  3. Entwicklung
  4. (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?
    6.5k
herdsmanzigbee
129 Beiträge 13 Kommentatoren 31.7k Aufrufe 12 Beobachtet
    @diamand2k22
    Hier mal geschaut?
    https://forum.iobroker.net/topic/59852/hama-smartes-heizkörper-thermostat?_=1668467039158
    Diamand2k22
    Hallo Thomas,
    hab das mal reinkopiert aber dann startet der zigbee adapter nicht mehr :-/
    2022-11-15 21:15:17.734 - error: host.pi4b Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/saswell.js:52
    2022-11-15 21:15:17.734 - error: host.pi4b Caught by controller[0]: .withAwayMode()],
    2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: ^
    2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: TypeError: exposes.climate(...).withSetpoint(...).withLocalTemperature(...).withSystemMode(...).withLocalTemperatureCalibration(...).withAwayMode is not a function
    2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Object. (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/saswell.js:52:18)
    2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1155:14)
    2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
    2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1033:32)
    2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:868:12)
    2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1057:19)
    2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
    2022-11-15 21:15:17.736 - error: host.pi4b Caught by controller[0]: at Object. (/opt/iobroker/node_modules/zigbee-herdsman-converters/index.js:118:30)
    2022-11-15 21:15:17.736 - error: host.pi4b Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1155:14)
    2022-11-15 21:15:17.736 - error: host.pi4b Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
    2022-11-15 21:15:17.736 - error: host.pi4b instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    • D Diamand2k22
      Hallo Thomas,
      @diamand2k22 sagte in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
      Was wo reinkopiert?
        Was wo reinkopiert?
        Diamand2k22
        @david-jung said in Hama Smartes Heizkörper-Thermostat:
        @david-jung
        so, ich habe folgendes gemacht:
        die Datei: /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/saswell.js
        etwas erweitert, jetzt kann ich die Ist-Temperatur ablesen, so wie die Soll-Temperatur setzen/lesen.
        Den Modus (heizen/auto/aus) lesen, setzen.
        Ventil Status ablesen.
        Und Offset für Temperatur setzen/lesen.
        const exposes = require('../lib/exposes');
        const fz = {...require('../converters/fromZigbee'), legacy: require('../lib/legacy').fromZigbee};
        const tz = require('../converters/toZigbee');
        const tuya = require('../lib/tuya');
        const reporting = require('../lib/reporting');
        const e = exposes.presets;
        const ea = exposes.access;
        module.exports = [
                fingerprint: [{modelID: 'GbxAXL2\u0000', manufacturerName: '_TYST11_KGbxAXL2'},
                    {modelID: 'uhszj9s\u0000', manufacturerName: '_TYST11_zuhszj9s'},
                    {modelID: '88teujp\u0000', manufacturerName: '_TYST11_c88teujp'},
                    {modelID: 'w7cahqs\u0000', manufacturerName: '_TYST11_yw7cahqs'},
                    {modelID: 'w7cahqs', manufacturerName: '_TYST11_yw7cahqs'},
                    {modelID: 'TS0601', manufacturerName: '_TZE200_c88teujp'},
                    {modelID: 'TS0601', manufacturerName: '_TZE200_yw7cahqs'},
                    {modelID: 'TS0601', manufacturerName: '_TZE200_azqp6ssj'},
                    {modelID: 'TS0601', manufacturerName: '_TZE200_bvu2wnxz'},
                    {modelID: 'TS0601', manufacturerName: '_TZE200_zuhszj9s'},
