  4. JS-Controller Update, danach Admin und Web nicht erreichbar
    6.7k
js-controlleradminwebfehler
96 Beiträge 21 Kommentatoren 13.9k Aufrufe 20 Beobachtet
  • MichMeinM MichMein
    @Homoran sagte in JS-Controller Update, danach Admin und Web nicht erreichbar:
    @MichMein sagte in JS-Controller Update, danach Admin und Web nicht erreichbar:
    Das funktioniert bei mir leider nicht
    wo bist du denn da?
    Wenn du vorher nicht ins Installationsvereichnis (üblicherweise /opt/iobroker) wechselst kann es nicht helfen, eher noch weiteren Schaden anrichten
    ich bin hier
    pi@raspberrypi:/opt/iobroker $ npm i iobroker.js-controller@3.1.6 --production
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    > iobroker.js-controller@3.1.6 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.10
    > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp WARN Using request for node-pre-gyp https download
    node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v72-linux-glibc-arm.tar.gz
    node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@12.20.0 (node-v72 ABI, glibc) (falling back to source compile with node-gyp)
    Package pixman-1 was not found in the pkg-config search path.
    Perhaps you should add the directory containing `pixman-1.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
    gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    gyp ERR! System Linux 5.4.79-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! node -v v12.20.0
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1022:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
    node-pre-gyp ERR! System Linux 5.4.79-v7l+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    node-pre-gyp ERR! node -v v12.20.0
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    > iobroker.js-controller@3.1.6 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    Existing earlier generated certificate is invalid (too old, validity longer then 345 days or keylength too short). Generating new Certificate!
    object system.certificates updated
    The following notifications happened during sync:
    - Ignoring Directory "admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "cloud.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "coronavirus-statistics.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "energymanager.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "lovelace.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "mobile" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "mobile.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "terminal" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "terminal.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "tr-064.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "weishaupt-wem.admin" because officially not created as meta object. Please remove directory!
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: canvas@2.6.1 (node_modules/canvas):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    + iobroker.js-controller@3.1.6
    updated 2 packages in 45.689s
    12 packages are looking for funding
      run `npm fund` for details
    Danach bleibt alles beim anderen, leider.
    Wie komme ich zurück auf 3.1.6?
    #41
    No package 'pixman-1' found gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp gyp ERR! configure error
    Dann fehlt dir das Paket!
    Such mal bitte nach der Meldung (pixman) und der lösung - ist mehrfach hier im Forum vorhanden
    • MichMeinM Offline
      MichMeinM Offline
      MichMein
      #42
      @Homoran @ErRi
      Sehr komisch, jetzt hat es bei mir mit dem downgrade auf 3.1.6 funktioniert.
      Gruß Michael
      Sofern Beiträge hilfreich für Dich sind, nutze das Voting unten rechts.
        wo bist du denn da?
        ich bin hier
        gyp ERR! not ok
        Jan1
        #43
        @MichMein
        nein bleibt es nicht, es wird schlimmer ;)
        falsches Verzeichnis, da NPM nix im IOBroker Verzeichnis zu suchen hat.
        MichMeinM 1 Antwort Letzte Antwort
        • J Jan1
          @MichMein
          MichMeinM Offline
          MichMeinM Offline
          MichMein
          #44
          @Jan1 wie geschriebn es läuft aber jetzt
          Gruß Michael
          J 1 Antwort Letzte Antwort
            Jan1
            #45
            @MichMein
            Man weiß auch nicht was da jetzt noch alles versaut wurde und wann sich das dann negativ auswirkt ;)
            NPM ist Bestandteil von Node und Node eben kein Bestandteil von IOBroker. Somit ist alles was Du dann im IOBroker Verzeichnis macht falsch.
            • J Jan1
              @MichMein
              #46
              @Jan1 Sorry - mein Fehler!
