31.383	debug	Duration 'Test 2': 2
        sayit.8	2017-01-05 17:50:31.383	info	Set 'mpd.0.say: 100;http://192.168.1.10:8082/state/sayit.8.tts.mp3
        sayit.8	2017-01-05 17:50:31.381	info	saying: Test 2
        host.	2017-01-05 17:50:31.378	debug	redis pmessage io.sayit.8.* io.sayit.8.tts.text {'val':'Test 2','ack':false,'ts':1483635031376,'q':0,'from':'system.adapter.admin.0','lc':1483635031376}
        mpd.0	2017-01-05 17:50:29.960	info	client.sendCommand {'playlistsearch': 'any,sayit'} OK! - ''
        host.	2017-01-05 17:50:28.996	debug	redis pmessage io.mpd.0.* io.mpd.0.uptime {'val':'169271','ack':true,'ts':1483635028994,'q':0,'from':'system.adapter.mpd.0','lc':1483635028994}
        host.	2017-01-05 17:50:28.996	debug	redis pmessage io.mpd.0.* io.mpd.0.id {'val':'','ack':true,'ts':1483635028993,'q':0,'from':'system.adapter.mpd.0','lc':1483635028993}
        host.	2017-01-05 17:50:28.995	debug	redis pmessage io.mpd.0.* io.mpd.0.state {'val':'stop','ack':true,'ts':1483635028992,'q':0,'from':'system.adapter.mpd.0','lc':1483635028992}
        host.	2017-01-05 17:50:28.994	debug	redis publish io.mpd.0.uptime {'val':'169271','ack':true,'ts':1483635028994,'q':0,'from':'system.adapter.mpd.0','lc':1483635028994}
        host.	2017-01-05 17:50:28.993	debug	redis publish io.mpd.0.id {'val':'','ack':true,'ts':1483635028993,'q':0,'from':'system.adapter.mpd.0','lc':1483635028993}
        host.	2017-01-05 17:50:28.992	debug	redis publish io.mpd.0.state {'val':'stop','ack':true,'ts':1483635028992,'q':0,'from':'system.adapter.mpd.0','lc':1483635028992}
        mpd.0	2017-01-05 17:50:28.948	debug	update system - 'player'
        host.	2017-01-05 17:50:27.966	debug	redis pmessage io.mpd.0.* io.mpd.0.elapsed {'val':'0.554','ack':true,'ts':1483635027962,'q':0,'from':'system.adapter.mpd.0','lc':1483635027962}
        host.	2017-01-05 17:50:27.966	debug	redis pmessage io.mpd.0.* io.mpd.0.time {'val':'1:1','ack':true,'ts':1483635027961,'q':0,'from':'system.adapter.mpd.0','lc':1483635027961}
        host.	2017-01-05 17:50:27.966	debug	redis pmessage io.mpd.0.* io.mpd.0.seek {'val':'100.00','ack':true,'ts':1483635027960,'q':0,'from':'system.adapter.mpd.0','lc':1483635027960}
        host.	2017-01-05 17:50:27.965	debug	redis pmessage io.mpd.0.* io.mpd.0.current_elapsed {'val':'00:01','ack':true,'ts':1483635027960,'q':0,'from':'system.adapter.mpd.0','lc':1483635027960}
        host.	2017-01-05 17:50:27.962	debug	redis publish io.mpd.0.elapsed {'val':'0.554','ack':true,'ts':1483635027962,'q':0,'from':'system.adapter.mpd.0','lc':1483635027962}
        host.	2017-01-05 17:50:27.961	debug	redis publish io.mpd.0.time {'val':'1:1','ack':true,'ts':1483635027961,'q':0,'from':'system.adapter.mpd.0','lc':1483635027961}
        host.	2017-01-05 17:50:27.960	debug	redis publish io.mpd.0.seek {'val':'100.00','ack':true,'ts':1483635027960,'q':0,'from':'system.adapter.mpd.0','lc':1483635027960}
        host.	2017-01-05 17:50:27.960	debug	redis publish io.mpd.0.current_elapsed {'val':'00:01','ack':true,'ts':1483635027960,'q':0,'from':'system.adapter.mpd.0','lc':1483635027960}
        mpd.0	2017-01-05 17:50:27.957	debug	update system - 'mixer'
        mpd.0	2017-01-05 17:50:27.956	debug	sayTimeDelete...
        mpd.0	2017-01-05 17:50:27.956	info	client.sendCommand {'setvol': '100'} OK! - ''
        mpd.0	2017-01-05 17:50:27.953	debug	setVol...