                    {modelID: 'TS0601', manufacturerName: '_TZE200_9gvruqf5'},
                    {modelID: 'TS0601', manufacturerName: '_TZE200_zr9c0day'},
                model: 'SEA801-Zigbee/SEA802-Zigbee',
                vendor: 'Saswell',
                description: 'Thermostatic radiator valve',
                whiteLabel: [{vendor: 'HiHome', model: 'WZB-TRVL'}, {vendor: 'Hama', model: '00176592'},
                    {vendor: 'RTX', model: 'ZB-RT1'}],
                fromZigbee: [fz.saswell_thermostat, fz.ignore_tuya_set_time, fz.ignore_basic_report, fz.legacy.tuya_thermostat_weekly_schedule],
                toZigbee: [tz.saswell_thermostat_current_heating_setpoint, tz.saswell_thermostat_mode, tz.saswell_thermostat_away,
                    tz.saswell_thermostat_child_lock, tz.saswell_thermostat_window_detection, tz.saswell_thermostat_frost_detection,
                    tz.saswell_thermostat_calibration, tz.saswell_thermostat_anti_scaling, tz.tuya_thermostat_weekly_schedule],
                onEvent: tuya.onEventSetTime,
                meta: {
                    thermostat: {
                        weeklyScheduleMaxTransitions: 4,
                        weeklyScheduleSupportedModes: [1], // bits: 0-heat present, 1-cool present (dec: 1-heat,2-cool,3-heat+cool)
                        weeklyScheduleConversion: 'saswell',
                configure: async (device, coordinatorEndpoint, logger) => {
                    const endpoint = device.getEndpoint(1);
                    await reporting.bind(endpoint, coordinatorEndpoint, ['genBasic']);
                exposes: [e.battery_low(), e.window_detection(), e.child_lock(),
                    exposes.binary('heating', ea.STATE, 'ON', 'OFF').withDescription('Device valve is open or closed (heating or not)'),
                    exposes.climate()
                        .withSetpoint('current_heating_setpoint', 5, 30, 0.5, ea.STATE_SET).withLocalTemperature(ea.STATE)
                        .withSystemMode(['off', 'heat', 'auto'], ea.STATE_SET)
                        // Range is -6 - 6 and step 1: https://github.com/Koenkk/zigbee2mqtt/issues/11777
                        .withLocalTemperatureCalibration(-6, 6, 1, ea.STATE_SET)
                        .withAwayMode()],
        		/*added by djung 10.11.2022*/
        	fingerprint: [{modelID: 'TS0601', manufacturerName: '_TZE200_h4cgnbzg'}],
                model: 'HZ',
                vendor: 'HAMA',
                whiteLabel: [{vendor: 'Hama', model: 'XXXxxxXXX'},],
                fromZigbee: [fz.saswell_thermostat],
                    tz.saswell_thermostat_calibration],
                exposes: [
        			e.battery_low(),
        			/*e.switch(),*/
        			/*e.lock(),*/
                    exposes.climate()
        soll man das irgendwo auf github oder so noch posten? Wenn ja, bitte zeigen wo =)
        Grüße.
        David.
        • D Diamand2k22
          @david-jung
          module.exports = [
                  vendor: 'Saswell',
                  meta: {
                      thermostat: {
                      exposes.climate()
                          .withAwayMode()],
                  model: 'HZ',
                  vendor: 'HAMA',
                  exposes: [
          			e.battery_low(),
          			/*e.switch(),*/
          			/*e.lock(),*/
                      exposes.climate()
          Grüße.
          David.
          @diamand2k22
          Alles? Das war nur als Denkansatz für dich gedacht.
          Ich hätte da erstmal nur die Manufacturer-ID hinzugefügt. Sind ja schon ein paar Varianten von dem Thermostat mit der Modellbezeichnung TS0601 vorhanden.
            @diamand2k22
            Diamand2k22
            hab die manufactor id eingefügt, jetzt erkennt er das thermostat, liefert aber keine werte!
