  3. Entwicklung
  4. (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?
    6.5k
herdsmanzigbee
129 Beiträge 13 Kommentatoren 31.7k Aufrufe 12 Beobachtet
    @diamand2k22
    Und das Gerät ist auch drin?
    Diamand2k22
    scheint nicht zu klappen :-/
    • D Diamand2k22
      @diamand2k22
      Hier mal geschaut?
      https://forum.iobroker.net/topic/59852/hama-smartes-heizkörper-thermostat?_=1668467039158
        @diamand2k22
        Hier mal geschaut?
        Diamand2k22
        Hallo Thomas,
        hab das mal reinkopiert aber dann startet der zigbee adapter nicht mehr :-/
        2022-11-15 21:15:17.734 - error: host.pi4b Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/saswell.js:52
        2022-11-15 21:15:17.734 - error: host.pi4b Caught by controller[0]: .withAwayMode()],
        2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: ^
        2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: TypeError: exposes.climate(...).withSetpoint(...).withLocalTemperature(...).withSystemMode(...).withLocalTemperatureCalibration(...).withAwayMode is not a function
        2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Object. (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/saswell.js:52:18)
        2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1155:14)
        2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
        2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1033:32)
        2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:868:12)
        2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1057:19)
        2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
        2022-11-15 21:15:17.736 - error: host.pi4b Caught by controller[0]: at Object. (/opt/iobroker/node_modules/zigbee-herdsman-converters/index.js:118:30)
        2022-11-15 21:15:17.736 - error: host.pi4b Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1155:14)
        2022-11-15 21:15:17.736 - error: host.pi4b Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
        2022-11-15 21:15:17.736 - error: host.pi4b instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        • D Diamand2k22
          Hallo Thomas,
          @diamand2k22 sagte in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
          Was wo reinkopiert?
            Was wo reinkopiert?
            Diamand2k22
            @david-jung said in Hama Smartes Heizkörper-Thermostat:
            @david-jung
            so, ich habe folgendes gemacht:
            die Datei: /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/saswell.js
            etwas erweitert, jetzt kann ich die Ist-Temperatur ablesen, so wie die Soll-Temperatur setzen/lesen.
            Den Modus (heizen/auto/aus) lesen, setzen.
            Ventil Status ablesen.
            Und Offset für Temperatur setzen/lesen.
            const exposes = require('../lib/exposes');
            const fz = {...require('../converters/fromZigbee'), legacy: require('../lib/legacy').fromZigbee};
            const tz = require('../converters/toZigbee');
            const tuya = require('../lib/tuya');
            const reporting = require('../lib/reporting');
            const e = exposes.presets;
            const ea = exposes.access;
            module.exports = [
                    fingerprint: [{modelID: 'GbxAXL2\u0000', manufacturerName: '_TYST11_KGbxAXL2'},
                        {modelID: 'uhszj9s\u0000', manufacturerName: '_TYST11_zuhszj9s'},
                        {modelID: '88teujp\u0000', manufacturerName: '_TYST11_c88teujp'},
                        {modelID: 'w7cahqs\u0000', manufacturerName: '_TYST11_yw7cahqs'},
                        {modelID: 'w7cahqs', manufacturerName: '_TYST11_yw7cahqs'},
                        {modelID: 'TS0601', manufacturerName: '_TZE200_c88teujp'},
                        {modelID: 'TS0601', manufacturerName: '_TZE200_yw7cahqs'},
                        {modelID: 'TS0601', manufacturerName: '_TZE200_azqp6ssj'},
                        {modelID: 'TS0601', manufacturerName: '_TZE200_bvu2wnxz'},
                        {modelID: 'TS0601', manufacturerName: '_TZE200_zuhszj9s'},
                        {modelID: 'TS0601', manufacturerName: '_TZE200_9gvruqf5'},
                        {modelID: 'TS0601', manufacturerName: '_TZE200_zr9c0day'},
                    model: 'SEA801-Zigbee/SEA802-Zigbee',
                    vendor: 'Saswell',
                    description: 'Thermostatic radiator valve',
                    whiteLabel: [{vendor: 'HiHome', model: 'WZB-TRVL'}, {vendor: 'Hama', model: '00176592'},
                        {vendor: 'RTX', model: 'ZB-RT1'}],
                    fromZigbee: [fz.saswell_thermostat, fz.ignore_tuya_set_time, fz.ignore_basic_report, fz.legacy.tuya_thermostat_weekly_schedule],
                    toZigbee: [tz.saswell_thermostat_current_heating_setpoint, tz.saswell_thermostat_mode, tz.saswell_thermostat_away,
                        tz.saswell_thermostat_child_lock, tz.saswell_thermostat_window_detection, tz.saswell_thermostat_frost_detection,
                        tz.saswell_thermostat_calibration, tz.saswell_thermostat_anti_scaling, tz.tuya_thermostat_weekly_schedule],
                    onEvent: tuya.onEventSetTime,
                    meta: {
                        thermostat: {
                            weeklyScheduleMaxTransitions: 4,
                            weeklyScheduleSupportedModes: [1], // bits: 0-heat present, 1-cool present (dec: 1-heat,2-cool,3-heat+cool)
                            weeklyScheduleConversion: 'saswell',
                    configure: async (device, coordinatorEndpoint, logger) => {
