  4. Ical mehrere Instanzen -> nur bestimmte Termine
vishow-to
84 Beiträge 6 Kommentatoren 14.4k Aufrufe 5 Beobachtet
  • liv-in-skyL liv-in-sky
    @karel-puhli
    habe das script weiter oben ausgetauscht - bitte mal testen, ob jetzt die daten richtig angezeigt werden
    du musst dann die 4 variablen - oben - wieder anpassen
    Karel PuhliK Offline
    Karel Puhli
    schrieb am zuletzt editiert von Karel Puhli
    @liv-in-sky das kommt jetzt im log
    javascript.0	2021-01-14 09:59:53.624	error	(1734) at process._tickCallback (internal/process/next_tick.js:68:7)
    javascript.0	2021-01-14 09:59:53.624	error	(1734) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    javascript.0	2021-01-14 09:59:53.624	error	(1734) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2021-01-14 09:59:53.623	error	(1734) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33)
    javascript.0	2021-01-14 09:59:53.623	error	(1734) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1219:17)
    javascript.0	2021-01-14 09:59:53.623	error	(1734) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1681:17)
    javascript.0	2021-01-14 09:59:53.622	error	(1734) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1587:37)
    javascript.0	2021-01-14 09:59:53.622	error	(1734) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1364:28)
    javascript.0	2021-01-14 09:59:53.622	error	(1734) at Object.createScript (vm.js:277:10)
    javascript.0	2021-01-14 09:59:53.622	error	(1734) at new Script (vm.js:83:7)
    javascript.0	2021-01-14 09:59:53.621	error	(1734) SyntaxError: Unexpected end of input
    javascript.0	2021-01-14 09:59:53.621	error	(1734) log('registered ' + __engine.__subscriptions + ' subscription' + (__engine.__subscriptions === 1 ? '' : 's' ) + ' and ' + __engine.__schedules + ' schedule' + (__engine.__schedules === 1 ? ''
    javascript.0	2021-01-14 09:59:53.620	error	at script.js.Test.JavaScript.icalTabellen:71
    javascript.0	2021-01-14 09:59:53.620	error	(1734) script.js.Test.JavaScript.icalTabellen compile failed:
    edit: ganz unten die letzte Klammer: "}" wurde erwartet
    • Karel PuhliK Karel Puhli
      liv-in-skyL Offline
      liv-in-skyL Offline
      @karel-puhli
      @karel-puhli
      bitte die fehler und solche art von posts in code tag
      siehe: https://forum.iobroker.net/post/553912
      könnte da was beim kopieren schief gegangen sein
      schaut dann so aus:
      Karel PuhliK 1 Antwort Letzte Antwort
        @karel-puhli
        @karel-puhli
        schaut dann so aus:
        Karel Puhli
        @liv-in-sky
        Das war definitiv ein Kopierfehler... 🙄
        Jetzt passt auch alles mit den Terminen! 👍 👍 👍
        Ich befasse mich mal jetzt ausführlich mit dem Skript!
        Und sage vielen Dank dafür! Top!!! :-)
          @liv-in-sky
          liv-in-skyL Offline
          liv-in-skyL Offline
          @karel-puhli gerne - bei fragen einfach posten
          N 1 Antwort Letzte Antwort
            N Offline
            N Offline
            nousefor82
            schrieb am zuletzt editiert von nousefor82
            @liv-in-sky
            Servus und Danke für das Script.
            • N nousefor82
              @liv-in-sky
              N Offline
              N Offline
              nousefor82
              @liv-in-sky
              Guten Morgen,
              ich habe einen "Fehler"?
              Gestern stand unter NextGanzTägig: Morgen "balbal"
              Heute steht im gleichen Feld: Noch 1 Tag "blabla".
              Wäre es möglich, dass dann hier steht Heute, bzw. im Running-DP?
              Gerade gesehen, das Skript ja das, was es vom ical-bekommt.
              Und nach dem ical mir die Geburtstage (ganztägige Serientermine) über 2 Tage anzeigt, kommt es zu dieser unglücklichen Formulierung.
              @liv-in-sky : Kannst du im Skript einbauen, dass wenn da steht "Noch 1 Tag" umwandelt in "Heute"?