            2022-11-15 21:35:02.182 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #2 with data {"dp":2,"datatype":4,"data":{"type":"Buffer","data":[2]}}
            2022-11-15 21:35:02.434 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #4 with data {"dp":4,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,50]}}
            2022-11-15 21:35:02.551 - info: dwd.0 (92835) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.18.1, js-controller: 4.0.23
            2022-11-15 21:35:02.555 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #5 with data {"dp":5,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,200]}}
            2022-11-15 21:35:02.704 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #7 with data {"dp":7,"datatype":1,"data":{"type":"Buffer","data":[0]}}
            2022-11-15 21:35:02.789 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #28 with data {"dp":28,"datatype":0,"data":{"type":"Buffer","data":[1,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
            2022-11-15 21:35:02.906 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #29 with data {"dp":29,"datatype":0,"data":{"type":"Buffer","data":[2,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
            2022-11-15 21:35:03.032 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #30 with data {"dp":30,"datatype":0,"data":{"type":"Buffer","data":[3,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
            2022-11-15 21:35:03.144 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #31 with data {"dp":31,"datatype":0,"data":{"type":"Buffer","data":[4,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
            2022-11-15 21:35:03.264 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #32 with data {"dp":32,"datatype":0,"data":{"type":"Buffer","data":[5,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
            2022-11-15 21:35:03.380 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #33 with data {"dp":33,"datatype":0,"data":{"type":"Buffer","data":[6,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
            2022-11-15 21:35:03.502 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #34 with data {"dp":34,"datatype":0,"data":{"type":"Buffer","data":[7,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
            2022-11-15 21:35:03.615 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #35 with data {"dp":35,"datatype":5,"data":{"type":"Buffer","data":[0]}}
            2022-11-15 21:35:03.731 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #36 with data {"dp":36,"datatype":1,"data":{"type":"Buffer","data":[0]}}
            2022-11-15 21:35:03.848 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #39 with data {"dp":39,"datatype":1,"data":{"type":"Buffer","data":[0]}}
            2022-11-15 21:35:03.968 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #47 with data {"dp":47,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}
            • D Diamand2k22
              @diamand2k22
              Ich kann dir da nicht weiterhelfen.
              Vielleicht weiß @david-jung ja noch was dazu.
                Diamand2k22
                kann es sein, dass mit den Rechten was nicht stimmt?`
                $ iobroker url ioBroker/ioBroker.zigbee --host pi4b --debug
                install ioBroker/ioBroker.zigbee
                NPM version: 8.19.2
                Installing ioBroker/ioBroker.zigbee... (System call)
                npm WARN cleanup Failed to remove some directories [npm WARN cleanup [
                npm WARN cleanup '/opt/iobroker/node_modules/.zigbee-herdsman-converters-DzgWyYTV',npm WARN cleanup [Error: EACCES: permission denied, scandir '/opt/iobroker/node_modules/.zigbee-herdsman-converters-DzgWyYTV/devices'] {npm WARN cleanup errno: -13,npm WARN cleanup code: 'EACCES',npm WARN cleanup syscall: 'scandir',npm WARN cleanup path: '/opt/iobroker/node_modules/.zigbee-herdsman-converters-DzgWyYTV/devices'npm WARN cleanup }npm WARN cleanup ]npm WARN cleanup
                • D Diamand2k22
                  NPM version: 8.19.2
                  iob stop
                  iob fix
                  iob start
                    iob stop
                    iob fix
                    iob start
                    Diamand2k22
                    danke dir für die schnelle Rückmeldung.
                    Hab's dann doch selber hinbekommen!
                    • D Diamand2k22
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      Und des Rätsels Lösung war ?
                      Vll hilft das auch anderen Mitlesenden !
                      Lehrling seit 1975 !!!
                      • DJMarc75D DJMarc75
                        Diamand2k22
                        @djmarc75
                        hat Thomas schon geschrieben.
                        iob stop
                        iob fix
                        iob start
                        • D Diamand2k22
                          @djmarc75
                          iob stop
                          iob fix
                          iob start
                          @diamand2k22
                          Dann hast du da mal mit falschen Rechten hantiert.
                          root login?
                          P 1 Antwort Letzte Antwort
                            Diamand2k22
                            schrieb am zuletzt editiert von Diamand2k22
                            kann sein Thomas, hab ich aber wieder hingebogen bekommen.
                            @Asgothian
                            hab mir jetzt ne eigene ketotek.js für mein Heizkörperthermostat gebastelt.
                            Jetzt funktioniert es wunderbar und ich hab keine Unrecognized DP's mehr und kann es steuern und empfange Temperaturen.
                            Was mich nur interessieren würde, wie bekomme ich da ein vernünftiges Bild rein?
                            Kannst du das Thermostat aufnehmen?
                              @diamand2k22
                              root login?
                              Patrick Kenzler
                              @thomas-braun könntest du deinen externen Konverter zur Verfügung stellen? Sitze schon seit Tagen und komme nicht weiter.
                              • P Patrick Kenzler
                                @patrick-kenzler
                                Meinen was? Wüsste nicht das ich sowas im Einsatz hätte.
