  3. Entwicklung
  4. (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?
    5.2k
herdsmanzigbee
129 Beiträge 13 Kommentatoren 31.1k Aufrufe 12 Beobachtet
  • D Diamand2k22
    bei der Ausgabe kommen keine Fehler!
    Danke dir!
    #41
    @diamand2k22
    Und das Gerät ist auch drin?
      @diamand2k22
      Diamand2k22
      #42
      scheint nicht zu klappen :-/
      • D Diamand2k22
        #43
        @diamand2k22
        Hier mal geschaut?
        https://forum.iobroker.net/topic/59852/hama-smartes-heizkörper-thermostat?_=1668467039158
          @diamand2k22
          Hier mal geschaut?
          Diamand2k22
          #44
          Hallo Thomas,
          hab das mal reinkopiert aber dann startet der zigbee adapter nicht mehr :-/
          2022-11-15 21:15:17.734 - error: host.pi4b Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/saswell.js:52
          2022-11-15 21:15:17.734 - error: host.pi4b Caught by controller[0]: .withAwayMode()],
          2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: ^
          2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: TypeError: exposes.climate(...).withSetpoint(...).withLocalTemperature(...).withSystemMode(...).withLocalTemperatureCalibration(...).withAwayMode is not a function
          2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Object. (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/saswell.js:52:18)
          2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1155:14)
          2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
          2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1033:32)
          2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:868:12)
          2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1057:19)
          2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
          2022-11-15 21:15:17.736 - error: host.pi4b Caught by controller[0]: at Object. (/opt/iobroker/node_modules/zigbee-herdsman-converters/index.js:118:30)
          2022-11-15 21:15:17.736 - error: host.pi4b Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1155:14)
          2022-11-15 21:15:17.736 - error: host.pi4b Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
          2022-11-15 21:15:17.736 - error: host.pi4b instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          • D Diamand2k22
            Hallo Thomas,
            #45
            @diamand2k22 sagte in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
            Was wo reinkopiert?
              Was wo reinkopiert?
              Diamand2k22
              #46
              @david-jung said in Hama Smartes Heizkörper-Thermostat:
              @david-jung
              so, ich habe folgendes gemacht:
              die Datei: /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/saswell.js
              etwas erweitert, jetzt kann ich die Ist-Temperatur ablesen, so wie die Soll-Temperatur setzen/lesen.
              Den Modus (heizen/auto/aus) lesen, setzen.
              Ventil Status ablesen.
              Und Offset für Temperatur setzen/lesen.
              const exposes = require('../lib/exposes');
              const fz = {...require('../converters/fromZigbee'), legacy: require('../lib/legacy').fromZigbee};
              const tz = require('../converters/toZigbee');
              const tuya = require('../lib/tuya');
              const reporting = require('../lib/reporting');
              const e = exposes.presets;
              const ea = exposes.access;
              module.exports = [
                      fingerprint: [{modelID: 'GbxAXL2\u0000', manufacturerName: '_TYST11_KGbxAXL2'},
                          {modelID: 'uhszj9s\u0000', manufacturerName: '_TYST11_zuhszj9s'},
                          {modelID: '88teujp\u0000', manufacturerName: '_TYST11_c88teujp'},
                          {modelID: 'w7cahqs\u0000', manufacturerName: '_TYST11_yw7cahqs'},
                          {modelID: 'w7cahqs', manufacturerName: '_TYST11_yw7cahqs'},
                          {modelID: 'TS0601', manufacturerName: '_TZE200_c88teujp'},
                          {modelID: 'TS0601', manufacturerName: '_TZE200_yw7cahqs'},
                          {modelID: 'TS0601', manufacturerName: '_TZE200_azqp6ssj'},
                          {modelID: 'TS0601', manufacturerName: '_TZE200_bvu2wnxz'},
                          {modelID: 'TS0601', manufacturerName: '_TZE200_zuhszj9s'},
                          {modelID: 'TS0601', manufacturerName: '_TZE200_9gvruqf5'},
                          {modelID: 'TS0601', manufacturerName: '_TZE200_zr9c0day'},
                      model: 'SEA801-Zigbee/SEA802-Zigbee',
                      vendor: 'Saswell',
                      description: 'Thermostatic radiator valve',
                      whiteLabel: [{vendor: 'HiHome', model: 'WZB-TRVL'}, {vendor: 'Hama', model: '00176592'},
                          {vendor: 'RTX', model: 'ZB-RT1'}],
                      fromZigbee: [fz.saswell_thermostat, fz.ignore_tuya_set_time, fz.ignore_basic_report, fz.legacy.tuya_thermostat_weekly_schedule],
                      toZigbee: [tz.saswell_thermostat_current_heating_setpoint, tz.saswell_thermostat_mode, tz.saswell_thermostat_away,
                          tz.saswell_thermostat_child_lock, tz.saswell_thermostat_window_detection, tz.saswell_thermostat_frost_detection,
                          tz.saswell_thermostat_calibration, tz.saswell_thermostat_anti_scaling, tz.tuya_thermostat_weekly_schedule],
                      onEvent: tuya.onEventSetTime,
                      meta: {
                          thermostat: {
                              weeklyScheduleMaxTransitions: 4,
                              weeklyScheduleSupportedModes: [1], // bits: 0-heat present, 1-cool present (dec: 1-heat,2-cool,3-heat+cool)
                              weeklyScheduleConversion: 'saswell',