                        const endpoint = device.getEndpoint(1);
                        await reporting.bind(endpoint, coordinatorEndpoint, ['genBasic']);
                    exposes: [e.battery_low(), e.window_detection(), e.child_lock(),
                        exposes.binary('heating', ea.STATE, 'ON', 'OFF').withDescription('Device valve is open or closed (heating or not)'),
                        exposes.climate()
                            .withSetpoint('current_heating_setpoint', 5, 30, 0.5, ea.STATE_SET).withLocalTemperature(ea.STATE)
                            .withSystemMode(['off', 'heat', 'auto'], ea.STATE_SET)
                            // Range is -6 - 6 and step 1: https://github.com/Koenkk/zigbee2mqtt/issues/11777
                            .withLocalTemperatureCalibration(-6, 6, 1, ea.STATE_SET)
                            .withAwayMode()],
            		/*added by djung 10.11.2022*/
            	fingerprint: [{modelID: 'TS0601', manufacturerName: '_TZE200_h4cgnbzg'}],
                    model: 'HZ',
                    vendor: 'HAMA',
                    whiteLabel: [{vendor: 'Hama', model: 'XXXxxxXXX'},],
                    fromZigbee: [fz.saswell_thermostat],
                        tz.saswell_thermostat_calibration],
                    exposes: [
            			e.battery_low(),
            			/*e.switch(),*/
            			/*e.lock(),*/
                        exposes.climate()
            soll man das irgendwo auf github oder so noch posten? Wenn ja, bitte zeigen wo =)
            Grüße.
            David.
            • D Diamand2k22
              @david-jung
              module.exports = [
                      vendor: 'Saswell',
                      meta: {
                          thermostat: {
                          exposes.climate()
                              .withAwayMode()],
                      model: 'HZ',
                      vendor: 'HAMA',
                      exposes: [
              			e.battery_low(),
              			/*e.switch(),*/
              			/*e.lock(),*/
                          exposes.climate()
              Grüße.
              David.
              @diamand2k22
              Alles? Das war nur als Denkansatz für dich gedacht.
              Ich hätte da erstmal nur die Manufacturer-ID hinzugefügt. Sind ja schon ein paar Varianten von dem Thermostat mit der Modellbezeichnung TS0601 vorhanden.
                @diamand2k22
                Diamand2k22
                hab die manufactor id eingefügt, jetzt erkennt er das thermostat, liefert aber keine werte!
                2022-11-15 21:35:02.182 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #2 with data {"dp":2,"datatype":4,"data":{"type":"Buffer","data":[2]}}
                2022-11-15 21:35:02.434 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #4 with data {"dp":4,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,50]}}
                2022-11-15 21:35:02.551 - info: dwd.0 (92835) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.18.1, js-controller: 4.0.23
                2022-11-15 21:35:02.555 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #5 with data {"dp":5,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,200]}}
                2022-11-15 21:35:02.704 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #7 with data {"dp":7,"datatype":1,"data":{"type":"Buffer","data":[0]}}
                2022-11-15 21:35:02.789 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #28 with data {"dp":28,"datatype":0,"data":{"type":"Buffer","data":[1,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                2022-11-15 21:35:02.906 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #29 with data {"dp":29,"datatype":0,"data":{"type":"Buffer","data":[2,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                2022-11-15 21:35:03.032 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #30 with data {"dp":30,"datatype":0,"data":{"type":"Buffer","data":[3,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                2022-11-15 21:35:03.144 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #31 with data {"dp":31,"datatype":0,"data":{"type":"Buffer","data":[4,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                2022-11-15 21:35:03.264 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #32 with data {"dp":32,"datatype":0,"data":{"type":"Buffer","data":[5,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                2022-11-15 21:35:03.380 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #33 with data {"dp":33,"datatype":0,"data":{"type":"Buffer","data":[6,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                2022-11-15 21:35:03.502 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #34 with data {"dp":34,"datatype":0,"data":{"type":"Buffer","data":[7,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                2022-11-15 21:35:03.615 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #35 with data {"dp":35,"datatype":5,"data":{"type":"Buffer","data":[0]}}
                2022-11-15 21:35:03.731 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #36 with data {"dp":36,"datatype":1,"data":{"type":"Buffer","data":[0]}}
                2022-11-15 21:35:03.848 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #39 with data {"dp":39,"datatype":1,"data":{"type":"Buffer","data":[0]}}
                2022-11-15 21:35:03.968 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #47 with data {"dp":47,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}
                • D Diamand2k22
                  @diamand2k22
                  Ich kann dir da nicht weiterhelfen.