        host.	2017-01-05 17:50:27.869	debug	redis pmessage io.mpd.0.* io.mpd.0.id {'val':'9','ack':true,'ts':1483635027859,'q':0,'from':'system.adapter.mpd.0','lc':1483635027859}
        host.	2017-01-05 17:50:27.869	debug	redis pmessage io.mpd.0.* io.mpd.0.db_update {'val':'1482514854','ack':true,'ts':1483635027859,'q':0,'from':'system.adapter.mpd.0','lc':1482515920137}
        host.	2017-01-05 17:50:27.869	debug	redis pmessage io.mpd.0.* io.mpd.0.db_playtime {'val':'0','ack':true,'ts':1483635027858,'q':0,'from':'system.adapter.mpd.0','lc':1482515920137}
        host.	2017-01-05 17:50:27.868	debug	redis pmessage io.mpd.0.* io.mpd.0.songs {'val':'0','ack':true,'ts':1483635027857,'q':0,'from':'system.adapter.mpd.0','lc':1482515920136}
        host.	2017-01-05 17:50:27.868	debug	redis pmessage io.mpd.0.* io.mpd.0.albums {'val':'0','ack':true,'ts':1483635027856,'q':0,'from':'system.adapter.mpd.0','lc':1482515920135}
        host.	2017-01-05 17:50:27.868	debug	redis pmessage io.mpd.0.* io.mpd.0.artists {'val':'0','ack':true,'ts':1483635027856,'q':0,'from':'system.adapter.mpd.0','lc':1482515920135}
        host.	2017-01-05 17:50:27.868	debug	redis pmessage io.mpd.0.* io.mpd.0.playtime {'val':'10','ack':true,'ts':1483635027853,'q':0,'from':'system.adapter.mpd.0','lc':1483635027853}
        host.	2017-01-05 17:50:27.868	debug	redis pmessage io.mpd.0.* io.mpd.0.uptime {'val':'169270','ack':true,'ts':1483635027852,'q':0,'from':'system.adapter.mpd.0','lc':1483635027852}
        host.	2017-01-05 17:50:27.868	debug	redis pmessage io.mpd.0.* io.mpd.0.audio {'val':'24000:24:1','ack':true,'ts':1483635027852,'q':0,'from':'system.adapter.mpd.0','lc':1483465101294}
        host.	2017-01-05 17:50:27.867	debug	redis pmessage io.mpd.0.* io.mpd.0.bitrate {'val':'32','ack':true,'ts':1483635027851,'q':0,'from':'system.adapter.mpd.0','lc':1483620456904}
        host.	2017-01-05 17:50:27.867	debug	redis pmessage io.mpd.0.* io.mpd.0.elapsed {'val':'0.426','ack':true,'ts':1483635027851,'q':0,'from':'system.adapter.mpd.0','lc':1483635027851}
        host.	2017-01-05 17:50:27.867	debug	redis pmessage io.mpd.0.* io.mpd.0.time {'val':'0:1','ack':true,'ts':1483635027850,'q':0,'from':'system.adapter.mpd.0','lc':1483635027850}
        host.	2017-01-05 17:50:27.866	debug	redis pmessage io.mpd.0.* io.mpd.0.songid {'val':'9','ack':true,'ts':1483635027849,'q':0,'from':'system.adapter.mpd.0','lc':1483635027849}
        host.	2017-01-05 17:50:27.866	debug	redis pmessage io.mpd.0.* io.mpd.0.song {'val':'8','ack':true,'ts':1483635027849,'q':0,'from':'system.adapter.mpd.0','lc':1483635027849}
        host.	2017-01-05 17:50:27.866	debug	redis pmessage io.mpd.0.* io.mpd.0.pos {'val':'8','ack':true,'ts':1483635027846,'q':0,'from':'system.adapter.mpd.0','lc':1483635027846}
        host.	2017-01-05 17:50:27.865	debug	redis pmessage io.mpd.0.* io.mpd.0.file {'val':'http://192.168.1.10:8082/state/sayit.8.tts.mp3','ack':true,'ts':1483635027845,'q':0,'from':'system.adapter.mpd.0','lc':1483464850386}
        host.	2017-01-05 17:50:27.865	debug	redis pmessage io.mpd.0.* io.mpd.0.seek {'val':'0.00','ack':true,'ts':1483635027844,'q':0,'from':'system.adapter.mpd.0','lc':1483635027844}
        host.	2017-01-05 17:50:27.865	debug	redis pmessage io.mpd.0.* io.mpd.0.current_duration {'val':'00:01','ack':true,'ts':1483635027842,'q':0,'from':'system.adapter.mpd.0','lc':1483635027842}