                      configure: async (device, coordinatorEndpoint, logger) => {
                          const endpoint = device.getEndpoint(1);
                          await reporting.bind(endpoint, coordinatorEndpoint, ['genBasic']);
                      exposes: [e.battery_low(), e.window_detection(), e.child_lock(),
                          exposes.binary('heating', ea.STATE, 'ON', 'OFF').withDescription('Device valve is open or closed (heating or not)'),
                          exposes.climate()
                              .withSetpoint('current_heating_setpoint', 5, 30, 0.5, ea.STATE_SET).withLocalTemperature(ea.STATE)
                              .withSystemMode(['off', 'heat', 'auto'], ea.STATE_SET)
                              // Range is -6 - 6 and step 1: https://github.com/Koenkk/zigbee2mqtt/issues/11777
                              .withLocalTemperatureCalibration(-6, 6, 1, ea.STATE_SET)
                              .withAwayMode()],
              		/*added by djung 10.11.2022*/
              	fingerprint: [{modelID: 'TS0601', manufacturerName: '_TZE200_h4cgnbzg'}],
                      model: 'HZ',
                      vendor: 'HAMA',
                      whiteLabel: [{vendor: 'Hama', model: 'XXXxxxXXX'},],
                      fromZigbee: [fz.saswell_thermostat],
                          tz.saswell_thermostat_calibration],
                      exposes: [
              			e.battery_low(),
              			/*e.switch(),*/
              			/*e.lock(),*/
                          exposes.climate()
              soll man das irgendwo auf github oder so noch posten? Wenn ja, bitte zeigen wo =)
              Grüße.
              David.
              • D Diamand2k22
                @david-jung
                module.exports = [
                        vendor: 'Saswell',
                        meta: {
                            thermostat: {
                            exposes.climate()
                                .withAwayMode()],
                        model: 'HZ',
                        vendor: 'HAMA',
                        exposes: [
                			e.battery_low(),
                			/*e.switch(),*/
                			/*e.lock(),*/
                            exposes.climate()
                Grüße.
                David.
                #47
                @diamand2k22
                Alles? Das war nur als Denkansatz für dich gedacht.
                Ich hätte da erstmal nur die Manufacturer-ID hinzugefügt. Sind ja schon ein paar Varianten von dem Thermostat mit der Modellbezeichnung TS0601 vorhanden.
                  @diamand2k22
                  Diamand2k22
                  #48
                  hab die manufactor id eingefügt, jetzt erkennt er das thermostat, liefert aber keine werte!
                  2022-11-15 21:35:02.182 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #2 with data {"dp":2,"datatype":4,"data":{"type":"Buffer","data":[2]}}
                  2022-11-15 21:35:02.434 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #4 with data {"dp":4,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,50]}}
                  2022-11-15 21:35:02.551 - info: dwd.0 (92835) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.18.1, js-controller: 4.0.23
                  2022-11-15 21:35:02.555 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #5 with data {"dp":5,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,200]}}
                  2022-11-15 21:35:02.704 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #7 with data {"dp":7,"datatype":1,"data":{"type":"Buffer","data":[0]}}
                  2022-11-15 21:35:02.789 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #28 with data {"dp":28,"datatype":0,"data":{"type":"Buffer","data":[1,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                  2022-11-15 21:35:02.906 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #29 with data {"dp":29,"datatype":0,"data":{"type":"Buffer","data":[2,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                  2022-11-15 21:35:03.032 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #30 with data {"dp":30,"datatype":0,"data":{"type":"Buffer","data":[3,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                  2022-11-15 21:35:03.144 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #31 with data {"dp":31,"datatype":0,"data":{"type":"Buffer","data":[4,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                  2022-11-15 21:35:03.264 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #32 with data {"dp":32,"datatype":0,"data":{"type":"Buffer","data":[5,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                  2022-11-15 21:35:03.380 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #33 with data {"dp":33,"datatype":0,"data":{"type":"Buffer","data":[6,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                  2022-11-15 21:35:03.502 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #34 with data {"dp":34,"datatype":0,"data":{"type":"Buffer","data":[7,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                  2022-11-15 21:35:03.615 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #35 with data {"dp":35,"datatype":5,"data":{"type":"Buffer","data":[0]}}
                  2022-11-15 21:35:03.731 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #36 with data {"dp":36,"datatype":1,"data":{"type":"Buffer","data":[0]}}
                  2022-11-15 21:35:03.848 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #39 with data {"dp":39,"datatype":1,"data":{"type":"Buffer","data":[0]}}
                  2022-11-15 21:35:03.968 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #47 with data {"dp":47,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}
                  • D Diamand2k22
                    #49
                    @diamand2k22
                    Ich kann dir da nicht weiterhelfen.