                  Vielleicht weiß @david-jung ja noch was dazu.
                    Diamand2k22
                    kann es sein, dass mit den Rechten was nicht stimmt?`
                    $ iobroker url ioBroker/ioBroker.zigbee --host pi4b --debug
                    install ioBroker/ioBroker.zigbee
                    NPM version: 8.19.2
                    Installing ioBroker/ioBroker.zigbee... (System call)
                    npm WARN cleanup Failed to remove some directories [npm WARN cleanup [
                    npm WARN cleanup '/opt/iobroker/node_modules/.zigbee-herdsman-converters-DzgWyYTV',npm WARN cleanup [Error: EACCES: permission denied, scandir '/opt/iobroker/node_modules/.zigbee-herdsman-converters-DzgWyYTV/devices'] {npm WARN cleanup errno: -13,npm WARN cleanup code: 'EACCES',npm WARN cleanup syscall: 'scandir',npm WARN cleanup path: '/opt/iobroker/node_modules/.zigbee-herdsman-converters-DzgWyYTV/devices'npm WARN cleanup }npm WARN cleanup ]npm WARN cleanup
                    • D Diamand2k22
                      NPM version: 8.19.2
                      iob stop
                      iob fix
                      iob start
                        iob stop
                        iob fix
                        iob start
                        Diamand2k22
                        danke dir für die schnelle Rückmeldung.
                        Hab's dann doch selber hinbekommen!
                        • D Diamand2k22
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          Und des Rätsels Lösung war ?
                          Vll hilft das auch anderen Mitlesenden !
                          Lehrling seit 1975 !!!
                          • DJMarc75D DJMarc75
                            Diamand2k22
                            @djmarc75
                            hat Thomas schon geschrieben.
                            iob stop
                            iob fix
                            iob start
                            • D Diamand2k22
                              @djmarc75
                              iob stop
                              iob fix
                              iob start
                              @diamand2k22
                              Dann hast du da mal mit falschen Rechten hantiert.
                              root login?
                              P 1 Antwort Letzte Antwort
                                Diamand2k22
                                schrieb am zuletzt editiert von Diamand2k22
                                kann sein Thomas, hab ich aber wieder hingebogen bekommen.
                                @Asgothian
                                hab mir jetzt ne eigene ketotek.js für mein Heizkörperthermostat gebastelt.
                                Jetzt funktioniert es wunderbar und ich hab keine Unrecognized DP's mehr und kann es steuern und empfange Temperaturen.
                                Was mich nur interessieren würde, wie bekomme ich da ein vernünftiges Bild rein?
                                Kannst du das Thermostat aufnehmen?
                                  @diamand2k22
                                  root login?
                                  Patrick Kenzler
                                  @thomas-braun könntest du deinen externen Konverter zur Verfügung stellen? Sitze schon seit Tagen und komme nicht weiter.
                                  • P Patrick Kenzler
                                    @patrick-kenzler
                                    Meinen was? Wüsste nicht das ich sowas im Einsatz hätte.
                                      @patrick-kenzler
                                      Patrick Kenzler
                                      @thomas-braun sorry, die Frage sollte eigentlich an @Diamand2k22 gehen habe mich verklickt^^
                                      • P Patrick Kenzler
                                        Diamand2k22
                                        @patrick-kenzler
                                        Hast du auch so ein ketotek Teil von Amaz**?
                                        • D Diamand2k22
                                          @patrick-kenzler
                                          Patrick Kenzler
                                          @diamand2k22 said in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
                                          @patrick-kenzler
                                          nein, aber Avatto ME167 das wird auch unter _TZE200_bvu2wnxz geführt.