        host.	2017-01-05 17:50:27.865	debug	redis pmessage io.mpd.0.* io.mpd.0.current_duration_s {'val':1,'ack':true,'ts':1483635027838,'q':0,'from':'system.adapter.mpd.0','lc':1483635027838}
        host.	2017-01-05 17:50:27.865	debug	redis pmessage io.mpd.0.* io.mpd.0.state {'val':'play','ack':true,'ts':1483635027837,'q':0,'from':'system.adapter.mpd.0','lc':1483635027837}
        host.	2017-01-05 17:50:27.863	debug	redis pmessage io.mpd.0.* io.mpd.0.playlistlength {'val':'9','ack':true,'ts':1483635027837,'q':0,'from':'system.adapter.mpd.0','lc':1483635027837}
        host.	2017-01-05 17:50:27.863	debug	redis pmessage io.mpd.0.* io.mpd.0.playlist {'val':'19','ack':true,'ts':1483635027836,'q':0,'from':'system.adapter.mpd.0','lc':1483635027836}
        host.	2017-01-05 17:50:27.859	debug	redis publish io.mpd.0.id {'val':'9','ack':true,'ts':1483635027859,'q':0,'from':'system.adapter.mpd.0','lc':1483635027859}
        host.	2017-01-05 17:50:27.859	debug	redis publish io.mpd.0.db_update {'val':'1482514854','ack':true,'ts':1483635027859,'q':0,'from':'system.adapter.mpd.0','lc':1482515920137}
        host.	2017-01-05 17:50:27.858	debug	redis publish io.mpd.0.db_playtime {'val':'0','ack':true,'ts':1483635027858,'q':0,'from':'system.adapter.mpd.0','lc':1482515920137}
        host.	2017-01-05 17:50:27.857	debug	redis publish io.mpd.0.songs {'val':'0','ack':true,'ts':1483635027857,'q':0,'from':'system.adapter.mpd.0','lc':1482515920136}
        host.	2017-01-05 17:50:27.857	debug	redis publish io.mpd.0.albums {'val':'0','ack':true,'ts':1483635027856,'q':0,'from':'system.adapter.mpd.0','lc':1482515920135}
        host.	2017-01-05 17:50:27.856	debug	redis publish io.mpd.0.artists {'val':'0','ack':true,'ts':1483635027856,'q':0,'from':'system.adapter.mpd.0','lc':1482515920135}
        host.	2017-01-05 17:50:27.853	debug	redis publish io.mpd.0.playtime {'val':'10','ack':true,'ts':1483635027853,'q':0,'from':'system.adapter.mpd.0','lc':1483635027853}
        host.	2017-01-05 17:50:27.853	debug	redis publish io.mpd.0.uptime {'val':'169270','ack':true,'ts':1483635027852,'q':0,'from':'system.adapter.mpd.0','lc':1483635027852}
        host.	2017-01-05 17:50:27.852	debug	redis publish io.mpd.0.audio {'val':'24000:24:1','ack':true,'ts':1483635027852,'q':0,'from':'system.adapter.mpd.0','lc':1483465101294}
        host.	2017-01-05 17:50:27.851	debug	redis publish io.mpd.0.bitrate {'val':'32','ack':true,'ts':1483635027851,'q':0,'from':'system.adapter.mpd.0','lc':1483620456904}
        host.	2017-01-05 17:50:27.851	debug	redis publish io.mpd.0.elapsed {'val':'0.426','ack':true,'ts':1483635027851,'q':0,'from':'system.adapter.mpd.0','lc':1483635027851}
        host.	2017-01-05 17:50:27.850	debug	redis publish io.mpd.0.time {'val':'0:1','ack':true,'ts':1483635027850,'q':0,'from':'system.adapter.mpd.0','lc':1483635027850}
        host.	2017-01-05 17:50:27.849	debug	redis publish io.mpd.0.songid {'val':'9','ack':true,'ts':1483635027849,'q':0,'from':'system.adapter.mpd.0','lc':1483635027849}
        host.	2017-01-05 17:50:27.849	debug	redis publish io.mpd.0.song {'val':'8','ack':true,'ts':1483635027849,'q':0,'from':'system.adapter.mpd.0','lc':1483635027849}
        host.	2017-01-05 17:50:27.847	debug	redis publish io.mpd.0.pos {'val':'8','ack':true,'ts':1483635027846,'q':0,'from':'system.adapter.mpd.0','lc':1483635027846}