              • N nousefor82
                @liv-in-sky
                Guten Morgen,
                liv-in-skyL Offline
                liv-in-skyL Offline
                @nousefor82
                muss ertmal nachdenken - dieses teilscript wurde ja hier rausgenommen - https://forum.iobroker.net/post/553690 in dem script brauche ich unbedingt dieses setting in ical:
                das "ersetze datum mit worten" darf nicht angklickt sein
                ich habe ein neues script im post oben drin - dort sollte mit dem "setting des bildes" das heute und morgen funktionieren
                @Karel-Puhli
                beim kopieren des scripts die settings (auch schedule) wieder angleichen!
                  @nousefor82
                  @Karel-Puhli
                  Karel Puhli
                  @liv-in-sky said in Ical mehrere Instanzen -> nur bestimmte Termine:
                  komisch, habe es bei mir angeklickt... es wird trotzdem korrekt angezeigt. Bezieht sich das nur auf einen der 3 Datenpunkte?
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    @karel-puhli
                    habe es mit der einstellung bei dem script hier nicht getestet - aber es wäre schon möglich - ich suche ja nach einem bestimmten format und ersetze dann. wenn das format nicht gefunden wird, bleibt der text unverändert und heute bzw morgen wird angezeigt
                    ich wollte nur einen standard für die beiden scripte haben - damit gehe ich auf nummer sicher, wenn jmd mal einen fehler hat. damit kann ich sicherstellen., dass der user die selben daten bekommt wie ich. ändert sich da mal was, kann ich das script umschreiben.
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      @karel-puhli
                      hi - ich mußt bei meinem anderen script (https://forum.iobroker.net/post/562178) noch etwas korrigieren , was auch dein script betrifft
                      habe es in den post kopiert - vielleicht kannst du bei gelegenheit testen
                        @karel-puhli
                        Karel Puhli
                        @liv-in-sky
                        Hi! Oben im Spoiler ist jetzt ein aktuelleres Skript?
                        Grüße!
                          @liv-in-sky
                          Grüße!
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          @karel-puhli
                          ja - hier: https://forum.iobroker.net/post/557333
                          Karel PuhliK 2 Antworten Letzte Antwort
                            @karel-puhli
                            Karel Puhli
                            @liv-in-sky
                            Ich teste und sage bescheid. Was hast du denn geändert?
                            Danke und beste Grüße!
                              @liv-in-sky
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              @karel-puhli es geht um die anzeige bzw um das erkennen . was der nächste termin ist. der ical adapter hat eine eigenwillige art zu zeigen, welche art der termin ist
                              wenn z.b. ein ganztagestermin heute ist, steht nur ein datum. ist ein ganz tagestermin in einen der folgenden tagen, steht dort: termin 01:00-00:00 und das datum des folgetages.
                              das habe ich versucht besser zu filtern, weil bei bestimmten konstellationen, falsche termine in den datenpunkten stand
                              Karel PuhliK N 2 Antworten Letzte Antwort
                                Karel Puhli
                                @liv-in-sky
                                Bis dato läuft alles tacko! 👍
                                  N Offline
                                  N Offline
                                  nousefor82
                                  @liv-in-sky
                                  seit 1-2 Wochen hängt irgendwas.
                                  Und zwar zeigt er mir immer noch im Datenpunkt
                                  TerminNextGanzerTag
                                  einen Geburtstag an, der schon längst vorbei ist.
                                  Am Script habe ich nichts verändert.
                                  Kannst du dir einen Reim drauf machen?
                                  VG,
                                  Jörg
                                  • N nousefor82
                                    @liv-in-sky
                                    TerminNextGanzerTag
                                    VG,
                                    Jörg
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    @nousefor82
                                    hast du den ical adapter upgedatet ?
                                      @nousefor82
                                      N Offline
                                      N Offline
                                      nousefor82
                                      @liv-in-sky
                                      Ist auf dem neusten Stand!
                                      • N nousefor82
                                        @liv-in-sky
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        @nousefor82 dann gibt es ein problem - da der ical neue datenpunkt struktur hat
                                        teste mal
                                        ersetze diese zeile
                                        mit dieser - wie im bild gezeigt
                                        let myDpInput=JSON.parse((getState(dpTSJson[i]).val));
                                          teste mal
                                          ersetze diese zeile
                                          N Offline
                                          N Offline
                                          nousefor82
                                          @liv-in-sky
                                          keine Änderung 😕
