  4. Diskussion zum HowTo nodejs-Installation und upgrade
    1.0k
    6.1k
nodejs
844 Beiträge 91 Kommentatoren 309.3k Aufrufe 63 Beobachtet
    @willi-wunder
    Sorry, mein Fehler.
    Muss
    iob nodejs-update 18
    lauten.
    W Offline
    W Offline
    Willi-Wunder
    #661
    TOP, vielen Dank. Jetzt sollte es passen.
    ioBroker nodejs fixer 2023-10-13
    You requested to intall latest version from nodejs v18 tree.
    Your current setup is:
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
         18.19.0+dfsg-6~deb12u1 500
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    Nothing to do - Your installation is using the correct paths.
    You are running nodejs v18.19.0. Do you want to install latest version from nodejs v.18 tree?
    Press <y> to continue or any other key to quit
    Trying to update your installation now. Please be patient.
    find: '/run/user/1000/doc': Permission denied
    find: '/run/user/1000/gvfs': Permission denied
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://repos.influxdata.com/debian stable InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:3 https://repos.influxdata.com/debian stable InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Get:7 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Get:8 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [6613 B]
    Get:9 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [6656 B]
    Fetched 25.4 kB in 2s (13.0 kB/s)
    Installing the recommended nodejs version now!
    Installing the recommended nodejs version!
    We tried our best to fix your nodejs. Please run iob diag again to verify.
    *** RESTARTING ioBroker NOW! ***
     Please refresh or restart your browser in a few moments.
    Beim ausführen des Befehls kam noch am Anfang......
    pi@iobroker:~ $ iob nodejs-update 18
    /usr/bin/bash: warning: setlocale: LC_ALL: cannot change locale (de_DE)
    ioBroker node-update v2023-10-13 is starting. Please be patient!
    Hat das noch etwas zu sagen?
    • W Willi-Wunder
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Package: nodejs
      Pin-Priority: 1001
      #662
      @willi-wunder sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
      Nein, ist für dich nicht wichtig.
      W 1 Antwort Letzte Antwort
        W Offline
        W Offline
        Willi-Wunder
        #663
        Dann danke für deine erneute Hilfe 👍
        • J Offline
          JoSbg
          #664
          Hallo
          Wollt gerade das Update von v16 auf v18 machen. Leider scheitere ich schon beim ersten Schritt "Altlasten entfernen".
          sudo rm `sudo find / -name nodesource.gpg`
          Es werden da eine Menge Ordner aufgelistet, aber bei allen kommt "Permission denied"
          iobroker@CT101:~$ sudo rm `sudo find / -name nodesource.gpg`
          find: '/proc/tty/driver': Permission denied
          find: '/sys/kernel/debug': Permission denied
          find: '/sys/fs/fuse/connections/41': Permission denied
          find: '/sys/fs/fuse/connections/38': Permission denied
          iobroker läuft bei mir auf Proxmox mit Debian.
          • J JoSbg
            Hallo
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            #665
            @josbg sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
            Was machst du da !?
            schau ein paar .... Beiträge über deine !
            iob stop
            iob fix
            iob nodejs-update
            sudo reboot
            J 1 Antwort Letzte Antwort
            • GlasfaserG Glasfaser
              Was machst du da !?
              iob stop
              iob fix
              iob nodejs-update
              sudo reboot
              JoSbg
              #666
              @glasfaser
              Danke hat so natürlich funktioniert.
              Manchmal sieht man den Wald vor lauter Bäumen nicht.
                Stefan_NK
                #667
                Hallo Zusammen,
                ich habe einen Raspi4 für Testzwecke komplett neu aufgesetzt und den iobroker installiert.
                curl -sLf https://iobroker.net/install.sh | bash -
                Ich habe jetzt in der Übersicht folgende Versionen:
                Node.js: v18.19.0
                NPM: 9.2.0(10.2.3)
                Wie kann ich denn die NPM-Version auf 19.x updaten? Ich habe dazu leider nichts gefunden, was mir weitergeholfen hätte.
                LG Stefan
                • S Stefan_NK
                  Hallo Zusammen,
                  Node.js: v18.19.0
                  NPM: 9.2.0(10.2.3)
                  LG Stefan
                  #668
                  @stefan_nk
                  npm wird gar nicht separat installiert.
                  Mach es danach:
                  https://forum.iobroker.net/topic/71478/plötzliche-probleme-durch-nodejs-dfsg-version-npm-fehlt
                  Hinterher per
                  iob nodejs-update
                  schauen ob das dann senkrecht installiert wurde.