        host.	2017-01-05 17:50:27.846	debug	redis publish io.mpd.0.file {'val':'http://192.168.1.10:8082/state/sayit.8.tts.mp3','ack':true,'ts':1483635027845,'q':0,'from':'system.adapter.mpd.0','lc':1483464850386}
        host.	2017-01-05 17:50:27.844	debug	redis publish io.mpd.0.seek {'val':'0.00','ack':true,'ts':1483635027844,'q':0,'from':'system.adapter.mpd.0','lc':1483635027844}
        host.	2017-01-05 17:50:27.842	debug	redis publish io.mpd.0.current_duration {'val':'00:01','ack':true,'ts':1483635027842,'q':0,'from':'system.adapter.mpd.0','lc':1483635027842}
        host.	2017-01-05 17:50:27.842	debug	redis publish io.mpd.0.current_duration_s {'val':1,'ack':true,'ts':1483635027838,'q':0,'from':'system.adapter.mpd.0','lc':1483635027838}
        host.	2017-01-05 17:50:27.837	debug	redis publish io.mpd.0.state {'val':'play','ack':true,'ts':1483635027837,'q':0,'from':'system.adapter.mpd.0','lc':1483635027837}
        host.	2017-01-05 17:50:27.837	debug	redis publish io.mpd.0.playlistlength {'val':'9','ack':true,'ts':1483635027837,'q':0,'from':'system.adapter.mpd.0','lc':1483635027837}
        host.	2017-01-05 17:50:27.836	debug	redis publish io.mpd.0.playlist {'val':'19','ack':true,'ts':1483635027836,'q':0,'from':'system.adapter.mpd.0','lc':1483635027836}
        mpd.0	2017-01-05 17:50:27.831	debug	update system - 'player'
        mpd.0	2017-01-05 17:50:27.830	debug	update system - 'playlist'
        mpd.0	2017-01-05 17:50:27.790	debug	update system - 'player'
        host.	2017-01-05 17:50:27.756	debug	redis pmessage io.mpd.0.* io.mpd.0.playlist_list {'val':'[{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'}]','ack':true,'ts':1483635027753,'q':0,'from':'system.adapter.mpd.0','lc':1483635027753}
        host.	2017-01-05 17:50:27.753	debug	redis publish io.mpd.0.playlist_list {'val':'[{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'}]','ack':true,'ts':1483635027753,'q':0,'from':'system.adapter.mpd.0','lc':1483635027753}
        mpd.0	2017-01-05 17:50:27.751	info	client.sendCommand {'playid': '9'} OK! - ''
        mpd.0	2017-01-05 17:50:27.713	debug	update system - 'playlist'
        mpd.0	2017-01-05 17:50:27.711	info	client.sendCommand {'addid': 'http://192.168.1.10:8082/state/sayit.8.tts.mp3'} OK! - 'Id: 9\n'
        mpd.0	2017-01-05 17:50:27.706	debug	stateChange mpd.0.say {'val':'100;http://192.168.1.10:8082/state/sayit.8.tts.mp3','ack':false,'ts':1483635027703,'q':0,'from':'system.adapter.sayit.8','lc':1483633093521}
        host.	2017-01-05 17:50:27.703	debug	redis publish io.mpd.0.say {'val':'100;http://192.168.1.10:8082/state/sayit.8.tts.mp3','ack':false,'ts':1483635027703,'q':0,'from':'system.adapter.sayit.8','lc':1483633093521}
        sayit.8	2017-01-05 17:50:27.702	debug	Duration 'Test 1': 2
        sayit.8	2017-01-05 17:50:27.702	info	Set 'mpd.0.say: 100;http://192.168.1.10:8082/state/sayit.8.tts.mp3
        host.	2017-01-05 17:50:27.704	debug	redis pmessage io.mpd.0.* io.mpd.0.say {'val':'100;http://192.168.1.10:8082/state/sayit.8.tts.mp3','ack':false,'ts':1483635027703,'q':0,'from':'system.adapter.sayit.8','lc':1483633093521}
        sayit.8	2017-01-05 17:50:27.699	info	saying: Test 1
        host.	2017-01-05 17:50:27.695	debug	redis pmessage io.sayit.8.* io.sayit.8.tts.text {'val':'Test 1','ack':false,'ts':1483635027694,'q':0,'from':'system.adapter.admin.0','lc':1483635027694}
