  4. Ical mehrere Instanzen -> nur bestimmte Termine
vishow-to
84 Beiträge 6 Kommentatoren 14.4k Aufrufe 5 Beobachtet
  • liv-in-skyL liv-in-sky
    @karel-puhli
    @karel-puhli
    bitte die fehler und solche art von posts in code tag
    siehe: https://forum.iobroker.net/post/553912
    könnte da was beim kopieren schief gegangen sein
    schaut dann so aus:
    javascript.0 2021-01-14 09:59:53.624 error (1734) at process._tickCallback (internal/process/next_tick.js:68:7)
    javascript.0 2021-01-14 09:59:53.624 error (1734) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    javascript.0 2021-01-14 09:59:53.624 error (1734) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0 2021-01-14 09:59:53.623 error (1734) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33)
    javascript.0 2021-01-14 09:59:53.623 error (1734) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1219:17)
    javascript.0 2021-01-14 09:59:53.623 error (1734) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1681:17)
    javascript.0 2021-01-14 09:59:53.622 error (1734) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1587:37)
    javascript.0 2021-01-14 09:59:53.622 error (1734) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1364:28)
    javascript.0 2021-01-14 09:59:53.622 error (1734) at Object.createScript (vm.js:277:10)
    javascript.0 2021-01-14 09:59:53.622 error (1734) at new Script (vm.js:83:7)
    javascript.0 2021-01-14 09:59:53.621 error (1734) SyntaxError: Unexpected end of input
    javascript.0 2021-01-14 09:59:53.621 error (1734) log('registered ' + __engine.__subscriptions + ' subscription' + (__engine.__subscriptions === 1 ? '' : 's' ) + ' and ' + __engine.__schedules + ' schedule' + (__engine.__schedules === 1 ? ''
    javascript.0 2021-01-14 09:59:53.620 error at script.js.Test.JavaScript.icalTabellen:71
    javascript.0 2021-01-14 09:59:53.620 error (1734) script.js.Test.JavaScript.icalTabellen compile failed:
    Karel PuhliK Offline
    Karel Puhli
    @liv-in-sky
    Das war definitiv ein Kopierfehler... 🙄
    Jetzt passt auch alles mit den Terminen! 👍 👍 👍
    Ich befasse mich mal jetzt ausführlich mit dem Skript!
    Und sage vielen Dank dafür! Top!!! :-)
    • Karel PuhliK Karel Puhli
      @liv-in-sky
      liv-in-skyL Offline
      liv-in-skyL Offline
      liv-in-sky
      @karel-puhli gerne - bei fragen einfach posten
      N 1 Antwort Letzte Antwort
        N Offline
        N Offline
        nousefor82
        schrieb am zuletzt editiert von nousefor82
        @liv-in-sky
        Servus und Danke für das Script.
        • N nousefor82
          @liv-in-sky
          N Offline
          N Offline
          nousefor82
          @liv-in-sky
          Guten Morgen,
          ich habe einen "Fehler"?
          Gestern stand unter NextGanzTägig: Morgen "balbal"
          Heute steht im gleichen Feld: Noch 1 Tag "blabla".
          Wäre es möglich, dass dann hier steht Heute, bzw. im Running-DP?
          Gerade gesehen, das Skript ja das, was es vom ical-bekommt.
          Und nach dem ical mir die Geburtstage (ganztägige Serientermine) über 2 Tage anzeigt, kommt es zu dieser unglücklichen Formulierung.
          @liv-in-sky : Kannst du im Skript einbauen, dass wenn da steht "Noch 1 Tag" umwandelt in "Heute"?
          • N nousefor82
            @liv-in-sky
            Guten Morgen,
            liv-in-skyL Offline
            liv-in-skyL Offline
            liv-in-sky
            @nousefor82
            muss ertmal nachdenken - dieses teilscript wurde ja hier rausgenommen - https://forum.iobroker.net/post/553690 in dem script brauche ich unbedingt dieses setting in ical:
            das "ersetze datum mit worten" darf nicht angklickt sein
            ich habe ein neues script im post oben drin - dort sollte mit dem "setting des bildes" das heute und morgen funktionieren
            @Karel-Puhli
            beim kopieren des scripts die settings (auch schedule) wieder angleichen!