              Bin von einer iob Installation über npm ausgegangen 😕
              Aber bitte auch kein sudo bei npm nutzen, wie von @barney_b vorgeschlagen!
              zuviele Baustellen heute morgen :-/
                Jan1
                #47
                @Homoran
                deshalb schrieb ich ja auch "unter root oder besser mit su" ;)
                E 1 Antwort Letzte Antwort
                • J Jan1
                  @Homoran
                  ErRi
                  #48
                  @Jan1 Was muss man tun damit es wieder läuft?
                  MfG Erhard
                  Win11 Notebook, Lenovo MiniPC mit Proxmox, iobroker, Raspberrymatic, Maria DB, OMV
                  Fritzbox 7490, 1 Jeelink, 12 HM Rolladenschalter, 1 HM Energiezähler, VU UNO SE :)
                  • E ErRi
                    MichMeinM Offline
                    MichMeinM Offline
                    MichMein
                    #49
                    @ErRi sagte in JS-Controller Update, danach Admin und Web nicht erreichbar:
                    Bei mir hat es damit geklappt
                    allerdings irgendwie nicht beim ersten mal und dann auch noch fälscherweise im /opt/iobroker Verzeichnis. Dies soll man nach Aussage von @Jan1 aber NICHT machen.
                    Gruß Michael
                      #50
                      nein, das ist genau das, was ich falsch gelesen hatte!
                      Befehle um über npm etwas bei iobroker zu installieren müssen im ioBroker-Verzeichnis ausgeführt werden
                      Befehle um npm zu installieren jedoch nicht
                      E MichMeinM 2 Antworten Letzte Antwort
                        ErRi
                        #51
                        @Homoran Vielen Dank, läuft wieder😊
                        MfG Erhard
                          MichMeinM Offline
                          MichMeinM Offline
                          MichMein
                          #52
                          @Homoran ah,ok dann habe ich ja Glück gehabt.
                          Gruß Michael
                            Rushmed
                            #53
                            Ich bin jetzt ganz durcheinander von wegen was in opt/iobroker gehört und was nicht.
                            Bei mir sieht der Ordnerinhalt so aus, ist das ok?
                            F J 2 Antworten Letzte Antwort
                            • F Offline
                              Flopsi
                              #54
                              Wie kann ich den prüfen wo was ist installiert ist und ob alles an seinem richtigen Ort ist ? Bei mir geht aktuell gar nix mehr ich weis auch leider nicht was ich weiter machen muss.
                              Da aus irgendewelchen günden meine Backups bis auf das was heute morgen gemacht worden ist weg sind.
                              Und das an Weihnachten.
                              Wer kann mir weiter helfen ??
                              • R Rushmed
                                Flopsi
                                #55
                                @Rushmed
                                Ich weis auch nix mehr wo was sein soll :(
                                • F Flopsi
                                  @Rushmed
                                  Jan1
                                  #56
                                  @Flopsi
                                  Na das Backup von heute morgen ist doch auch genau das richtige. Warum machst nicht damit einfach ein Restor.
                                  F 1 Antwort Letzte Antwort
                                  • J Jan1
                                    @Flopsi
                                    Flopsi
                                    schrieb am zuletzt editiert von Flopsi
                                    #57
                                    @Jan1
                                    habe das durchlaufen lassen selben problem wie vorher deswegen wunder ich mich ja
                                    oder ich mache was falsch
                                    oder meinst du alles neu machen !
                                    • R Rushmed
                                      Jan1
                                      #58
                                      @Rushmed
                                      Es ist relevant von wo man was aufruft und hat mit den Ordnern erstb mal nichts zu tun ;)
                                      • F Flopsi
                                        @Jan1
                                        Jan1
                                        #59
                                        @Flopsi
                                        Die Frage ist wie hast das durch laufen lassen?
                                        • J Jan1
                                          @Flopsi
                                          Flopsi
                                          #60
                                          @Jan1
                                          So.....
                                          sudo iobroker stop
                                          sudo iobroker restore 0
                                          sudo iobroker start all
                                          sudo iobroker start
                                          sudo iobroker upload all