        host.	2017-01-05 17:50:23.836	debug	redis get sayit.8.tts.playing ok: {'val':false,'ack':false,'ts':1483465468179,'q':0,'from':'system.adapter.admin.0','lc':1482511508776}
        host.	2017-01-05 17:50:23.835	debug	redis get sayit.8.tts.volume ok: {'val':100,'ack':false,'ts':1483465129616,'q':0,'from':'system.adapter.admin.0','lc':1483465129616}
        host.	2017-01-05 17:50:23.835	debug	redis get sayit.8.tts.text ok: {'val':'Test 3','ack':false,'ts':1483634638951,'q':0,'from':'system.adapter.admin.0','lc':1483634638951}
        host.	2017-01-05 17:50:23.834	debug	redis psubscribe io.sayit.8.*
        host.	2017-01-05 17:50:23.823	debug	redis mget 1 1
        host.	2017-01-05 17:50:23.817	debug	redis publish io.system.adapter.sayit.8.uptime {'val':0,'ack':true,'ts':1483635023817,'q':0,'from':'system.adapter.sayit.8','lc':1483635023817}
        host.	2017-01-05 17:50:23.817	debug	redis publish io.system.adapter.sayit.8.memHeapUsed {'val':9.63,'ack':true,'ts':1483635023817,'q':0,'from':'system.adapter.sayit.8','lc':1483635023817}
        host.	2017-01-05 17:50:23.816	debug	redis publish io.system.adapter.sayit.8.memHeapTotal {'val':18.74,'ack':true,'ts':1483635023816,'q':0,'from':'system.adapter.sayit.8','lc':1483635004484}
        host.	2017-01-05 17:50:23.816	debug	redis publish io.system.adapter.sayit.8.memRss {'val':29.38,'ack':true,'ts':1483635023816,'q':0,'from':'system.adapter.sayit.8','lc':1483635023816}
        host.	2017-01-05 17:50:23.815	debug	redis publish io.system.adapter.sayit.8.connected {'val':true,'ack':true,'ts':1483635023815,'q':0,'from':'system.adapter.sayit.8','lc':1483635023815}
        host.	2017-01-05 17:50:23.814	debug	redis publish io.system.adapter.sayit.8.alive {'val':true,'ack':true,'ts':1483635023814,'q':0,'from':'system.adapter.sayit.8','lc':1483635023814}
        host.	2017-01-05 17:50:23.813	debug	redis keys 1 *.logging
        host.	2017-01-05 17:50:23.811	debug	redis psubscribe io.sayit.8.checkLogging
        sayit.8	2017-01-05 17:50:23.810	info	Upload announce mp3 files
        sayit.8	2017-01-05 17:50:23.807	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.sayit, node: v0.10.33
        host.	2017-01-05 17:50:23.790	debug	redis get system.adapter.sayit.8.alive ok: {'val':false,'ack':true,'ts':1483635020628,'q':0,'from':'system.host.Mastermind','lc':1483635020620}
        host.	2017-01-05 17:50:23.783	info	States connected to redis 127.0.0.1:6379
        sayit.8	2017-01-05 17:50:23.774	debug	statesDB connected
        sayit.8	2017-01-05 17:50:23.762	debug	objectDB connected
        host.Mastermind	2017-01-05 17:50:23.129	info	instance system.adapter.sayit.8 started with pid 21992
        host.Mastermind	2017-01-05 17:50:20.627	info	instance system.adapter.sayit.8 terminated with code 0 (OK)
        sayit.8	2017-01-05 17:50:20.621	info	terminating
        host.	2017-01-05 17:50:20.620	debug	redis publish io.system.adapter.sayit.8.alive {'val':false,'ack':true,'ts':1483635020620,'q':0,'from':'system.adapter.sayit.8','lc':1483635020620}
        sayit.8	2017-01-05 17:50:20.619	info	stopping...
        host.Mastermind	2017-01-05 17:50:20.617	info	stopInstance system.adapter.sayit.8 killing pid 21970
        sayit.8	2017-01-05 17:50:19.628	debug	sendTo 'stopInstance' to system.adapter.system.host.Mastermind from system.adapter.sayit.8
        sayit.8	2017-01-05 17:50:19.625	info	stopping...