                    Vielleicht weiß @david-jung ja noch was dazu.
                      Diamand2k22
                      #50
                      kann es sein, dass mit den Rechten was nicht stimmt?`
                      $ iobroker url ioBroker/ioBroker.zigbee --host pi4b --debug
                      install ioBroker/ioBroker.zigbee
                      NPM version: 8.19.2
                      Installing ioBroker/ioBroker.zigbee... (System call)
                      npm WARN cleanup Failed to remove some directories [npm WARN cleanup [
                      npm WARN cleanup '/opt/iobroker/node_modules/.zigbee-herdsman-converters-DzgWyYTV',npm WARN cleanup [Error: EACCES: permission denied, scandir '/opt/iobroker/node_modules/.zigbee-herdsman-converters-DzgWyYTV/devices'] {npm WARN cleanup errno: -13,npm WARN cleanup code: 'EACCES',npm WARN cleanup syscall: 'scandir',npm WARN cleanup path: '/opt/iobroker/node_modules/.zigbee-herdsman-converters-DzgWyYTV/devices'npm WARN cleanup }npm WARN cleanup ]npm WARN cleanup
                      • D Diamand2k22
                        NPM version: 8.19.2
                        #51
                        iob stop
                        iob fix
                        iob start
                          iob stop
                          iob fix
                          iob start
                          Diamand2k22
                          #52
                          danke dir für die schnelle Rückmeldung.
                          Hab's dann doch selber hinbekommen!
                          • D Diamand2k22
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            #53
                            Und des Rätsels Lösung war ?
                            Vll hilft das auch anderen Mitlesenden !
                            Lehrling seit 1975 !!!
                            • DJMarc75D DJMarc75
                              Diamand2k22
                              #54
                              @djmarc75
                              hat Thomas schon geschrieben.
                              iob stop
                              iob fix
                              iob start
                              • D Diamand2k22
                                @djmarc75
                                iob stop
                                iob fix
                                iob start
                                #55
                                @diamand2k22
                                Dann hast du da mal mit falschen Rechten hantiert.
                                root login?
                                P 1 Antwort Letzte Antwort
                                  Diamand2k22
                                  schrieb am zuletzt editiert von Diamand2k22
                                  #56
                                  kann sein Thomas, hab ich aber wieder hingebogen bekommen.
                                  @Asgothian
                                  hab mir jetzt ne eigene ketotek.js für mein Heizkörperthermostat gebastelt.
                                  Jetzt funktioniert es wunderbar und ich hab keine Unrecognized DP's mehr und kann es steuern und empfange Temperaturen.
                                  Was mich nur interessieren würde, wie bekomme ich da ein vernünftiges Bild rein?
                                  Kannst du das Thermostat aufnehmen?
                                    @diamand2k22
                                    root login?
                                    Patrick Kenzler
                                    #57
                                    @thomas-braun könntest du deinen externen Konverter zur Verfügung stellen? Sitze schon seit Tagen und komme nicht weiter.
                                    • P Patrick Kenzler
                                      #58
                                      @patrick-kenzler
                                      Meinen was? Wüsste nicht das ich sowas im Einsatz hätte.
                                        @patrick-kenzler
                                        Patrick Kenzler
                                        #59
                                        @thomas-braun sorry, die Frage sollte eigentlich an @Diamand2k22 gehen habe mich verklickt^^
                                        • P Patrick Kenzler
                                          Diamand2k22
                                          #60
                                          @patrick-kenzler
                                          Hast du auch so ein ketotek Teil von Amaz**?