                    @stefan_nk
                    Mach es danach:
                    Hinterher per
                    iob nodejs-update
                    Stefan_NK
                    #669
                    @thomas-braun sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                    iob nodejs-update
                    Hat funktioniert. Vielen Dank Thomas
                    • K Offline
                      knatterman
                      #670
                      ich habe versucht, Nodejs von 14 auf 18 upzugraden, habe gemäß der Anleitung die beiden Repos eingetragen und erhielt dann beim Update aber immer den Hinweis, dass ein Schlüssel fehlen ...
                      iobroker@iobroker:~$ sudo apt update
                      OK:1 http://deb.debian.org/debian buster InRelease
                      OK:2 http://deb.debian.org/debian buster-updates InRelease
                      OK:3 http://security.debian.org/debian-security buster/updates InRelease
                      OK:4 https://deb.nodesource.com/node_14.x buster InRelease
                      Holen:5 https://deb.nodesource.com/node_16.x nodistro InRelease [12,1 kB]
                      Holen:6 https://deb.nodesource.com/node_18.x nodistro InRelease [12,1 kB]
                      Fehl:5 https://deb.nodesource.com/node_16.x nodistro InRelease
                        Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 2F59B5F99B1BE0B4
                      Fehl:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                      W: GPG-Fehler: https://deb.nodesource.com/node_16.x nodistro InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 2F59B5F99B1BE0B4
                      E: Das Depot »https://deb.nodesource.com/node_16.x nodistro InRelease« ist nicht signiert.
                      N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                      N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                      W: GPG-Fehler: https://deb.nodesource.com/node_18.x nodistro InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 2F59B5F99B1BE0B4
                      E: Das Depot »https://deb.nodesource.com/node_18.x nodistro InRelease« ist nicht signiert.
                      Die Hinweise hier im Thread haben nicht wirklich geholfen. Habe dann auf https://den.nodesource.com einen Hinweis auf die (wohl) aktuellste Key Datei gefunden und sie wie folgt hinzugefügt.
                      iobroker@iobroker:~$ curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo apt-key add -
                      Ein
                      liefert nun
                      OK:2 http://security.debian.org/debian-security buster/updates InRelease
                      OK:3 http://deb.debian.org/debian buster-updates InRelease
                      Holen:7 https://deb.nodesource.com/node_16.x nodistro/main amd64 Packages [7.462 B]
                      Holen:8 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [6.634 B]
                      Es wurden 14,1 kB in 2 s geholt (8.844 B/s).
                      Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
                      Vielleicht hilft es irgendwem irgendwann ...
                      Frank
                      • GlasfaserG Offline
                        GlasfaserG Offline
                        Glasfaser
                        #671
                        @knatterman sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                        Auch nicht !?
                        iob nodejs-update
                        Da hast du aber schon lange nichts mehr gemacht ....
                        K 1 Antwort Letzte Antwort
                        • K knatterman
                          Ein
                          liefert nun
                          Frank
                          #672
                          Nein, es hilft nicht, denn die Schlüsselverwaltung wird nicht mehr via apt-key gemacht.
                          iob nodejs-update
                          macht das alles für dich.
                          Und den Buster musst du auch beerdigen, installier da Bookworm / Debian 12.
                            Auch nicht !?
                            iob nodejs-update
                            knatterman
                            #673
                            @glasfaser
                            Hi
                            Auch nicht !?
                            iob nodejs-update
                            nein, die Option nodejs-update wurde nicht 'erkannt' ...
                            Tja, never change a running system 😄
                            Frank
                            Thomas BraunT GlasfaserG HomoranH 4 Antworten Letzte Antwort
                            • K knatterman
                              @glasfaser
                              Hi
                              Auch nicht !?
                              iob nodejs-update
                              Frank
                              #674
                              @knatterman
                              So lange nur nix changen, bis gar nix mehr geht...
                              Wer gibt eigentlich immer diesen schwachsinnigen Rat?
                                @knatterman
                                knatterman
                                schrieb am zuletzt editiert von knatterman
                                #675
                                Hast ja recht, ich denke halt nur zu selten daran, Mal wieder upzudaten.
                                Habe gerade aber nochmal geschaut, die Option nodejs-update gibt's auf meinem System (immer) noch nicht. Muss ich hier noch was manuell tun?
                                Frank
                                GlasfaserG 2 Antworten Letzte Antwort
                                • K knatterman
                                  @glasfaser
                                  Hi
                                  Auch nicht !?
                                  iob nodejs-update
                                  Frank
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  #676
                                  Dann war dein System ... Steinalt
                                  bzw. ist es immer noch!
                                  das würde man per
                                  iob fix
                                  sich den Befehl dazu holen !
                                  • K knatterman
                                    @glasfaser
                                    Hi
                                    Auch nicht !?
                                    iob nodejs-update
                                    Frank
                                    #677
                                    siehst ja was dann passiert
                                    • K knatterman
                                      @glasfaser
                                      Hi
                                      Auch nicht !?
                                      iob nodejs-update
                                      Frank
                                      #678
                                      iob stop
                                      iob fix
                                      danach ist auch nodejs-update bekannt.
                                      Aber lieber wird da ja irgendein veralteter Kram festgetackert...
                                      Näwah tschäintsch.... Ich weiß...
                                      • K knatterman
                                        Frank
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Glasfaser
                                        #679
                                        dann vermute ich auch das du noch Buster hast ...
                                          #680
                                          @glasfaser sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                                          oder jessie
                                          oder gab es 2017 noch was älteres?