        host.	2017-01-05 17:50:19.619	debug	redis pmessage messagebox.system.adapter.sayit.8 messagebox.system.adapter.sayit.8 {'command':'stopInstance','message':null,'from':'system.host.Mastermind','callback':{'message':null,'id':44,'ack':false,'time':1483635019615},'_id':95001819}
        host.Mastermind	2017-01-05 17:50:19.615	info	stopInstance system.adapter.sayit.8
        host.Mastermind	2017-01-05 17:50:19.615	info	object change system.adapter.sayit.8
        host.	2017-01-05 17:50:19.497	debug	redis publish io.system.adapter.sayit.8.uptime {'val':15,'ack':true,'ts':1483635019497,'q':0,'from':'system.adapter.sayit.8','lc':1483635019497}
        host.	2017-01-05 17:50:19.494	debug	redis publish io.system.adapter.sayit.8.memHeapUsed {'val':11.17,'ack':true,'ts':1483635019492,'q':0,'from':'system.adapter.sayit.8','lc':1483635019492}
        host.	2017-01-05 17:50:19.487	debug	redis publish io.system.adapter.sayit.8.memHeapTotal {'val':18.74,'ack':true,'ts':1483635019487,'q':0,'from':'system.adapter.sayit.8','lc':1483635004484}
        host.	2017-01-05 17:50:19.486	debug	redis publish io.system.adapter.sayit.8.memRss {'val':32.15,'ack':true,'ts':1483635019486,'q':0,'from':'system.adapter.sayit.8','lc':1483635019486}
        host.	2017-01-05 17:50:19.486	debug	redis publish io.system.adapter.sayit.8.connected {'val':true,'ack':true,'ts':1483635019486,'q':0,'from':'system.adapter.sayit.8','lc':1483635004483}
        host.	2017-01-05 17:50:19.484	debug	redis publish io.system.adapter.sayit.8.alive {'val':true,'ack':true,'ts':1483635019484,'q':0,'from':'system.adapter.sayit.8','lc':1483635004482}
        host.	2017-01-05 17:50:18.467	debug	redis pmessage io.mpd.0.* io.mpd.0.seek {'val':0,'ack':true,'ts':1483635018459,'q':0,'from':'system.adapter.mpd.0','lc':1483634999210}
        host.	2017-01-05 17:50:18.464	debug	redis pmessage io.mpd.0.* io.mpd.0.current_elapsed {'val':'00:00','ack':true,'ts':1483635018458,'q':0,'from':'system.adapter.mpd.0','lc':1483634999209}
        host.	2017-01-05 17:50:18.464	debug	redis pmessage io.mpd.0.* io.mpd.0.current_duration {'val':'00:00','ack':true,'ts':1483635018457,'q':0,'from':'system.adapter.mpd.0','lc':1483634999208}
        host.	2017-01-05 17:50:18.463	debug	redis pmessage io.mpd.0.* io.mpd.0.current_duration_s {'val':0,'ack':true,'ts':1483635018457,'q':0,'from':'system.adapter.mpd.0','lc':1483634999207}
        host.	2017-01-05 17:50:18.463	debug	redis pmessage io.mpd.0.* io.mpd.0.playlist_list {'val':'[{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'},{\'artist\':\'\',\'album\':\'\',\'bitrate\':0,\'title\':\'\',\'file\':\'http://192.168.1.10:8082/state/sayit.8.tts.mp3\',\'genre\':\'\',\'year\':0,\'len\':\'00:00\',\'rating\':\'\',\'cover\':\'\'}]','ack':true,'ts':1483635018451,'q':0,'from':'system.adapter.mpd.0','lc':1483634632821}
        host.	2017-01-05 17:50:18.463	debug	redis pmessage io.mpd.0.* io.mpd.0.state {'val':'stop','ack':true,'ts':1483635018450,'q':0,'from':'system.adapter.mpd.0','lc':1483634634050}
        host.	2017-01-05 17:50:18.462	debug	redis pmessage io.mpd.0.* io.mpd.0.mixrampdb {'val':'0.000000','ack':true,'ts':1483635018448,'q':0,'from':'system.adapter.mpd.0','lc':1482515850534}
        host.	2017-01-05 17:50:18.462	debug	redis pmessage io.mpd.0.* io.mpd.0.playlistlength {'val':'8','ack':true,'ts':1483635018448,'q':0,'from':'system.adapter.mpd.0','lc':1483634632914}
        host.	2017-01-05 17:50:18.462	debug	redis pmessage io.mpd.0.* io.mpd.0.playlist {'val':'17','ack':true,'ts':1483635018447,'q':0,'from':'system.adapter.mpd.0','lc':1483634632914}
        host.	2017-01-05 17:50:18.462	debug	redis pmessage io.mpd.0.* io.mpd.0.consume {'val':'0','ack':true,'ts':1483635018447,'q':0,'from':'system.adapter.mpd.0','lc':1482515850532}
        host.	2017-01-05 17:50:18.462	debug	redis pmessage io.mpd.0.* io.mpd.0.single {'val':'0','ack':true,'ts':1483635018447,'q':0,'from':'system.adapter.mpd.0','lc':1482515850531}
        • I Offline
          I Offline
          instalator
          @rascal:
          0.1.6
            rascal
            Du bist der Beste, es funktioniert jetzt.