            Karel PuhliK 1 Antwort Letzte Antwort
              @nousefor82
              @Karel-Puhli
              Karel Puhli
              schrieb am zuletzt editiert von Karel Puhli
              @liv-in-sky said in Ical mehrere Instanzen -> nur bestimmte Termine:
              komisch, habe es bei mir angeklickt... es wird trotzdem korrekt angezeigt. Bezieht sich das nur auf einen der 3 Datenpunkte?
                liv-in-skyL Offline
                liv-in-skyL Offline
                liv-in-sky
                @karel-puhli
                habe es mit der einstellung bei dem script hier nicht getestet - aber es wäre schon möglich - ich suche ja nach einem bestimmten format und ersetze dann. wenn das format nicht gefunden wird, bleibt der text unverändert und heute bzw morgen wird angezeigt
                ich wollte nur einen standard für die beiden scripte haben - damit gehe ich auf nummer sicher, wenn jmd mal einen fehler hat. damit kann ich sicherstellen., dass der user die selben daten bekommt wie ich. ändert sich da mal was, kann ich das script umschreiben.
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  liv-in-sky
                  @karel-puhli
                  hi - ich mußt bei meinem anderen script (https://forum.iobroker.net/post/562178) noch etwas korrigieren , was auch dein script betrifft
                  habe es in den post kopiert - vielleicht kannst du bei gelegenheit testen
                    @karel-puhli
                    Karel Puhli
                    @liv-in-sky
                    Hi! Oben im Spoiler ist jetzt ein aktuelleres Skript?
                    Grüße!
                      @liv-in-sky
                      Grüße!
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      liv-in-sky
                      @karel-puhli
                      ja - hier: https://forum.iobroker.net/post/557333
                      Karel PuhliK 2 Antworten Letzte Antwort
                        @karel-puhli
                        Karel Puhli
                        @liv-in-sky
                        Ich teste und sage bescheid. Was hast du denn geändert?
                        Danke und beste Grüße!
                          @liv-in-sky
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          liv-in-sky
                          @karel-puhli es geht um die anzeige bzw um das erkennen . was der nächste termin ist. der ical adapter hat eine eigenwillige art zu zeigen, welche art der termin ist
                          wenn z.b. ein ganztagestermin heute ist, steht nur ein datum. ist ein ganz tagestermin in einen der folgenden tagen, steht dort: termin 01:00-00:00 und das datum des folgetages.
                          das habe ich versucht besser zu filtern, weil bei bestimmten konstellationen, falsche termine in den datenpunkten stand
                          Karel PuhliK N 2 Antworten Letzte Antwort
                            Karel Puhli
                            @liv-in-sky
                            Bis dato läuft alles tacko! 👍
                              N Offline
                              N Offline
                              nousefor82
                              @liv-in-sky
                              seit 1-2 Wochen hängt irgendwas.
                              Und zwar zeigt er mir immer noch im Datenpunkt
                              TerminNextGanzerTag
                              einen Geburtstag an, der schon längst vorbei ist.
                              Am Script habe ich nichts verändert.
                              Kannst du dir einen Reim drauf machen?
                              VG,
                              Jörg
                              • N nousefor82
                                @liv-in-sky
                                TerminNextGanzerTag
                                VG,
                                Jörg
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                liv-in-sky
                                @nousefor82
                                hast du den ical adapter upgedatet ?
                                  @nousefor82
                                  N Offline
                                  N Offline
                                  nousefor82
                                  @liv-in-sky
                                  Ist auf dem neusten Stand!
                                  • N nousefor82
                                    @liv-in-sky
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    liv-in-sky
                                    @nousefor82 dann gibt es ein problem - da der ical neue datenpunkt struktur hat
                                    teste mal
                                    ersetze diese zeile
                                    mit dieser - wie im bild gezeigt
                                    let myDpInput=JSON.parse((getState(dpTSJson[i]).val));
                                      teste mal
                                      ersetze diese zeile
                                      N Offline
                                      N Offline
                                      nousefor82
                                      @liv-in-sky
                                      keine Änderung 😕
                                      • N nousefor82
                                        @liv-in-sky
                                        keine Änderung 😕
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        liv-in-sky
                                        @nousefor82 welcher version hat der ical-adapter
                                        • N nousefor82
                                          @liv-in-sky
                                          keine Änderung 😕
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          liv-in-sky
                                          @nousefor82
                                          das script läuft nur zur 0, 15, 30 und 45 minute - hast du das bedacht ?