                                  @patrick-kenzler
                                  Patrick Kenzler
                                  @thomas-braun sorry, die Frage sollte eigentlich an @Diamand2k22 gehen habe mich verklickt^^
                                  • P Patrick Kenzler
                                    Diamand2k22
                                    @patrick-kenzler
                                    Hast du auch so ein ketotek Teil von Amaz**?
                                    • D Diamand2k22
                                      @patrick-kenzler
                                      Patrick Kenzler
                                      @diamand2k22 said in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
                                      @patrick-kenzler
                                      nein, aber Avatto ME167 das wird auch unter _TZE200_bvu2wnxz geführt.
                                        Diamand2k22
                                        @patrick-kenzler
                                        06b9e9de-716c-4a03-95a1-94f34a45ccf6-avatto_me167.js
                                        Hab's angepasst für dein ME167 Thermostat.
                                        Probiers mal aus.
                                        Du weißt ja wo die Datei hin muss oder?
                                        • D Diamand2k22
                                          @patrick-kenzler
                                          Probiers mal aus.
                                          Patrick Kenzler
                                          @diamand2k22 Danke aber leider bekomme ich Fehler ausgeworfen und der Adapter startet nicht mehr. Naja ich packe den Pfad unter Einstellungen der jeweiligen Zigbee Instanz und die Datei in "/opt/iobroker/iobroker-data/zigbee_2"?!
                                          anbei das protokoll
                                          2022-11-22 07:57:47.563 - error: zigbee.2 (22077) Exception-Code: MODULE_NOT_FOUND: Cannot find module '../lib/exposes'
                                          Require stack:
                                          - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                                          2022-11-22 07:57:47.641 - info: zigbee.2 (22077) cleaned everything up...
                                          2022-11-22 07:57:47.645 - info: zigbee.2 (22077) terminating
                                          2022-11-22 07:57:47.648 - warn: zigbee.2 (22077) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                          2022-11-22 07:57:48.285 - error: host.SmartHome Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                          2022-11-22 07:57:48.286 - error: host.SmartHome Caught by controller[1]: node:internal/modules/cjs/loader:936
                                          2022-11-22 07:57:48.287 - error: host.SmartHome Caught by controller[1]: throw err;
                                          2022-11-22 07:57:48.287 - error: host.SmartHome Caught by controller[1]: ^
                                          2022-11-22 07:57:48.287 - error: host.SmartHome Caught by controller[1]: Error: Cannot find module '../lib/exposes'
                                          2022-11-22 07:57:48.288 - error: host.SmartHome Caught by controller[1]: Require stack:
                                          2022-11-22 07:57:48.288 - error: host.SmartHome Caught by controller[1]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                                          2022-11-22 07:57:48.289 - error: host.SmartHome Caught by controller[1]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                                          2022-11-22 07:57:48.289 - error: host.SmartHome Caught by controller[1]: at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                                          2022-11-22 07:57:48.289 - error: host.SmartHome Caught by controller[1]: at Module.require (node:internal/modules/cjs/loader:1005:19)
                                          2022-11-22 07:57:48.290 - error: host.SmartHome Caught by controller[1]: at require (node:internal/modules/cjs/helpers:102:18)
                                          2022-11-22 07:57:48.290 - error: host.SmartHome Caught by controller[1]: at evalmachine.:1:17
                                          2022-11-22 07:57:48.290 - error: host.SmartHome Caught by controller[1]: at Script.runInContext (node:vm:139:12)
                                          2022-11-22 07:57:48.291 - error: host.SmartHome Caught by controller[1]: at Script.runInNewContext (node:vm:144:17)
                                          2022-11-22 07:57:48.291 - error: host.SmartHome Caught by controller[1]: at Object.runInNewContext (node:vm:298:38)
                                          2022-11-22 07:57:48.291 - error: host.SmartHome Caught by controller[1]: at Zigbee.getExternalDefinition (/opt/iobroker/node_modules/iobroker.zigbee/main.js:222:16)
                                          2022-11-22 07:57:48.292 - error: host.SmartHome Caught by controller[1]: at getExternalDefinition.next ()
                                          2022-11-22 07:57:48.292 - error: host.SmartHome instance system.adapter.zigbee.2 terminated with code 6 (UNCAUGHT_EXCEPTION)