            Viele dank, ich werde alles auf mpd umstellen denke ich
            • I Offline
              I Offline
              instalator
              @rascal:
              Viele dank, ich werde alles auf mpd umstellen denke ich `
              Es ist einfach perfekt!
              Bitte melden Sie alle Fehler. Ich habe mich zu diesem Thema und ich werde in Kontakt.
                Hallo rascal,
                Ich lese hier schon länger mit, habe aber das Gesamtkonstrukt noch nicht verstanden.
                Mpd = daemon
                Wo läuft der?
                Client - host
                Ist der adapter der Client? Wo ist der Host?
                Was muss ich wo installieren?
                Rainer
                  rascal
                  @Homoran:
                  Hallo rascal,
                  Mpd = daemon
                  Wo läuft der?
                  Client - host
                  Rainer `
                  du hast deine Iobroker Installation laufen, auf einem Raspberry oder sonstwo. Dort musst du den mpd Adapter installieren.
                  Ich habe einen zweiten Raspberry im Netzwerk laufen, mit angeschlossenen Lautsprechern, auf diesem Läuft ein MPD (Music Player Daemon) - welcher praktisch als Empfänger der Befehle des Iobroker mpd-Adapters dient.
                  Jetzt musst du im mpd-Adapter die IP-Adresse des 2. Raspberry mit dem mpd-Service angeben und voala, nun kannst du über Iobroker auf dem 2. Raspberry Musik ausgeben lassen. Möglicherweise brauchst du auf dem 2. Raspberry auch noch einen mp3 Codec installiert (mpg123).
                  Wenn du nun auf dem 2. Raspberry auch Sprachmeldungen von Iobroker ausgeben willst, musst du in Iobroker auch einen sayit Adapter installieren. In diesem Adapter musst du als "Ausgabe durch" den MPD einstellen. Als Gerät den mpd-Adapter "mpd.0", als Web instance den Web Adapter "web.0" und in Web Server IP kommt die Iobroker IP.
                  Nun kannst du bei den Objekten unter sayit.x/tts/text einen Text eintragen und wenn du Enter drückst, sollte der 2. Raspberry die Sprache ausgeben.
                  Kurz: sayit-Adapter (rasp1-iobroker) -> mpd-Adapter (rasp1-iobroker) -> MPD-Service (rasp2-linux)
                  Ich hoffe ich konnte helfen.
                  LG
                  Martin
                  • wendy2702W Online
                    wendy2702W Online
                    wendy2702
                    Moin,
                    äääähhh…
                    Verständnis Frage: Mit einem MPD Client auf dem IPAD könnte ich das ding nur Steuern aber keine Ansagen über MPD am IPAD abspielen?
                    Um Ansagen abspielen zu können muss mein "remote" device, bei mir ein Tablet", einen MPD Daemon installiert haben?
                      rascal
                      Ja.
                      funktioniert am Ipad die sayit Einstellung "browser" nicht
                      Gesendet von meinem HUAWEI CRR-L09 mit Tapatalk
                      • wendy2702W Online
                        wendy2702W Online
                        wendy2702
                        Prinzipiell schon, allerdings erhalte ich da zur Zeit die Ansagen mehrfach als Echo.
                        Deshalb suche ich nach einer Alternative.
                        • Alex1808A Offline
                          Alex1808A Offline
                          Alex1808
                          @wendy2702:
                          Deshalb suche ich nach einer Alternative. `
                          iOS ist ein geschlossenes System, daher "mpd" am iPad wird nie geben. Man kann den MPD am iOS (iPhone, iPad) nur steuern.
                          Ich glaube Aussprache über "browser" ist im Moment einzige Möglichkeit.
                          Eventuell kann man ein raspberry pi mit laufendem "mpd" (z.b. Max2Play) so konfigurieren das alles über AirPlay abgespielt wird und halt iPad als Wiedergabegerät auswählen (z.b. AirFloat). Aber das ist keine saubere Lösung 😢
                            rascal
                            Wenn ich über sayit eine Sprache auf dem mpd ausgeben lasse, sehe ich da irgendwo, ob die Ausgabe noch aktiv ist?
                            Soweit ich gesehen habe hat sowohl sayit, als auch mpd einen Datenpunkt "playing" oder "play".
                            Bei sayit bleibt "playing" auf false
                            Bei mpd ist bei "play" gar kein Wert vorhanden.
                            könntest du bei mpd die Funktion einbauen?
                            Danke im Voraus
                            • I Offline
                              I Offline
                              instalator
                              @rascal:
                              Danke im Voraus `
                              Es ist nicht in Sayit realisiert
                                rascal
                                gibt es eine Möglichkeit zu sehen, ob der mpd Adapter gerade ein mp3 abspielt?
                                • I Offline
                                  I Offline
                                  instalator
                                  @rascal:
                                  gibt es eine Möglichkeit zu sehen, ob der mpd Adapter gerade ein mp3 abspielt? `
                                  Ja, gibt es:
                                  current_duration
                                  current_duration_s
                                  current_elapsed
                                  elapsed
                                  Aber Sait es funktioniert nicht.
                                    rascal
                                    bei mir ist ein neuer Fehler aufgetreten, welcher mit setvol zusammenhängt… die Fehlermeldung läuft solange, bis ich den mpd-Adapter neu starte:
                                    mpd.2	2017-01-09 12:39:49.195	error	client.sendCommand {"setvol": "52.5"} ERROR - Error: [2@0] {setvol} Integer expected: 52.5
                                    mpd.2	2017-01-09 12:39:48.993	error	client.sendCommand {"setvol": "52.5"} ERROR - Error: [2@0] {setvol} Integer expected: 52.5
                                    mpd.2	2017-01-09 12:39:48.750	error	client.sendCommand {"setvol": "52.5"} ERROR - Error: [2@0] {setvol} Integer expected: 52.5
                                    mpd.2	2017-01-09 12:39:48.548	error	client.sendCommand {"setvol": "52.5"} ERROR - Error: [2@0] {setvol} Integer expected: 52.5
                                    mpd.2	2017-01-09 12:39:48.346	error	client.sendCommand {"setvol": "52.5"} ERROR - Error: [2@0] {setvol} Integer expected: 52.5
                                    mpd.2	2017-01-09 12:39:48.144	error	client.sendCommand {"setvol": "52.5"} ERROR - Error: [2@0] {setvol} Integer expected: 52.5
                                    mpd.2	2017-01-09 12:39:47.941	error	client.sendCommand {"setvol": "52.5"} ERROR - Error: [2@0] {setvol} Integer expected: 52.5
                                    mpd.2	2017-01-09 12:39:47.740	error	client.sendCommand {"setvol": "52.5"} ERROR - Error: [2@0] {setvol} Integer expected: 52.5
                                    mpd.2	2017-01-09 12:39:47.539	error	client.sendCommand {"setvol": "52.5"} ERROR - Error: [2@0] {setvol} Integer expected: 52.5
                                    mpd.2	2017-01-09 12:39:47.337	error	client.sendCommand {"setvol": "52.5"} ERROR - Error: [2@0] {setvol} Integer expected: 52.5
                                    mpd.2	2017-01-09 12:39:47.136	error	client.sendCommand {"setvol": "52.5"} ERROR - Error: [2@0] {setvol} Integer expected: 52.5
                                    mpd.2	2017-01-09 12:39:46.934	error	client.sendCommand {"setvol": "52.5"} ERROR - Error: [2@0] {setvol} Integer expected: 52.5
                                    mpd.2	2017-01-09 12:39:46.733	error	client.sendCommand {"setvol": "52.5"} ERROR - Error: [2@0] {setvol} Integer expected: 52.5
                                    mpd.2	2017-01-09 12:39:46.531	error	client.sendCommand {"setvol": "52.5"} ERROR - Error: [2@0] {setvol} Integer expected: 52.5
                                    mpd.2	2017-01-09 12:39:46.329	error	client.sendCommand {"setvol": "52.5"} ERROR - Error: [2@0] {setvol} Integer expected: 52.5
                                    mpd.2	2017-01-09 12:39:46.127	error	client.sendCommand {"setvol": "52.5"} ERROR - Error: [2@0] {setvol} Integer expected: 52.5
                                    sayit.2	2017-01-09 12:39:46.052	info	Set "mpd.2.say: 100;http://192.168.1.10:8082/state/sayit.2.tts.mp3
                                    • BluefoxB Offline
                                      BluefoxB Offline
                                      @rascal:
                                      Installiere mal die aktuellste Version von mpd.
                                        rascal
                                        Oh man, ihr seid schneller beim programmieren als andere beim posten hier…
                                          rascal
                                          pha….. hatte ich schon drauf 8-)
                                          meine Versionen:
                                          mpd: 0.1.7
                                          text to speech: 1.3.1
